[2548]set pll end
[2550]PL gpio voltage : 1.8V
[2554][pmu]: bus read error
[2556]unknow PMU
[2558][pmu]: bus read error
[2561]PMU: AXP2202
[2564][pmu]: bus read error
[2567]vaild para:1 select dram para0
[2571]board init ok, set sys_vol to 950mv!
[2575]beign to init dram
[2577]DRAM BOOT DRIVE INFO: V0.697
[2580]the chip id is 0x1000
[2583]ic cant match axp, please check…
[2587]rtc[3] value = 0xb00f
安卓固件目前是只支持A133,没有R818吧
好吧,我以为同一个马甲都是共用的
