以下是sd卡启动
[02.763]Starting kernel …
[02.765][mmc]: MMC Device 2 not found
[02.768][mmc]: mmc 2 not find, so not exit
[ 0.000000] Linux version 5.4.61 (ubuntu@ubuntu1804) (arm-openwrt-linux-muslgnueabi-gcc.bin (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) 6.4.1, GNU ld (GNU Binutils) 2.27) #1 SMP PREEMPT Fri May 22 02:47:48 UTC 2026
[ 0.000000] cma: Reserved 8 MiB at 0x47800000
[ 0.000000] percpu: Embedded 15 pages/cpu s30348 r8192 d22900 u61440
[ 0.000000] pcpu-alloc: s30348 r8192 d22900 u61440 alloc=15*4096
[ 0.000000] Kernel command line: earlyprintk=sunxi-uart,0x02500C00 clk_ignore_unused initcall_debug=0 console=ttyS3,115200 loglevel=8 root=/dev/mmcblk0p5 init=/pseudo_init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:private@mmcblk0p6:rootfs_data@mmcblk0p7:UDISK@mmcblk0p8 cma=8M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.mode=normal androidboot.hardware=sun8iw20p1 boot_type=1 androidboot.boot_type=1 gpt=1 uboot_message=2018.05-g24521d6-dirty(05/21/2026-21:53:35) androidboot.dramsize=128
[ 0.000000] Memory: 108612K/131072K available (6144K kernel code, 264K rwdata, 1504K rodata, 1024K init, 1164K bss, 14268K reserved, 8192K cma-reserved)
[ 0.000000] random: get_random_bytes called from start_kernel+0x26c/0x3ec with crng_init=0
[ 0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.008016] Switching to timer-based delay loop, resolution 41ns
[ 0.014175] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.023854] Calibrating delay loop (skipped), value calculated using timer frequency… 48.00 BogoMIPS (lpj=240000)
[ 0.034219] pid_max: default: 32768 minimum: 301
[ 0.038965] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.046279] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.054592] CPU: Testing write buffer coherency: ok
[ 0.059797] /cpus/cpu@0 missing clock-frequency property
[ 0.065122] /cpus/cpu@1 missing clock-frequency property
[ 0.070461] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.076597] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.083263] rcu: Hierarchical SRCU implementation.
[ 0.088478] smp: Bringing up secondary CPUs …
[ 0.094095] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.094214] smp: Brought up 1 node, 2 CPUs
[ 0.104035] SMP: Total of 2 processors activated (96.00 BogoMIPS).
[ 0.110222] CPU: All CPU(s) started in SVC mode.
[ 0.115302] devtmpfs: initialized
[ 0.129717] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.137822] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.147693] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.154912] pinctrl core: initialized pinctrl subsystem
[ 0.161068] NET: Registered protocol family 16
[ 0.166924] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.202481] rtc_ccu: sunxi ccu init OK
[ 0.208385] ccu: sunxi ccu init OK
[ 0.212113] r_ccu: sunxi ccu init OK
[ 0.236547] iommu: Default domain type: Translated
[ 0.241614] sunxi iommu: irq = 24
[ 0.245773] SCSI subsystem initialized
[ 0.249756] usbcore: registered new interface driver usbfs
[ 0.255327] usbcore: registered new interface driver hub
[ 0.260724] usbcore: registered new device driver usb
[ 0.266569] Advanced Linux Sound Architecture Driver Initialized.
[ 0.273205] Bluetooth: Core ver 2.22
[ 0.276884] NET: Registered protocol family 31
[ 0.281340] Bluetooth: HCI device and connection manager initialized
[ 0.287719] Bluetooth: HCI socket layer initialized
[ 0.292610] Bluetooth: L2CAP socket layer initialized
[ 0.297676] Bluetooth: SCO socket layer initialized
[ 0.302771] pwm module init!
[ 0.306806] g2d 5410000.g2d: Adding to iommu group 0
[ 0.312086] G2D: rcq version initialized.major:252
[ 0.317614] clocksource: Switched to clocksource arch_sys_counter
[ 0.332053] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
[ 0.341328] NET: Registered protocol family 2
[ 0.346235] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.354676] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.362382] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 0.369452] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.375891] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.382448] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.389627] NET: Registered protocol family 1
[ 0.394923] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
[ 0.405221] spi spi0: spi0 supply spi not found, using dummy regulator
[ 0.411958] sunxi_spi_resource_get()2151 - [spi0] SPI MASTER MODE
[ 0.418099] sunxi_spi_resource_get()2189 - Failed to get sample mode
[ 0.424452] sunxi_spi_resource_get()2194 - Failed to get sample delay
[ 0.430916] sunxi_spi_resource_get()2198 - sample_mode:-1431633921 sample_delay:-1431633921
[ 0.439333] sunxi_spi_clk_init()2240 - [spi0] mclk 100000000
[ 0.445544] sunxi_spi_probe()2653 - [spi0]: driver probe succeed, base c881f000, irq 42
[ 0.455073] workingset: timestamp_bits=30 max_order=15 bucket_order=0
[ 0.465599] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.471640] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.504101] io scheduler mq-deadline registered
[ 0.508665] io scheduler kyber registered
[ 0.513940] [DISP]disp_module_init
[ 0.517813] disp 5000000.disp: Adding to iommu group 0
[ 0.534435] disp 5000000.disp: 5000000.disp supply vcc-lcd not found, using dummy regulator
[ 0.543008] disp 5000000.disp: 5000000.disp supply vcc-pd not found, using dummy regulator
[ 0.556562] display_fb_request,fb_id:0
[ 0.563877] [DISP] Fb_copy_boot_fb,line:1443:
[ 0.563882] no boot_fb0
[ 0.571165] disp_al_manager_apply ouput_type:0
[ 0.576196] [DISP]disp_module_init finish
[ 0.581043] [DISP] lcd_clk_config,line:732:
[ 0.581055] disp 0, clk: pll(306000000),clk(306000000),dclk(51000000) dsi_rate(306000000)
[ 0.581055] clk real:pll(300000000),clk(300000000),dclk(50000000) dsi_rate(0)
[ 0.581303] sunxi_sid_init()551 - insmod ok
[ 0.586109] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
[ 0.602096] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
[ 0.625207] uart uart1: get regulator failed
[ 0.629518] uart uart1: uart1 supply uart not found, using dummy regulator
[ 0.636619] uart1: ttyS1 at MMIO 0x2500400 (irq = 34, base_baud = 1500000) is a SUNXI
[ 0.645004] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
[ 0.655121] uart uart3: get regulator failed
[ 0.659430] uart uart3: uart3 supply uart not found, using dummy regulator
[ 0.666540] uart3: ttyS3 at MMIO 0x2500c00 (irq = 35, base_baud = 1500000) is a SUNXI
[ 0.674396] sw_console_setup()1808 - console setup baud 115200 parity n bits 8, flow n
⚌[ 0.682367] printk: console [ttyS3] enabled
[ 0.691305] printk: bootconsole [earlycon0] disabled
[ 0.702643] misc dump reg init
[ 0.707029] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
[ 0.714321] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
[ 0.721670] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
[ 0.729113] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
[ 0.735656] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
[ 0.742614] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
[ 0.750373] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=204 assert=1
[ 0.758240] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
[ 0.766357] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
[ 0.774010] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
[ 0.780792] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
[ 0.788342] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=207 assert=0
[ 0.796494] dma-buf: Running sanitycheck
[ 0.800918] dma-buf: Running dma_fence
[ 0.805120] sizeof(dma_fence)=48
[ 0.807807] [DISP] disp_device_attached_and_enable,line:233:
[ 0.807812] attached ok, mgr0<–>dev0
[ 0.808893] dma-buf: Running dma_fence/sanitycheck
[ 0.815072] [DISP] disp_device_attached_and_enable,line:236:
[ 0.815080] type:1,mode:0,fmt:rgb,bits:8bits,eotf:4,cs:0 dvi_hdmi:2, range:2 scan:0 ratio:8
[ 0.819202] dma-buf: Running dma_fence/test_signaling
[ 0.819209] dma-buf: Running dma_fence/test_add_callback
[ 0.851965] dma-buf: Running dma_fence/test_late_add_callback
[ 0.858423] dma-buf: Running dma_fence/test_rm_callback
[ 0.864284] dma-buf: Running dma_fence/test_late_rm_callback
[ 0.870643] dma-buf: Running dma_fence/test_status
[ 0.876014] dma-buf: Running dma_fence/test_error
[ 0.881299] dma-buf: Running dma_fence/test_wait
[ 0.886466] dma-buf: Running dma_fence/test_wait_timeout
[ 0.927625] dma-buf: Running dma_fence/test_stub
[ 0.932822] dma-buf: Running dma_fence/race_signal_callback
[ 1.017642] thread_signal_callback[0] completed 40893 passes, 87 misses
[ 1.025084] thread_signal_callback[1] completed 40911 passes, 106 misses
[ 1.107633] thread_signal_callback[0] completed 45127 passes, 45127 misses
[ 1.115349] thread_signal_callback[1] completed 45170 passes, 45168 misses
[ 1.123566] sunxi-spinand: AW SPINand MTD Layer Version: 2.0 20201228
[ 1.130885] sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.10 20200306
[ 1.138867] sunxi-spinand-phy: not detect any munufacture from id table
[ 1.146302] sunxi-spinand-phy: get spi-nand Model from fdt fail
[ 1.152976] sunxi-spinand-phy: get phy info from fdt fail
[ 1.159097] sunxi-spinand-phy: not detect munufacture from fdt
[ 1.165850] sunxi-spinand-phy: detect munufacture from id table: Mxic
[ 1.173103] sunxi-spinand-phy: detect spinand id: ffff12c2 ffffffff
[ 1.180205] sunxi-spinand-phy: ========== arch info ==========
[ 1.186748] sunxi-spinand-phy: Model: MX35LF1GE4AB
[ 1.193513] sunxi-spinand-phy: Munufacture: Mxic
[ 1.199489] sunxi-spinand-phy: DieCntPerChip: 1
[ 1.205153] sunxi-spinand-phy: BlkCntPerDie: 1024
[ 1.211124] sunxi-spinand-phy: PageCntPerBlk: 64
[ 1.216884] sunxi-spinand-phy: SectCntPerPage: 4
[ 1.222565] sunxi-spinand-phy: OobSizePerPage: 64
[ 1.228341] sunxi-spinand-phy: BadBlockFlag: 0x1
[ 1.234198] sunxi-spinand-phy: OperationOpt: 0x7
[ 1.240066] sunxi-spinand-phy: MaxEraseTimes: 65000
[ 1.246125] sunxi-spinand-phy: EccFlag: 0x2
[ 1.251990] sunxi-spinand-phy: EccType: 4
[ 1.257664] sunxi-spinand-phy: EccProtectedType: 3
[ 1.263332] sunxi-spinand-phy: ========================================
[ 1.270755] sunxi-spinand-phy:
[ 1.274274] sunxi-spinand-phy: ========== physical info ==========
[ 1.281219] sunxi-spinand-phy: TotalSize: 128 M
[ 1.286589] sunxi-spinand-phy: SectorSize: 512 B
[ 1.291966] sunxi-spinand-phy: PageSize: 2 K
[ 1.297146] sunxi-spinand-phy: BlockSize: 128 K
[ 1.302526] sunxi-spinand-phy: OOBSize: 64 B
[ 1.307809] sunxi-spinand-phy: ========================================
[ 1.315232] sunxi-spinand-phy:
[ 1.318773] sunxi-spinand-phy: ========== logical info ==========
[ 1.325606] sunxi-spinand-phy: TotalSize: 128 M
[ 1.330995] sunxi-spinand-phy: SectorSize: 512 B
[ 1.336364] sunxi-spinand-phy: PageSize: 4 K
[ 1.341551] sunxi-spinand-phy: BlockSize: 256 K
[ 1.346926] sunxi-spinand-phy: OOBSize: 128 B
[ 1.352306] sunxi-spinand-phy: ========================================
[ 1.359839] sunxi-spinand-phy: block lock register: 0x00
[ 1.365947] sunxi-spinand-phy: feature register: 0x11
[ 1.371627] sunxi-spinand-phy: sunxi physic nand init end
[ 1.378124] Creating 4 MTD partitions on “sunxi_mtd_nand”:
[ 1.384303] 0x000000000000-0x000000100000 : “boot0”
[ 1.398555] 0x000000100000-0x000000500000 : “uboot”
[ 1.406750] random: fast init done
[ 1.438455] 0x000000500000-0x000000600000 : “secure_storage”
[ 1.458450] 0x000000600000-0x000008000000 : “sys”
[ 1.866204] sunxi-spinand-phy: phy blk 818 is bad
[ 1.939930] random: crng init done
[ 1.988913] libphy: Fixed MDIO Bus: probed
[ 1.994348] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
[ 2.005662] sunxi gmac driver’s version: 1.0.0
[ 2.010830] gmac-power0: NULL
[ 2.014172] gmac-power1: NULL
[ 2.017496] gmac-power2: NULL
[ 2.021898] Failed to alloc md5
[ 2.025429] eth0: Use random mac address
[ 2.030131] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 2.037456] sunxi-ehci: EHCI SUNXI driver
[ 2.042298] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 2.049290] sunxi-ohci: OHCI SUNXI driver
[ 2.054235] i2c /dev entries driver
[ 2.058261] sunxi cedar version 1.1
[ 2.062334] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
[ 2.068669] VE: sunxi_cedar_probe power-domain init!!!
[ 2.074435] VE: install start!!!
[ 2.074435]
[ 2.079947] VE: cedar-ve the get irq is 43
[ 2.079947]
[ 2.086398] VE: ve_debug_proc_info:96496e4b, data:3ff2b0f7, lock:d7e98ddb
[ 2.086398]
[ 2.095691] VE: install end!!!
[ 2.095691]
[ 2.100791] VE: sunxi_cedar_probe
[ 2.104748] Bluetooth: HCI UART driver ver 2.3
[ 2.109761] Bluetooth: HCI UART protocol H4 registered
[ 2.115534] Bluetooth: HCI UART protocol BCSP registered
[ 2.121553] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 1.0.10
[ 2.128754] [XR_BT_LPM] bluesleep_probe: bt_wake polarity: 1
[ 2.135164] [XR_BT_LPM] bluesleep_probe: host_wake polarity: 1
[ 2.141739] [XR_BT_LPM] bluesleep_probe: wakeup source is disabled!
[ 2.141739]
[ 2.150444] [XR_BT_LPM] bluesleep_probe: uart_index(1)
[ 2.158231] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-11-18 10:02)
[ 2.168222] sunxi-mmc 4020000.sdmmc: ctl-spec-caps 8
[ 2.174419] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
[ 2.180785] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
[ 2.187243] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
[ 2.193700] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
[ 2.200257] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
[ 2.206802] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
[ 2.213353] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
[ 2.220350] sunxi-mmc 4020000.sdmmc: Got CD GPIO
[ 2.225753] sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
[ 2.232445] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.243639] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
[ 2.263832] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.288283] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
[ 2.293972] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.306128] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-11-18 10:02)
[ 2.308653] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.316089] sunxi-mmc 4021000.sdmmc: ctl-spec-caps 8
[ 2.329838] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.333693] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
[ 2.348256] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.351612] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
[ 2.369661] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
[ 2.376106] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
[ 2.382657] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
[ 2.389210] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
[ 2.395751] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
[ 2.402323] sunxi-mmc 4021000.sdmmc: Cann’t get pin bias hs pinstate,check if needed
[ 2.411713] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.412730] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.422882] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
[ 2.434796] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 2.451091] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 2.452004] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.462948] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[ 2.486216] mmc0: new high speed SDHC card at address aaaa
[ 2.487020] sunxi-mmc 4021000.sdmmc: detmode:manually by software
[ 2.493328] mmcblk0: mmc0:aaaa SD32G 29.7 GiB
[ 2.500159] exFAT: Version 1.3.0
[ 2.504233] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 2.509945] sunxi-spdif 2036000.spdif: request pinctrl handle for audio failed
[ 2.518392] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
[ 2.522824] sunxi-spdif 2036000.spdif: [sunxi_spdif_dev_probe] failed
[ 2.527651] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 2.534961] sunxi-spdif: probe of 2036000.spdif failed with error -22
[ 2.548972] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.558911] [AUDIOCODEC][sunxi_codec_parse_params][2412]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
[ 2.558911]
[ 2.577835] [AUDIOCODEC][sunxi_codec_parse_params][2448]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
[ 2.579059] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.589160] [AUDIOCODEC][sunxi_internal_codec_probe][2609]:codec probe finished
[ 2.608620] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 2.615374] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 2.622140] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 2.628910] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 2.628937] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 2.636545] debugfs: Directory ‘203034c.dummy_cpudai’ with parent ‘audiocodec’ already present!
[ 2.656646] [SNDCODEC][sunxi_card_init][583]:card init finished
[ 2.663778] sunxi-codec-machine 2030340.sound: 2030000.codec ↔ 203034c.dummy_cpudai mapping ok
[ 2.674679] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input0
[ 2.686645] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
[ 2.695094] NET: Registered protocol family 10
[ 2.700135] [SNDCODEC][sunxi_hs_init_work][259]:resume–>report switch
[ 2.708505] Segment Routing with IPv6
[ 2.712714] NET: Registered protocol family 17
[ 2.717937] Bluetooth: RFCOMM TTY layer initialized
[ 2.723420] Bluetooth: RFCOMM socket layer initialized
[ 2.729229] Bluetooth: RFCOMM ver 1.11
[ 2.733973] Registering SWP/SWPB emulation handler
[ 2.753988] sunxi-i2c sunxi-i2c2: sunxi-i2c2 supply twi not found, using dummy regulator
[ 2.763915] sunxi-i2c sunxi-i2c2: probe success
[ 2.770267] sunxi-spdif 2036000.spdif: request pinctrl handle for audio failed
[ 2.778410] sunxi-spdif 2036000.spdif: [sunxi_spdif_dev_probe] failed
[ 2.785731] sunxi-spdif: probe of 2036000.spdif failed with error -22
[ 2.794528] debugfs: Directory ‘2031000.dmic’ with parent ‘snddmic’ already present!
[ 2.803776] sunxi-audio-card 2031060.sounddmic: dmic-hifi ↔ 2031000.dmic mapping ok
[ 2.813697] get ehci0-controller wakeup-source is fail.
[ 2.819715] sunxi ehci0-controller don’t init wakeup source
[ 2.825975] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0b5df98, 0x:c88a5000, irq_no:3a
[ 2.837990] [sunxi-ehci0]: Not init ehci0
[ 2.842818] get ohci0-controller wakeup-source is fail.
[ 2.848801] sunxi ohci0-controller don’t init wakeup source
[ 2.855056] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0b5e228
[ 2.864735] [sunxi-ohci0]: Not init ohci0
[ 2.869543] get ehci1-controller wakeup-source is fail.
[ 2.875480] sunxi ehci1-controller don’t init wakeup source
[ 2.881754] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0b5e4b8, 0x:c88af000, irq_no:3c
[ 2.893997] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
[ 2.907389] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
[ 2.914683] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
[ 2.924629] sunxi-ehci 4200000.ehci1-controller: irq 60, io mem 0x04200000
[ 2.957636] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
[ 2.965454] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
[ 2.974487] hub 1-0:1.0: USB hub found
[ 2.978754] hub 1-0:1.0: 1 port detected
[ 2.983874] get ohci1-controller wakeup-source is fail.
[ 2.989882] sunxi ohci1-controller don’t init wakeup source
[ 2.996140] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0b5e748
[ 3.006023] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
[ 3.018316] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
[ 3.025579] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
[ 3.035506] sunxi-ohci 4200400.ohci1-controller: irq 61, io mem 0x04200400
[ 3.112401] hub 2-0:1.0: USB hub found
[ 3.116643] hub 2-0:1.0: 1 port detected
[ 3.122823] sun8iw20-pinctrl 2000000.pinctrl: pin PB6 already requested by 2500c00.uart; cannot claim for 2000000.pinctrl:38
[ 3.135462] sun8iw20-pinctrl 2000000.pinctrl: pin-38 (2000000.pinctrl:38) status -22
[ 3.146619] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 3.147678] clk: Not disabling unused clocks
[ 3.156338] cfg80211: failed to load regulatory.db
[ 3.161124] ALSA device list:
[ 3.169801] #0: audiocodec
[ 3.173057] #1: snddmic
[ 3.176000] alloc_fd: slot 0 not NULL!
[ 3.183430] VFS: Mounted root (squashfs filesystem) readonly on device 179:5.
[ 3.193415] devtmpfs: mounted
[ 3.198666] Freeing unused kernel memory: 1024K
[ 3.207776] Run /pseudo_init as init process
mount: mounting none on /dev failed: Resource busy
[ 3.347698] usb 1-1: new high-speed USB device number 2 using sunxi-ehci
mount: mounting /dev/by-name/rootfs_data on /overlay failed: No such device
Mount Failed: formating /dev/by-name/rootfs_data to ext4 …
/pseudo_init: line 395: mkfs.ext4: not found
can’t run ‘/etc/preinit’: No such file or directory
mount: mounting proc on /proc failed: Resource busy
hostname: can’t open ‘/etc/hostname’: No such file or directory
/etc/init.d/rcS: line 136: mkfs.ext4: not found
------run rc.final file-----
numid=30,iface=MIXER,name=‘Headphone Switch’
: values=on
Mon Feb 6 00:00:00 GMT 2023
nodev debugfs
root@TinaLinux:/# [ 3.608022] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[ 4.677904] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
[ 4.693717] read descriptors
[ 4.696965] read strings
root@TinaLinux:/#
root@TinaLinux:/# ifconfig -a
eth0 Link encap:Ethernet HWaddr A2:FC:FA:FB:D3:B9
BROADCAST MULTICAST MTU:1500 Metric:1
collisions:0 txqueuelen:1000
Interrupt:38
lo Link encap:Local Loopback
烧录的同一img,sd卡没有启动wifi
