初步看,操作没有什么问题,按这样操作试试:
1.切换到专业版,映像文件选择百度云" 03_开发板系统固件/Emmc/emmc.img"
2.烧写成功后,切换到emmc启动,注意拨码开关拨到位
3.如果没有成功,截图烧写成功界面和emmc启动提示界面
是不是拨码是坏的?
MMC write: dev # 1, block # 2, count 1054 … 1054 blocks written: OK
Writing ‘bootloader’ DONE!
UCmd : UCmd:if env exists emmc_ack; then ; else setenv emmc_ack 0; fi;
UCmd : UCmd:mmc partconf ${emmc_dev} ${emmc_ack} 1 0
你3拨上去4拨下来了么?
4处在ON的位置,无论3是on还是off都是usb模式
你要处于emmc模式,就只能3在on,手册的图展示的很清楚呀
我知道,我这边切换到emmc模式还是死活起不来,我在排查是不是拨码开关坏了,然后发现上面说的那个问题
很简单,你把所有的开关都弄到off,看下是不是还是从usb启动。
uuu (Universal Update Utility) for nxp imx chips – libuuu_1.3.136-0-g1ecc47f
Wait for Known USB Device Appear…
New USB Device Attached at 1:22
1:22>Start Cmd:SDP: boot -f “./firmware/u-boot-dtb_fastboot_100ask.imx”
0%
6400%
0%
209%
0%
5%
11%
17%
23%
29%
35%
41%
47%
53%
59%
65%
71%
77%
83%
89%
95%
100%
0%
6400%
0%
6400%
1:22>Okay (0.817s)
1:22>Start Cmd:SDP: done
1:22>Okay (0s)
e[?25h
1:22>Start Cmd:FB: ucmd setenv fastboot_dev mmc
1:22>Okay (0.006s)
1:22>Start Cmd:FB: ucmd setenv emmc_dev 1
1:22>Okay (0.002s)
1:22>Start Cmd:FB: ucmd setenv emmc_ack 1
1:22>Okay (0.003s)
1:22>Start Cmd:FB: ucmd setenv mmcdev ${emmc_dev}
1:22>Okay (0.004s)
1:22>Start Cmd:FB: ucmd mmc dev ${emmc_dev}
1:22>Okay (0.108s)
1:22>Start Cmd:FB: flash -raw2sparse all …/…/…/files/emmc.img
0x7000000max-download-size=0x7000000
0x200logical-block-size=0x200
1%
3%
5%
7%
9%
11%
13%
15%
16%
18%
20%
22%
24%
26%
28%
30%
31%
33%
35%
37%
39%
41%
43%
45%
47%
48%
50%
52%
54%
56%
58%
60%
62%
63%
65%
67%
69%
71%
73%
75%
77%
78%
80%
82%
84%
86%
88%
90%
92%
94%
95%
97%
99%
100%
1:22>Okay (206.1s)
1:22>Start Cmd:FB: flash bootloader …/…/…/files/u-boot-dtb.imx
1:22>Okay (0.228s)
1:22>Start Cmd:FB: ucmd if env exists emmc_ack; then ; else setenv emmc_ack 0; fi;
1:22>Okay (0.006s)
1:22>Start Cmd:FB: ucmd mmc partconf ${emmc_dev} ${emmc_ack} 1 0
1:22>Okay (0.007s)
1:22>Start Cmd:FB: done
1:22>Okay (0s)
e[?25h
-----Execution completed, Please set to EMMC mode and restart the board.----
试了十几次了 终究是无法起来 我怀疑是emmc掉了
https://pan.baidu.com/s/1bFgKNm5616DPd8zb7zv5wQ?pwd=root
给一个尝试方案,下载下图的 zip 文件;
然后双击下图的 vbs 文件烧录;看看能否正常启动;
你好 提示No Device Connected
开发板要设置为 usb 烧录模式;
设置了 然后以上方式都不行 然后我尝试把sdcard.img写入sd卡,但是必须要把拨码设置为usb方式才能启动,设置成sd卡模式反而启动不了
不行 还是No Device Connected
