把 dev_led.c 的代码贴出来看看;
#include <linux/module.h>
#include <linux/fs.h>
#include <linux/errno.h>
#include <linux/miscdevice.h>
#include <linux/kernel.h>
#include <linux/major.h>
#include <linux/mutex.h>
#include <linux/proc_fs.h>
#include <linux/seq_file.h>
#include <linux/stat.h>
#include <linux/init.h>
#include <linux/device.h>
#include <linux/tty.h>
#include <linux/kmod.h>
#include <linux/gfp.h>
#include <asm/io.h>
//#define FUN_INFO_LOG() printk("%s %s ",FILE,LINE)
/确定主设备号 major device number/
static int major =0;
static struct class *led_class;
static volatile unsigned int *SNVS_TAMPER3;
static volatile unsigned int *gpio5_GDIR;
static volatile unsigned int *gpio5_DR;
//#define GPIO5_ROOT_ARRD 0x02290000
//#define GPIO5_3 (GPIO5_ROOT_ARRD+0X14)
static int led_dev_open (struct inode *node, struct file *file)
//enable pin
//config pin as gpio
//config gpio open
*SNVS_TAMPER3 &=~0x0f;
*SNVS_TAMPER3 |=0x05; //配置为gpio
*gpio5_GDIR |= (1<<3);
static ssize_t led_dev_write (struct file *file, const char __user *buf, size_t size, loff_t *offset)
char value =0;
if(copy_from_user(&value,buf,1))
return -EFAULT;
if(value)
*gpio5_DR &= ~(1<<3); //set led on;
*gpio5_DR |= (1<<3);
//set led off;
return 1;
static struct file_operations ledfops = {
.owner = THIS_MODULE,
.write = led_dev_write,
.open = led_dev_open,
static int __init led_init(void)
// FUN_INFO_LOG();
register_chrdev(0, "100ask_led",&ledfops);
//ioremap
SNVS_TAMPER3 = ioremap(0x02290000+0x14,4);
gpio5_GDIR = ioremap(0x020AC004+0x14,4);
gpio5_DR = ioremap(0x020AC000+0x14,4);
//class 让内核分配设备号-》 /dev/myled
led_class = class_create(THIS_MODULE, "myled");
if (IS_ERR(led_class))
unregister_chrdev(major, "100ask_led");
printk("classerr*******\n");
return PTR_ERR(led_class);
device_create(led_class,NULL,MKDEV(major,0),NULL, "myled");
printk("%s %s %d\n", __FILE__, __FUNCTION__, __LINE__);
static void __exit led_exit(void)
iounmap(SNVS_TAMPER3);
iounmap(gpio5_GDIR);
iounmap(gpio5_DR);
device_destroy(led_class,MKDEV(major,0));
class_destroy(led_class);
module_init(led_init);
module_exit(led_exit);
MODULE_LICENSE(“GPL”);
把
修改为
major = register_chrdev(0, "100ask_led",&ledfops);
原因就是没有主设备号 device_create 失败?我对这个只了解大概;
还真是,谢谢嘻嘻
