wu@ubuntu:~/100ask_imx6ull-sdk$ …/repo/repo sync -j4
fatal: No names found, cannot describe anything.
remote: Enumerating objects: 180, done.
remote: Counting objects: 100% (180/180), done.
remote: Enumerating objects: 14986, done.
remote: Compressing objects: 100% (165/165), done.
remote: Counting objects: 100% (14986/14986), done.
remote: Compressing objects: 100% (13951/13951), done.
remote: Enumerating objects: 110477, done.
remote: Total 180 (delta 82), reused 0 (delta 0), pack-reused 0
Receiving objects: 100% (180/180), 305.39 KiB | 791.00 KiB/s, done.
Resolving deltas: 100% (82/82), done.
remote: Enumerating objects: 5125833, done. 86.00 KiB/s iving objects: 0% (127/14986), 604.00 KiB | 551.00 KiB/s
remote: Counting objects: 100% (89/89), done.
remote: Compressing objects: 100% (89/89), done.
remote: Enumerating objects: 826, done. KiB | 386.00 KiB/s
remote: Counting objects: 100% (826/826), done.
remote: Compressing objects: 100% (824/824), done. KiB/s
remote: Total 14986 (delta 855), reused 14715 (delta 738), pack-reused 0
Receiving objects: 100% (14986/14986), 20.66 MiB | 611.00 KiB/s, done.
Resolving deltas: 100% (855/855), done. KiB | 24.00 KiB/s
remote: Enumerating objects: 1008, done. B | 795.00 KiB/s 0% (31864/5125833), 15.34 MiB | 499.00 KiB/s
remote: Total 110477 (delta 0), reused 0 (delta 0), pack-reused 110477
Receiving objects: 100% (110477/110477), 36.92 MiB | 304.00 KiB/s, done.
Resolving deltas: 100% (87139/87139), done. | 517.00 KiB/s /s
remote: Enumerating objects: 39701, done. 90.00 KiB/s B/s 1% (73839/5125833), 34.74 MiB | 897.00 KiB/s
remote: Counting objects: 100% (39701/39701), done. 0 KiB/s
remote: Compressing objects: 100% (26700/26700), done.
error: RPC failed; curl 56 GnuTLS recv error (-9): A TLS packet with unexpected length was received.
fatal: The remote end hung up unexpectedly
fatal: early EOF
fatal: index-pack failed
weidongshan/imx6ull_NoosProgramProject:
fatal: early EOF
remote: Enumerating objects: 1008, done. 5.00 KiB/s s s
error: RPC failed; curl 18 transfer closed with outstanding read data remaining
fatal: early EOF
weidongshan/imx-linux4.9.88:
fatal: early EOF
remote: Enumerating objects: 5125833, done. 1.06 MiB/s
fatal: early EOF
ST-Buildoot-dl/ST-Buildoot-dl:
fatal: early EOF
remote: Enumerating objects: 826, done. iB | 351.00 KiB/s
remote: Compressing objects: 100% (824/824), done. 00 KiB/s
fatal: early EOF
ToolChain-7.x/ToolChain-7.x:
fatal: early EOF
remote: Enumerating objects: 39701, done. MiB | 378.00 KiB/s
fatal: early EOF
fatal: early EOF
error: Cannot fetch ST-Buildoot-dl/ST-Buildoot-dl from CODING | 一站式软件研发管理平台
remote: Enumerating objects: 7206, done. | 91.00 KiB/s /s objects: 33% (13239/39701), 90.15 MiB | 153.00 KiB/s
remote: Counting objects: 100% (7206/7206), done. KiB/s /s
remote: Compressing objects: 100% (3864/3864), done. 0 KiB/s
fatal: early EOF
weidongshan/ToolChain-6.2.1:
fatal: early EOF
remote: Enumerating objects: 7206, done. 6 MiB | 566.00 KiB/s
remote: Compressing objects: 100% (3864/3864), done. /s
remote: Total 7206 (delta 3109), reused 7196 (delta 3108), pack-reused 0
Receiving objects: 100% (7206/7206), 120.42 MiB | 408.00 KiB/s, done.
Resolving deltas: 100% (3109/3109), done.
remote: Enumerating objects: 460041, done. MiB | 497.00 KiB/s ects: 81% (32306/39701), 318.61 MiB | 404.00 KiB/s
remote: Counting objects: 100% (460041/460041), done. B/s
remote: Compressing objects: 100% (77358/77358), done.
remote: Total 460041 (delta 375560), reused 460001 (delta 375533), pack-reused 0
Receiving objects: 100% (460041/460041), 82.88 MiB | 286.00 KiB/s, done.
Resolving deltas: 100% (375560/375560), done.4.95 MiB | 288.00 KiB/s
remote: Enumerating objects: 15602, done. | 349.00 KiB/s g objects: 83% (4301497/5125833), 825.73 MiB | 257.00 KiB/s
remote: Counting objects: 100% (15602/15602), done.
remote: Compressing objects: 100% (12397/12397), done.
remote: Total 15602 (delta 3048), reused 15418 (delta 2920), pack-reused 0
Receiving objects: 100% (15602/15602), 23.16 MiB | 328.00 KiB/s, done.
Resolving deltas: 100% (3048/3048), done.
remote: Total 39701 (delta 10327), reused 39701 (delta 10327), pack-reused 0 (38353/39701), 487.86 MiB | 690.00 KiB/s
Receiving objects: 100% (39701/39701), 494.54 MiB | 336.00 KiB/s, done.
Resolving deltas: 100% (10327/10327), done.858.64 MiB | 476.00 KiB/s
remote: Total 5125833 (delta 61), reused 0 (delta 0), pack-reused 5125744 (4579785/5125833), 859.18 MiB | 496.00 KiB/s
Receiving objects: 100% (5125833/5125833), 920.72 MiB | 406.00 KiB/s, done.
Resolving deltas: 100% (4290931/4290931), done.
Fetching projects: 90% (9/10) weidongshan/imx-linux4.9.88
error: RPC failed; curl 56 GnuTLS recv error (-54): Error in the pull function.
fatal: early EOF
fatal: early EOF
error: Cannot fetch weidongshan/imx6ull_NoosProgramProject from https://gitee.com/weidongshan/imx6ull_NoosProgramProject
Fetching projects: 100% (10/10), done.
Checking out projects: 10% (1/10) buildroot/buildrooterror: Cannot checkout ST-Buildoot-dl/ST-Buildoot-dl: ManifestInvalidRevisionError: revision imx6ull in ST-Buildoot-dl/ST-Buildoot-dl not found
error: in sync -j4: revision imx6ull in ST-Buildoot-dl/ST-Buildoot-dl not found
