Hello all,
I am have a T113-S3 Pro Board and download Image for SD Card (100ask-t113-pro_sdcard.img [557MB]),
but have some error while booting process like a post log boot below.
is there any solution for that?
Thanks.
[153]HELLO! BOOT0 is starting!
[156]BOOT0 commit : 2c94b33
[159]set pll start
[165]periph0 has been enabled
[168]set pll end
[169][pmu]: bus read error
[172]board init ok
[174]enable_jtag
[176]ZQ value = 0x30***********
[179]get_pmu_exist() = -1
[181]ddr_efuse_type: 0xa
[185][AUTO DEBUG] single rank and full DQ!
[189]ddr_efuse_type: 0xa
[192][AUTO DEBUG] rank 0 row = 13
[195][AUTO DEBUG] rank 0 bank = 8
[199][AUTO DEBUG] rank 0 page size = 2 KB
[203]DRAM BOOT DRIVE INFO: V0.24
[206]DRAM CLK = 792 MHz
[208]DRAM Type = 3 (2:DDR2,3:DDR3)
[212]DRAMC read ODT off.
[214]DRAM ODT value: 0x42.
[217]ddr_efuse_type: 0xa
[220]DRAM SIZE =128 M
[222]PLL_DDR_CTRL_REG:0xf8004100
[225]DRAM_CLK_REG:0xc0000000
[233]DRAM simple test OK.
[235]rtc standby flag is 0x0, super standby flag is 0x0
[241]dram size =128
[243]card no is 0
[245]sdcard 0 line count 4
[248][mmc]: mmc driver ver 2021-03-22 20:20
[257][mmc]: Wrong media type 0x0
[260][mmc]: ***Try SD card 0***
[279][mmc]: HSSDR52/SDR25 4 bit
[282][mmc]: 50000000 Hz
[284][mmc]: 30436 MB
[286][mmc]: ***SD/MMC 0 init OK!!!***
[381]Loading boot-pkg Succeed(index=0).
[385]Entry_name = u-boot
[392]Entry_name = optee
[396]Entry_name = logo
[398]Entry_name = dtb
[401]mmc not para
[403]Jump to second Boot.
U-Boot 2018.05 (Aug 01 2022 - 04:03:28 +0000) Allwinner Technology
[00.458]CPU: Allwinner Family
[00.461]Model: sun8iw20
[00.463]DRAM: 128 MiB
[00.467]Relocation Offset is: 04ebd000
[00.494]secure enable bit: 0
[00.497]smc_tee_inform_fdt failed with: -65526[00.501]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=300Mhz
[00.507]gic: sec monitor mode
[00.510]line:703 init_clocks
[00.513]drv_disp_init
request pwm success, pwm7:pwm7:0x2000c00.
[00.527]drv_disp_init finish
[00.530]boot_gui_init:start
[00.532]set disp.dev2_output_type fail. using defval=0
[00.539]boot_gui_init:finish
[00.557]flash init start
[00.559]workmode = 0,storage type = 1
[00.562][mmc]: mmc driver ver uboot2018:2021-09-07 19:43:00
[00.568][mmc]: get sdc_type fail and use default host:tm1.
[00.574][mmc]: can't find node "mmc0",will add new node
[00.579][mmc]: fdt err returned <no error>
[00.582][mmc]: Using default timing para
[00.586][mmc]: SUNXI SDMMC Controller Version:0x50310
[00.614][mmc]: card_caps:0x3000000a
[00.617][mmc]: host_caps:0x3000003f
[00.622]sunxi flash init ok
[00.637]Loading Environment from SUNXI_FLASH... OK
[00.660]Item0 (Map) magic is bad
[00.663]the secure storage item0 copy0 magic is bad
[00.673]Item0 (Map) magic is bad
[00.676]the secure storage item0 copy1 magic is bad
[00.681]Item0 (Map) magic is bad
[00.687]secure storage read widevine fail with:-1
[00.694]secure storage read ec_key fail with:-1
[00.701]secure storage read ec_cert1 fail with:-1
[00.709]secure storage read ec_cert2 fail with:-1
[00.716]secure storage re[00.719]LCD open finish
ad ec_cert3 fail with:-1
[00.726]secure storage read rsa_key fail with:-1
[00.734]secure storage read rsa_cert1 fail with:-1
[00.741]secure storage read rsa_cert2 fail with:-1
[00.749]secure storage read rsa_cert3 fail with:-1
[00.754]usb burn from boot
delay time 0
weak:otg_phy_config
[00.765]usb prepare ok
[01.029]usb sof ok
[01.031]usb probe ok
[01.033]usb setup ok
set address 0x27
set address 0x27 ok
set address 0x26
set address 0x26 ok
try to update
[04.038]do_burn_from_boot usb : have no handshake
partno erro : can't find partition private
root_partition is rootfs
set root to /dev/mmcblk0p5
[04.056]update part info
[04.060]update bootcmd
[04.064]change working_fdt 0x4487ce70 to 0x4485ce70
[04.081]update dts
phy_mode=rmii, phy_interface=6
eth0
Error: eth0 address not set.
card0 has inited
curr_device:0
Device: SUNXI SD/MMC
Manufacturer ID: 3
OEM: 5344
Bus Speed: 50000000
Mode : SD High Speed (50MHz)
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 29.7 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
Partition Map for MMC device 0 -- Partition Type: EFI
Part Start LBA End LBA Name
Attributes
Type GUID
Partition GUID
1 0x00008a40 0x00009a3f "boot-resource"
attrs: 0x0000000000000000
type: 0fc63daf-8483-4772-8e79-3d69d8477de4
guid: 7c1aa552-060d-468e-85ed-df57fdf711c9
2 0x00009a40 0x00009b3f "env"
guid: 729e74af-f666-41ae-bc02-36bab89b86e7
3 0x00009b40 0x00009c3f "env-redund"
guid: db1b4c6d-52ca-43f3-b15c-2a0e8131fd4f
4 0x00009c40 0x00019c3f "boot"
attrs: 0x0000000000000004
guid: 832d6419-2418-4164-aa82-fbca1725ee60
5 0x00019c40 0x00099c3f "rootfs"
guid: d06434b9-6e6d-497d-b89e-c91b43702210
6 0x00099c40 0x00119c3f "share"
guid: 5f281b55-c115-41d9-a8b7-4c666b732708
261240 bytes read in 12 ms (20.8 MiB/s)
5025792 bytes read in 210 ms (22.8 MiB/s)
[06.453]no vendor_boot partition is found
Android's image name: sun8iw20p1
[06.466]Starting kernel ...
[06.468][mmc]: MMC Device 2 not found
[06.472][mmc]: mmc 2 not find, so not exit
[ 0.000000] Linux version 5.4.61 (book@virtual-machine) (arm-linux-gnueabi-gcc (Linaro GCC 7.2-2017.11) 7.2.1 20171011, GNU ld (Linaro_Binutils-2017.11) 2.28.2.20170706) #4 SMP PREEMPT Fri Aug 5 03:58:45 UTC 2022
[ 0.000000] cma: Reserved 16 MiB at 0x47000000
[ 0.000000] percpu: Embedded 15 pages/cpu s30860 r8192 d22388 u61440
[ 0.000000] pcpu-alloc: s30860 r8192 d22388 u61440 alloc=15*4096
[ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0x05000000 clk_ignore_unused initcall_debug=0 console=ttyS3,115200 loglevel=8 root=/dev/mmcblk0p5 init=/sbin/init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:share@mmcblk0p6 cma=16M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.hardware=sun8iw20p1 boot_type=1 androidboot.boot_type=1 gpt=1 uboot_message=2018.05(08/01/2022-04:03:28) disp_reserve=2457600,0x448a6000 androidboot.dramsize=128
[ 0.000000] Memory: 90588K/131072K available (7168K kernel code, 410K rwdata, 2424K rodata, 1024K init, 183K bss, 24100K reserved, 16384K cma-reserved)
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] random: get_random_bytes called from start_kernel+0x248/0x3d0 with crng_init=0
[ 0.000193] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000786] Console: colour dummy device 80x30
[ 0.000827] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000841] pid_max: default: 32768 minimum: 301
[ 0.000922] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.000936] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.001546] CPU: Testing write buffer coherency: ok
[ 0.001881] /cpus/cpu@0 missing clock-frequency property
[ 0.001902] /cpus/cpu@1 missing clock-frequency property
[ 0.001913] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002598] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.002760] rcu: Hierarchical SRCU implementation.
[ 0.003102] BOOTEVENT: 3.093540: ON
[ 0.003306] smp: Bringing up secondary CPUs ...
[ 0.004596] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.004752] smp: Brought up 1 node, 2 CPUs
[ 0.004767] SMP: Total of 2 processors activated (96.00 BogoMIPS).
[ 0.004774] CPU: All CPU(s) started in SVC mode.
[ 0.005343] devtmpfs: initialized
[ 0.106771] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.109610] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.109641] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.110392] pinctrl core: initialized pinctrl subsystem
[ 0.122069] NET: Registered protocol family 16
[ 0.125139] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.445684] rtc_ccu: sunxi ccu init OK
[ 0.489772] ccu: sunxi ccu init OK
[ 0.494191] r_ccu: sunxi ccu init OK
[ 0.996250] iommu: Default domain type: Translated
[ 1.001197] sunxi iommu: irq = 24
[ 1.029052] SCSI subsystem initialized
[ 1.044466] usbcore: registered new interface driver usbfs
[ 1.044621] usbcore: registered new interface driver hub
[ 1.049578] usbcore: registered new device driver usb
[ 1.055517] mc: Linux media interface: v0.10
[ 1.057901] videodev: Linux video capture interface: v2.00
[ 1.077320] Advanced Linux Sound Architecture Driver Initialized.
[ 1.093042] Bluetooth: Core ver 2.22
[ 1.093152] NET: Registered protocol family 31
[ 1.093161] Bluetooth: HCI device and connection manager initialized
[ 1.093185] Bluetooth: HCI socket layer initialized
[ 1.093198] Bluetooth: L2CAP socket layer initialized
[ 1.093232] Bluetooth: SCO socket layer initialized
[ 1.098614] pwm module init!
[ 1.115003] g2d 5410000.g2d: Adding to iommu group 0
[ 1.118035] G2D: rcq version initialized.major:251
[ 1.131572] input: sunxi-keyboard as /devices/virtual/input/input0
[ 1.143113] clocksource: Switched to clocksource arch_sys_counter
[ 1.338037] sun8iw20-pinctrl pio: initialized sunXi PIO driver
[ 1.717273] thermal_sys: Registered thermal governor 'step_wise'
[ 1.717278] thermal_sys: Registered thermal governor 'user_space'
[ 1.733761] NET: Registered protocol family 2
[ 1.744381] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 1.744417] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 1.744442] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 1.744464] TCP: Hash tables configured (established 1024 bind 1024)
[ 1.744585] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 1.745074] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 1.751213] NET: Registered protocol family 1
[ 1.761685] RPC: Registered named UNIX socket transport module.
[ 1.761702] RPC: Registered udp transport module.
[ 1.761709] RPC: Registered tcp transport module.
[ 1.761716] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.775990] sun8iw20-pinctrl pio: pio supply vcc-pc not found, using dummy regulator
[ 1.786138] spi spi0: spi0 supply spi not found, using dummy regulator
[ 1.786548] sunxi_spi_resource_get()2151 - [spi0] SPI MASTER MODE
[ 1.789818] sunxi_spi_resource_get()2189 - Failed to get sample mode
[ 1.789831] sunxi_spi_resource_get()2194 - Failed to get sample delay
[ 1.789842] sunxi_spi_resource_get()2198 - sample_mode:-1431633921 sample_delay:-1431633921
[ 1.789923] sunxi_spi_clk_init()2240 - [spi0] mclk 100000000
[ 1.803930] sunxi_spi_probe()2653 - [spi0]: driver probe succeed, base c8821000, irq 42
[ 1.854572] Initialise system trusted keyrings
[ 1.854822] workingset: timestamp_bits=30 max_order=15 bucket_order=0
[ 1.865989] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 1.866144] fuse: init (API version 7.31)
[ 1.908014] NET: Registered protocol family 38
[ 1.908051] Key type asymmetric registered
[ 1.908059] Asymmetric key parser 'x509' registered
[ 1.908160] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 1.908173] io scheduler mq-deadline registered
[ 1.908182] io scheduler kyber registered
[ 1.908306] atomic64_test: passed
[ 1.932722] [DISP]disp_module_init
[ 1.946401] disp 5000000.disp: Adding to iommu group 0
[ 1.950381] [DISP] disp_init,line:2386:
[ 1.950389] smooth display screen:0 type:1 mode:4
[ 1.968212] disp 5000000.disp: 5000000.disp supply vcc-lcd not found, using dummy regulator
[ 1.972002] disp 5000000.disp: 5000000.disp supply vcc-pd not found, using dummy regulator
[ 1.981108] display_fb_request,fb_id:0
[ 1.998011] disp_al_manager_apply ouput_type:1
[ 1.998344] [DISP] lcd_clk_config,line:732:
[ 1.998355] disp 0, clk: pll(306000000),clk(306000000),dclk(51000000) dsi_rate(306000000)
[ 1.998355] clk real:pll(300000000),clk(300000000),dclk(50000000) dsi_rate(0)
[ 1.998713] sun8iw20-pinctrl pio: pio supply vcc-pd not found, using dummy regulator
[ 2.002429] wait for new fb take effect
[ 2.044808] Freeing logo buffer memory: 2400K
[ 2.055605] [DISP]disp_module_init finish
[ 2.060387] sunxi_sid_init()551 - insmod ok
[ 2.070946] pwm-regulator: supplied by regulator-dummy
[ 2.096403] sun8iw20-pinctrl pio: pio supply vcc-pg not found, using dummy regulator
[ 2.097012] uart uart1: get regulator failed
[ 2.097037] uart uart1: uart1 supply uart not found, using dummy regulator
[ 2.107493] uart1: ttyS1 at MMIO 0x2500400 (irq = 34, base_baud = 1500000) is a SUNXI
[ 2.108392] sun8iw20-pinctrl pio: pio supply vcc-pb not found, using dummy regulator
[ 2.115681] uart uart3: get regulator failed
[ 2.115711] uart uart3: uart3 supply uart not found, using dummy regulator
[ 2.126059] uart3: ttyS3 at MMIO 0x2500c00 (irq = 35, base_baud = 1500000) is a SUNXI
[ 2.126090] sw_console_setup()1784 - console setup baud 115200 parity n bits 8, flow n
[ 3.123260] printk: console [ttyS3] enabled
[ 3.142903] misc dump reg init
[ 3.172438] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
[ 3.179815] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
[ 3.190474] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
[ 3.198058] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
[ 3.204644] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
[ 3.211616] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
[ 3.219404] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=204 assert=1
[ 3.227306] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
[ 3.235447] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
[ 3.243243] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
[ 3.250006] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
[ 3.257606] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=207 assert=0
[ 3.311889] libphy: Fixed MDIO Bus: probed
[ 3.327271] sun8iw20-pinctrl pio: pio supply vcc-pe not found, using dummy regulator
[ 3.336346] sunxi gmac driver's version: 1.0.0
[ 3.345132] gmac-power0: NULL
[ 3.348460] gmac-power1: NULL
[ 3.351815] gmac-power2: NULL
[ 3.384427] Failed to alloc md5
[ 3.387964] eth0: Use random mac address
[ 3.392740] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.400176] sunxi-ehci: EHCI SUNXI driver
[ 3.405117] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 3.412104] sunxi-ohci: OHCI SUNXI driver
[ 3.417702] usbcore: registered new interface driver uas
[ 3.423863] usbcore: registered new interface driver usb-storage
[ 3.430679] usbcore: registered new interface driver ums-alauda
[ 3.437512] usbcore: registered new interface driver ums-cypress
[ 3.444359] usbcore: registered new interface driver ums-datafab
[ 3.451192] usbcore: registered new interface driver ums_eneub6250
[ 3.458210] usbcore: registered new interface driver ums-freecom
[ 3.468097] usbcore: registered new interface driver ums-isd200
[ 3.474877] usbcore: registered new interface driver ums-jumpshot
[ 3.481819] usbcore: registered new interface driver ums-karma
[ 3.488458] usbcore: registered new interface driver ums-onetouch
[ 3.495489] usbcore: registered new interface driver ums-realtek
[ 3.502335] usbcore: registered new interface driver ums-sddr09
[ 3.509101] usbcore: registered new interface driver ums-sddr55
[ 3.518882] usbcore: registered new interface driver ums-usbat
[ 3.550465] ts probe start
[ 3.561918] input: 2009c00.rtp as /devices/platform/soc@3000000/2009c00.rtp/input/input1
[ 3.577534] ts probe success
[ 3.588545] sunxi_gpadc_init,2137, success
[ 3.596797] sunxi_gpadc_setup: get channel scan data failed
[ 3.603846] input: sunxi-gpadc0 as /devices/virtual/input/input2
[ 3.648167] sunxi-rtc 7090000.rtc: registered as rtc0
[ 3.654033] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T01:56:10 UTC (6970)
[ 3.663305] sunxi-rtc 7090000.rtc: sunxi rtc probed
[ 3.669296] i2c /dev entries driver
[ 3.673461] IR NEC protocol handler initialized
[ 3.678581] IR RC5(x/sz) protocol handler initialized
[ 3.691821] sunxi_ir_startup: get ir protocol failed
[ 3.691852] (NULL device *): deviceless supply not found, using dummy regulator
[ 3.705907] Registered IR keymap rc_map_sunxi
[ 3.718083] rc rc0: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0
[ 3.733541] input: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0/s_cir_rx
[ 3.762343] usbcore: registered new interface driver uvcvideo
[ 3.768855] USB Video Class driver (1.1.1)
[ 3.773512] gspca_main: v2.14.0 registered
[ 3.778115] sunxi cedar version 1.1
[ 3.782274] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
[ 3.788592] VE: sunxi_cedar_probe power-domain init!!!
[ 3.794405] VE: install start!!!
[ 3.794405]
[ 3.800038] VE: cedar-ve the get irq is 43
[ 3.800038]
[ 3.806606] VE: ve_debug_proc_info:(ptrval), data:(ptrval), lock:(ptrval)
[ 3.806606]
[ 3.815922] VE: install end!!!
[ 3.815922]
[ 3.821017] VE: sunxi_cedar_probe
[ 3.833692] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 3.842928] Bluetooth: HCI UART driver ver 2.3
[ 3.848013] Bluetooth: HCI UART protocol H4 registered
[ 3.853807] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 1.0.10
[ 3.861080] [XR_BT_LPM] bluesleep_probe: bt_wake polarity: 1
[ 3.867533] [XR_BT_LPM] bluesleep_probe: host_wake polarity: 1
[ 3.874126] [XR_BT_LPM] bluesleep_probe: wakeup source is disabled!
[ 3.874126]
[ 3.882829] [XR_BT_LPM] bluesleep_probe: uart_index(1)
[ 3.953973] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-05-24 16:10)
[ 3.964007] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
[ 3.970216] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
[ 3.976602] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
[ 3.983049] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
[ 3.989510] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
[ 3.996073] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
[ 4.002614] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
[ 4.009177] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
[ 4.019952] sunxi-mmc 4020000.sdmmc: Got CD GPIO
[ 4.025459] sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
[ 4.036538] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 4.047760] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
[ 4.067941] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 4.092469] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
[ 4.101993] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-05-24 16:10)
[ 4.112512] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
[ 4.118777] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
[ 4.125146] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
[ 4.131592] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
[ 4.138062] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
[ 4.144617] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
[ 4.151167] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
[ 4.157765] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
[ 4.167467] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
[ 4.188363] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 4.199593] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
[ 4.219772] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 4.244038] sunxi-mmc 4021000.sdmmc: detmode:manually by software
[ 4.254824] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 4.265465] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 4.272386] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 4.281317] usbcore: registered new interface driver usbhid
[ 4.287214] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 4.290298] usbhid: USB HID core driver
[ 4.294698] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 4.310594] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 4.328726] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 4.339637] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 4.349906] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 4.356747] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 4.399450] [AUDIOCODEC][sunxi_codec_parse_params][2412]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
[ 4.399450]
[ 4.416693] [AUDIOCODEC][sunxi_codec_parse_params][2448]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
[ 4.428192] [AUDIOCODEC][sunxi_internal_codec_probe][2609]:codec probe finished
[ 4.477944] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
[ 4.487807] [SNDCODEC][sunxi_card_init][583]:card init finished
[ 4.502583] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
[ 4.551841] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input4
[ 4.579327] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
[ 4.594872] [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
[ 4.595669] NET: Registered protocol family 10
[ 4.623879] Segment Routing with IPv6
[ 4.628107] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 4.673793] NET: Registered protocol family 17
[ 4.678813] NET: Registered protocol family 15
[ 4.684029] Bluetooth: RFCOMM TTY layer initialized
[ 4.689516] Bluetooth: RFCOMM socket layer initialized
[ 4.695374] Bluetooth: RFCOMM ver 1.11
[ 4.700362] Registering SWP/SWPB emulation handler
[ 4.706369] Loading compiled-in X.509 certificates
[ 5.101650] twi twi2: twi2 supply twi not found, using dummy regulator
[ 5.129779] sunxi_i2c_probe()2266 - [i2c2] probe success
[ 5.218362] get ehci0-controller wakeup-source is fail.
[ 5.224387] sunxi ehci0-controller don't init wakeup source
[ 5.230639] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0c88088, 0x:c88dd000, irq_no:3a
[ 5.242647] [sunxi-ehci0]: Not init ehci0
[ 5.249620] get ohci0-controller wakeup-source is fail.
[ 5.259116] sunxi ohci0-controller don't init wakeup source
[ 5.265404] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0c88318
[ 5.275070] [sunxi-ohci0]: Not init ohci0
[ 5.283747] get ehci1-controller wakeup-source is fail.
[ 5.289734] sunxi ehci1-controller don't init wakeup source
[ 5.296007] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0c885a8, 0x:c88e7000, irq_no:3c
[ 5.315745] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
[ 5.336839] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
[ 5.344132] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
[ 5.354099] sunxi-ehci 4200000.ehci1-controller: irq 60, io mem 0x04200000
[ 5.383127] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
[ 5.390940] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
[ 5.415396] hub 1-0:1.0: USB hub found
[ 5.419671] hub 1-0:1.0: 1 port detected
[ 5.436695] get ohci1-controller wakeup-source is fail.
[ 5.446475] sunxi ohci1-controller don't init wakeup source
[ 5.452734] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0c88838
[ 5.462729] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
[ 5.486322] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
[ 5.497327] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
[ 5.507477] sunxi-ohci 4200400.ohci1-controller: irq 61, io mem 0x04200400
[ 5.526393] random: fast init done
[ 5.603214] hub 2-0:1.0: USB hub found
[ 5.607490] hub 2-0:1.0: 1 port detected
[ 5.641463] sun8iw20-pinctrl pio: pin PB6 already requested by 2500c00.uart; cannot claim for pio:38
[ 5.651751] sun8iw20-pinctrl pio: pin-38 (pio:38) status -22
[ 5.658286] ERR: id gpio_request failed
[ 5.671947] get ctp_power is fail, -22
[ 5.676199] get ctp_power_ldo_vol is fail, -22
[ 5.681197] sunxi_ctp_startup: ctp_power_io is invalid.
[ 5.687115] get ctp_gesture_wakeup fail, no gesture wakeup
[ 5.693300] gt9xxnew_ts 2-0014: 2-0014 supply ctp not found, using dummy regulator
[ 5.803139] usb 1-1: new high-speed USB device number 2 using sunxi-ehci
[ 5.893439] input: gt9xxnew_ts as /devices/virtual/input/input5
[ 5.928695] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 5.951858] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 5.965465] clk: Not disabling unused clocks
[ 5.965497] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 5.970297] ALSA device list:
[ 5.979986] cfg80211: failed to load regulatory.db
[ 5.983389] #0: audiocodec
[ 5.991956] alloc_fd: slot 0 not NULL!
[ 5.998473] VFS: Cannot open root device "mmcblk0p5" or unknown-block(0,0): error -6
[ 6.007219] Please append a correct "root=" boot option; here are the available partitions:
[ 6.016622] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[ 6.025892] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.4.61 #4
[ 6.032523] Hardware name: Generic DT based system
[ 6.037914] [<c010e238>] (unwind_backtrace) from [<c010a844>] (show_stack+0x10/0x14)
[ 6.046599] [<c010a844>] (show_stack) from [<c075569c>] (dump_stack+0x7c/0x98)
[ 6.054700] [<c075569c>] (dump_stack) from [<c0119524>] (panic+0x104/0x3d8)
[ 6.062509] [<c0119524>] (panic) from [<c0b01254>] (mount_block_root+0x244/0x33c)
[ 6.070899] [<c0b01254>] (mount_block_root) from [<c0b01504>] (prepare_namespace+0x138/0x178)
[ 6.080459] [<c0b01504>] (prepare_namespace) from [<c0769730>] (kernel_init+0x8/0x118)
[ 6.089336] [<c0769730>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
[ 6.097819] Exception stack(0xc6817fb0 to 0xc6817ff8)
[ 6.103479] 7fa0: 00000000 00000000 00000000 00000000
[ 6.112646] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.121812] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 6.129235] CPU1: stopping
[ 6.132270] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 5.4.61 #4
[ 6.138900] Hardware name: Generic DT based system
[ 6.144275] [<c010e238>] (unwind_backtrace) from [<c010a844>] (show_stack+0x10/0x14)
[ 6.152958] [<c010a844>] (show_stack) from [<c075569c>] (dump_stack+0x7c/0x98)
[ 6.161057] [<c075569c>] (dump_stack) from [<c010c64c>] (handle_IPI+0xcc/0x168)
[ 6.169256] [<c010c64c>] (handle_IPI) from [<c039758c>] (gic_handle_irq+0x70/0x78)
[ 6.177746] [<c039758c>] (gic_handle_irq) from [<c01021cc>] (__irq_svc+0x6c/0xa8)
[ 6.186130] Exception stack(0xc6841f80 to 0xc6841fc8)
[ 6.191793] 1f80: 00000cd4 c6ec4534 00000000 c0114b00 00000002 c0c03de8 ffffe000 c0c5fea2
[ 6.200961] 1fa0: c0c03e24 410fc075 00000000 00000000 c0c02d00 c6841fd0 c0107f40 c0107f30
[ 6.210125] 1fc0: 60000013 ffffffff
[ 6.214038] [<c01021cc>] (__irq_svc) from [<c0107f30>] (arch_cpu_idle+0x1c/0x38)
[ 6.222332] [<c0107f30>] (arch_cpu_idle) from [<c013dee0>] (do_idle+0xdc/0x12c)
[ 6.230528] [<c013dee0>] (do_idle) from [<c013e1cc>] (cpu_startup_entry+0x18/0x1c)
[ 6.239014] [<c013e1cc>] (cpu_startup_entry) from [<40102c2c>] (0x40102c2c)
[ 6.246827] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---
