Yuzuki Lizard V851S开发板 – RTSP推流 (群友Blev提供)
你好 我也碰到了同样的问题,请问你的问题解决了吗
Hi Sergpenshin,I meet the same question with you,have you solved the question and can give me some advice?
没有解决,有没有大神帮忙看一下啊?
您好:
我尝试推流,报错显示ISP配置未找到,不知有没有类似的情况?盼回复!
root@TinaLinux:/mnt/extsd# ./sample_rtsp -path sample_rtsp.conf
WARNING: Logging before InitGoogleLogging() is written to STDERR
I0101 00:02:26.878400  1023 dup2SeldomUsedFd.c:20]          <dup2SeldomUsedFdInit> gFdLock init
I0101 00:02:26.887502  1023 sample_rtsp.c:95]               <ParseCmdLine> sample virvi2venc path:[./sample_rtsp], arg number is [3]
I0101 00:02:26.892372  1023 confparser.c:60]                <createConfParser> load conf file sample_rtsp.conf ok!
I0101 00:02[  142.608074] VE: before freq=300000000
:26.892842  1023 sample_rtsp.c:2[  142.613339] VE: real freq=300000000
92]                                                         <loadSampleConfig> IspAndVeLinkage config: Enable=1, StreamChn=0
Committed_AS:       3740 kB
I0101 00:02:26.902375  1023 mpi_sys.c:840]                  <AW_MPI_SYS_SetConf> kfctmpdir is [/tmp]
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Media Process Platform<<<<<<<<<<<<<<<<<<<<<<<<<<<<
modName : MPP-Platform
tag   : V1.0 Release
branch: v5-dev
commit: 4eed413532ad87725895a8cb1ba75e22fc328233
date  : 20170725
author: jenkins
iniparser: cannot open /etc/cedarx.conf
iniparser: cannot open /vendor/etc/cedarx.conf
I0101 00:02:26.915210  1023 mpi_sys.c:1280]                 <AW_MPI_SYS_Init> ISP init
[ISP]>>>>>>>>>>>>>>>>>>>> ISP VERSION INFO <<<<<<<<<<<<<<<<<<<
IPCORE: ISP600
branch: libisp-dev
commit: 14df8348718d093707641fea73eba7db962885f5
date  : Thu Jul 14 15:40:38 2022 +0800
author: <mayifei@allwinnertech.com>
I0101 00:02:26.916141  1023 mpi_sys.c:1282]                 <AW_MPI_SYS_Init> ISP init done
INFO   : cedarc <VeInitialize:1185>: *** ic_version = 0x1302000023010,
I0101 00:02:26.931874  1023 hwdisplay.c:84]                 <hw_display_init>
I0101 00:02:26.932136  1023 hwdisplay.c:993]                <hwd_init> (hwd_init 993)
I0101 00:02:26.932339  1023 hwdisplay.c:1048]               <hwd_init> ret[0][2,0]ch[0]lyl[0] init: enable[0], screenwin[0,0, 0x0], zorder[0], alpha[mode:0, value:0]
I0101 00:02:26.934004  1023 alsa_interface.c:701]           <alsaOpenMixer> open mixer:hw:0
I0101 00:02:26.988552  1023 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:ADC1 ADC2 swap
I0101 00:02:26.988760  1023 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:ADC1 volume
I0101 00:02:26.988865  1023 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:ADC2 volume
I0101 00:02:26.988950  1023 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:ADCDRC
I0101 00:02:26.989053  1023 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:ADCHPF
I0101 00:02:26.989128  1023 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:DAC volume
I0101 00:02:26.989200  1023 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:DACDRC
I0101 00:02:26.989270  1023 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:DACHPF
I0101 00:02:26.989348  1023 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEIN
I0101 00:02:26.989418  1023 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEINL gain volume
I0101 00:02:26.989514  1023 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEINR gain volume
I0101 00:02:26.989590  1023 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEOUT
I0101 00:02:26.989853  1023 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEOUT Output Select
I0101 00:02:26.990145  1023 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEOUT volume
I0101 00:02:26.990316  1023 alsa_interface.c:756]           <alsaOpenMixer> set playback vol_val to value: 27
I0101 00:02:26.990426  1023 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC1
I0101 00:02:26.990645  1023 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC1 Input Select
I0101 00:02:26.990759  1023 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC1 gain volume
I0101 00:02:26.990845  1023 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC2
I0101 00:02:26.990924  1023 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC2 Input Select
I0101 00:02:26.990997  1023 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC2 gain volume
I0101 00:02:26.991073  1023 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:SPK
I0101 00:02:26.991275  1023 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:digital volume
I0101 00:02:26.991392  1023 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:rx sync mode
I0101 00:02:26.991477  1023 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:tx hub mode
E0101 00:02:26.991563  1023 alsa_interface.c:970]           <alsaMixerSetAudioCodecHubMode> aec_elem_audio_codec_hub_mode:tx hub mode-1
E0101 00:02:26.991691  1023 alsa_interface.c:853]           <alsaMixerSetCapPlaySyncMode> aec_elem_sync_mode_switch:rx sync mode-1
I0101 00:02:26.991809  1023 alsa_interface.c:701]           <alsaOpenMixer> open mixer:hw:1
I0101 00:02:26.992683  1023 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:loopback debug
I0101 00:02:26.992861  1023 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:rx sync mode
I0101 00:02:26.992964  1023 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:tx hub mode
E0101 00:02:26.993089  1023 alsa_interface.c:993]           <alsaMixerSetDAudio0HubMode> aec_elem_daudio0_hub_mode:tx hub mode-1
E0101 00:02:26.993217  1023 alsa_interface.c:1016]          <alsaMixerSetDAudio0LoopBackEn> aec_elem_daudio0_loopback_en:loopback debug-1
E0101 00:02:27.325210  1023 alsa_interface.c:853]           <alsaMixerSetCapPlaySyncMode> aec_elem_sync_mode_switch:rx sync mode-1
I0101 00:02:27.325540  1023 sample_rtsp.c:490]              <configMainStream> main vipp0 ve_online_en:1, dma_buf_num:2, venc ch0 OnlineEnable:1, OnlineShareBufNum:2
I0101 00:02:27.325662  1023 sample_rtsp.c:517]              <configMainStream> main EncppSharpAttenCoefPer: 100%
I0101 00:02:27.325760  1023 sample_rtsp.c:527]              <configMainStream> main vbvThreshSize: 147450, vbvBufSize: 933882
[ISP]video device name is vin_video0
[ISP]open video device[0], detect isp0 success!
I0101 00:02:27.326131  1023 media_debug.c:45]               <getDictByConfPath> MPP_DEDIA_DEBUG_FILE_PATH=(null)
I0101 00:02:27.326705  1023 videoInputHw.c:942]             <videoInputHw_SetChnAttr> ViCh[0] update width:1920(1920), height:1080(1088)
[ISP]video0 fd[10] ve_online_en=[  143.257477] [VIN]ve_online open, buffer_num is 2
1, dma_buf_num=2
open /dev/sunxi_soc_info failed![ISP]open isp device[0] success!
[ISP_WARN]open /mnt/extsd/isp0_1920_1088_20_ctx_saved.bin failed, err:No such file or directory.
[ISP]prefer isp config: [gc2053_mipi], 1920x1088, 20, 0, 0
[ISP_WARN]cannot find gc2053_mipi_1920_1088_20_0_0 isp config, use default config []
[  143.323081] [DISP] disp_mgr_set_layer_config,line:1504:
[  143.328923] NULL hdl!
[  144.357027] [DISP] de_fcm_set_para,line:491:
[  144.361629] fcm lut 0 not find, auto retry after init
[  144.367736] [DISP] de_fcm_set_para,line:491:
[  144.372331] fcm lut 0 not find, auto retry after init
Segmentation fault (core dumped)
我也是下载了docker镜像,和 Ted5038问题相同,我也修改了nano /root/tina-v853-docker/out/v851s/lizard/openwrt/build_dir/target/eyesee-mpp-middleware/eyesee-mpp-middleware/sample/rtsp_server.cpp。出现的问题是,这个如何解决?
root@a9e8f64cb3a7:~/tina-v853-docker# make with -j1 V=s
===There is tina environment.===
 Note: make is the shell functon in envsetup.sh.
== action: openwrt_build, action_args: with -j1 V=s ==
========ACTION List: build_linuxdev with -j1 V=s;========
options :
INFO: build linuxdev ...
INFO: chip: sun8iw21p1
INFO: platform: linux
INFO: kernel: linux-4.9
INFO: board: lizard
INFO: output: /root/tina-v853-docker/out/v851s/lizard/openwrt
INFO: don't build dtbo ...
INFO: build arisc
INFO: build_bootloader: brandy_path= /root/tina-v853-docker/brandy/brandy-2.0
INFO: skip build brandy.
INFO: build kernel ...
INFO: Prepare toolchain ...
Building kernel
/root/tina-v853-docker/kernel/linux-4.9/output/lib/modules/4.9.191
  CHK     include/config/kernel.release
  CHK     include/generated/uapi/linux/version.h
  CHK     include/generated/utsrelease.h
  CHK     scripts/mod/devicetable-offsets.h
  CHK     include/generated/timeconst.h
  CHK     include/generated/bounds.h
  CHK     include/generated/asm-offsets.h
  CALL    scripts/checksyscalls.sh
  CHK     include/generated/compile.h
  DTC     arch/arm/boot/dts/board.dtb
  Kernel: arch/arm/boot/Image is ready
  Building modules, stage 2.
  MODPOST 16 modules
  Kernel: arch/arm/boot/zImage is ready
  Kernel: arch/arm/boot/uImage is ready
'arch/arm/boot/Image' -> 'output/bImage'
'arch/arm/boot/uImage' -> 'output/uImage'
'arch/arm/boot/zImage' -> 'output/zImage'
Copy rootfs.cpio.gz for arm
Building modules
[GPU]: No GPU type is configured in /root/tina-v853-docker/kernel/linux-4.9/.config.
INFO: build dts ...
removed '/root/tina-v853-docker/out/v851s/lizard/openwrt/.board.dtb.d.dtc.tmp'
removed '/root/tina-v853-docker/out/v851s/lizard/openwrt/.board.dtb.dts.tmp'
'/root/tina-v853-docker/kernel/linux-4.9/arch/arm/boot/dts/.board.dtb.d.dtc.tmp' -> '/root/tina-v853-docker/out/v851s/lizard/openwrt/.board.dtb.d.dtc.tmp'
'/root/tina-v853-docker/kernel/linux-4.9/arch/arm/boot/dts/.board.dtb.dts.tmp' -> '/root/tina-v853-docker/out/v851s/lizard/openwrt/.board.dtb.dts.tmp'
INFO: build rootfs ...
==mkcmd.sh: build_openwrt_rootfs with -j1 V=s==
make: Entering directory '/root/tina-v853-docker/openwrt/openwrt'
make[1]: Entering directory '/root/tina-v853-docker/openwrt/openwrt'
CreateSoftLink  /root/tina-v853-docker/openwrt/openwrt/tmp link to  /root/tina-v853-docker/out/v851s/lizard/openwrt/tmp
CreateSoftLink  /root/tina-v853-docker/openwrt/openwrt/staging_dir link to  /root/tina-v853-docker/out/v851s/lizard/openwrt/staging_dir
make[2]: Entering directory '/root/tina-v853-docker/openwrt/openwrt'
make[2]: Leaving directory '/root/tina-v853-docker/openwrt/openwrt'
Check Vendor Package...
CreateSoftLink  /root/tina-v853-docker/openwrt/openwrt/package/subpackage link to  /root/tina-v853-docker/openwrt/package
end
WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-libav/Makefile' has a build dependency on 'libgstreamer1', which does not exist
WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-libav/Makefile' has a build dependency on 'gstreamer1-plugins-base', which does not exist
WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-omx/Makefile' has a dependency on 'libgst1gl', which does not exist
WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-aw/Makefile' has a build dependency on 'libgstreamer1', which does not exist
WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-aw/Makefile' has a build dependency on 'gstreamer1-plugins-base', which does not exist
WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-aw/Makefile' has a build dependency on 'gstreamer1-plugins-good', which does not exist
WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile' has a dependency on 'wayland', which does not exist
WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile' has a dependency on 'wayland-protocols', which does not exist
WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile' has a dependency on 'libgst1badvideo', which does not exist
WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile' has a dependency on 'libgst1gl', which does not exist
WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile' has a build dependency on 'libgstreamer1', which does not exist
WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile' has a build dependency on 'gstreamer1-plugins-base', which does not exist
WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-base/Makefile' has a build dependency on 'libgstreamer1', which does not exist
WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-good/Makefile' has a build dependency on 'libgstreamer1', which does not exist
WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-good/Makefile' has a build dependency on 'gstreamer1-plugins-base', which does not exist
WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-ugly/Makefile' has a build dependency on 'libgstreamer1', which does not exist
WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-ugly/Makefile' has a build dependency on 'gstreamer1-plugins-base', which does not exist
WARNING: Makefile 'package/kernel/linux/Makefile' has a dependency on 'kmod-sunxi-rf-wlan', which does not exist
WARNING: Makefile 'package/subpackage/allwinner/eyesee-mpp/middleware/Makefile' has a dependency on 'awsystrace', which does not exist
WARNING: Makefile 'package/subpackage/thirdparty/gui/qt/qt5/Makefile' has a dependency on 'weston', which does not exist
WARNING: Makefile 'package/subpackage/thirdparty/gui/qt/qt5/Makefile' has a dependency on 'wayland', which does not exist
WARNING: Makefile 'package/subpackage/thirdparty/gui/qt/qt5/Makefile' has a dependency on 'qt5-multimediawidgets', which does not exist
WARNING: Makefile 'package/subpackage/thirdparty/gui/qt/qt5/Makefile' has a build dependency on 'libstdcpp', which does not exist
make[2]: Entering directory '/root/tina-v853-docker/openwrt/openwrt/scripts/config'
make[2]: 'conf' is up to date.
make[2]: Leaving directory '/root/tina-v853-docker/openwrt/openwrt/scripts/config'
copy from /root/tina-v853-docker/openwrt/target/v851s/v851s-lizard/defconfig
target/linux/generic/image/Config.in:12:warning: choice default symbol 'uImage' is not contained in the choice
target/linux/generic/image/Config.in:47:warning: choice default symbol 'uImage' is not contained in the choice
target/linux/generic/image/Config.in:72:warning: choice default symbol 'CONFIG_BOOT_IMAGE_NAME_SUFFIX_NONE' is not contained in the choice
target/linux/generic/image/Config.in:89:warning: choice default symbol 'CONFIG_ROOTFS_IMAGE_NAME_SUFFIX_NONE' is not contained in the choice
# No change to .config
copy to /root/tina-v853-docker/openwrt/target/v851s/v851s-lizard/defconfig
Makefile:29: "NOTE: Will skip kernel build."
The command image-prereq(include/kernel-build.mk) execute.
time: target/linux/prereq#0.26#0.14#0.38
make[1]: Leaving directory '/root/tina-v853-docker/openwrt/openwrt'
make[1]: *** No rule to make target 'with'.  Stop.
/root/tina-v853-docker/openwrt/openwrt/include/toplevel.mk:236: recipe for target 'with' failed
make: *** [with] Error 2
make: Leaving directory '/root/tina-v853-docker/openwrt/openwrt'
INFO: build_openwrt_rootfs failed
menuconfig,搜索不到相关的配置呢
我用的是下载的SDK,也是找不到eyesee相关的文件
我也是找不到eyesee的配置 请问有用新版本的朋友知道怎么拉流吗
用docker镜像里面有,ubuntu里面eyesee在github的开源软件资料里面有,把文件夹复制进去就行,但是我使用ubuntu编译出来不支持摄像头,干脆换docker了
