T-HeadDebugServer启动后,错误
ERROR: Fail to check had module of CPU 0, please check:
1. the physical connection;
2. the power of the target;
3. the link clock (link clock <= (CPU clock/2));
4. the reference voltage of link, default 3.3v;
2个USB线都已连接,开关也已拨至CKLink模式
按图示连线之后,还是不行
CONNECT: ±-Try to access CPU.–+
CONNECT: Init hacr width for CPU 0.
CONNECT: Set cpus[i].hacr_width with had_info->hacr_width 0CONNECT: Check HAD connection for CPU 0.
CONNECT: Read HID get 0xffffffff, HAD version is HAD_V5.
CONNECT: Write DDCADDR with 0x00000000000abcd0.
CONNECT: Read DDCADDR get 0xffffffffffffffff.
CONNECT: Can not access to HAD module as DDCADDR can not be written.
Extra Info: hacr width is 8.
For more information, please run Debugserver with connect log:
Console: run Debugserver with arguments “–debug connect”.
UI : select “Connect” from menu “Setting->Verbose Setting”.
