通过STM32 Cube刷写根文件系统以及镜像时均无问题,可以正常登录板子,
但是设置成nfs启动时,失败,无法登录进入系统,失败日志如下,
有大佬可以帮忙看下是因为啥导致的吗
NOTICE: CPU: STM32MP157DAC Rev.Z
NOTICE: Model: 100ASK ASK-STM32MP157-512D PRO V1 Board
INFO: Reset reason (0x14):
INFO: Pad Reset from NRST
INFO: Using EMMC
INFO: Instance 2
INFO: Boot used partition fsbl1
NOTICE: BL2: v2.2-r1.0(debug):7b94c85
NOTICE: BL2: Built : 05:01:41, May 14 2023
INFO: Using crypto library ‘stm32_crypto_lib’
INFO: BL2: Doing platform setup
INFO: RAM: DDR3-1066/888 bin G 2x2Gb 533MHz v1.44
INFO: Memory size = 0x20000000 (512 MB)
INFO: BL2 runs SP_MIN setup
INFO: BL2: Loading image id 4
INFO: Loading image id=4 at address 0x2ffed000
INFO: Image id=4 loaded: 0x2ffed000 - 0x2ffff000
INFO: BL2: Loading image id 5
INFO: Loading image id=5 at address 0xc0100000
INFO: STM32 Image size : 872633
INFO: Image id=5 loaded: 0xc0100000 - 0xc01d50b9
WARNING: Skip signature check (header option)
NOTICE: ROTPK is not deployed on platform. Skipping ROTPK verification.
NOTICE: BL2: Booting BL32
INFO: Entry point address = 0x2ffed000
INFO: SPSR = 0x1d3
NOTICE: SP_MIN: v2.2-r1.0(debug):7b94c85
NOTICE: SP_MIN: Built : 05:01:41, May 14 2023
INFO: ARM GICv2 driver initialized
INFO: stm32mp IWDG1 (12): Secure
INFO: ETZPC: CRYP1 (9) could be non secure
INFO: SP_MIN: Initializing runtime services
INFO: SP_MIN: Preparing exit to normal world
U-Boot 2020.01-stm32mp-r1 (May 14 2023 - 05:01:49 -0400)
Board: stm32mp1 in trusted mode (st,stm32mp157c-100ask-512d-v1)
DRAM: 512 MiB
Clocks:
- MPU : 650 MHz
- MCU : 208.878 MHz
- AXI : 266.500 MHz
- PER : 24 MHz
- DDR : 533 MHz
WDT: Started with servicing (32s timeout)
NAND: 0 MiB
MMC: STM32 SD/MMC: 0, STM32 SD/MMC: 1
Loading Environment from MMC… OK
In: serial
Out: serial
Err: serial
Net: eth0: ethernet@5800a000
Press SPACE to abort autoboot in 1 seconds
STM32MP>
STM32MP> setenv serverip 192.168.5.11
STM32MP> setenv ipaddr 192.168.5.9
STM32MP> saveenv
Saving Environment to MMC… Writing to redundant MMC(1)… OK
STM32MP> tftpboot 0xc4000000 stm32mp157c-100ask-512d-v1.dtb; tftpboot c4100000 uImage;
test ar8035 !!!ethernet@5800a000 Waiting for PHY auto negotiation to complete… done
Using ethernet@5800a000 device
TFTP from server 192.168.5.11; our IP address is 192.168.5.9
Filename ‘stm32mp157c-100ask-512d-v1.dtb’.
Load address: 0xc4000000
Loading: ########
20.5 KiB/s
done
Bytes transferred = 107530 (1a40a hex)
Filename ‘uImage’.
Load address: 0xc4100000
Loading: #################################################################
1.6 MiB/s
done
Bytes transferred = 8189120 (7cf4c0 hex)
STM32MP> setenv bootargs root=/dev/nfs nfsroot=192.168.5.11:/home/book/nfs_rootfs/rootfs,vers=3 rw ip=dhcp;
STM32MP> bootm c4100000 - 0xc4000000
Booting kernel from Legacy Image at c4100000 …
Image Name: Linux-5.4.31
Created: 2023-05-14 9:15:08 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 8189056 Bytes = 7.8 MiB
Load Address: c2000040
Entry Point: c2000040
Verifying Checksum … OK
Flattened Device Tree blob at c4000000
Booting using the fdt blob at 0xc4000000
Loading Kernel Image
Loading Device Tree to cffe2000, end cffff409 … OK
Starting kernel …
[ 0.000000] Linux version 5.4.31 (chuang@chuang-virtual-machine) (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 SMP PREEMPT Sun May 14 05:04:15 EDT 2023
[ 0.000000] OF: fdt: Machine model: 100ASK YA157C v2 www.100ask.com
[ 0.000000] Reserved memory: created DMA memory pool at 0x10000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node mcuram2@10000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x10040000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vdev0vring0@10040000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x10041000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vdev0vring1@10041000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x10042000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vdev0buffer@10042000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x30000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node mcuram@30000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x38000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node retram@38000000, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 128 MiB at 0xd2000000
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] percpu: Embedded 20 pages/cpu s50124 r8192 d23604 u81920
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 113536
[ 0.000000] Kernel command line: root=/dev/nfs nfsroot=192.168.5.11:/home/book/nfs_rootfs/rootfs,vers=3 rw ip=dhcp
[ 0.000000] Memory: 303816K/458752K available (12288K kernel code, 962K rwdata, 3560K rodata, 1024K init, 226K bss, 23864K reserved, 131072K cma-reserved, 0K highmem)
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] random: get_random_bytes called from start_kernel+0x31c/0x4f4 with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (virt).
[ 0.000010] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000030] Switching to timer-based delay loop, resolution 41ns
[ 0.002120] Console: colour dummy device 80x30
[ 0.003255] printk: console [tty0] enabled
[ 0.003317] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.003369] pid_max: default: 32768 minimum: 301
[ 0.003667] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.003722] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.005138] CPU: Testing write buffer coherency: ok
[ 0.005714] /cpus/cpu@0 missing clock-frequency property
[ 0.005780] /cpus/cpu@1 missing clock-frequency property
[ 0.005820] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.059753] Setting up static identity map for 0xc0100000 - 0xc0100060
[ 0.079736] rcu: Hierarchical SRCU implementation.
[ 0.105427] smp: Bringing up secondary CPUs …
[ 0.180418] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.180652] smp: Brought up 1 node, 2 CPUs
[ 0.180715] SMP: Total of 2 processors activated (96.00 BogoMIPS).
[ 0.180744] CPU: All CPU(s) started in SVC mode.
[ 0.181641] devtmpfs: initialized
[ 0.216772] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.217478] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.217557] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.224838] pinctrl core: initialized pinctrl subsystem
[ 0.227398] NET: Registered protocol family 16
[ 0.233305] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.236038] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.236102] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.236574] Serial: AMBA PL011 UART driver
[ 0.240033] stm32-pm-domain pm_domain: domain core-ret-power-domain registered
[ 0.240109] stm32-pm-domain pm_domain: subdomain core-power-domain registered
[ 0.240147] stm32-pm-domain pm_domain: domains probed
[ 0.295005] gpio-regulator regulators: No ‘states’ property found
[ 0.295077] gpio-regulator: probe of regulators failed with error -22
[ 0.296606] SCSI subsystem initialized
[ 0.297539] usbcore: registered new interface driver usbfs
[ 0.297651] usbcore: registered new interface driver hub
[ 0.297839] usbcore: registered new device driver usb
[ 0.298264] pps_core: LinuxPPS API ver. 1 registered
[ 0.298298] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.298369] PTP clock support registered
[ 0.298763] EDAC MC: Ver: 3.0.0
[ 0.300167] Advanced Linux Sound Architecture Driver Initialized.
[ 0.301229] Bluetooth: Core ver 2.22
[ 0.301370] NET: Registered protocol family 31
[ 0.301402] Bluetooth: HCI device and connection manager initialized
[ 0.301443] Bluetooth: HCI socket layer initialized
[ 0.301479] Bluetooth: L2CAP socket layer initialized
[ 0.301540] Bluetooth: SCO socket layer initialized
[ 0.302569] clocksource: Switched to clocksource arch_sys_counter
[ 1.100060] thermal_sys: Registered thermal governor ‘step_wise’
[ 1.100696] NET: Registered protocol family 2
[ 1.101922] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 1.102021] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 1.102120] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 1.102240] TCP: Hash tables configured (established 4096 bind 4096)
[ 1.102421] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 1.102491] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 1.103018] NET: Registered protocol family 1
[ 1.104029] RPC: Registered named UNIX socket transport module.
[ 1.104075] RPC: Registered udp transport module.
[ 1.104102] RPC: Registered tcp transport module.
[ 1.104130] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.106060] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 1.108341] Initialise system trusted keyrings
[ 1.108733] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 1.122338] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.133936] NFS: Registering the id_resolver key type
[ 1.134016] Key type id_resolver registered
[ 1.134044] Key type id_legacy registered
[ 1.134338] ntfs: driver 2.1.32 [Flags: R/O].
[ 1.134903] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 1.135771] fuse: init (API version 7.31)
[ 1.196405] NET: Registered protocol family 38
[ 1.196461] Key type asymmetric registered
[ 1.196491] Asymmetric key parser ‘x509’ registered
[ 1.196602] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.196644] io scheduler mq-deadline registered
[ 1.196671] io scheduler kyber registered
[ 1.207559] STM32 USART driver initialized
[ 1.209206] ar8035 phy init
[ 1.209719] the phy gpio failed
[ 1.231735] brd: module loaded
[ 1.247208] loop: module loaded
[ 1.253933] libphy: Fixed MDIO Bus: probed
[ 1.256001] CAN device driver interface
[ 1.258676] PPP generic driver version 2.4.2
[ 1.259065] PPP BSD Compression module registered
[ 1.259106] PPP Deflate Compression module registered
[ 1.259147] PPP MPPE Compression module registered
[ 1.259176] NET: Registered protocol family 24
[ 1.259237] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 1.259281] CSLIP: code copyright 1989 Regents of the University of California.
[ 1.259319] SLIP linefill/keepalive option.
[ 1.259351] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.259486] usbcore: registered new interface driver pegasus
[ 1.259589] usbcore: registered new interface driver r8152
[ 1.259712] usbcore: registered new interface driver asix
[ 1.259808] usbcore: registered new interface driver ax88179_178a
[ 1.259891] usbcore: registered new interface driver cdc_ether
[ 1.260006] usbcore: registered new interface driver smsc75xx
[ 1.260111] usbcore: registered new interface driver smsc95xx
[ 1.260190] usbcore: registered new interface driver net1080
[ 1.260277] usbcore: registered new interface driver cdc_subset
[ 1.260375] usbcore: registered new interface driver zaurus
[ 1.260487] usbcore: registered new interface driver cdc_ncm
[ 1.262243] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.262327] ehci-platform: EHCI generic platform driver
[ 1.262981] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.263053] ohci-platform: OHCI generic platform driver
[ 1.264174] usbcore: registered new interface driver cdc_acm
[ 1.264215] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.264330] usbcore: registered new interface driver usblp
[ 1.264425] usbcore: registered new interface driver cdc_wdm
[ 1.264510] usbcore: registered new interface driver uas
[ 1.264611] usbcore: registered new interface driver usb-storage
[ 1.264799] usbcore: registered new interface driver usbserial_generic
[ 1.264874] usbserial: USB Serial support registered for generic
[ 1.264962] usbcore: registered new interface driver option
[ 1.265043] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.270370] i2c /dev entries driver
[ 1.275753] stm32-cpufreq stm32-cpufreq: Failed to get chip info: -517
[ 1.280604] sdhci: Secure Digital Host Controller Interface driver
[ 1.280650] sdhci: Copyright(c) Pierre Ossman
[ 1.280675] Synopsys Designware Multimedia Card Interface Driver
[ 1.281316] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.282791] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.285279] usbcore: registered new interface driver usbhid
[ 1.285330] usbhid: USB HID core driver
[ 1.285355] dtbocfg_module_init
[ 1.285432] dtbocfg_module_init: OK
[ 1.285834] arm-smc-mbox mailbox-0: ARM SMC mailbox enabled.
[ 1.286004] arm-smc-mbox mailbox-1: ARM SMC mailbox enabled.
[ 1.287906] remoteproc remoteproc0: releasing m4
[ 1.291242] Unable to get STM32 DDR PMU clock
[ 1.297021] drop_monitor: Initializing network drop monitor service
[ 1.297406] NET: Registered protocol family 17
[ 1.297458] can: controller area network core (rev 20170425 abi 9)
[ 1.297632] NET: Registered protocol family 29
[ 1.297671] can: raw protocol (rev 20170425)
[ 1.297698] can: broadcast manager protocol (rev 20170425 t)
[ 1.297736] can: netlink gateway (rev 20190810) max_hops=1
[ 1.298266] Bluetooth: RFCOMM TTY layer initialized
[ 1.298328] Bluetooth: RFCOMM socket layer initialized
[ 1.298397] Bluetooth: RFCOMM ver 1.11
[ 1.298440] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.298473] Bluetooth: BNEP filters: protocol multicast
[ 1.298514] Bluetooth: BNEP socket layer initialized
[ 1.298547] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.298588] Bluetooth: HIDP socket layer initialized
[ 1.299233] Key type dns_resolver registered
[ 1.299433] ThumbEE CPU extension supported.
[ 1.299483] Registering SWP/SWPB emulation handler
[ 1.299982] registered taskstats version 1
[ 1.300018] Loading compiled-in X.509 certificates
[ 1.312052] Loaded X.509 cert ‘Build time autogenerated kernel key: a551a3bcaf9a62271059adf2e1003b2f3df06de0’
[ 1.338311] arm-scmi firmware:scmi-0: SCMI Protocol v2.0 ‘ST:’ Firmware version 0x0
[ 1.343035] remoteproc remoteproc0: releasing m4
[ 1.344636] Unable to get STM32 DDR PMU clock
[ 1.367271] debugfs: Directory ‘cpu0’ with parent ‘opp’ already present!
[ 1.377614] remoteproc remoteproc0: releasing m4
[ 1.379190] Unable to get STM32 DDR PMU clock
[ 1.421084] stm32-mdma 58000000.dma: STM32 MDMA driver registered
[ 1.426246] stm32-dma 48000000.dma: STM32 DMA driver registered
[ 1.428571] stm32-dma 48001000.dma: STM32 DMA driver registered
[ 1.429262] reg11: supplied by regulator-dummy
[ 1.429785] reg18: supplied by regulator-dummy
[ 1.430295] usb33: supplied by regulator-dummy
[ 1.452946] stm_thermal 50028000.thermal: stm_thermal_probe: Driver initialized successfully
[ 1.455740] random: fast init done
[ 1.455913] debugfs: Directory ‘cpu0’ with parent ‘opp’ already present!
[ 1.460217] random: crng init done
[ 1.460259] stm32-crc32 58009000.crc: Initialized
[ 1.461988] stm32-hash 54002000.hash: will run requests pump with realtime priority
[ 1.467156] stm32-hash 54002000.hash: Init HASH done HW ver 23 DMA mode 1
[ 1.479698] remoteproc remoteproc0: releasing m4
[ 1.481615] stm32-ddr-pmu: probed (ID=0x00140061 VER=0x00000010), DDR@533MHz
[ 1.484274] /soc/interrupt-controller@5000d000: bank0
[ 1.484324] /soc/interrupt-controller@5000d000: bank1
[ 1.484358] /soc/interrupt-controller@5000d000: bank2
[ 1.486856] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOA bank added
[ 1.487501] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOB bank added
[ 1.488094] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOC bank added
[ 1.488676] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOD bank added
[ 1.489244] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOE bank added
[ 1.489835] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOF bank added
[ 1.490412] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOG bank added
[ 1.490986] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOH bank added
[ 1.491557] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOI bank added
[ 1.491929] stm32mp157-pinctrl soc:pin-controller@50002000: Pinctrl STM32 initialized
[ 1.493319] stm32mp157-pinctrl soc:pin-controller-z@54004000: GPIOZ bank added
[ 1.493383] stm32mp157-pinctrl soc:pin-controller-z@54004000: Pinctrl STM32 initialized
[ 1.495922] stm32-usbphyc 5a006000.usbphyc: registered rev:1.0
[ 1.497540] stm32-usart 40010000.serial: interrupt mode for rx (no dma)
[ 1.497597] stm32-usart 40010000.serial: interrupt mode for tx (no dma)
[ 1.497665] 40010000.serial: ttySTM0 at MMIO 0x40010000 (irq = 55, base_baud = 4000000) is a stm32-usart
[ 2.894152] printk: console [ttySTM0] enabled
[ 2.900532] 44003000.serial: ttySTM1 at MMIO 0x44003000 (irq = 56, base_baud = 4000000) is a stm32-usart
[ 2.910372] stm32-usart 5c000000.serial: interrupt mode for rx (no dma)
[ 2.915649] stm32-usart 5c000000.serial: interrupt mode for tx (no dma)
[ 2.922199] 5c000000.serial: ttySTM2 at MMIO 0x5c000000 (irq = 57, base_baud = 4000000) is a stm32-usart
[ 2.931998] serial serial0: tty port ttySTM2 registered
[ 2.938771] m_can_platform 4400f000.can: m_can device registered (irq=52, version=32)
[ 2.947249] stm32-dwmac 5800a000.ethernet: PTP uses main clock
[ 2.951663] stm32-dwmac 5800a000.ethernet: no reset control found
[ 2.957882] stm32-dwmac 5800a000.ethernet: No phy clock provided…
[ 2.964729] stm32-dwmac 5800a000.ethernet: User ID: 0x40, Synopsys ID: 0x42
[ 2.970986] stm32-dwmac 5800a000.ethernet: DWMAC4/5
[ 2.975988] stm32-dwmac 5800a000.ethernet: DMA HW capability register supported
[ 2.983276] stm32-dwmac 5800a000.ethernet: RX Checksum Offload Engine supported
[ 2.990561] stm32-dwmac 5800a000.ethernet: TX Checksum insertion supported
[ 2.997455] stm32-dwmac 5800a000.ethernet: Wake-Up On Lan supported
[ 3.003728] stm32-dwmac 5800a000.ethernet: TSO supported
[ 3.009010] stm32-dwmac 5800a000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 3.016880] stm32-dwmac 5800a000.ethernet: TSO feature enabled
[ 3.023164] libphy: stmmac: probed
[ 3.028931] Atheros 8035 ethernet: probe of stmmac-0:06 failed with error -12
[ 3.036590] dwc2 49000000.usb-otg: 49000000.usb-otg supply vusb_d not found, using dummy regulator
[ 3.044392] dwc2 49000000.usb-otg: 49000000.usb-otg supply vusb_a not found, using dummy regulator
[ 3.182876] dwc2 49000000.usb-otg: EPs: 9, dedicated fifos, 952 entries in SPRAM
[ 3.189909] dwc2 49000000.usb-otg: DWC OTG Controller
[ 3.194039] dwc2 49000000.usb-otg: new USB bus registered, assigned bus number 1
[ 3.201348] dwc2 49000000.usb-otg: irq 59, io mem 0x49000000
[ 3.207312] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[ 3.215260] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.222440] usb usb1: Product: DWC OTG Controller
[ 3.227157] usb usb1: Manufacturer: Linux 5.4.31 dwc2_hsotg
[ 3.232732] usb usb1: SerialNumber: 49000000.usb-otg
[ 3.238651] hub 1-0:1.0: USB hub found
[ 3.241467] hub 1-0:1.0: 1 port detected
[ 3.247211] ehci-platform 5800d000.usbh-ehci: EHCI Host Controller
[ 3.252006] ehci-platform 5800d000.usbh-ehci: new USB bus registered, assigned bus number 2
[ 3.260870] ehci-platform 5800d000.usbh-ehci: irq 60, io mem 0x5800d000
[ 3.292620] ehci-platform 5800d000.usbh-ehci: USB 2.0 started, EHCI 1.00
[ 3.298314] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[ 3.306213] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.313414] usb usb2: Product: EHCI Host Controller
[ 3.318244] usb usb2: Manufacturer: Linux 5.4.31 ehci_hcd
[ 3.323666] usb usb2: SerialNumber: 5800d000.usbh-ehci
[ 3.329755] hub 2-0:1.0: USB hub found
[ 3.332641] hub 2-0:1.0: 2 ports detected
[ 3.338027] ohci-platform 5800c000.usbh-ohci: Generic Platform OHCI controller
[ 3.343952] ohci-platform 5800c000.usbh-ohci: new USB bus registered, assigned bus number 3
[ 3.352674] ohci-platform 5800c000.usbh-ohci: irq 51, io mem 0x5800c000
[ 3.426955] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
[ 3.433856] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.441021] usb usb3: Product: Generic Platform OHCI controller
[ 3.446959] usb usb3: Manufacturer: Linux 5.4.31 ohci_hcd
[ 3.452326] usb usb3: SerialNumber: 5800c000.usbh-ohci
[ 3.459463] hub 3-0:1.0: USB hub found
[ 3.461841] hub 3-0:1.0: 2 ports detected
[ 3.468672] stm32_rtc 5c004000.rtc: registered as rtc0
[ 3.473320] stm32_rtc 5c004000.rtc: Date/Time must be initialized
[ 3.478475] stm32_rtc 5c004000.rtc: registered rev:1.2
[ 3.504609] stm32f7-i2c 40012000.i2c: doesn’t use DMA
[ 3.510493] fusb302 0-0022: Can’t get property of role, set role to default DRP
[ 3.524833] fusb302 0-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[ 3.533150] stm32f7-i2c 40012000.i2c: STM32F7 I2C-0 bus adapter
[ 3.559627] stm32f7-i2c 40013000.i2c: doesn’t use DMA
[ 3.563999] stm32f7-i2c 40013000.i2c: STM32F7 I2C-1 bus adapter
[ 3.592968] stm32f7-i2c 5c002000.i2c: doesn’t use DMA
[ 3.598052] Goodix-TS 2-005d: 2-005d supply AVDD28 not found, using dummy regulator
[ 3.604539] Goodix-TS 2-005d: 2-005d supply VDDIO not found, using dummy regulator
[ 3.722703] Goodix-TS 2-005d: i2c test failed attempt 1: -6
[ 3.762673] Goodix-TS 2-005d: i2c test failed attempt 2: -6
[ 3.802600] Goodix-TS 2-005d: I2C communication failure: -6
[ 3.807158] stm32f7-i2c 5c002000.i2c: STM32F7 I2C-2 bus adapter
[ 3.815381] mmci-pl18x 48004000.sdmmc: allocated mmc-pwrseq
[ 3.819995] mmci-pl18x 48004000.sdmmc: mmc0: PL180 manf 53 rev1 at 0x48004000 irq 42,0 (pio)
[ 3.856198] mmci-pl18x 58005000.sdmmc: mmc1: PL180 manf 53 rev2 at 0x58005000 irq 48,0 (pio)
[ 3.891931] mmci-pl18x 58007000.sdmmc: mmc2: PL180 manf 53 rev2 at 0x58007000 irq 49,0 (pio)
[ 3.932688] stm32-ipcc 4c001000.mailbox: ipcc rev:1.0 enabled, 6 chans, proc 0
[ 3.944148] stm32-rproc mlahb:m4@10000000: wdg irq registered
[ 3.951397] remoteproc remoteproc0: m4 is available
[ 3.956139] stm32mp157-pinctrl soc:pin-controller@50002000: missing pins property in node pins .
[ 3.964878] stm32-adc-core: probe of 48003000.adc failed with error -22
[ 3.981736] wm8960 0-001a: Failed to issue reset
[ 3.999234] input: joystick as /devices/platform/joystick/input/input0
[ 4.009548] stm32_rtc 5c004000.rtc: setting system clock to 2000-01-01T00:03:12 UTC (946684992)
[ 4.026419] stm32-dwmac 5800a000.ethernet eth0: PHY [stmmac-0:06] driver [Generic PHY]
[ 4.040014] mmc2: new high speed MMC card at address 0001
[ 4.044043] dwmac4: Master AXI performs any burst length
[ 4.044068] stm32-dwmac 5800a000.ethernet eth0: No Safety Features support found
[ 4.044090] stm32-dwmac 5800a000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
[ 4.061931] mmcblk2: mmc2:0001 004G60 3.69 GiB
[ 4.065553] stm32-dwmac 5800a000.ethernet eth0: registered PTP clock
[ 4.070417] mmcblk2boot0: mmc2:0001 004G60 partition 1 2.00 MiB
[ 4.076318] stm32-dwmac 5800a000.ethernet eth0: configuring for phy/rgmii link mode
[ 4.082817] mmcblk2boot1: mmc2:0001 004G60 partition 2 2.00 MiB
[ 4.097256] mmcblk2rpmb: mmc2:0001 004G60 partition 3 512 KiB, chardev (242:0)
[ 4.112277] mmcblk2: p1 p2 p3
[ 8.234296] stm32-dwmac 5800a000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
