本人刚开始玩这个开发板,自己编译下载后启动,打印很多错误,向各位大神请教一下。
mount: mounting none on /dev failed: Resource busy
[ 5.167807] UBIFS (ubi0:6): background thread “ubifs_bgt0_6” started, PID 741
[ 5.234891] UBIFS (ubi0:6): recovery needed
[ 5.318823] UBIFS (ubi0:6): recovery completed
[ 5.324535] UBIFS (ubi0:6): UBIFS: mounted UBI device 0, volume 6, name “UDISK”
[ 5.332779] UBIFS (ubi0:6): LEB size: 258048 bytes (252 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
[ 5.344011] UBIFS (ubi0:6): FS size: 13418496 bytes (12 MiB, 52 LEBs), journal size 2064385 bytes (1 MiB, 6 LEBs)
[ 5.355541] UBIFS (ubi0:6): reserved for root: 633787 bytes (618 KiB)
[ 5.362761] UBIFS (ubi0:6): media format: w4/r0 (latest is w4/r0), UUID 80E0845B-2F72-4727-AA45-BAE0AE3249CA, small LPT model
Error locking file /var/lock/fw_printenv.lock
starting pid 757, tty ‘’: ‘/etc/preinit’
can’t run ‘/etc/preinit’: No such file or directory
starting pid 758, tty ‘’: ‘/bin/mount -t proc proc /proc’
mount: mounting proc on /proc failed: Resource busy
starting pid 759, tty ‘’: ‘/bin/mount -t tmpfs tmpfs /run’
starting pid 760, tty ‘’: ‘/bin/mount -o remount,rw /’
starting pid 761, tty ‘’: ‘/bin/mkdir -p /dev/pts’
starting pid 762, tty ‘’: ‘/bin/mkdir -p /dev/shm’
starting pid 763, tty ‘’: ‘/bin/mount -a’
starting pid 764, tty ‘’: ‘/bin/hostname -F /etc/hostname’
hostname: can’t open ‘/etc/hostname’: No such file or directory
starting pid 765, tty ‘’: ‘/etc/init.d/rcS boot’
/etc/init.d/rcS: line 23: mkfs.ubifs: not found
[ 5.748175] ======== XRADIO WIFI OPEN ========
[ 5.753232] [XRADIO] Driver Label:XR_V02.16.91 _HT40_01.33 Jul 4 2023 22:30:37
[ 5.761753] [XRADIO] Allocated hw_priv @ c3bc6c80
[ 5.767090]
[ 5.767090] insmod_device_driver
[ 5.767090]
[ 5.767702] device_chose finished 122!
[ 5.779253] [XRADIO_ERR] Access_file failed, path:/data/misc/wifi/xr_wifi.conf!
[ 5.788601] sunxi-wlan soc@03000000:wlan@0: bus_index: 1
[ 5.904652] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 5.914909] [XRADIO] Detect SDIO card 1
[ 5.929783] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
[ 5.965217] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 6.005862] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 6.019092] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 6.040220] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 6.050966] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 6.062013] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[ 6.073800] mmc1: new high speed SDIO card at address 0001
[ 6.080812] [SBUS] XRadio Device:sdio clk=50000000
[ 6.087823] [XRADIO] XRADIO_HW_REV 1.0 detected.
[ 6.225653] [XRADIO] xradio_update_dpllctrl: DPLL_CTRL Sync=0x00c00000.
[ 6.326682] [XRADIO] Bootloader complete
[ 6.415425] [XRADIO] Firmware completed.
[ 6.421313] [WSM] Firmware Label:XR_C09.08.52.73_DBG_02.122 2GHZ HT40 May 18 2021 13:36:09
[ 6.438758] [XRADIO] Firmware Startup Done.
[ 6.443786] [XRADIO_WRN] enable Multi-Rx!
[ 6.460594] ieee80211 phy0: Failed to initialize wep: -2
[ 6.466779] ieee80211 phy0: Selected rate control algorithm ‘minstrel_ht’
------run rc.final file-----
/etc/init.d/rcS: /etc/init.d/rc.final: line 24: /etc/init.d/S00mpp: Permission denied
/etc/init.d/rcS: /etc/init.d/rc.final: line 24: /etc/init.d/S01logging: Permission denied
/etc/init.d/rcS: /etc/init.d/rc.final: line 24: /etc/init.d/S10udev: Permission denied
/etc/init.d/rcS: /etc/init.d/rc.final: line 24: /etc/init.d/S11dev: Permission denied
/etc/init.d/rcS: /etc/init.d/rc.final: line 24: /etc/init.d/S20urandom: Permission denied
/etc/init.d/rcS: /etc/init.d/rc.final: line 24: /etc/init.d/S40network: Permission denied
/etc/init.d/rcS: /etc/init.d/rc.final: line 24: /etc/init.d/S41netparam: Permission denied
/etc/init.d/rcS: /etc/init.d/rc.final: line 24: /etc/init.d/S50telnet: Permission denied
/etc/init.d/rcS: /etc/init.d/rc.final: line 24: /etc/init.d/S50usb: Permission denied
/etc/init.d/rcS: /etc/init.d/rc.final: line 24: /etc/init.d/S50wifideamon: Permission denied
mount: mounting /dev/mmcblk0p1 on /mnt/extsd failed: No such file or directory
starting pid 816, tty ‘/dev/console’: ‘-/bin/sh’
BusyBox v1.33.2 (2022-07-08 07:13:49 UTC) built-in shell (ash)
------run profile file-----
|_ ||| ___ _ _ | | || ___ _ _ _ _
| | _ | || | | |__ | || || | ||'|
| | | || | || _ | |_____|||||||||,|
|| |||||||_| Tina is Based on OpenWrt!
Tina Linux (5.0, r0-7277fac)
root@TinaLinux:/# lsmod
Module Size Used by
xradio_wlan 598 0
xradio_core 431911 1 xradio_wlan
xradio_mac 222724 1 xradio_core
root@TinaLinux:/#
