sample_virvi2venc用例也不行
之前用摄像头编码生成MP4的用例不行,现在试试直接输出裸流文件的sample,也是不行的。这是100ask的bsp支持包问题?还是全志的sdk的问题啊?
root@TinaLinux:/mnt/extsd/bin# ./sample_virvi2venc -path sample_vi2venc2muxer.co
nf
sample_virvi2venc running!
I0101 00:02:11.922549 1121 confparser.c:60] load conf file sample_vi2venc2muxer.conf ok!
I0101 00[ 124.580141] VE: before freq=300000000
:02:11.922780 1121 sample_virvi[ 124.584945] VE: real freq=300000000
2venc.c:115] vippDe v: 0, veChn: 0
I0101 00:02:11.922989 1121 sample_virvi2venc.c:119] srcWid th: 1920, srcHeight: 1080
I0101 00:02:11.923100 1121 sample_virvi2venc.c:123] dstWid th: 1280, dstHeight: 720
I0101 00:02:11.923180 1121 sample_virvi2venc.c:199] srcPix Fmt=32, ColorSpace=31
I0101 00:02:11.923249 1121 sample_virvi2venc.c:202] Satura tionChange=0
I0101 00:02:11.923456 1121 sample_virvi2venc.c:259] H.264
I0101 00:02:11.923531 1121 sample_virvi2venc.c:284] vipp:0 , frame rate:20, bitrate:1572864, test_time=20, profile=2
I0101 00:02:11.923653 1121 sample_virvi2venc.c:317] mirror :0, Color2Grey:0, RoiNum:0, RoiQp:50, RoiBgFrameRate Enable:0 Attenuation:3, IntraR efreshBlockNum:0, OrlNum:0VbvBufferSize:0, VbvThreshSize:0
I0101 00:02:11.923743 1121 sample_virvi2venc.c:328] venc c rop enable:0, X:0, Y:0, Width:1280, Height:720
I0101 00:02:11.923808 1121 sample_virvi2venc.c:331] VuiTim ingInfoPresentFlag:0
I0101 00:02:11.923869 1121 sample_virvi2venc.c:334] mVeFre q:0 MHz
I0101 00:02:11.923935 1121 sample_virvi2venc.c:339] Online Enable: 0, OnlineShareBufNum: 2
I0101 00:02:11.923993 1121 sample_virvi2venc.c:345] ViDrop FrameNum: 50
I0101 00:02:11.924060 1121 sample_virvi2venc.c:355] wdr_en : 0
I0101 00:02:11.924121 1121 sample_virvi2venc.c:358] Enable Gdc: 0
I0101 00:02:11.924186 1121 sample_virvi2venc.c:362] EncppE nable: 1, IspAndVeLinkageEnable: 1
I0101 00:02:11.924259 1121 sample_virvi2venc.c:367] SuperF rm Mode: -1, I:0, P:0
I0101 00:02:11.924318 1121 sample_virvi2venc.c:370] ReqIDR Enable: 0
I0101 00:02:11.924451 1121 sample_virvi2venc.c:1380] ViDropFrameNum=5 0
I0101 00:02:11.924511 1121 mpi_sys.c:840] <AW_MPI_SYS_SetConf> kf ctmpdir is [/tmp]
Media Process Platform<<<<<<<<<<<<<<<<<<<<<<<<<<<<
modName : MPP-Platform
tag : V1.0 Release
branch: v5-dev
commit: 4eed413532ad87725895a8cb1ba75e22fc328233
date : 20170725
author: jenkins
iniparser: cannot open /etc/cedarx.conf
iniparser: cannot open /vendor/etc/cedarx.conf
I0101 00:02:11.932308 1121 mpi_sys.c:1280] <AW_MPI_SYS_Init> ISP i nit
[ISP]>>>>>>>>>>>>>>>>>>>> ISP VERSION INFO <<<<<<<<<<<<<<<<<<<
IPCORE: ISP600
branch: libisp-dev
commit: 14df8348718d093707641fea73eba7db962885f5
date : Thu Jul 14 15:40:38 2022 +0800
author: mayifei@allwinnertech.com
I0101 00:02:11.932975 1121 mpi_sys.c:1282] <AW_MPI_SYS_Init> ISP i nit done
INFO : cedarc VeInitialize:1185: *** ic_version = 0x1302000023010,
I0101 00:02:11.946751 1121 hwdisplay.c:84] <hw_display_init>
I0101 00:02:11.946899 1121 hwdisplay.c:993] <hwd_init> (hwd_init 99 3)
I0101 00:02:11.947034 1121 hwdisplay.c:1048] <hwd_init> ret[0][2,0]c h[0]lyl[0] init: enable[0], screenwin[0,0, 0x0], zorder[0], alpha[mode:0, value:0]
I0101 00:02:11.949376 1121 alsa_interface.c:701] open mi xer:hw:0
I0101 00:02:11.954741 1121 alsa_interface.c:736] alsa_el em:ADC1 ADC2 swap
I0101 00:02:11.954894 1121 alsa_interface.c:736] alsa_el em:ADC1 volume
I0101 00:02:11.954972 1121 alsa_interface.c:736] alsa_el em:ADC2 volume
I0101 00:02:11.955036 1121 alsa_interface.c:736] alsa_el em:ADCDRC
I0101 00:02:11.955092 1121 alsa_interface.c:736] alsa_el em:ADCHPF
I0101 00:02:11.955146 1121 alsa_interface.c:736] alsa_el em:DAC volume
I0101 00:02:11.955200 1121 alsa_interface.c:736] alsa_el em:DACDRC
I0101 00:02:11.955253 1121 alsa_interface.c:736] alsa_el em:DACHPF
I0101 00:02:12.285757 1121 alsa_interface.c:736] alsa_el em:LINEIN
I0101 00:02:12.285882 1121 alsa_interface.c:736] alsa_el em:LINEINL gain volume
I0101 00:02:12.285955 1121 alsa_interface.c:736] alsa_el em:LINEINR gain volume
I0101 00:02:12.286014 1121 alsa_interface.c:736] alsa_el em:LINEOUT
I0101 00:02:12.286074 1121 alsa_interface.c:736] alsa_el em:LINEOUT Output Select
I0101 00:02:12.286175 1121 alsa_interface.c:736] alsa_el em:LINEOUT volume
I0101 00:02:12.286250 1121 alsa_interface.c:756] set pla yback vol_val to value: 27
I0101 00:02:12.286315 1121 alsa_interface.c:736] alsa_el em:MIC1
I0101 00:02:12.286374 1121 alsa_interface.c:736] alsa_el em:MIC1 Input Select
I0101 00:02:12.286431 1121 alsa_interface.c:736] alsa_el em:MIC1 gain volume
I0101 00:02:12.286486 1121 alsa_interface.c:736] alsa_el em:MIC2
I0101 00:02:12.286540 1121 alsa_interface.c:736] alsa_el em:MIC2 Input Select
I0101 00:02:12.286595 1121 alsa_interface.c:736] alsa_el em:MIC2 gain volume
I0101 00:02:12.286649 1121 alsa_interface.c:736] alsa_el em:SPK
I0101 00:02:12.286705 1121 alsa_interface.c:736] alsa_el em:digital volume
I0101 00:02:12.286759 1121 alsa_interface.c:736] alsa_el em:rx sync mode
I0101 00:02:12.286813 1121 alsa_interface.c:736] alsa_el em:tx hub mode
E0101 00:02:12.286880 1121 alsa_interface.c:970] aec_elem_audio_codec_hub_mode:tx hub mode-1
E0101 00:02:12.286974 1121 alsa_interface.c:853] aec_elem_sync_mode_switch:rx sync mode-1
I0101 00:02:12.287060 1121 alsa_interface.c:701] open mi xer:hw:1
I0101 00:02:12.287658 1121 alsa_interface.c:736] alsa_el em:loopback debug
I0101 00:02:12.287782 1121 alsa_interface.c:736] alsa_el em:rx sync mode
I0101 00:02:12.287855 1121 alsa_interface.c:736] alsa_el em:tx hub mode
E0101 00:02:12.287921 1121 alsa_interface.c:993] aec_elem_daudio0_hub_mode:tx hub mode-1
E0101 00:02:12.288005 1121 alsa_interface.c:1016] aec_elem_daudio0_loopback_en:loopback debug-1
E0101 00:02:12.28[ 125.190327] [VIN]ve_online close
8074 1121 alsa_interface.c:853] aec_elem_sync_mode_switch:rx sync mode-1
[ISP]video device name is vin_video0
[ISP]open video device[0], detect isp0 success!
I0101 00:02:12.288334 1121 sample_virvi2venc.c:1058] vipp use 3 v4l2 buffers, colorspace: 0x1f
I0101 00:02:12.288454 1121 sample_virvi2venc.c:1061] wdr_mode 0
I0101 00:02:12.288533 1121 media_debug.c:45] MPP DEDIA_DEBUG_FILE_PATH=(null)
I0101 00:02:12.288892 1121 videoInputHw.c:942] <videoInputHw_SetChnAtt r> ViCh[0] update width:1920(1920), height:1080(1088)
[ISP]video0 fd[10] ve_online_en=0, dma_buf_num=0
[ISP]open isp device[0] success!
[ISP_WARN]open /mnt/extsd/isp0_1920_1088_20_ctx_saved.bin failed, err:No such file or directory.
[ISP]prefer isp config: [gc2053_mipi], 1920x1088, 20, 0[ 125.270543] VE: before fr eq=300000000
, 0
[ISP]find gc2053_mipi_1920
[ 125.275971] VE: real freq=300000000
1088_20_0 [gc2053_mipi_isp600_20220511_164617_vlc4_day] isp conf[ 125.285771] VE: before freq=300000000
ig
[ISP]create isp0 server thre[ 125.292412] VE: real freq=300000000
ad!
I0101 00:02:12.578981 1121 mpi_vi.c:1018] <AW_MPI_VI_CreateVirChn > we allow to create virChn[0] in disable status of vipp[0]
I0101 00:02:12.579302 1121 VideoVirVi_Component.c:1160] VideoVirvi component Init! thread_id[0xb6c25d50]
I0101 00:02:12.621386 1121 sample_virvi2venc.c:626] pix fmt:0x20, colorSpace:0x1f
I0101 00:02:12.621535 1121 sample_virvi2venc.c:628] Dro pFrameNum:0
I0101 00:02:12.621620 1121 sample_virvi2venc.c:790] ven c set Rcmode=2
I0101 00:02:12.622179 1121 VideoEnc_Component.c:7042] create VideoEnc threadId:0xb62e8d50
I0101 00:02:12.622372 1121 VideoEnc_Component.c:5422] s et VencChn[0] Comp StateIdle
I0101 00:02:12.622570 1125 media_debug.c:45] MPP _DEDIA_DEBUG_FILE_PATH=(null)
I0101 00:02:12.622743 1125 VideoEnc_Component.c:1110] VencChn [0] Create VeType=96
I0101 00:02:12.623013 1124 videoInputHw.c:4787] <VideoInputHw_CapThread > loop VideoInputHw_CapThread vipp_id = 0, buf_num=3.
iniparser: cannot open /tmp/libcedarc_dynamic_log_level
INFO : cedarc <cdc_log_set_level:43>: Set log level to 5 from /vendor/etc/cedarc. conf
WARNING: cedarc LogVersionInfo:44:
Cedar Codec <<<<<<<<<<<<<<<<<<<<<<<<<<<<
tag :
branch: tina-v853-dev
commit: ee230a47e5a2392ec315795121c2d112492fac1c
date : Fri Jul 22 10:37:50 2022 +0800
author: wuguanjian
change-id : I28fe0c31c718f097d61ad6bdbcb4cb5df0bd3575
release_author : lichaopdc
patch :
I0101 00:02:12.652501 1121 sample_virvi2venc.c:838] create venc channel[0] success!
I0101 00:02:12.652654 1121 sample_virvi2venc.c:871] set ven c framerate: src 20fps, dst 20fps
I0101 00:02:12.652737 1121 VideoEnc_Component.c:3961] vencChn[0] set new framerate:20
I0101 00:02:12.652947 1121 sample_virvi2venc.c:1127] open /mnt/ext sd/test.mp4 success
I0101 00:02:12.653067 1121 VideoEnc_Component.c:6284] set inputPortTunnelFlag = TRUE
I0101 00:02:12.653291 1121 sample_virvi2venc.c:1400] create Msg Queue Thread success! threadId[0xb6fee768]
I0101 00:02:12.653395 1121 sample_virvi2venc.c:1145] start
I0101 00:02:12.653620 1121 VideoEnc_Component.c:5418] s et VencChn[0] Comp StateExecuting
I0101 00:02:12.653750 1125 media_debug.c:45] MPP _DEDIA_DEBUG_FILE_PATH=(null)
I0101 00:02:12.653938 1125 VideoEnc_Component.c:825] bi t rate is 1536Kb, set encode vbv size 1708032, frame length threshold 921600
I0101 00:02:12.654036 1125 VideoEnc_Component.c:1930] ve Chn[0], EncppEnable=1
I0101 00:02:12.654110 1125 VideoEnc_Component.c:1936] Dr opFrameNum: 0
I0101 00:02:12.654169 1125 VideoEnc_Component.c:1946] GD C enable: 0
I0101 00:02:12.654235 1125 VideoEnc_Component.c:2011] On line Mode=1, Channel=0, ShareBufNum=0, OnlineEnableFlag=0
I0101 00:02:12.654342 1125 VideoEnc_Component.c:2038] re c_lbc_mode=1
I0101 00:02:12.668588 1125 VideoEnc_Component.c:2059] Ve nc Init success
I0101 00:02:12.668763 1125 VideoEnc_Component.c:2068] Ve nc SetCallbacks success
I0101 00:02:12.668893 1125 VideoEnc_Component.c:2078] Ve nc Start success
I0101 00:02:12.669064 1125 VideoEnc_Component.c:2121] se t Color2Grey [0], in Venchn[0]
I0101 00:02:12.669165 1125 VideoEnc_Component.c:2128] ve ncChn[0] had init!
I0101 00:02:12.669250 1125 VideoEnc_Component.c:8042] VencC hn[0]: idle/pause[0x2]->executing …
[ISP_ERR]isp_stat_process_buffer, line: 268,AEWB: stats error, skipping buffer.
[ISP_WARN]gc2053_mipi get sensor_temp failed: Invalid argument (22).
[ISP_ERR]isp_sync_debug_info, line: 747,VIDIOC_VIN_ISP_GET_INFO error!
[ISP]video device name is vin_video12
[ISP]open video device[12], detect isp0 success!
[ISP]--------- LDCI Video12 Init OK ---------
[ISP]--------- LDCI Video12 Streamon OK ---------
I0101 00:02:14.653729 1123 VideoVirVi_Component.c:1354] <Vi_ComponentThread> vi rvi[0-0] has no frame input?
I0101 00:02:15.351445 1124 videoInputHw.c:4882] <VideoInputHw_CapThread > vipp[0] drop 50 frames done!
I0101 00:02:15.401750 1123 VideoEnc_Component.c:6383] VencChn[0]: first video frame pts[127918644]us,tm1[127918809]us, vSize[1920x1088 ], frmId[2,52]
I0101 00:02:16.669463 1126 sample_virvi2venc.c:1257] get first frmae failed!
全志公开的SDK并没有包含MPP这部分内容,这部分我们是单独抽出来供大家学习的。可能会应为公开版本的SDK导致依赖有问题,我们后面会尽快解决这部分问题。
解决了吗? yuzukilizard v851s 也有同样的问题?
解决了吗?????????????
