求助,lvgl8.2.0版本中,怎么关闭选项卡滑动切换页面,我只想点击切换
以 lv_example_tabview 示例为例,只需要将 ta 中为 btnm 添加的回调函数删除后自己实现即可:
static void btns_value_changed_event_cb(lv_event_t * e)
    lv_obj_t * btns = lv_event_get_target(e);
    lv_obj_t * tv = lv_obj_get_parent(btns);
    uint32_t id = lv_btnmatrix_get_selected_btn(btns);
    lv_tabview_set_act(tv, id, LV_ANIM_OFF);
void lv_example_tabview_100ask(void)
    /*Create a Tab view object*/
    lv_obj_t *tabview;
    tabview = lv_tabview_create(lv_scr_act(), LV_DIR_TOP, 50);
    lv_obj_clear_flag(tabview, LV_OBJ_FLAG_SCROLLABLE);
    /*Add 3 tabs (the tabs are page (lv_page) and can be scrolled*/
    lv_obj_t *tab1 = lv_tabview_add_tab(tabview, "Tab 1");
    lv_obj_t *tab2 = lv_tabview_add_tab(tabview, "Tab 2");
    lv_obj_t *tab3 = lv_tabview_add_tab(tabview, "Tab 3");
    /*Add content to the tabs*/
    lv_obj_t * label = lv_label_create(tab1);
    lv_label_set_text(label, "This the first tab\n\n"
                             "If the content\n"
                             "of a tab\n"
                             "becomes too\n"
                             "longer\n"
                             "than the\n"
                             "container\n"
                             "then it\n"
                             "automatically\n"
                             "becomes\n"
                             "scrollable.\n"
                             "\n"
                             "\n"
                             "\n"
                             "Can you see it?");
    label = lv_label_create(tab2);
    lv_label_set_text(label, "Second tab");
    label = lv_label_create(tab3);
    lv_label_set_text(label, "Third tab");
    lv_obj_scroll_to_view_recursive(label, LV_ANIM_OFF);
    lv_obj_t * btnm = lv_tabview_get_tab_btns(tabview);
    lv_obj_remove_event_cb(btnm, NULL);
    lv_obj_add_event_cb(btnm, btns_value_changed_event_cb, LV_EVENT_VALUE_CHANGED, NULL);
