全新重新烧写emmc,重启,出现错误end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,3)
在学习过程中发现不正常,然后按照开发指南的第7章重新烧写系统,重启后,发现错误,下面附上所有启动日志(不同重启),判断是否是硬件有问题,需要更换硬件?
NOTICE: CPU: STM32MP157AAC Rev.Z
NOTICE: Model: 100ASK ASK-STM32MP157-512D PRO V1 Board
INFO: Reset reason (0x15):
INFO: Power-on Reset (rst_por)
INFO: Using EMMC
INFO: Instance 2
INFO: Boot used partition fsbl1
NOTICE: BL2: v2.2-r1.0(debug):8ad4a8c-dirty
NOTICE: BL2: Built : 10:42:11, Oct 27 2022
INFO: Using crypto library ‘stm32_crypto_lib’
INFO: BL2: Doing platform setup
INFO: RAM: DDR3-1066/888 bin G 2x2Gb 533MHz v1.44
INFO: Memory size = 0x20000000 (512 MB)
INFO: BL2 runs SP_MIN setup
INFO: BL2: Loading image id 4
INFO: Loading image id=4 at address 0x2ffed000
INFO: Image id=4 loaded: 0x2ffed000 - 0x2ffff000
INFO: BL2: Loading image id 5
INFO: Loading image id=5 at address 0xc0100000
INFO: STM32 Image size : 869961
INFO: Image id=5 loaded: 0xc0100000 - 0xc01d4649
WARNING: Skip signature check (header option)
NOTICE: ROTPK is not deployed on platform. Skipping ROTPK verification.
NOTICE: BL2: Booting BL32
INFO: Entry point address = 0x2ffed000
INFO: SPSR = 0x1d3
NOTICE: SP_MIN: v2.2-r1.0(debug):8ad4a8c-dirty
NOTICE: SP_MIN: Built : 10:42:11, Oct 27 2022
INFO: ARM GICv2 driver initialized
INFO: stm32mp IWDG1 (12): Secure
INFO: ETZPC: CRYP1 (9) could be non secure
INFO: SP_MIN: Initializing runtime services
INFO: SP_MIN: Preparing exit to normal world
U-Boot 2020.01-stm32mp-r1-g8851a55b-dirty (Oct 28 2022 - 02:23:17 +0000)
Board: stm32mp1 in trusted mode (st,stm32mp157c-100ask-512d-v1)
DRAM: 512 MiB
Clocks:
  • MPU : 650 MHz
  • MCU : 208.878 MHz
  • AXI : 266.500 MHz
  • PER : 24 MHz
  • DDR : 533 MHz
    WDT: Started with servicing (32s timeout)
    NAND: 0 MiB
    MMC: STM32 SD/MMC: 0, STM32 SD/MMC: 1
    Loading Environment from MMC… OK
    In: serial
    Out: serial
    Err: serial
    Net: eth0: ethernet@5800a000
    Press SPACE to abort autoboot in 1 seconds
    Boot over mmc1!
    switch to partitions #0, OK
    mmc1(part 0) is current device
    Scanning mmc 1:2…
    Found /mmc1_extlinux/stm32mp157c-100ask-512d-v1_extlinux.conf
    Retrieving file: /mmc1_extlinux/stm32mp157c-100ask-512d-v1_extlinux.conf
    210 bytes read in 37 ms (4.9 KiB/s)
    1: 100ask-lcd
    Retrieving file: /uImage
    8187672 bytes read in 316 ms (24.7 MiB/s)
    append: root=/dev/mmcblk2p3 rootwait rw console=ttySTM0,115200
    Retrieving file: /stm32mp157c-100ask-512d-lcd-v1.dtb
    109078 bytes read in 42 ms (2.5 MiB/s)
Booting kernel from Legacy Image at c2000000 …
Image Name: Linux-5.4.31
Created: 2022-10-27 11:09:36 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 8187608 Bytes = 7.8 MiB
Load Address: c2000040
Entry Point: c2000040
Verifying Checksum … OK
Flattened Device Tree blob at c4000000
Booting using the fdt blob at 0xc4000000
XIP Kernel Image
Loading Device Tree to cffe2000, end cffffa15 … OK
Starting kernel …
[ 0.000000] Linux version 5.4.31 (book@virtual-machine) (gcc version 8.4.0 (Buildroot 2020.02-g8ad4a8c-dirty)) #1 SMP PREEMPT Thu Oct 27 11:04:26 UTC 2022
[ 0.000000] OF: fdt: Machine model: 100ASK YA157C v2 www.100ask.com
[ 0.000000] Reserved memory: created DMA memory pool at 0x10000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node mcuram2@10000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x10040000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vdev0vring0@10040000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x10041000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vdev0vring1@10041000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x10042000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vdev0buffer@10042000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x30000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node mcuram@30000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x38000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node retram@38000000, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 128 MiB at 0xd2000000
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] percpu: Embedded 20 pages/cpu s50124 r8192 d23604 u81920
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 113536
[ 0.000000] Kernel command line: root=/dev/mmcblk2p3 rootwait rw console=ttySTM0,115200
[ 0.000000] Memory: 303812K/458752K available (12288K kernel code, 962K rwdata, 3516K rodata, 1024K init, 226K bss, 23868K reserved, 131072K cma-reserved, 0K highmem)
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] random: get_random_bytes called from start_kernel+0x320/0x4f4 with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (virt).
[ 0.000008] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000026] Switching to timer-based delay loop, resolution 41ns
[ 0.002028] Console: colour dummy device 80x30
[ 0.002080] Calibrating delay loop (skipped), value calculated using timer frequency… 48.00 BogoMIPS (lpj=240000)
[ 0.002101] pid_max: default: 32768 minimum: 301
[ 0.002363] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.002387] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.003679] CPU: Testing write buffer coherency: ok
[ 0.004205] /cpus/cpu@0 missing clock-frequency property
[ 0.004242] /cpus/cpu@1 missing clock-frequency property
[ 0.004260] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.059750] Setting up static identity map for 0xc0100000 - 0xc0100060
[ 0.079731] rcu: Hierarchical SRCU implementation.
[ 0.105115] smp: Bringing up secondary CPUs …
[ 0.180370] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.180587] smp: Brought up 1 node, 2 CPUs
[ 0.180612] SMP: Total of 2 processors activated (96.00 BogoMIPS).
[ 0.180623] CPU: All CPU(s) started in SVC mode.
[ 0.181471] devtmpfs: initialized
[ 0.214884] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.215506] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.215540] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.222429] pinctrl core: initialized pinctrl subsystem
[ 0.224840] NET: Registered protocol family 16
[ 0.233121] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.235727] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.235750] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.236185] Serial: AMBA PL011 UART driver
[ 0.239450] stm32-pm-domain pm_domain: domain core-ret-power-domain registered
[ 0.239490] stm32-pm-domain pm_domain: subdomain core-power-domain registered
[ 0.239505] stm32-pm-domain pm_domain: domains probed
[ 0.292386] gpio-regulator regulators: No ‘states’ property found
[ 0.292429] gpio-regulator: probe of regulators failed with error -22
[ 0.293848] SCSI subsystem initialized
[ 0.294736] usbcore: registered new interface driver usbfs
[ 0.294820] usbcore: registered new interface driver hub
[ 0.294971] usbcore: registered new device driver usb
[ 0.295363] pps_core: LinuxPPS API ver. 1 registered
[ 0.295377] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.295420] PTP clock support registered
[ 0.295791] EDAC MC: Ver: 3.0.0
[ 0.297139] Advanced Linux Sound Architecture Driver Initialized.
[ 0.298017] Bluetooth: Core ver 2.22
[ 0.298105] NET: Registered protocol family 31
[ 0.298117] Bluetooth: HCI device and connection manager initialized
[ 0.298139] Bluetooth: HCI socket layer initialized
[ 0.298156] Bluetooth: L2CAP socket layer initialized
[ 0.298192] Bluetooth: SCO socket layer initialized
[ 0.299184] clocksource: Switched to clocksource arch_sys_counter
[ 1.058636] thermal_sys: Registered thermal governor ‘step_wise’
[ 1.059356] NET: Registered protocol family 2
[ 1.060490] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 1.060545] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 1.060624] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 1.060720] TCP: Hash tables configured (established 4096 bind 4096)
[ 1.060861] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 1.060909] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 1.061231] NET: Registered protocol family 1
[ 1.062241] RPC: Registered named UNIX socket transport module.
[ 1.062261] RPC: Registered udp transport module.
[ 1.062272] RPC: Registered tcp transport module.
[ 1.062282] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.064140] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 1.066274] Initialise system trusted keyrings
[ 1.066668] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 1.079411] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.080794] NFS: Registering the id_resolver key type
[ 1.080846] Key type id_resolver registered
[ 1.080858] Key type id_legacy registered
[ 1.081086] ntfs: driver 2.1.32 [Flags: R/O].
[ 1.081587] jffs2: version 2.2. (NAND) ? 2001-2006 Red Hat, Inc.
[ 1.082375] fuse: init (API version 7.31)
[ 1.138553] NET: Registered protocol family 38
[ 1.138583] Key type asymmetric registered
[ 1.138596] Asymmetric key parser ‘x509’ registered
[ 1.138691] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.138707] io scheduler mq-deadline registered
[ 1.138720] io scheduler kyber registered
[ 1.149364] STM32 USART driver initialized
[ 1.151003] ar8035 phy init
[ 1.151474] the phy gpio failed
[ 1.173068] brd: module loaded
[ 1.187419] loop: module loaded
[ 1.194077] libphy: Fixed MDIO Bus: probed
[ 1.195961] CAN device driver interface
[ 1.198535] PPP generic driver version 2.4.2
[ 1.198887] PPP BSD Compression module registered
[ 1.198904] PPP Deflate Compression module registered
[ 1.198931] PPP MPPE Compression module registered
[ 1.198944] NET: Registered protocol family 24
[ 1.198991] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 1.199002] CSLIP: code copyright 1989 Regents of the University of California.
[ 1.199011] SLIP linefill/keepalive option.
[ 1.199025] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.199130] usbcore: registered new interface driver pegasus
[ 1.199305] usbcore: registered new interface driver r8152
[ 1.199386] usbcore: registered new interface driver asix
[ 1.199450] usbcore: registered new interface driver ax88179_178a
[ 1.199525] usbcore: registered new interface driver cdc_ether
[ 1.199605] usbcore: registered new interface driver smsc75xx
[ 1.199682] usbcore: registered new interface driver smsc95xx
[ 1.199742] usbcore: registered new interface driver net1080
[ 1.199801] usbcore: registered new interface driver cdc_subset
[ 1.199858] usbcore: registered new interface driver zaurus
[ 1.199960] usbcore: registered new interface driver cdc_ncm
[ 1.201677] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.201737] ehci-platform: EHCI generic platform driver
[ 1.202252] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.202294] ohci-platform: OHCI generic platform driver
[ 1.203331] usbcore: registered new interface driver cdc_acm
[ 1.203348] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.203445] usbcore: registered new interface driver usblp
[ 1.203507] usbcore: registered new interface driver cdc_wdm
[ 1.203565] usbcore: registered new interface driver uas
[ 1.203645] usbcore: registered new interface driver usb-storage
[ 1.203805] usbcore: registered new interface driver usbserial_generic
[ 1.203856] usbserial: USB Serial support registered for generic
[ 1.203927] usbcore: registered new interface driver option
[ 1.203971] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.209091] i2c /dev entries driver
[ 1.214265] stm32-cpufreq stm32-cpufreq: Failed to get chip info: -517
[ 1.218911] sdhci: Secure Digital Host Controller Interface driver
[ 1.218927] sdhci: Copyright(c) Pierre Ossman
[ 1.218937] Synopsys Designware Multimedia Card Interface Driver
[ 1.219674] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.221026] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.223451] usbcore: registered new interface driver usbhid
[ 1.223470] usbhid: USB HID core driver
[ 1.223482] dtbocfg_module_init
[ 1.223539] dtbocfg_module_init: OK
[ 1.223925] arm-smc-mbox mailbox-0: ARM SMC mailbox enabled.
[ 1.224060] arm-smc-mbox mailbox-1: ARM SMC mailbox enabled.
[ 1.225822] remoteproc remoteproc0: releasing m4
[ 1.229055] Unable to get STM32 DDR PMU clock
[ 1.234692] drop_monitor: Initializing network drop monitor service
[ 1.235034] NET: Registered protocol family 17
[ 1.235067] can: controller area network core (rev 20170425 abi 9)
[ 1.235200] NET: Registered protocol family 29
[ 1.235217] can: raw protocol (rev 20170425)
[ 1.235229] can: broadcast manager protocol (rev 20170425 t)
[ 1.235248] can: netlink gateway (rev 20190810) max_hops=1
[ 1.235760] Bluetooth: RFCOMM TTY layer initialized
[ 1.235796] Bluetooth: RFCOMM socket layer initialized
[ 1.235847] Bluetooth: RFCOMM ver 1.11
[ 1.235876] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.235887] Bluetooth: BNEP filters: protocol multicast
[ 1.235908] Bluetooth: BNEP socket layer initialized
[ 1.235920] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.235938] Bluetooth: HIDP socket layer initialized
[ 1.236517] Key type dns_resolver registered
[ 1.236711] ThumbEE CPU extension supported.
[ 1.236740] Registering SWP/SWPB emulation handler
[ 1.237181] registered taskstats version 1
[ 1.237196] Loading compiled-in X.509 certificates
[ 1.248498] Loaded X.509 cert ‘Build time autogenerated kernel key: a551a3bcaf9a62271059adf2e1003b2f3df06de0’
[ 1.275596] arm-scmi firmware:scmi-0: SCMI Protocol v2.0 ‘ST:’ Firmware version 0x0
[ 1.280111] remoteproc remoteproc0: releasing m4
[ 1.281595] Unable to get STM32 DDR PMU clock
[ 1.304880] debugfs: Directory ‘cpu0’ with parent ‘opp’ already present!
[ 1.314821] remoteproc remoteproc0: releasing m4
[ 1.316297] Unable to get STM32 DDR PMU clock
[ 1.355319] stm32-mdma 58000000.dma: STM32 MDMA driver registered
[ 1.359909] stm32-dma 48000000.dma: STM32 DMA driver registered
[ 1.362091] stm32-dma 48001000.dma: STM32 DMA driver registered
[ 1.362756] reg11: supplied by regulator-dummy
[ 1.363204] reg18: supplied by regulator-dummy
[ 1.363655] usb33: supplied by regulator-dummy
[ 1.388819] random: fast init done
[ 1.389574] stm_thermal 50028000.thermal: stm_thermal_probe: Driver initialized successfully
[ 1.392430] debugfs: Directory ‘cpu0’ with parent ‘opp’ already present!
[ 1.393314] random: crng init done
[ 1.396655] stm32-crc32 58009000.crc: Initialized
[ 1.398247] stm32-hash 54002000.hash: will run requests pump with realtime priority
[ 1.403166] stm32-hash 54002000.hash: Init HASH done HW ver 23 DMA mode 1
[ 1.415541] remoteproc remoteproc0: releasing m4
[ 1.417343] stm32-ddr-pmu: probed (ID=0x00140061 VER=0x00000010), DDR@533MHz
[ 1.419820] /soc/interrupt-controller@5000d000: bank0
[ 1.419842] /soc/interrupt-controller@5000d000: bank1
[ 1.419854] /soc/interrupt-controller@5000d000: bank2
[ 1.422213] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOA bank added
[ 1.422784] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOB bank added
[ 1.423335] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOC bank added
[ 1.423831] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOD bank added
[ 1.424367] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOE bank added
[ 1.424911] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOF bank added
[ 1.425415] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOG bank added
[ 1.425922] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOH bank added
[ 1.426426] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOI bank added
[ 1.426758] stm32mp157-pinctrl soc:pin-controller@50002000: Pinctrl STM32 initialized
[ 1.427852] stm32mp157-pinctrl soc:pin-controller-z@54004000: GPIOZ bank added
[ 1.427882] stm32mp157-pinctrl soc:pin-controller-z@54004000: Pinctrl STM32 initialized
[ 1.430444] stm32-usbphyc 5a006000.usbphyc: registered rev:1.0
[ 1.431977] stm32-usart 40010000.serial: interrupt mode for rx (no dma)
[ 1.431999] stm32-usart 40010000.serial: interrupt mode for tx (no dma)
[ 1.432036] 40010000.serial: ttySTM0 at MMIO 0x40010000 (irq = 58, base_baud = 4000000) is a stm32-usart
[ 2.818727] printk: console [ttySTM0] enabled
[ 2.825027] 44003000.serial: ttySTM1 at MMIO 0x44003000 (irq = 59, base_baud = 4000000) is a stm32-usart
[ 2.834739] stm32-usart 5c000000.serial: interrupt mode for rx (no dma)
[ 2.839984] stm32-usart 5c000000.serial: interrupt mode for tx (no dma)
[ 2.846546] 5c000000.serial: ttySTM2 at MMIO 0x5c000000 (irq = 60, base_baud = 4000000) is a stm32-usart
[ 2.856325] serial serial0: tty port ttySTM2 registered
[ 2.867857] inv-mpu6000-spi spi0.0: mounting matrix not found: using identity…
[ 2.874000] inv-mpu6000-spi spi0.0: spi0.0 supply vddio not found, using dummy regulator
[ 3.102581] spi_stm32 44009000.spi: driver initialized
[ 3.108069] m_can_platform 4400f000.can: m_can device registered (irq=55, version=32)
[ 3.116459] stm32-dwmac 5800a000.ethernet: PTP uses main clock
[ 3.120924] stm32-dwmac 5800a000.ethernet: no reset control found
[ 3.126984] stm32-dwmac 5800a000.ethernet: No phy clock provided…
[ 3.133913] stm32-dwmac 5800a000.ethernet: User ID: 0x40, Synopsys ID: 0x42
[ 3.140260] stm32-dwmac 5800a000.ethernet: DWMAC4/5
[ 3.145153] stm32-dwmac 5800a000.ethernet: DMA HW capability register supported
[ 3.152496] stm32-dwmac 5800a000.ethernet: RX Checksum Offload Engine supported
[ 3.159807] stm32-dwmac 5800a000.ethernet: TX Checksum insertion supported
[ 3.166666] stm32-dwmac 5800a000.ethernet: Wake-Up On Lan supported
[ 3.172958] stm32-dwmac 5800a000.ethernet: TSO supported
[ 3.178253] stm32-dwmac 5800a000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 3.186119] stm32-dwmac 5800a000.ethernet: TSO feature enabled
[ 3.192372] libphy: stmmac: probed
[ 3.195613] yzhang…get YT8511, abt to set 125m clk out, phyaddr=6, phyid=0000010a
[ 3.203925] yt8511_config_out_125m, phy clk out, val=0x008057
[ 3.209021] yzhang…8511 set 125m clk out, reg=0x8057
[ 3.216317] dwc2 49000000.usb-otg: 49000000.usb-otg supply vusb_d not found, using dummy regulator
[ 3.224063] dwc2 49000000.usb-otg: 49000000.usb-otg supply vusb_a not found, using dummy regulator
[ 3.359470] dwc2 49000000.usb-otg: EPs: 9, dedicated fifos, 952 entries in SPRAM
[ 3.366445] dwc2 49000000.usb-otg: DWC OTG Controller
[ 3.370588] dwc2 49000000.usb-otg: new USB bus registered, assigned bus number 1
[ 3.377931] dwc2 49000000.usb-otg: irq 65, io mem 0x49000000
[ 3.383898] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[ 3.391850] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.399045] usb usb1: Product: DWC OTG Controller
[ 3.403773] usb usb1: Manufacturer: Linux 5.4.31 dwc2_hsotg
[ 3.409351] usb usb1: SerialNumber: 49000000.usb-otg
[ 3.415261] hub 1-0:1.0: USB hub found
[ 3.418099] hub 1-0:1.0: 1 port detected
[ 3.423790] ehci-platform 5800d000.usbh-ehci: EHCI Host Controller
[ 3.428555] ehci-platform 5800d000.usbh-ehci: new USB bus registered, assigned bus number 2
[ 3.437397] ehci-platform 5800d000.usbh-ehci: irq 66, io mem 0x5800d000
[ 3.469235] ehci-platform 5800d000.usbh-ehci: USB 2.0 started, EHCI 1.00
[ 3.474904] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[ 3.482808] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.490015] usb usb2: Product: EHCI Host Controller
[ 3.494868] usb usb2: Manufacturer: Linux 5.4.31 ehci_hcd
[ 3.500295] usb usb2: SerialNumber: 5800d000.usbh-ehci
[ 3.506326] hub 2-0:1.0: USB hub found
[ 3.509269] hub 2-0:1.0: 2 ports detected
[ 3.514590] ohci-platform 5800c000.usbh-ohci: Generic Platform OHCI controller
[ 3.520479] ohci-platform 5800c000.usbh-ohci: new USB bus registered, assigned bus number 3
[ 3.529215] ohci-platform 5800c000.usbh-ohci: irq 52, io mem 0x5800c000
[ 3.603570] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
[ 3.610438] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.617616] usb usb3: Product: Generic Platform OHCI controller
[ 3.623568] usb usb3: Manufacturer: Linux 5.4.31 ohci_hcd
[ 3.628940] usb usb3: SerialNumber: 5800c000.usbh-ohci
[ 3.636014] hub 3-0:1.0: USB hub found
[ 3.638364] hub 3-0:1.0: 2 ports detected
[ 3.645173] stm32_rtc 5c004000.rtc: registered as rtc0
[ 3.649725] stm32_rtc 5c004000.rtc: Date/Time must be initialized
[ 3.654957] stm32_rtc 5c004000.rtc: registered rev:1.2
[ 3.681185] stm32f7-i2c 40012000.i2c: doesn’t use DMA
[ 3.686990] fusb302 0-0022: Can’t get property of role, set role to default DRP
[ 3.700843] fusb302 0-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[ 3.709028] stm32f7-i2c 40012000.i2c: STM32F7 I2C-0 bus adapter
[ 3.735386] stm32f7-i2c 40013000.i2c: doesn’t use DMA
[ 3.739717] stm32f7-i2c 40013000.i2c: STM32F7 I2C-1 bus adapter
[ 3.766070] stm32f7-i2c 5c002000.i2c: doesn’t use DMA
[ 3.771130] Goodix-TS 2-005d: 2-005d supply AVDD28 not found, using dummy regulator
[ 3.777494] Goodix-TS 2-005d: 2-005d supply VDDIO not found, using dummy regulator
[ 3.899376] Goodix-TS 2-005d: i2c test failed attempt 1: -6
[ 3.939356] Goodix-TS 2-005d: i2c test failed attempt 2: -6
[ 3.979214] Goodix-TS 2-005d: I2C communication failure: -6
[ 3.991312] stm32f7-i2c 5c002000.i2c: STM32F7 I2C-2 bus adapter
[ 3.998321] mmci-pl18x 48004000.sdmmc: allocated mmc-pwrseq
[ 4.002970] mmci-pl18x 48004000.sdmmc: mmc0: PL180 manf 53 rev1 at 0x48004000 irq 43,0 (pio)
[ 4.039008] mmci-pl18x 58005000.sdmmc: mmc1: PL180 manf 53 rev2 at 0x58005000 irq 49,0 (pio)
[ 4.063242] mmc0: queuing unknown CIS tuple 0x80 (2 bytes)
[ 4.068748] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
[ 4.074840] mmci-pl18x 58007000.sdmmc: mmc2: PL180 manf 53 rev2 at 0x58007000 irq 50,0 (pio)
[ 4.084421] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
[ 4.092159] mmc0: queuing unknown CIS tuple 0x80 (7 bytes)
[ 4.102237] mmc0: queuing unknown CIS tuple 0x81 (9 bytes)
[ 4.114044] stm32-ipcc 4c001000.mailbox: ipcc rev:1.0 enabled, 6 chans, proc 0
[ 4.123921] stm32-rproc mlahb:m4@10000000: wdg irq registered
[ 4.130498] remoteproc remoteproc0: m4 is available
[ 4.136141] stm32mp157-pinctrl soc:pin-controller@50002000: missing pins property in node pins .
[ 4.143677] stm32-adc-core: probe of 48003000.adc failed with error -22
[ 4.162810] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 4.168039] [drm] Driver supports precise vblank timestamp query.
[ 4.178357] [drm] Initialized stm 1.0.0 20170330 for 5a001000.display-controller on minor 0
[ 4.238600] mmc2: new high speed MMC card at address 0001
[ 4.250403] mmcblk2: mmc2:0001 S40004 3.64 GiB
[ 4.251149] mmcblk2boot0: mmc2:0001 S40004 partition 1 4.00 MiB
[ 4.251848] mmcblk2boot1: mmc2:0001 S40004 partition 2 4.00 MiB
[ 4.253441] mmcblk2rpmb: mmc2:0001 S40004 partition 3 4.00 MiB, chardev (242:0)
[ 4.267884] mmc0: new high speed SDIO card at address 0001
[ 4.273863] mmcblk2: p1 p2 p3
[ 4.349595] Console: switching to colour frame buffer device 128x37
[ 4.409036] stm32-display 5a001000.display-controller: fb0: stmdrmfb frame buffer device
[ 4.548867] asoc-audio-graph-card sound: wm8960-hifi-Playback ↔ 4400a004.audio-controller mapping ok
[ 4.557974] asoc-audio-graph-card sound: wm8960-hifi-Capture ↔ 4400a024.audio-controller mapping ok
[ 4.686511] input: joystick as /devices/platform/joystick/input/input0
[ 4.692312] stm32_rtc 5c004000.rtc: setting system clock to 2000-01-01T00:00:10 UTC (946684810)
[ 4.701833] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 4.711265] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 4.716571] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 4.725503] ALSA device list:
[ 4.727931] #0: WM8960-100ASK
[ 4.731146] cfg80211: failed to load regulatory.db
[ 4.757817] VFS: could not find a valid V7 on mmcblk2p3.
[ 4.767966] VFS: could not find a valid V7 on mmcblk2p3.
[ 4.772617] List of all partitions:
[ 4.775322] 0100 65536 ram0
[ 4.775325] (driver?)
[ 4.781479] 0101 65536 ram1
[ 4.781483] (driver?)
[ 4.787511] 0102 65536 ram2
[ 4.787514] (driver?)
[ 4.793749] 0103 65536 ram3
[ 4.793753] (driver?)
[ 4.799925] 0104 65536 ram4
[ 4.799929] (driver?)
[ 4.805807] 0105 65536 ram5
[ 4.805810] (driver?)
[ 4.811906] 0106 65536 ram6
[ 4.811909] (driver?)
[ 4.818001] 0107 65536 ram7
[ 4.818004] (driver?)
[ 4.824101] 0108 65536 ram8
[ 4.824104] (driver?)
[ 4.830222] 0109 65536 ram9
[ 4.830225] (driver?)
[ 4.836298] 010a 65536 ram10
[ 4.836301] (driver?)
[ 4.842487] 010b 65536 ram11
[ 4.842491] (driver?)
[ 4.848670] 010c 65536 ram12
[ 4.848673] (driver?)
[ 4.854859] 010d 65536 ram13
[ 4.854863] (driver?)
[ 4.861066] 010e 65536 ram14
[ 4.861069] (driver?)
[ 4.867228] 010f 65536 ram15
[ 4.867231] (driver?)
[ 4.873423] b300 3817472 mmcblk2
[ 4.873427] driver: mmcblk
[ 4.880232] b301 2048 mmcblk2p1 82fd05aa-585c-43a3-9c3b-8fd9a23868e1
[ 4.880235]
[ 4.889204] b302 131072 mmcblk2p2 3317d741-cbf3-45c5-9d61-f9163c4b9962
[ 4.889207]
[ 4.898157] b303 3683328 mmcblk2p3 a065a4a9-2892-4e87-a5a8-2cfe918b2f0e
[ 4.898159]
[ 4.907129] No filesystem could mount root, tried:
[ 4.907132] ext3
[ 4.912021] ext2
[ 4.913920] ext4
[ 4.915837] squashfs
[ 4.917754] vfat
[ 4.920040] msdos
[ 4.921937] sysv
[ 4.923941] v7
[ 4.925857] ntfs
[ 4.927600] fuseblk
[ 4.929537]
[ 4.933185] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,3)
[ 4.941638] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 5.4.31 #1
[ 4.947555] Hardware name: STM32 (Device Tree Support)
[ 4.952734] [] (unwind_backtrace) from [] (show_stack+0x10/0x14)
[ 4.960465] [] (show_stack) from [] (dump_stack+0xb0/0xc4)
[ 4.967700] [] (dump_stack) from [] (panic+0x114/0x314)
[ 4.974671] [] (panic) from [] (mount_block_root+0x25c/0x284)
[ 4.982162] [] (mount_block_root) from [] (mount_root+0x124/0x140)
[ 4.990089] [] (mount_root) from [] (prepare_namespace+0x17c/0x1c4)
[ 4.998104] [] (prepare_namespace) from [] (kernel_init+0x8/0x110)
[ 5.006032] [] (kernel_init) from [] (ret_from_fork+0x14/0x2c)
[ 5.013607] Exception stack(0xdf087fb0 to 0xdf087ff8)
[ 5.018665] 7fa0: 00000000 00000000 00000000 00000000
[ 5.026860] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 5.035051] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 5.041682] CPU0: stopping
[ 5.044375] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 5.4.31 #1
[ 5.050295] Hardware name: STM32 (Device Tree Support)
[ 5.055454] [] (unwind_backtrace) from [] (show_stack+0x10/0x14)
[ 5.063204] [] (show_stack) from [] (dump_stack+0xb0/0xc4)
[ 5.070437] [] (dump_stack) from [] (handle_IPI+0x41c/0x448)
[ 5.077845] [] (handle_IPI) from [] (gic_handle_irq+0x8c/0x90)
[ 5.085425] [] (gic_handle_irq) from [] (__irq_svc+0x6c/0xa8)
[ 5.092911] Exception stack(0xc1201f38 to 0xc1201f80)
[ 5.097968] 1f20: 00000000 00002008
[ 5.106165] 1f40: dfad4074 c011b800 ffffe000 c1204ea4 c1204ee4 00000001 c12bc2fd c0eebd80
[ 5.114357] 1f60: dffffe00 00000000 00000000 c1201f88 c010a1a4 c010a1a8 60000113 ffffffff
[ 5.122551] [] (__irq_svc) from [] (arch_cpu_idle+0x38/0x3c)
[ 5.129959] [] (arch_cpu_idle) from [] (do_idle+0x10c/0x150)
[ 5.137363] [] (do_idle) from [] (cpu_startup_entry+0x18/0x20)
[ 5.144946] [] (cpu_startup_entry) from [] (start_kernel+0x4b8/0x4f4)
[ 5.153136] [] (start_kernel) from [<00000000>] (0x0)
[ 5.159065] —[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,3) ]—
