参照老师给的程序写了个GPIO控制的程序,就一个文件编译通过,运行提示一个错误Segmentation fault,请教是什么原因导致的,怎么解决?
static volatile unsigned int *CCM_CCGR1 ;
static volatile unsigned int *IOMUXC_SNVS_SW_MUX_CTL_PAD_SNVS_TAMPER3;
static volatile unsigned int *GPIO5_GDIR ;
static volatile unsigned int *GPIO5_DR ;
函数名称: led_init
功能描述: 初始化LED引脚,就是把它设置为输出引脚
输入参数: 无
输出参数: 无
返 回 值: 无
修改日期 版本号 修改人 修改内容
2020/02/07 V1.0 韦东山 创建
void led_init(void)
unsigned int val;CCM_CCGR1 = (volatile unsigned int *)(0x20C406C);
IOMUXC_SNVS_SW_MUX_CTL_PAD_SNVS_TAMPER3 = (volatile unsigned int *)(0x2290014);
GPIO5_GDIR = (volatile unsigned int *)(0x020AC000 + 0x4);
GPIO5_DR = (volatile unsigned int *)(0x020AC000);/* GPIO5_IO03 /
/ a. 使能GPIO5- set CCM to enable GPIO5
- CCM_CCGR1[CG15] 0x20C406C
- bit[31:30] = 0b11
*CCM_CCGR1 |= (3<<30);
/* b. 设置GPIO5_IO03用于GPIO
- set IOMUXC_SNVS_SW_MUX_CTL_PAD_SNVS_TAMPER3
to configure GPIO5_IO03 as GPIO - IOMUXC_SNVS_SW_MUX_CTL_PAD_SNVS_TAMPER3 0x2290014
- bit[3:0] = 0b0101 alt5
val = *IOMUXC_SNVS_SW_MUX_CTL_PAD_SNVS_TAMPER3;
val &= ~(0xf);
val |= (5);
*IOMUXC_SNVS_SW_MUX_CTL_PAD_SNVS_TAMPER3 = val;
/* c. 设置GPIO5_IO03作为output引脚
- set GPIO5_GDIR to configure GPIO5_IO03 as output
- GPIO5_GDIR 0x020AC000 + 0x4
- bit[3] = 0b1
*GPIO5_GDIR |= (1<<3);
- 函数名称: led_ctl
- 功能描述: 设置LED状态
- 输入参数:
on : 1-LED点亮, 0-LED熄灭 - 输出参数: 无
- 返 回 值: 无
- 修改日期 版本号 修改人 修改内容
- 2020/02/07 V1.0 韦东山 创建
void led_ctl(int on)
if (on) / on: output 0/
/ d. 设置GPIO5_DR输出低电平
* set GPIO5_DR to configure GPIO5_IO03 output 0
* GPIO5_DR 0x020AC000 + 0
* bit[3] = 0b0
GPIO5_DR &= ~(1<<3);
else / off: output 1/
/ e. 设置GPIO5_IO3输出高电平
* set GPIO5_DR to configure GPIO5_IO03 output 1
* bit[3] = 0b1
*GPIO5_DR |= (1<<3);
void delay(volatile unsigned int d)
while(d–);
int main()
led_init();
while(1)
led_ctl(1);
delay(1000000);
led_ctl(0);
delay(1000000);
