insmod: can't insert '/lib/modules/4.9.191/videobuf2-core.ko': No such file or directory
我改了一下配置,开启了CONFIG_VIN_LOG=y,然后mkernel pack,或者make pack,怎么都没有这些ko了,难道要clean重新编。
另外V851S用的.config是通过哪个defconfig生成的。
------run rc.final file-----
Load mpp modules
insmod: can’t insert ‘/lib/modules/4.9.191/videobuf2-core.ko’: No such file or directory
insmod: can’t insert ‘/lib/modules/4.9.191/videobuf2-memops.ko’: No such file or directory
insmod: can’t insert ‘/lib/modules/4.9.191/videobuf2-dma-contig.ko’: No such file or directory
insmod: can’t insert ‘/lib/modules/4.9.191/videobuf2-v4l2.ko’: No such file or directory
insmod: can’t insert ‘/lib/modules/4.9.191/vin_io.ko’: No such file or directory
[ 6.739517] init_sensor
insmod: can’t insert ‘/lib/modules/4.9.191/vin_v4l2.ko’: No such file or directory
insmod: can’t insert ‘/lib/modules/4.9.191/sunxi_aio.ko’: No such file or directory
insmod: can’t insert ‘/lib/modules/4.9.191/sunxi_eise.ko’: No such file or directory
insmod: can’t insert ‘/lib/modules/4.9.191/nna_sunxi.ko’: No such file or directory
Starting logging: start-stop-daemon: unrecognized option: exec
OK
mkdir: can’t create directory ‘/dev/pts’: File exists
mkdir: can’t create directory ‘/dev/shm’: File exists
Initializing random number generator… done.
cat: can’t open ‘/sys/class/sunxi_info/sys_info’: No such file or directory
Starting network: Failed to connect to ubus
/sbin/ifup: line 43: /sbin/wifi: not found
FAIL
ifconfig: invalid hw-addr 00:
udhcpc: SIOCGIFINDEX: No such device
Starting telnetd: OK
enable android usb
[ 7.323208] file system registered
[ 7.340897] configfs-gadget 4100000.udc-controller: failed to start g1: -19
Starting wifi_deamon…: /etc/init.d/S50wifideamon: line 8: wifi_deamon: not found
[ 7.405688] read descriptors
[ 7.409150] read strings
Cannot connect to the wifi deamon server: No such file or directory
mount: mounting /dev/mmcblk0p1 on /mnt/extsd failed: No such file or directory
starting pid 955, tty ‘/dev/console’: ‘-/bin/sh’
BusyBox v1.33.2 (2022-07-08 07:13:49 UTC) built-in shell (ash)
------run profile file-----
|_ ||| ___ _ _ | | || ___ _ _ _ _
| | _ | || | | |__ | || || | ||
| | | || | || _ | |_____||
| |||||||_| Tina is Based on OpenWrt!
Tina Linux (5.0, r0-7277fac)
root@TinaLinux:/# ls /lib/modules/4.9.191/
gc2053_mipi.ko xradio_core.ko xradio_mac.ko xradio_wlan.ko
root@TinaLinux:/#
这里我作一下几种推断:
1.您是否有尝试修改回之前的配置项呢
2.通过打印信息我推断出可能是内核驱动没有拷贝到对应开发板上,因为openwrt/target/V851s/v851s-lizard/modulesmk中有定义启动后驱动的安装顺序。
这里冒昧的将您的帖子移动到V851S板块。
