这边按照文档进行编译,移植,启动后出现各种报错。
下面是部分启动日志。
root@TinaLinux:/# reboot
root@TinaLinux:/# /etc/init.d/rcK: line 7: /etc/init.d/S01app: not found
Not defined “stop” functions!!!
Stopping telnetd: FAIL
mkdir: can’t create directory ‘/run/’: Read-only file system
cat: can’t open ‘/sys/class/sunxi_info/sys_info’: No such file or directory
Stopping network: FAIL
stop…
killall: udevd: no process killed
Stopping logging: OK
Unload mpp modules
rmmod: can’t unload module ‘sunxi_eise’: No such file or directory
rmmod: can’t unload module ‘sunxi_aio’: No such file or directory
rmmod: can’t unload module ‘vin_v4l2’: No such file or directory
rmmod: can’t unload module ‘imx386_mipi’: No such file or directory
rmmod: can’t unload module ‘vin_io’: No such file or directory
rmmod: can’t unload module ‘videobuf2_v4l2’: No such file or directory
rmmod: can’t unload module ‘videobuf2_dma_cont[ 26.024214] android_work: sent uevent USB_STATE=DISCONNECTED
ig’: No such file or directory
rmmod: can’t unload module ‘videobuf2_memops’: No such file or directory
rmmod: can’t unload module ‘videobuf2_core’: No such file or directory
can’t run ‘/sbin/swapoff’: No such file or directory
umount: can’t remount adb read-only
umount: devtmpfs busy - remounted read-only
The system is going down NOW!
Sent SIGTERM to all processes
Se[ 28.024492] [ohci1-controller]: ohci shutdown start
[ 28.029993] [ohci1-controller]: ohci shutdown end
[ 28.035243] [ehci1-controller]: ehci shutdown start
[ 28.040698] [ehci1-controller]: ehci shutdown end
[ 28.045938] sunxi_ohci_hcd_shutdown, ohci0-controller is disable, need not sh utdown
[ 28.054468] sunxi_ehci_hcd_shutdown, ehci0-controller is disable, need not sh utdown
[ 28.077944] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 w idth 1 timing LEGACY(SDR12) dt B
[ 28.868374] reboot: Restarting system
[19]HELLO! BOOT0 is starting!
[22]BOOT0 commit : 88480af-dirty
[25]set pll start
[31]periph0 has been enabled
[34]set pll end
[35][pmu]: bus read error
[38]board init ok
[40]ZQ value = 0x31
[42]get_pmu_exist() = -1
[44]ddr_efuse_type: 0xa
[46]trefi:7.8ms
[49][AUTO DEBUG] single rank and full DQ!
[53]ddr_efuse_type: 0xa
[55]trefi:7.8ms
[57][AUTO DEBUG] rank 0 row = 13
[61][AUTO DEBUG] rank 0 bank = 8
[64][AUTO DEBUG] rank 0 page size = 2 KB
[68]DRAM BOOT DRIVE INFO: V0.33
[71]DRAM CLK = 936 MHz
[73]DRAM Type = 3 (2:DDR2,3:DDR3)
[76]DRAMC read ODT off.
[78]DRAM ODT value: 0x42.
[81]ddr_efuse_type: 0xa
[84]DRAM SIZE =128 M
[86]dram_tpr4:0x0
[88]PLL_DDR_CTRL_REG:0xf8004d00
[91]DRAM_CLK_REG:0xc0000000
[93][TIMING DEBUG] MR2= 0x20
[101]DRAM simple test OK.
[103]rtc standby flag is 0x0, super standby flag is 0x0
[108]dram size =128
[111]card no is 0
[113]sdcard 0 line count 4
[115][mmc]: mmc driver ver 2021-05-21 14:47
[125][mmc]: Wrong media type 0x0
[128][mmc]: Try SD card 0
[136][mmc]: HSSDR52/SDR25 4 bit
[139][mmc]: 50000000 Hz
[141][mmc]: 29580 MB
[143][mmc]: SD/MMC 0 init OK!!!
[215]Loading boot-pkg Succeed(index=0).
[219]Entry_name = u-boot
[224]Entry_name = optee
[228]Entry_name = dtb
[231]mmc not para
[233]Jump to second Boot.
M/TC: OP-TEE version: 6aef7bb2-dirty (gcc version 5.3.1 20160412 (Linaro GCC 5.3 -2016.05)) #1 Fri Jul 23 09:25:11 UTC 2021 arm
U-Boot 2018.05-g24521d6-dirty (Aug 04 2023 - 05:02:49 -0400) Allwinner Technolog y
[00.286]CPU: Allwinner Family
[00.289]Model: sun8iw20
I2C: FDT ERROR:fdt_set_all_pin:[twi0]–>FDT_ERR_BADPATH
FDT ERROR:fdt_set_all_pin:[twi1]–>FDT_ERR_BADPATH
ready
[00.310]DRAM: 128 MiB
[00.314]Relocation Offset is: 04f01000
[00.333]secure enable bit: 0
[00.335]smc_tee_inform_fdt failed with: -65526[00.340]CPU=1008 MHz,PLL6=600 Mhz, AHB=200 Mhz, APB1=100Mhz MBus=300Mhz
[00.347]gic: sec monitor mode
[00.349]flash init start
[00.351]workmode = 0,storage type = 1
[00.355][mmc]: mmc driver ver uboot2018:2021-11-19 15:38:00
[00.360][mmc]: get sdc_type fail and use default host:tm1.
[00.366][mmc]: can’t find node “mmc0”,will add new node
[00.371][mmc]: fdt err returned
[00.375][mmc]: Using default timing para
[00.379][mmc]: SUNXI SDMMC Controller Version:0x50310
[00.396][mmc]: card_caps:0x3000000a
[00.399][mmc]: host_caps:0x3000003f
[00.403]sunxi flash init ok
[00.410]Loading Environment from SUNXI_FLASH… OK
[00.441]Item0 (Map) magic is bad
[00.444]the secure storage item0 copy0 magic is bad
[00.460]Item0 (Map) magic is bad
[00.463]the secure storage item0 copy1 magic is bad
[00.467]Item0 (Map) magic is bad
[00.473]secure storage read widevine fail with:-1
[00.481]secure storage read ec_key fail with:-1
[00.488]secure storage read ec_cert1 fail with:-1
[00.495]secure storage read ec_cert2 fail with:-1
[00.503]secure storage read ec_cert3 fail with:-1
[00.510]secure storage read rsa_key fail with:-1
[00.518]secure storage read rsa_cert1 fail with:-1
[00.525]secure storage read rsa_cert2 fail with:-1
[00.533]secure storage read rsa_cert3 fail with:-1
[00.537]usb burn from boot
delay time 0
weak:otg_phy_config
[00.549]usb prepare ok
[00.717]usb sof ok
[00.719]usb probe ok
[00.721]usb setup ok
set address 0x8
set address 0x8 ok
[03.726]do_burn_from_boot usb : have no handshake
root_partition is rootfs
set root to /dev/mmcblk0p5
[03.736]update part info
[03.739]update bootcmd
[03.741]change working_fdt 0x43ec0e70 to 0x43ea0e70
disable nand error: FDT_ERR_BADPATH
[03.763]update dts
[04.932]no vendor_boot partition is found
Android’s image name: t113-100ask
[04.943]Starting kernel …
[04.945][mmc]: MMC Device 2 not found
[04.949][mmc]: mmc 2 not find, so not exit
[ 0.000000] Linux version 5.4.61 (book@100ask) (arm-openwrt-linux-muslgnueabi -gcc.bin (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) 6.4.1, GNU ld (GNU Binutils) 2 .27) #5 SMP PREEMPT Sat Aug 5 01:14:13 UTC 2023
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructio n cache
[ 0.000000] cma: Reserved 8 MiB at 0x47800000
[ 0.000000] percpu: Embedded 15 pages/cpu s30348 r8192 d22900 u61440
[ 0.000000] pcpu-alloc: s30348 r8192 d22900 u61440 alloc=15*4096
[ 0.000000] Kernel command line: earlyprintk=sunxi-uart,0x02500C00 clk_ignore unused initcall_debug=0 console=ttyS3,115200 loglevel=8 root=/dev/mmcblk0p5 ini t=/pseudo_init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcbl k0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:private@mmcblk0p6:rootfs_data@mmcblk0p7:UDI SK@mmcblk0p8 cma=8M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidb oot.mode=normal androidboot.hardware=sun8iw20p1 boot_type=1 androidboot.boot_typ e=1 gpt=1 uboot_message=2018.05-g24521d6-dirty(08/04/2023-05:02:49) androidboot. dramsize=128
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes, li near)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes, line ar)
[ 0.000000] Memory: 108612K/131072K available (6144K kernel code, 264K rwdata , 1504K rodata, 1024K init, 1164K bss, 14268K reserved, 8192K cma-reserved)
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jif fies.
[ 0.000000] random: get_random_bytes called from start_kernel+0x264/0x3e8 wit h crng_init=0
[ 0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 43980 46511097ns
[ 0.008007] Switching to timer-based delay loop, resolution 41ns
[ 0.014183] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max idle_ns: 79635851949 ns
[ 0.023868] Calibrating delay loop (skipped), value calculated using timer fr equency… 48.00 BogoMIPS (lpj=240000)
[ 0.034233] pid_max: default: 32768 minimum: 301
[ 0.038958] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linea r)
[ 0.046272] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.054583] CPU: Testing write buffer coherency: ok
[ 0.059793] /cpus/cpu@0 missing clock-frequency property
[ 0.065126] /cpus/cpu@1 missing clock-frequency property
[ 0.070473] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.076617] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.083268] rcu: Hierarchical SRCU implementation.
[ 0.088477] smp: Bringing up secondary CPUs …
[ 0.094089] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.094207] smp: Brought up 1 node, 2 CPUs
[ 0.104011] SMP: Total of 2 processors activated (96.00 BogoMIPS).
[ 0.110188] CPU: All CPU(s) started in SVC mode.
[ 0.115263] devtmpfs: initialized
[ 0.129501] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.137624] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma x_idle_ns: 19112604462750000 ns
[ 0.147479] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.154710] pinctrl core: initialized pinctrl subsystem
[ 0.160862] NET: Registered protocol family 16
[ 0.166709] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.202146] rtc_ccu: sunxi ccu init OK
[ 0.208015] ccu: sunxi ccu init OK
[ 0.211758] r_ccu: sunxi ccu init OK
[ 0.236354] iommu: Default domain type: Translated
[ 0.241432] sunxi iommu: irq = 24
[ 0.245615] SCSI subsystem initialized
[ 0.249589] usbcore: registered new interface driver usbfs
[ 0.255177] usbcore: registered new interface driver hub
[ 0.260576] usbcore: registered new device driver usb
[ 0.266620] Advanced Linux Sound Architecture Driver Initialized.
[ 0.273214] Bluetooth: Core ver 2.22
[ 0.276909] NET: Registered protocol family 31
[ 0.281355] Bluetooth: HCI device and connection manager initialized
[ 0.287737] Bluetooth: HCI socket layer initialized
[ 0.292628] Bluetooth: L2CAP socket layer initialized
[ 0.297702] Bluetooth: SCO socket layer initialized
[ 0.302837] pwm module init!
[ 0.306871] g2d 5410000.g2d: Adding to iommu group 0
[ 0.312147] G2D: rcq version initialized.major:252
[ 0.317722] clocksource: Switched to clocksource arch_sys_counter
[ 0.332199] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
[ 0.341449] NET: Registered protocol family 2
[ 0.346356] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.354777] TCP established hash table entries: 1024 (order: 0, 4096 bytes, l inear)
[ 0.362457] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 0.369518] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.375969] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.382540] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.389726] NET: Registered protocol family 1
[ 0.395030] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc n ot found, using dummy regulator
[ 0.405303] spi spi0: spi0 supply spi not found, using dummy regulator
[ 0.412027] sunxi_spi_resource_get()2151 - [spi0] SPI MASTER MODE
[ 0.418165] sunxi_spi_resource_get()2189 - Failed to get sample mode
[ 0.424510] sunxi_spi_resource_get()2194 - Failed to get sample delay
[ 0.430956] sunxi_spi_resource_get()2198 - sample_mode:-1431633921 sample_del ay:-1431633921
[ 0.439381] sunxi_spi_clk_init()2240 - [spi0] mclk 100000000
[ 0.445596] sunxi_spi_probe()2653 - [spi0]: driver probe succeed, base c881f0 00, irq 42
[ 0.455150] workingset: timestamp_bits=30 max_order=15 bucket_order=0
[ 0.465746] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.471781] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.505658] io scheduler mq-deadline registered
[ 0.510214] io scheduler kyber registered
[ 0.515457] [DISP]disp_module_init
[ 0.519370] disp 5000000.disp: Adding to iommu group 0
[ 0.536059] disp 5000000.disp: 5000000.disp supply vcc-lcd not found, using d ummy regulator
[ 0.544638] disp 5000000.disp: 5000000.disp supply vcc-pd not found, using du mmy regulator
[ 0.558231] display_fb_request,fb_id:0
[ 0.565510] [DISP] Fb_copy_boot_fb,line:1443:
[ 0.565514] no boot_fb0
[ 0.572800] disp_al_manager_apply ouput_type:0
[ 0.577866] [DISP]disp_module_init finish
[ 0.582649] [DISP] lcd_clk_config,line:732:
[ 0.582662] disp 0, clk: pll(306000000),clk(306000000),dclk(51000000) dsi_rat e(306000000)
[ 0.582662] clk real:pll(300000000),clk(300000000),dclk(50000000) dsi_ra te(0)
[ 0.582905] sunxi_sid_init()551 - insmod ok
[ 0.587677] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd n ot found, using dummy regulator
[ 0.603675] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg n ot found, using dummy regulator
[ 0.626852] uart uart1: get regulator failed
[ 0.631156] uart uart1: uart1 supply uart not found, using dummy regulator
[ 0.638279] uart1: ttyS1 at MMIO 0x2500400 (irq = 34, base_baud = 1500000) is a SUNXI
[ 0.646654] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb n ot found, using dummy regulator
[ 0.656793] uart uart3: get regulator failed
[ 0.661095] uart uart3: uart3 supply uart not found, using dummy regulator
[ 0.668229] uart3: ttyS3 at MMIO 0x2500c00 (irq = 35, base_baud = 1500000) is a SUNXI
[ 0.676069] sw_console_setup()1808 - console setup baud 115200 parity n bits 8, flow n
▒[ 0.684061] printk: console [ttyS3] enabled
[ 0.692996] printk: bootconsole [earlycon0] disabled
[ 0.704325] misc dump reg init
[ 0.708688] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
[ 0.715968] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
[ 0.723340] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
[ 0.730782] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
[ 0.737335] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
[ 0.744293] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
[ 0.752059] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=204 assert=1
[ 0.759924] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert= 1
[ 0.768062] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
[ 0.775685] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
[ 0.782462] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
[ 0.790022] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=207 assert=0
[ 0.798195] dma-buf: Running sanitycheck
[ 0.802615] dma-buf: Running dma_fence
[ 0.806815] sizeof(dma_fence)=48
[ 0.810582] dma-buf: Running dma_fence/sanitycheck
[ 0.815969] dma-buf: Running dma_fence/test_signaling
[ 0.817904] [DISP] disp_device_attached_and_enable,line:233:
[ 0.817909] attached ok, mgr0<–>dev0
[ 0.821670] dma-buf: Running dma_fence/test_add_callback
[ 0.827991] [DISP] disp_device_attached_and_enable,line:236:
[ 0.828002] type:1,mode:0,fmt:rgb,bits:8bits,eotf:4,cs:0 dvi_hdmi:2, range:2 scan:0 ratio:8
[ 0.832122] dma-buf: Running dma_fence/test_late_add_callback
[ 0.860247] dma-buf: Running dma_fence/test_rm_callback
[ 0.866107] dma-buf: Running dma_fence/test_late_rm_callback
[ 0.872473] dma-buf: Running dma_fence/test_status
[ 0.877856] dma-buf: Running dma_fence/test_error
[ 0.883130] dma-buf: Running dma_fence/test_wait
[ 0.888326] dma-buf: Running dma_fence/test_wait_timeout
[ 0.927735] dma-buf: Running dma_fence/test_stub
[ 0.932931] dma-buf: Running dma_fence/race_signal_callback
[ 1.007734] thread_signal_callback[0] completed 36848 passes, 70 misses
[ 1.015184] thread_signal_callback[1] completed 36844 passes, 67 misses
[ 1.087740] thread_signal_callback[0] completed 40206 passes, 40205 misses
[ 1.095482] thread_signal_callback[1] completed 40212 passes, 40211 misses
[ 1.103699] sunxi-spinand: AW SPINand MTD Layer Version: 2.0 20201228
[ 1.110982] sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.10 20200306
[ 1.118979] sunxi-spinand-phy: not detect any munufacture from id table
[ 1.126402] sunxi-spinand-phy: get spi-nand Model from fdt fail
[ 1.133067] sunxi-spinand-phy: get phy info from fdt fail
[ 1.139129] sunxi-spinand-phy: not detect munufacture from fdt
[ 1.145839] sunxi-spinand-phy: detect munufacture from id table: Mxic
[ 1.153084] sunxi-spinand-phy: detect spinand id: ffff12c2 ffffffff
[ 1.160167] sunxi-spinand-phy: ========== arch info ==========
[ 1.166707] sunxi-spinand-phy: Model: MX35LF1GE4AB
[ 1.173477] sunxi-spinand-phy: Munufacture: Mxic
[ 1.179446] sunxi-spinand-phy: DieCntPerChip: 1
[ 1.185108] sunxi-spinand-phy: BlkCntPerDie: 1024
[ 1.191079] sunxi-spinand-phy: PageCntPerBlk: 64
[ 1.196838] sunxi-spinand-phy: SectCntPerPage: 4
[ 1.202511] sunxi-spinand-phy: OobSizePerPage: 64
[ 1.208279] sunxi-spinand-phy: BadBlockFlag: 0x1
[ 1.214135] sunxi-spinand-phy: OperationOpt: 0x7
[ 1.220001] sunxi-spinand-phy: MaxEraseTimes: 65000
[ 1.226052] sunxi-spinand-phy: EccFlag: 0x2
[ 1.231916] sunxi-spinand-phy: EccType: 4
[ 1.237577] sunxi-spinand-phy: EccProtectedType: 3
[ 1.243248] sunxi-spinand-phy: ========================================
[ 1.250671] sunxi-spinand-phy:
[ 1.254188] sunxi-spinand-phy: ========== physical info ==========
[ 1.261124] sunxi-spinand-phy: TotalSize: 128 M
[ 1.266493] sunxi-spinand-phy: SectorSize: 512 B
[ 1.271869] sunxi-spinand-phy: PageSize: 2 K
[ 1.277043] sunxi-spinand-phy: BlockSize: 128 K
[ 1.282419] sunxi-spinand-phy: OOBSize: 64 B
[ 1.287691] sunxi-spinand-phy: ========================================
[ 1.295121] sunxi-spinand-phy:
[ 1.298654] sunxi-spinand-phy: ========== logical info ==========
[ 1.305485] sunxi-spinand-phy: TotalSize: 128 M
[ 1.310866] sunxi-spinand-phy: SectorSize: 512 B
[ 1.316235] sunxi-spinand-phy: PageSize: 4 K
[ 1.321419] sunxi-spinand-phy: BlockSize: 256 K
[ 1.326788] sunxi-spinand-phy: OOBSize: 128 B
[ 1.332164] sunxi-spinand-phy: ========================================
[ 1.339732] sunxi-spinand-phy: block lock register: 0x00
[ 1.345881] sunxi-spinand-phy: feature register: 0x11
[ 1.351564] sunxi-spinand-phy: sunxi physic nand init end
[ 1.358080] Creating 4 MTD partitions on “sunxi_mtd_nand”:
[ 1.364241] 0x000000000000-0x000000100000 : “boot0”
[ 1.378651] 0x000000100000-0x000000500000 : “uboot”
[ 1.386774] random: fast init done
[ 1.408605] 0x000000500000-0x000000600000 : “secure_storage”
[ 1.428558] 0x000000600000-0x000008000000 : “sys”
[ 1.708206] sunxi-spinand-phy: phy blk 739 is bad
[ 1.795973] random: crng init done
[ 1.848989] libphy: Fixed MDIO Bus: probed
[ 1.854420] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe n ot found, using dummy regulator
[ 1.865753] sunxi gmac driver’s version: 1.0.0
[ 1.870918] gmac-power0: NULL
[ 1.874246] gmac-power1: NULL
[ 1.877585] gmac-power2: NULL
[ 1.881981] Failed to alloc md5
[ 1.885511] eth0: Use random mac address
[ 1.890183] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.897530] sunxi-ehci: EHCI SUNXI driver
[ 1.902368] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.909339] sunxi-ohci: OHCI SUNXI driver
[ 1.914269] i2c /dev entries driver
[ 1.918284] sunxi cedar version 1.1
[ 1.922347] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
[ 1.928680] VE: sunxi_cedar_probe power-domain init!!!
[ 1.934446] VE: install start!!!
[ 1.934446]
[ 1.939956] VE: cedar-ve the get irq is 43
[ 1.939956]
[ 1.946415] VE: ve_debug_proc_info:8f20a642, data:6b2c42d9, lock:60b3ded7
[ 1.946415]
[ 1.955711] VE: install end!!!
[ 1.955711]
[ 1.960798] VE: sunxi_cedar_probe
[ 1.964756] Bluetooth: HCI UART driver ver 2.3
[ 1.969766] Bluetooth: HCI UART protocol H4 registered
[ 1.975527] Bluetooth: HCI UART protocol BCSP registered
[ 1.981525] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 1.0.10
[ 1.988707] [XR_BT_LPM] bluesleep_probe: bt_wake polarity: 1
[ 1.995132] [XR_BT_LPM] bluesleep_probe: host_wake polarity: 1
[ 2.001703] [XR_BT_LPM] bluesleep_probe: wakeup source is disabled!
[ 2.001703]
[ 2.010400] [XR_BT_LPM] bluesleep_probe: uart_index(1)
[ 2.018204] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-11-18 10:02)
[ 2.028168] sunxi-mmc 4020000.sdmmc: ctl-spec-caps 8
[ 2.034384] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
[ 2.040749] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
[ 2.047203] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
[ 2.053656] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
[ 2.060206] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
[ 2.066754] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
[ 2.073305] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
[ 2.080275] sunxi-mmc 4020000.sdmmc: Got CD GPIO
