[23]HELLO! BOOT0 is starting!
[26]BOOT0 commit : 88480af-dirty
[29]set pll start
[35]periph0 has been enabled
[38]set pll end
[39][pmu]: bus read error
[42]board init ok
[44]ZQ value = 0x31
[45]get_pmu_exist() = -1
[48]ddr_efuse_type: 0xa
[50]trefi:7.8ms
[53][AUTO DEBUG] single rank and full DQ!
[57]ddr_efuse_type: 0xa
[59]trefi:7.8ms
[61][AUTO DEBUG] rank 0 row = 13
[64][AUTO DEBUG] rank 0 bank = 8
[68][AUTO DEBUG] rank 0 page size = 2 KB
[71]DRAM BOOT DRIVE INFO: V0.33
[74]DRAM CLK = 936 MHz
[77]DRAM Type = 3 (2:DDR2,3:DDR3)
[80]DRAMC read ODT off.
[82]DRAM ODT value: 0x42.
[85]ddr_efuse_type: 0xa
[88]DRAM SIZE =128 M
[90]dram_tpr4:0x0
[91]PLL_DDR_CTRL_REG:0xf8004d00
[94]DRAM_CLK_REG:0xc0000000
[97][TIMING DEBUG] MR2= 0x20
[105]DRAM simple test OK.
[107]rtc standby flag is 0x0, super standby flag is 0x0
[112]dram size =128
[115]card no is 0
[116]sdcard 0 line count 4
[119][mmc]: mmc driver ver 2021-05-21 14:47
[128][mmc]: Wrong media type 0x0
[131][mmc]: Try SD card 0
[141][mmc]: HSSDR52/SDR25 4 bit
[144][mmc]: 50000000 Hz
[147][mmc]: 7680 MB
[148][mmc]: SD/MMC 0 init OK!!!
[230]Loading boot-pkg Succeed(index=0).
[233]Entry_name = u-boot
[239]Entry_name = optee
[243]Entry_name = dtb
[246]mmc not para
[247]Jump to second Boot.
U-Boot 2018.05-g24521d6-dirty (Aug 04 2023 - 10:12:10 -0400) Allwinner Technology
[00.301]CPU: Allwinner Family
[00.304]Model: sun8iw20
I2C: FDT ERROR:fdt_set_all_pin:[twi0]–>FDT_ERR_BADPATH
FDT ERROR:fdt_set_all_pin:[twi1]–>FDT_ERR_BADPATH
ready
[00.325]DRAM: 128 MiB
[00.328]Relocation Offset is: 04f01000
[00.347]secure enable bit: 0
[00.350]smc_tee_inform_fdt failed with: -65526[00.355]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=300Mhz
[00.361]gic: sec monitor mode
[00.364]flash init start
[00.366]workmode = 0,storage type = 1
[00.369][mmc]: mmc driver ver uboot2018:2021-11-19 15:38:00
[00.375][mmc]: get sdc_type fail and use default host:tm1.
[00.381][mmc]: can’t find node “mmc0”,will add new node
[00.386][mmc]: fdt err returned
[00.389][mmc]: Using default timing para
[00.418]sunxi flash init ok
[00.447]Loading Environment from SUNXI_FLASH… OK
[00.481]Item0 (Map) magic is bad
[00.484]the secure storage item0 copy0 magic is bad
[00.500]Item0 (Map) magic is bad
[00.503]the secure storage item0 copy1 magic is bad
[00.507]Item0 (Map) magic is bad
[00.513]secure storage read widevine fail with:-1
[00.521]secure storage read ec_key fail with:-1
[00.528]secure storage read ec_cert1 fail with:-1
[00.535]secure storage read ec_cert2 fail with:-1
[00.543]secure storage read ec_cert3 fail with:-1
[00.550]secure storage read rsa_key fail with:-1
[00.558]secure storage read rsa_cert1 fail with:-1
[00.565]secure storage read rsa_cert2 fail with:-1
[00.573]secure storage read rsa_cert3 fail with:-1
[00.578]usb burn from boot
delay time 0
weak:otg_phy_config
[00.589]usb prepare ok
[00.796]usb sof ok
[00.797]usb probe ok
[00.799]usb setup ok
set address 0xc
set address 0xc ok
[03.804]do_burn_from_boot usb : have no handshake
root_partition is rootfs
set root to /dev/mmcblk0p5
[03.817]update part info
[03.822]update bootcmd
[03.828]change working_fdt 0x43ec0e70 to 0x43ea0e70
disable nand error: FDT_ERR_BADPATH
[03.849]update dts
[05.056]no vendor_boot partition is found
Android’s image name: t113-100ask
[05.067]Starting kernel …
[05.069][mmc]: MMC Device 2 not found
[05.073][mmc]: mmc 2 not find, so not exit
[ 0.000000] Linux version 5.4.61 (book@100ask) (arm-openwrt-linux-muslgnueabi-gcc.bin (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) 6.4.1, GNU ld (GNU Binutils) 2.27) #9 SMP PREEMPT Fri Aug 4 15:25:31 UTC 2023
[ 0.000000] cma: Reserved 8 MiB at 0x47800000
[ 0.000000] percpu: Embedded 15 pages/cpu s30348 r8192 d22900 u61440
[ 0.000000] pcpu-alloc: s30348 r8192 d22900 u61440 alloc=15*4096
[ 0.000000] Kernel command line: earlyprintk=sunxi-uart,0x02500C00 clk_ignore_unused initcall_debug=0 console=ttyS3,115200 loglevel=8 root=/dev/mmcblk0p5 init=/pseudo_init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:private@mmcblk0p6:rootfs_data@mmcblk0p7:UDISK@mmcblk0p8 cma=8M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.mode=normal androidboot.hardware=sun8iw20p1 boot_type=1 androidboot.boot_type=1 gpt=1 uboot_message=2018.05-g24521d6-dirty(08/04/2023-10:12:10) androidboot.dramsize=128
[ 0.000000] Memory: 108612K/131072K available (6144K kernel code, 264K rwdata, 1504K rodata, 1024K init, 1164K bss, 14268K reserved, 8192K cma-reserved)
[ 0.000000] random: get_random_bytes called from start_kernel+0x264/0x3e8 with crng_init=0
[ 0.007998] Switching to timer-based delay loop, resolution 41ns
[ 0.014157] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.023869] Calibrating delay loop (skipped), value calculated using timer frequency… 48.00 BogoMIPS (lpj=240000)
[ 0.034233] pid_max: default: 32768 minimum: 301
[ 0.038958] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.046289] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.054614] CPU: Testing write buffer coherency: ok
[ 0.059831] /cpus/cpu@0 missing clock-frequency property
[ 0.065146] /cpus/cpu@1 missing clock-frequency property
[ 0.070493] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.076643] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.083308] rcu: Hierarchical SRCU implementation.
[ 0.088519] smp: Bringing up secondary CPUs …
[ 0.104153] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.104265] smp: Brought up 1 node, 2 CPUs
[ 0.114048] SMP: Total of 2 processors activated (96.00 BogoMIPS).
[ 0.120226] CPU: All CPU(s) started in SVC mode.
[ 0.125282] devtmpfs: initialized
[ 0.139511] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.147618] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.157472] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.164722] pinctrl core: initialized pinctrl subsystem
[ 0.170889] NET: Registered protocol family 16
[ 0.176745] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.212197] rtc_ccu: sunxi ccu init OK
[ 0.218073] ccu: sunxi ccu init OK
[ 0.221794] r_ccu: sunxi ccu init OK
[ 0.246354] iommu: Default domain type: Translated
[ 0.251429] sunxi iommu: irq = 24
[ 0.255618] SCSI subsystem initialized
[ 0.259587] usbcore: registered new interface driver usbfs
[ 0.265174] usbcore: registered new interface driver hub
[ 0.270556] usbcore: registered new device driver usb
[ 0.276404] Advanced Linux Sound Architecture Driver Initialized.
[ 0.283027] Bluetooth: Core ver 2.22
[ 0.286700] NET: Registered protocol family 31
[ 0.291155] Bluetooth: HCI device and connection manager initialized
[ 0.297552] Bluetooth: HCI socket layer initialized
[ 0.302442] Bluetooth: L2CAP socket layer initialized
[ 0.307510] Bluetooth: SCO socket layer initialized
[ 0.312606] pwm module init!
[ 0.316634] g2d 5410000.g2d: Adding to iommu group 0
[ 0.321903] G2D: rcq version initialized.major:252
[ 0.327469] clocksource: Switched to clocksource arch_sys_counter
[ 0.341855] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
[ 0.351124] NET: Registered protocol family 2
[ 0.356034] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.364476] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.372174] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 0.379270] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.385726] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.392306] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.399512] NET: Registered protocol family 1
[ 0.404817] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
[ 0.415105] spi spi0: spi0 supply spi not found, using dummy regulator
[ 0.421839] sunxi_spi_resource_get()2151 - [spi0] SPI MASTER MODE
[ 0.427988] sunxi_spi_resource_get()2189 - Failed to get sample mode
[ 0.434332] sunxi_spi_resource_get()2194 - Failed to get sample delay
[ 0.440796] sunxi_spi_resource_get()2198 - sample_mode:-1431633921 sample_delay:-1431633921
[ 0.449229] sunxi_spi_clk_init()2240 - [spi0] mclk 100000000
[ 0.455429] sunxi_spi_probe()2653 - [spi0]: driver probe succeed, base c881f000, irq 42
[ 0.464990] workingset: timestamp_bits=30 max_order=15 bucket_order=0
[ 0.475582] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.481621] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.515965] io scheduler mq-deadline registered
[ 0.520535] io scheduler kyber registered
[ 0.525812] [DISP]disp_module_init
[ 0.529719] disp 5000000.disp: Adding to iommu group 0
[ 0.546390] disp 5000000.disp: 5000000.disp supply vcc-lcd not found, using dummy regulator
[ 0.554974] disp 5000000.disp: 5000000.disp supply vcc-pd not found, using dummy regulator
[ 0.568576] display_fb_request,fb_id:0
[ 0.575890] [DISP] Fb_copy_boot_fb,line:1443:
[ 0.575894] no boot_fb0
[ 0.583196] disp_al_manager_apply ouput_type:0
[ 0.587780] [DISP]disp_module_init finish
[ 0.588131] [DISP] lcd_clk_config,line:732:
[ 0.588142] disp 0, clk: pll(306000000),clk(306000000),dclk(51000000) dsi_rate(306000000)
[ 0.588142] clk real:pll(300000000),clk(300000000),dclk(50000000) dsi_rate(0)
[ 0.592743] sunxi_sid_init()551 - insmod ok
[ 0.596840] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
[ 0.612831] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
[ 0.636007] uart uart1: get regulator failed
[ 0.640325] uart uart1: uart1 supply uart not found, using dummy regulator
[ 0.647440] uart1: ttyS1 at MMIO 0x2500400 (irq = 34, base_baud = 1500000) is a SUNXI
[ 0.655839] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
[ 0.665971] uart uart3: get regulator failed
[ 0.670273] uart uart3: uart3 supply uart not found, using dummy regulator
[ 0.677409] uart3: ttyS3 at MMIO 0x2500c00 (irq = 35, base_baud = 1500000) is a SUNXI
[ 0.685286] sw_console_setup()1808 - console setup baud 115200 parity n bits 8, flow n
[ 0.693278] printk: console [ttyS3] enabled
[ 0.702183] printk: bootconsole [earlycon0] disabled
[ 0.713496] misc dump reg init
[ 0.717880] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
[ 0.725081] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
[ 0.732399] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
[ 0.739797] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
[ 0.746295] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
[ 0.753207] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
[ 0.760915] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=204 assert=1
[ 0.768722] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
[ 0.776780] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
[ 0.784379] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
[ 0.791113] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
[ 0.798620] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=207 assert=0
[ 0.806702] dma-buf: Running sanitycheck
[ 0.811101] dma-buf: Running dma_fence
[ 0.815274] sizeof(dma_fence)=48
[ 0.817660] [DISP] disp_device_attached_and_enable,line:233:
[ 0.817665] attached ok, mgr0<–>dev0
[ 0.819027] dma-buf: Running dma_fence/sanitycheck
[ 0.825157] [DISP] disp_device_attached_and_enable,line:236:
[ 0.825165] type:1,mode:0,fmt:rgb,bits:8bits,eotf:4,cs:0 dvi_hdmi:2, range:2 scan:0 ratio:8
[ 0.829258] dma-buf: Running dma_fence/test_signaling
[ 0.829265] dma-buf: Running dma_fence/test_add_callback
[ 0.861791] dma-buf: Running dma_fence/test_late_add_callback
[ 0.868205] dma-buf: Running dma_fence/test_rm_callback
[ 0.874024] dma-buf: Running dma_fence/test_late_rm_callback
[ 0.880339] dma-buf: Running dma_fence/test_status
[ 0.885672] dma-buf: Running dma_fence/test_error
[ 0.890923] dma-buf: Running dma_fence/test_wait
[ 0.896069] dma-buf: Running dma_fence/test_wait_timeout
[ 0.937480] dma-buf: Running dma_fence/test_stub
[ 0.942647] dma-buf: Running dma_fence/race_signal_callback
[ 1.017499] thread_signal_callback[0] completed 36265 passes, 65 misses
[ 1.024887] thread_signal_callback[1] completed 36297 passes, 97 misses
[ 1.097488] thread_signal_callback[0] completed 40481 passes, 40480 misses
[ 1.105181] thread_signal_callback[1] completed 40467 passes, 40465 misses
[ 1.113356] sunxi-spinand: AW SPINand MTD Layer Version: 2.0 20201228
[ 1.120653] sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.10 20200306
[ 1.128585] sunxi-spinand-phy: not detect any munufacture from id table
[ 1.135975] sunxi-spinand-phy: get spi-nand Model from fdt fail
[ 1.142595] sunxi-spinand-phy: get phy info from fdt fail
[ 1.148671] sunxi-spinand-phy: not detect munufacture from fdt
[ 1.155334] sunxi-spinand-phy: detect munufacture from id table: Mxic
[ 1.162569] sunxi-spinand-phy: detect spinand id: ffff12c2 ffffffff
[ 1.169572] sunxi-spinand-phy: ========== arch info ==========
[ 1.176061] sunxi-spinand-phy: Model: MX35LF1GE4AB
[ 1.182764] sunxi-spinand-phy: Munufacture: Mxic
[ 1.188694] sunxi-spinand-phy: DieCntPerChip: 1
[ 1.194318] sunxi-spinand-phy: BlkCntPerDie: 1024
[ 1.200245] sunxi-spinand-phy: PageCntPerBlk: 64
[ 1.205973] sunxi-spinand-phy: SectCntPerPage: 4
[ 1.211610] sunxi-spinand-phy: OobSizePerPage: 64
[ 1.217334] sunxi-spinand-phy: BadBlockFlag: 0x1
[ 1.223170] sunxi-spinand-phy: OperationOpt: 0x7
[ 1.228996] sunxi-spinand-phy: MaxEraseTimes: 65000
[ 1.235009] sunxi-spinand-phy: EccFlag: 0x2
[ 1.240840] sunxi-spinand-phy: EccType: 4
[ 1.246465] sunxi-spinand-phy: EccProtectedType: 3
[ 1.252104] sunxi-spinand-phy: ========================================
[ 1.259490] sunxi-spinand-phy:
[ 1.262981] sunxi-spinand-phy: ========== physical info ==========
[ 1.269880] sunxi-spinand-phy: TotalSize: 128 M
[ 1.275221] sunxi-spinand-phy: SectorSize: 512 B
[ 1.280563] sunxi-spinand-phy: PageSize: 2 K
[ 1.285703] sunxi-spinand-phy: BlockSize: 128 K
[ 1.291066] sunxi-spinand-phy: OOBSize: 64 B
[ 1.296302] sunxi-spinand-phy: ========================================
[ 1.303690] sunxi-spinand-phy:
[ 1.307194] sunxi-spinand-phy: ========== logical info ==========
[ 1.314000] sunxi-spinand-phy: TotalSize: 128 M
[ 1.319345] sunxi-spinand-phy: SectorSize: 512 B
[ 1.324690] sunxi-spinand-phy: PageSize: 4 K
[ 1.329843] sunxi-spinand-phy: BlockSize: 256 K
[ 1.335184] sunxi-spinand-phy: OOBSize: 128 B
[ 1.340532] sunxi-spinand-phy: ========================================
[ 1.348013] sunxi-spinand-phy: block lock register: 0x00
[ 1.354069] sunxi-spinand-phy: feature register: 0x11
[ 1.359727] sunxi-spinand-phy: sunxi physic nand init end
[ 1.366165] Creating 4 MTD partitions on “sunxi_mtd_nand”:
[ 1.372306] 0x000000000000-0x000000100000 : “boot0”
[ 1.388376] 0x000000100000-0x000000500000 : “uboot”
[ 1.396531] random: fast init done
[ 1.428337] 0x000000500000-0x000000600000 : “secure_storage”
[ 1.448328] 0x000000600000-0x000008000000 : “sys”
[ 1.912375] random: crng init done
[ 1.958781] libphy: Fixed MDIO Bus: probed
[ 1.964173] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
[ 1.975411] sunxi gmac driver’s version: 1.0.0
[ 1.980561] gmac-power0: NULL
[ 1.983861] gmac-power1: NULL
[ 1.987169] gmac-power2: NULL
[ 1.991562] Failed to alloc md5
[ 1.995067] eth0: Use random mac address
[ 1.999720] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 2.007018] sunxi-ehci: EHCI SUNXI driver
[ 2.011829] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 2.018777] sunxi-ohci: OHCI SUNXI driver
[ 2.023688] i2c /dev entries driver
[ 2.027676] sunxi cedar version 1.1
[ 2.031715] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
[ 2.037980] VE: sunxi_cedar_probe power-domain init!!!
[ 2.043729] VE: install start!!!
[ 2.043729]
[ 2.049207] VE: cedar-ve the get irq is 43
[ 2.049207]
[ 2.055591] VE: ve_debug_proc_info:2623974e, data:9aa56afd, lock:2f14d63d
[ 2.055591]
[ 2.064833] VE: install end!!!
[ 2.064833]
[ 2.069888] VE: sunxi_cedar_probe
[ 2.073829] Bluetooth: HCI UART driver ver 2.3
[ 2.078815] Bluetooth: HCI UART protocol H4 registered
[ 2.084537] Bluetooth: HCI UART protocol BCSP registered
[ 2.090525] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 1.0.10
[ 2.097673] [XR_BT_LPM] bluesleep_probe: bt_wake polarity: 1
[ 2.104023] [XR_BT_LPM] bluesleep_probe: host_wake polarity: 1
[ 2.110566] [XR_BT_LPM] bluesleep_probe: wakeup source is disabled!
[ 2.110566]
[ 2.119232] [XR_BT_LPM] bluesleep_probe: uart_index(1)
[ 2.126956] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-11-18 10:02)
[ 2.136882] sunxi-mmc 4020000.sdmmc: ctl-spec-caps 8
[ 2.143078] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
[ 2.149398] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
[ 2.155798] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
[ 2.162220] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
[ 2.168733] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
[ 2.175236] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
[ 2.181753] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
[ 2.188683] sunxi-mmc 4020000.sdmmc: Got CD GPIO
[ 2.194077] sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
[ 2.200693] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.211804] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
[ 2.231919] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.256291] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
[ 2.261989] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.274045] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-11-18 10:02)
[ 2.276572] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.283945] sunxi-mmc 4021000.sdmmc: ctl-spec-caps 8
[ 2.297630] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.301448] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
[ 2.315932] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.319257] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
[ 2.337183] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
[ 2.343607] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
[ 2.350121] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
[ 2.356629] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
[ 2.363143] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
[ 2.366098] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.369666] sunxi-mmc 4021000.sdmmc: Cann’t get pin bias hs pinstate,check if needed
[ 2.380439] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 2.387952] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.398771] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 2.409733] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
[ 2.421468] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[ 2.440613] mmc0: new high speed SDHC card at address b368
[ 2.441425] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.447749] mmcblk0: mmc0:b368 NCard 7.50 GiB
[ 2.468812] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
[ 2.470911] sunxi-mmc 4021000.sdmmc: detmode:manually by software
[ 2.481323] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 2.481394] exFAT: Version 1.3.0
[ 2.492558] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 2.493817] sunxi-spdif 2036000.spdif: request pinctrl handle for audio failed
[ 2.507486] sunxi-spdif 2036000.spdif: [sunxi_spdif_dev_probe] failed
[ 2.514708] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.514793] sunxi-spdif: probe of 2036000.spdif failed with error -22
[ 2.534651] [AUDIOCODEC][sunxi_codec_parse_params][2412]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
[ 2.534651]
[ 2.534745] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.551804] [AUDIOCODEC][sunxi_codec_parse_params][2448]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
[ 2.574191] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 2.580934] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 2.587670] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 2.594393] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 2.594418] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 2.601495] [AUDIOCODEC][sunxi_internal_codec_probe][2609]:codec probe finished
[ 2.621295] debugfs: Directory ‘203034c.dummy_cpudai’ with parent ‘audiocodec’ already present!
[ 2.631079] [SNDCODEC][sunxi_card_init][583]:card init finished
[ 2.638192] sunxi-codec-machine 2030340.sound: 2030000.codec ↔ 203034c.dummy_cpudai mapping ok
[ 2.649063] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input0
[ 2.661005] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
[ 2.669368] NET: Registered protocol family 10
[ 2.675390] Segment Routing with IPv6
[ 2.679528] [SNDCODEC][sunxi_hs_init_work][259]:resume–>report switch
[ 2.686904] NET: Registered protocol family 17
[ 2.692049] Bluetooth: RFCOMM TTY layer initialized
[ 2.697511] Bluetooth: RFCOMM socket layer initialized
[ 2.703273] Bluetooth: RFCOMM ver 1.11
[ 2.708015] Registering SWP/SWPB emulation handler
[ 2.727980] sunxi-i2c sunxi-i2c2: sunxi-i2c2 supply twi not found, using dummy regulator
[ 2.737863] sunxi-i2c sunxi-i2c2: probe success
[ 2.744173] sunxi-spdif 2036000.spdif: request pinctrl handle for audio failed
[ 2.752279] sunxi-spdif 2036000.spdif: [sunxi_spdif_dev_probe] failed
[ 2.759570] sunxi-spdif: probe of 2036000.spdif failed with error -22
[ 2.768331] debugfs: Directory ‘2031000.dmic’ with parent ‘snddmic’ already present!
[ 2.777556] sunxi-audio-card 2031060.sounddmic: dmic-hifi ↔ 2031000.dmic mapping ok
[ 2.787424] get ehci0-controller wakeup-source is fail.
[ 2.793419] sunxi ehci0-controller don’t init wakeup source
[ 2.799678] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0b5df98, 0x:c88a5000, irq_no:3a
[ 2.811614] [sunxi-ehci0]: Not init ehci0
[ 2.816415] get ohci0-controller wakeup-source is fail.
[ 2.822366] sunxi ohci0-controller don’t init wakeup source
[ 2.828604] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0b5e228
[ 2.838212] [sunxi-ohci0]: Not init ohci0
[ 2.842989] get ehci1-controller wakeup-source is fail.
[ 2.848913] sunxi ehci1-controller don’t init wakeup source
[ 2.855128] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0b5e4b8, 0x:c88af000, irq_no:3c
[ 2.867270] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
[ 2.880621] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
[ 2.887857] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
[ 2.897724] sunxi-ehci 4200000.ehci1-controller: irq 60, io mem 0x04200000
[ 2.927502] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
[ 2.935278] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
[ 2.944254] hub 1-0:1.0: USB hub found
[ 2.948496] hub 1-0:1.0: 1 port detected
[ 2.953594] get ohci1-controller wakeup-source is fail.
[ 2.959566] sunxi ohci1-controller don’t init wakeup source
[ 2.965785] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0b5e748
[ 2.975617] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
[ 2.987818] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
[ 2.995030] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
[ 3.004913] sunxi-ohci 4200400.ohci1-controller: irq 61, io mem 0x04200400
[ 3.082291] hub 2-0:1.0: USB hub found
[ 3.086505] hub 2-0:1.0: 1 port detected
[ 3.092652] sun8iw20-pinctrl 2000000.pinctrl: pin PB6 already requested by 2500c00.uart; cannot claim for 2000000.pinctrl:38
[ 3.105208] sun8iw20-pinctrl 2000000.pinctrl: pin-38 (2000000.pinctrl:38) status -22
[ 3.116331] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 3.117535] clk: Not disabling unused clocks
[ 3.125976] cfg80211: failed to load regulatory.db
[ 3.130715] ALSA device list:
[ 3.139347] #0: audiocodec
[ 3.142557] #1: snddmic
[ 3.145481] alloc_fd: slot 0 not NULL!
[ 3.156434] [EXFAT] trying to mount…
[ 3.161690] VFS: Cannot open root device “mmcblk0p5” or unknown-block(179,5): error -5
[ 3.170551] Please append a correct “root=” boot option; here are the available partitions:
[ 3.179884] 1f00 1024 mtdblock0
[ 3.179887] (driver?)
[ 3.187172] 1f01 4096 mtdblock1
[ 3.187174] (driver?)
[ 3.194466] 1f02 1024 mtdblock2
[ 3.194468] (driver?)
[ 3.201766] 1f03 124928 mtdblock3
[ 3.201769] (driver?)
[ 3.209063] b300 7864320 mmcblk0
[ 3.209066] driver: mmcblk
[ 3.216641] b301 252 mmcblk0p1 a0085546-4166-744a-a353-fca9272b8e45
[ 3.216643]
[ 3.226651] b302 252 mmcblk0p2 a0085546-4166-744a-a353-fca9272b8e46
[ 3.226653]
[ 3.236657] b303 252 mmcblk0p3 a0085546-4166-744a-a353-fca9272b8e47
[ 3.236658]
[ 3.246664] b304 3840 mmcblk0p4 a0085546-4166-744a-a353-fca9272b8e48
[ 3.246666]
[ 3.256670] b305 262144 mmcblk0p5 a0085546-4166-744a-a353-fca9272b8e49
[ 3.256671]
[ 3.266679] b306 5120 mmcblk0p6 a0085546-4166-744a-a353-fca9272b8e4a
[ 3.266681]
[ 3.276690] b307 5120 mmcblk0p7 a0085546-4166-744a-a353-fca9272b8e4b
[ 3.276692]
[ 3.286692] 103:00000 7549452 mmcblk0p8 a0085546-4166-744a-a353-fca9272b8e4c
[ 3.286694]
[ 3.296717] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,5)
[ 3.306127] CPU0: stopping
[ 3.309143] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 5.4.61 #9
[ 3.315738] Hardware name: Generic DT based system
[ 3.321094] [] (unwind_backtrace) from [] (show_stack+0x10/0x14)
[ 3.329730] [] (show_stack) from [] (dump_stack+0x88/0xa4)
[ 3.337776] [] (dump_stack) from [] (handle_IPI+0xe4/0x180)
[ 3.345932] [] (handle_IPI) from [] (gic_handle_irq+0x70/0x78)
[ 3.354360] [] (gic_handle_irq) from [] (__irq_svc+0x6c/0xa8)
[ 3.362700] Exception stack(0xc0a01f40 to 0xc0a01f88)
[ 3.368325] 1f40: 000233d4 c76b9334 00000000 c0114740 00000001 c0a00000 c0a03de8 c0a03e24
[ 3.377440] 1f60: c0a43000 c77ff600 c09270c0 00000000 00000000 c0a01f90 c0107f48 c0107f38
[ 3.386537] 1f80: 60000013 ffffffff
[ 3.390429] [] (__irq_svc) from [] (arch_cpu_idle+0x1c/0x38)
[ 3.398668] [] (arch_cpu_idle) from [] (do_idle+0xd4/0x128)
[ 3.406820] [] (do_idle) from [] (cpu_startup_entry+0x18/0x20)
[ 3.415248] [] (cpu_startup_entry) from [] (start_kernel+0x358/0x3e8)
[ 3.424371] [] (start_kernel) from [<00000000>] (0x0)
[ 3.430966] —[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,5) ]—
100ask的TinaLinux基础上,修改了根文件系统为ext4格式、root filesystem大小。
编译后下载到sd卡,启动报错:[ 3.430966] —[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,5) ]–
