分析Tina打包流程,并在buildroot上来实现打包生成tina镜像,支持PhoenixSuit烧写
步骤简述
首先记录下官方 tina-sdk 打包的log输出。
book@virtual-machine:~/D1s-Core/tina-d1-h$ pack
PACK_CHIP         sun20iw1p1
PACK_PLATFORM     tina
PACK_BOARD        d1-h-nezha
PACK_KERN
PACK_DEBUG        uart0
PACK_SIG          none
PACK_SECURE       none
PACK_MODE         normal
PACK_FUNC         android
PACK_PROGRAMMER   none
PACK_TAR_IMAGE    none
PACK_TOPDIR       /home/book/D1s-Core/tina-d1-h
No kernel param, parse it from d1-h
copying tools file
copying configs file
storage_type value is 5
rm /home/book/D1s-Core/tina-d1-h/out/d1-h-nezha/image/sys_partition_nor.fex
rm /home/book/D1s-Core/tina-d1-h/out/d1-h-nezha/image/image_nor.cfg
copying boot resource
copying boot file
make user resource for : /home/book/D1s-Core/tina-d1-h/out/d1-h-nezha/image/sys_partition.fex
handle partition user-res
no user resource partitions
APP_PART_DOWNLOAD_FILE = /home/book/D1s-Core/tina-d1-h/out/d1-h-nezha/image/app.fex
Need size of filesystem
no data resource partitions
don't build dtbo ...
create sys_partiton.fex +++++++++++++++++++++++++++++++++++++++++++++++++++++4
argc = 2
input name sys_partition.fex
Script 1 source file Path=/home/book/D1s-Core/tina-d1-h/out/d1-h-nezha/image/sys_partition.fex
Script 1 bin file Path=/home/book/D1s-Core/tina-d1-h/out/d1-h-nezha/image/sys_partition.bin
update_fdt: num 1752 randto1k
parser 1 file ok
create sys_partiton.fex+++++++++++++++++++++++++++++++++++++++++++++++++++++5
update_chip
pack boot package
content_count=3
packing for tina linux
normal
update mbr use 4++++++++++++++++++++++
mbr count = 4
partitation file Path=/home/book/D1s-Core/tina-d1-h/out/d1-h-nezha/image/sys_partition.bin
mbr_name file Path=/home/book/D1s-Core/tina-d1-h/out/d1-h-nezha/image/sunxi_mbr.fex
download_name file Path=/home/book/D1s-Core/tina-d1-h/out/d1-h-nezha/image/dlinfo.fex
mbr size = 252
mbr magic softw411
disk name=boot-resource
disk name=env
disk name=env-redund
disk name=boot
disk name=rootfs
disk name=dsp0
disk name=recovery
this is not a partition key
update_for_part_info 0
crc 0 = 4c7bc2df
crc 1 = d9c69382
crc 2 = bc706624
crc 3 = 29cd3779
gpt_head->header_crc32 = 0x892c53ba
GPT----part num 8---
gpt_entry: 128
gpt_header: 92
GPT:boot-resource: a1f8          c177
GPT:env         : c178          c36f
GPT:env-redund  : c370          c567
GPT:boot        : c568          1161f
GPT:rootfs      : 11620         1b597
GPT:dsp0        : 1b598         1b987
GPT:recovery    : 1b988         227c7
GPT:UDISK       : 227c8         ffffffde
update gpt file ok
update mbr file ok
temp = 20
mbr size = 252
mbr magic softw411
disk name=env
disk name=boot
disk name=rootfs
disk name=dsp0
disk name=recovery
crc 0 = 4c7bc2df
crc 1 = d9c69382
crc 2 = bc706624
crc 3 = 29cd3779
gpt_head->header_crc32 = 0x1328fa28
gpt_entry: 128
gpt_header: 92
GPT:env         : c178          c36f
GPT:UDISK       : 227c8         e8ffde
update gpt file ok
update mbr file ok
cp sys parttion.fex  for dragon.fex ++++++++++++++++++++++++++++
  [mbr]
  mbr_size  : 252 Kbyte
  partition_name  : boot-resource
  partition_size  : 8064
  downloadfile  : boot-resource.fex
  boot-resource.fex size : 3.0M byte
  partition_name  : env
  partition_size  : 504
  downloadfile  : env.fex
  env.fex size : 128K byte
  partition_name  : env-redund
  partition_size  : 20664
  downloadfile  : boot.fex
  boot.fex -> /home/book/D1s-Core/tina-d1-h/out/d1-h-nezha/boot.img
  boot.img size : 5.0M byte
  partition_name  : rootfs
  partition_size  : 40824
  downloadfile  : rootfs.fex
  rootfs.fex -> /home/book/D1s-Core/tina-d1-h/out/d1-h-nezha/rootfs.img
  rootfs.img size : 5.9M byte
  partition_name  : dsp0
  partition_size  : 1008
  downloadfile  : dsp0.fex
  dsp0.fex size : 249K byte
  partition_name  : recovery
  partition_size  : 28224
/home/book/D1s-Core/tina-d1-h/out/host/bin/
Begin Parse sys_partion.fex
FilePath: boot-resource.fex
FileLength=2f8c00Add partion env.fex ENV_FEX000000000
FilePath: env.fex
FilePath: env.fex
FilePath: boot.fex
FileLength=4f4000Add partion rootfs.fex ROOTFS_FEX000000
FilePath: rootfs.fex
FileLength=5e0000Add partion dsp0.fex DSP0_FEX00000000
Add partion very dsp0.fex DSP0_FEX00000000
FilePath: dsp0.fex
FileLength=3e38cBuildImg 0
/home/book/D1s-Core/tina-d1-h/out/d1-h-nezha/tina_d1-h-nezha_uart0.img
pack finish
分析打包过程
从上述log可以看出整个打包过程大致分为这么几个步骤
  1. 指定一些比较环境变量,比如镜像输出目录 镜像的一些配置信息。
  2. 之后将镜像拷贝到需要打包的目录下,开始进行统一处理
  3. 根据文件系统分区信息,将其转换成 适合后续程序使用的格式。
  4. 转换分区信息为 专门的GPT/MBR分区头部。
  5. 使用dragon打包,将所有配置文件里指定的文件,进行汇总,打包输出。
使用命令操作 主要分为4步
busybox unix2dos sys_partition.fex
tina-d1-h/tools/pack-bintools/src/script  sys_partition.fex
tina-d1-h/tools/pack-bintools/src/update_mbr  sys_partition.bin 4
tina-d1-h/tools/pack-bintools/src/dragon  image.cfg sys_partition.fex
dragon分析
这里面 最关键的就是 sys_partition.fex 文件,它定义了分区的信息 以及大小等。
可以进入 编译后的 tina-d1-h/out/d1-h-nezha/image 目录下查看。
我们可以直接cat sys_partition.fex文件
book@virtual-machine:~/D1s-Core/tina-d1-h/out/d1-h-nezha/image$ cat sys_partition_for_dragon.fex
; 说明: 脚本中的字符串区分大小写,用户可以修改"="后面的数值,但是不要修改前面的字符串
;                                   固件下载参数配置
;    mbr的大小, 以Kbyte为单位
[mbr]
size = 252
;                                              分区配置
;  partition 定义范例:
;    [partition]                ;  //表示是一个分区
;    name        = USERFS2      ; //分区名称
;    size        = 16384        ; //分区大小 单位: 扇区.分区表示个数最多2^31 * 512 = 2T
;    downloadfile = "123.fex"   ; //下载文件的路径和名称,可以使用相对路径,相对是指相对于image.cfg文件所在分区。也可以使用绝对路径
;    keydata     = 1            ; //私有数据分区,重新量产数据将不丢失
;    encrypt     = 1            ; //采用加密方式烧录,将提供数据加密,但损失烧录速度
;    user_type   = ?            ; //私有用法
;    verify      = 1            ; //要求量产完成后校验是否正确
; 注:1、name唯一, 不允许同名
;     2、name最大12个字符
;     3、size = 0, 将创建一个无大小的空分区
;     4、align to logical block size(504 sectors), leb size = 2*(1 nand phy block size - 1 phy page size)
[partition_start]
[partition]
    name         = boot-resource
    size         = 8064
    downloadfile = "boot-resource.fex"
    user_type    = 0x8000
[partition]
    name         = env
    size         = 504
    downloadfile = "env.fex"
    user_type    = 0x8000
[partition]
    name         = env-redund
    size         = 504
    user_type    = 0x8000
[partition]
    name         = boot
    size         = 20664
    downloadfile = "boot.fex"
    user_type    = 0x8000
[partition]
    name         = rootfs
    size         = 40824
    downloadfile = "rootfs.fex"
    user_type    = 0x8000
[partition]
    name         = dsp0
    size         = 1008
    downloadfile = "dsp0.fex"
    user_type    = 0x8000
[partition]
    name         = recovery
    size         = 28224
    ;downloadfile = "recovery.fex"
    user_type    = 0x8000
这里面所有的 downloadfile文件 都是我们编译出来要烧写的文件。所以只需要把相应的文件放到这个目录下,就可以进行打包操作了。
如果你在不改变 文件大小的前提下,可以直接执行tina-d1-h/tools/pack-bintools/src/dragon image.cfg sys_partition.fex 命令,你会发现它生成了一个 tina_d1-h-nezha_uart0.img,镜像,这个镜像是和使用pack命令打包生成的一样。
那么这里面还有一个 img.cfg文件。这个文件里面包含了很多 fex二进制文件,目前我认为这些文件都是和全志官方的烧写工具绑定死的,所以不用管它,只要制作的时候 当前目录下有这些工具即可。
有了这两个文件以后,就可以直接使用 dragon打包生成可以用 凤凰烧写器 烧写的系统镜像啦。
SYS_PARTITON分析
如果你的系统镜像格式 一直保持大小不变,那么上面这个命令 就可以一直用,但是这个时候 我想自己编译内核 增加 驱动模块,编译文件系统 增加组件 导致系统镜像变大了 这要怎么办?
简单点,直接修改 sys_partition.fex为 文件大小不就可以了吗?
但是你会发现 这样做不行,他会提示错误。
这个时候 我们就要继续分析 log日志输出了,会发现,我们执行 dragon打包 只有下面这些输出信息,没有上面的 GPT/MBR分区信息。
/home/book/D1s-Core/tina-d1-h/tools/pack-bintools/src/
FilePath: env.fex
FilePath: env.fex
FilePath: boot.fex
FilePath: dsp0.fex
那么这个时候 就需要往回找,这个文件是哪里来的 怎么生成的?
通过 搜索 分析 发现是 来自于 sys_partiton.bin 文件,但是这个文件又是一个 二进制文件,而且也是后面打包生成的,那么还是要继续往回找 sys_partition.bin文件又是怎么生成的。
同样是结合log 加打印
找到了 如下这两个命令。
一开始以为这个 script 是ubuntu的某一个包,后来发现也是一个全志自家提供的工具。
既然 工具都找全了 那我们可以修改试试看。
修改 sys_partition.fex 把它的大小 调整为 70824
之后保存退出,从头执行如下命令 来确认猜想是否正确。
book@virtual-machine:~/D1s-Core/tina-d1-h/out/d1-h-nezha/image$ busybox unix2dos sys_partition.fex
book@virtual-machine:~/D1s-Core/tina-d1-h/out/d1-h-nezha/image$ ~/D1s-Core/tina-d1-h/tools/pack-bintools/src/script  sys_partition.fex
argc = 2
parser 1 file ok
book@virtual-machine:~/D1s-Core/tina-d1-h/out/d1-h-nezha/image$ ~/D1s-Core/tina-d1-h/tools/pack-bintools/src/update_mbr  sys_partition.bin 4
mbr count = 4
mbr size = 252
mbr magic softw411
disk name=env
disk name=boot
disk name=rootfs
disk name=dsp0
disk name=recovery
crc 0 = ea84dacc
crc 1 = 7f398b91
crc 2 = 1a8f7e37
crc 3 = 8f322f6a
gpt_head->header_crc32 = 0x53fc3a66
gpt_entry: 128
gpt_header: 92
GPT:env         : c178          c36f
GPT:rootfs      : 11620         22ac7
GPT:dsp0        : 22ac8         22eb7
GPT:recovery    : 22eb8         29cf7
GPT:UDISK       : 29cf8         ffffffde
update gpt file ok
update mbr file ok
book@virtual-machine:~/D1s-Core/tina-d1-h/out/d1-h-nezha/image$ ~/D1s-Core/tina-d1-h/tools/pack-bintools/src/dragon  image.cfg sys_partition.fex
FilePath: env.fex
FilePath: env.fex
FilePath: boot.fex
FilePath: dsp0.fex
最后在当前目录下 生成了一个 名为 tina_d1-h-nezha_uart0.img 文件,把它用 凤凰烧录 工具烧录进去。
你会发现你可以把你增加过文件的分区 烧进去 并启动啦。
那么这个时候,还存在一个问题,就是D1使用的都是 squashfs 类型的文件系统,这个时候,你也需要分析一下 他们的这个文件系统 生产方式,这个就可以借助 grep 命令了,参考如下。
分析文件系统生成方式
最后得到 这个
rootfs.squashfs -noappend -processors 9 -nopad -noappend -root-owned -comp xz -b 256k -p ‘’‘/dev d 755 0 0’‘’ -p ‘’‘/dev/console c 600 0 0 5 1’‘’ -processors 4\n’ >> /home/book/buildroot_dshannezhastu/buildroot-awol/output/build/buildroot-fs/squashfs/fakeroot
然后 把它 扔进 buildroot 就可以制作出 可以供 D1内核使用的系统,
注意 tina的环境变量里面的 init 进程位置和buildroot 不一样 需要修改。
最后 给大家放上,我们已经支持过 NEZHA D1的buildroot完整系统镜像源码
clone下来后,需要更新git 子模块 执行如下命令来拉取子模块的源码。
git submodule update --recursive --remote
git pull --recurse-submodules
之后进入 buildroot-awol 目录下,稍等一会 就可以生成 供spi nand 烧写的flash镜像了。 当然,也可以烧到tf卡启动。。
buildroot_dshannezhastu/buildroot-awol$ make BR2_DL_DIR=../Download BR2_EXTERNAL=../br2nezhastu/ dshannezhastu_spinand_core_defconfig
编译完成后的输出信息。
镜像输出在 output/images/目录下
你好老师, 您上面rootfs.fex 的size是70824
如果按照下图我这样,如果设置的size大小和dl_file_size和一样都设置成85680,那我在实际运行的时候,是否就无法再往里面 存放任何东西了(比如我的应用程序变大了)?
并不是,你可以修改 这个分区配置文件,调整size大小 来实现。
