DongshanPI-PicoW problem connect usb windows7
I can’t update the firmware, I do everything according to the instructions, the answer is an unknown device, although during normal boot the logs are displayed as expected. The cable has been checked; replacing the computer does not help.
I’ve decided to answer myself, don’t short-circuit the M4 and solder the button to the GND with tweezers and use it to control the loading, interference and chatter will otherwise interfere with you.
