显示的错误如下:
但是运行摄像头拍照功能是正常的
配置文件为:
请大佬指导一下
您好,可以尝试关闭在线模式
按照这个修改后还是出现错误:
Cedar Codec <<<<<<<<<<<<<<<<<<<<<<<<<<<<
tag :
branch: tina-v853-dev
commit: ee230a47e5a2392ec315795121c2d112492fac1c
date : Fri Jul 22 10:37:50 2022 +0800
author: wuguanjian
change-id : I28fe0c31c718f097d61ad6bdbcb4cb5df0bd3575
release_author : lichaopdc
patch :
INFO : cedarc VeInitialize:1185: *** ic_version = 0x1302000023010,
DEBUG : cedarc VeInitialize:1228: *** nPhyOffset = 0x0, bSoleResetVe = 1
[ISP_ERR]isp_sync_debug_info, line: 747,VIDIOC_VIN_ISP_GET_INFO error!
DEBUG : cedarc VeSetSpeed:1750: *** set ve freq to 400 Mhz ***
DEBUG : cedarc VeInitialize:1283: ve init ok
DEBUG : ionAlloc <__GetIonMemOpsS:965>: *** get __GetIonMemOpsS ***
DEBUG : ionAlloc <ion_alloc_open:140>: begin ion_alloc_open
DEBUG : cedarc H264EncOpenVer2:9424: icverion = 0x23010, bIsRegVerE230 = 1
DEBUG : cedarc CdcMessageQueueCreate:47: nMessageSize = 20
I0101 00:08:26.087568 1148 VideoEnc_Component.c:3961] vencChn[2] set new framerate:20
I0101 00:08:26.087714 1148 sample_rtsp.c:1264] Lapse set TimeLapse 1000000 us
I0101 00:08:26.087808 1148 VideoEnc_Component.c:4036] SetTimeLapse: captureIntervalUs =1000000.000000, dstFrameIntervalUs=50000.000000, recType=1
DEBUG : cedarc H264SetParameterVer2:11299: VENC_IndexParam2DFilter: 2DNR:1, StrengthY:127, StrengthUV:127, ThY: 11, ThUV:7
I0101 00:08:26.087920 1148 sample_rtsp.c:1072] VencChn[2] enable and set 2DFilter p aram
DEBUG : cedarc H264SetParameterVer2:11346: VENC_IndexParam3DFilterNew: 3DNR:1, LevelEn:0, SmoothEn:1, MvTh:8, M adTh:14, DiffTh:6, Coef[13~16]
I0101 00:08:26.088021 1148 sample_rtsp.c:1085] VencChn[2] enable and set 3DFilter p aram
I0101 00:08:26.088090 1148 sample_rtsp.c:1103] VencChn[2] SuperFrm Mode:0, Ifr mSize:266666 bits, PfrmSize:88888 bits
E0101 00:08:26.088161 1148 mpi_sys.c:1538] <AW_MPI_SYS_Bind> fatal error! Bind error! source comp onent not found!
I0101 00:08:26.088307 1148 VideoEnc_Component.c:5418] set VencChn[0] Comp StateExecuti ng
I0101 00:08:26.088425 1155 media_debug.c:45] MPP_DEDIA_DEBUG_FILE_PATH=(null)
DEBUG : cedarc H265SetParameter:12343: VENC_IndexParamPFrameIntraEn: use_intra_in_p_flag:1
I0101 00:08:26.088634 1155 VideoEnc_Component.c:788] user set stream buffer size[93388 2]bytes
I0101 00:08:26.088724 1155 VideoEnc_Component.c:798] user set threshSize[147450]bytes
I0101 00:08:26.088797 1155 VideoEnc_Component.c:825] bit rate is 1536Kb, set encode vb v size 933888, frame length threshold 147450
DEBUG : cedarc H265SetParameter:11924: set rot angle: p_enc->rot_angle = 0…
DEBUG : cedarc H265SetParameter:12479: VENC_IndexParamIsNightCaseFlag: is_night_case = 0
DEBUG : cedarc H265SetParameter:12498: VENC_IndexParamProductCase: is_ipc_case = 1
DEBUG : cedarc H265SetParameter:12515: VENC_IndexParamSensorType: sensor_type = 1
DEBUG : cedarc H265SetParameter:12382: VENC_IndexParam2DFilter: 2DNR:1, StrengthY:127, StrengthUV:127, ThY:11, ThUV:7
DEBUG : cedarc H265SetParameter:12427: VENC_IndexParam3DFilterNew: 3DNR:1, LevelEn:0, SmoothEn:1, MvTh:8, MadTh :14, DiffTh:6, Coef[13~16]
I0101 00:08:26.120615 1154 VideoEnc_Component.c:6308] send frame when venc state[0 x2] is not executing
I0101 00:08:26.420333 1154 VideoEnc_Component.c:6383] VencChn[0]: first video fram e pts[503211147]us,tm1[503511106]us, vSize[1920x1088], frmId[1,12]
I0101 00:08:26.420151 1155 VideoEnc_Component.c:1930] veChn[0], EncppEnable=1
I0101 00:08:26.420492 1155 VideoEnc_Component.c:1936] DropFrameNum: 0
I0101 00:08:26.420577 1155 VideoEnc_Component.c:1946] GDC enable: 0
I0101 00:08:26.420655 1155 VideoEnc_Component.c:2011] Online Mode=1, Channel=0, ShareBu fNum=0, OnlineEnableFlag=0
I0101 00:08:26.420720 1155 VideoEnc_Component.c:2038] rec_lbc_mode=1
DEBUG : cedarc VencInit:683: func = VencInit, line = 683
DEBUG : cedarc VencInit:696: bOnlineMode = 1, bOnlineChannel = 0
DEBUG : cedarc VencInit:699: lbc2.5 = 0, 2.0 = 1, 1.5 = 0, format = 19
DEBUG : cedarc H265Init:10110: share buf num = 1
DEBUG : cedarc BitStreamCreate:121: BitStreamCreate OK
DEBUG : cedarc h265InitMemRecRefE230:3982: **qSubDataBufSize = 136448, phy_addr = 0x5e7c00, ori_phy_addr = 0x5e 7c0000 i = 0
DEBUG : cedarc h265InitMemRecRefE230:3997: qSubInfoBufSize = 5408, phy_addr = 0x5e79c0, ori_phy_addr = 0x5e79c0 00 i = 0
DEBUG : cedarc h265InitMemRecRefE230:4012: lbcBusSize = 2151968, phy_addr = 0x5d4000, ori_phy_addr = 0x5d400000 i = 0
DEBUG : cedarc h265InitMemRecRefE230:3982: **qSubDataBufSize = 136448, phy_addr = 0x5d7000, ori_phy_addr = 0x5d 700000 i = 1
DEBUG : cedarc h265InitMemRecRefE230:3997: qSubInfoBufSize = 5408, phy_addr = 0x5d60e0, ori_phy_addr = 0x5d60e0 00 i = 1
[ISP]video device name is vin_video12
[ISP]open video device[12], detect isp0 success!
DEBUG : cedarc h265InitMemRecRefE230:4012: lbcBusSize = 2151968, phy_addr = 0x5d0000, ori_phy_addr = 0x5d000000 i = 1
DEBUG : cedarc H265Init:10347: ********Channal[0]: H265Enc Ver.ee230a47e5a2392ec315795121c2d112492fac1c ******* *
DEBUG : cedarc H265Init:10348: h265 basic params*
DEBUG : cedarc H265Init:10354: profile:1, level:120, frameRate:20, bitRate:1572864, 3d_filter:1
DEBUG : cedarc H265Init:10359: idr_period:100, intra_period:100, gop_size:2, virtual_i_period:0
DEBUG : cedarc H265Init:10364: init_qp:37, color_format:19, rotage_angle:0, longTerm ref:0
DEBUG : cedarc H265Init:10366: size params*
DEBUG : cedarc H265Init:10372: input_size[1920x1088], output_size[1920x1080], vbv_size:933888
DEBUG : cedarc H265Init:10374: bitRate qp params*
DEBUG : cedarc H265Init:10404: bitRate mode: VBR: maxBitRate = 1572864, movingTh = 20, quality = 10, qp_init:37 , i_qp[10~50], p_qp[10~50], mb_qp_limit:0
DEBUG : cedarc H265Init:10408: vbv params*
DEBUG : cedarc H265Init:10413: vbv_size:933888, coded_frame_num:0, coded_size:0, maxFrameLen:147450.
DEBUG : cedarc H265Init:10423: rc params*
DEBUG : cedarc H265Init:10424: rc_mode:1, set_mad_th:0
DEBUG : cedarc H265Init:10445: ctu_info_flag:1, bin_flag:1
DEBUG : cedarc H265Init:10458: intra inter parm*
DEBUG : cedarc H265Init:10462: intra4x4_flag:1, intra_in_p_flag:1, adaptive_intra_in_p_flag:0
DEBUG : cedarc H265Init:10473: is_night_case:0, is_ipc_case:1, sensor_type:1
DEBUG : cedarc VencInit:810: pOnlineCxt->eOnlineBufNum = 0
[ISP]--------- LDCI Video12 Init OK ---------
DEBUG : cedarc VencInit:848: func = VencInit, line = 848
DEBUG : cedarc OnlineThreadProcess:1602: online thread start
I0101 00:08:26.770333 1155 VideoEnc_Component.c:2059] Venc Init success
I0101 00:08:26.770496 1155 VideoEnc_Component.c:2068] Venc SetCallbacks success
DEBUG : cedarc VencStart:867: func = VencStart, line = 867
I0101 00:08:26.770687 1155 VideoEnc_Component.c:2078] Venc Start success
DEBUG : cedarc H265SetParameter:11715: save bs filename:, save_start_time:0, save_end_time:0
E0101 00:08:26.772221 1148 mpi_vi.c:1161] <AW_MPI_VI_EnableVirChn> vichn[0] is unexist!!
I0101 00:08:26.772374 1148 VideoEnc_Component.c:5418] set VencChn[1] Comp StateExecuti ng
I0101 00:08:26.772556 1157 media_debug.c:45] MPP_DEDIA_DEBUG_FILE_PATH=(null)
DEBUG : cedarc h264SetH264Param:363: H264SetParameter
DEBUG : cedarc h264SetH264Param:374: profile:77, level:0, frameRate:20, bitRate:256000, idr_period:100, init_qp :37, i_qp[10~50], p_qp[10~50]
DEBUG : cedarc h264SetH264Param:379: 3d_filter:1, lt:0, hpf_flag:0, hpf_level:0
DEBUG : cedarc h264SetH264Param:384: vbr info: maxBitRate = 256000, movingTh = 20, quality = 10
DEBUG : cedarc H264SetParameterVer2:11264: VENC_IndexParamPFrameIntraEn : use_intra_in_p_flag = 1
I0101 00:08:26.772913 1157 VideoEnc_Component.c:788] user set stream buffer size[15200 0]bytes
I0101 00:08:26.773009 1157 VideoEnc_Component.c:798] user set threshSize[24000]bytes
I0101 00:08:26.773079 1157 VideoEnc_Component.c:825] bit rate is 250Kb, set encode vbv size 152576, frame length threshold 24000
DEBUG : cedarc H264SetParameterVer2:10754: set rot angle: pEnc->rot_angle = 0…
DEBUG : cedarc H264SetParameterVer2:11427: VENC_IndexParamIsNightCaseFlag: is_night_case = 0
DEBUG : cedarc H264SetParameterVer2:11446: VENC_IndexParamProductCase: is_ipc_case = 1
DEBUG : cedarc H264SetParameterVer2:11452: VENC_IndexParamSensorType: sensor_type = 1
I0101 00:08:26.773332 1157 VideoEnc_Component.c:1930] veChn[1], EncppEnable=1
I0101 00:08:26.773413 1157 VideoEnc_Component.c:1936] DropFrameNum: 0
I0101 00:08:26.773477 1157 VideoEnc_Component.c:1946] GDC enable: 0
I0101 00:08:26.773544 1157 VideoEnc_Component.c:2011] Online Mode=1, Channel=0, ShareBu fNum=0, OnlineEnableFlag=0
I0101 00:08:27.105057 1157 VideoEnc_Component.c:2038] rec_lbc_mode=1
[ISP]--------- LDCI Video12 Streamon OK ---------
DEBUG : cedarc GdcCreate:245: func = GdcCreate, line = 245
WARNING: cedarc <LDC_K_Adjust:45>: calib_w&h[0 x 0] is valid, force setup to 1920x1080
DEBUG : cedarc SharpCreate:104: func = SharpCreate, line = 104
DEBUG : cedarc H264InitVer2:9497: share buf num = 1
DEBUG : cedarc h264InitMemRecRefE230:4269: *qSubDataBufSize = 17408, phy_addr = 0x5d7280, ori_phy_addr = 0x5d72 8000 i = 0
DEBUG : cedarc h264InitMemRecRefE230:4284: qSubInfoBufSize = 3200, phy_addr = 0x5d72f0, ori_phy_addr = 0x5d72f0 00 i = 0
DEBUG : cedarc h264InitMemRecRefE230:4301: lbcBusSize = 254848, phy_addr = 0x5d7400, ori_phy_addr = 0x5d740000 i = 0
DEBUG : cedarc h264InitMemRecRefE230:4269: *qSubDataBufSize = 17408, phy_addr = 0x5d3a00, ori_phy_addr = 0x5d3a 0000 i = 1
DEBUG : cedarc h264InitMemRecRefE230:4284: qSubInfoBufSize = 3200, phy_addr = 0x5d3a70, ori_phy_addr = 0x5d3a70 00 i = 1
DEBUG : cedarc h264InitMemRecRefE230:4301: lbcBusSize = 254848, phy_addr = 0x5d6400, ori_phy_addr = 0x5d640000 i = 1
W0101 00:08:27.774285 1161 sample_rtsp.c:1045] fatal error! vencChn[0] get fram e failed! check code!
请问是否是哪里配置问题
rtsp://192.168.31.124:8554/ch0
访问一下地址,看是否可以正常预览
无法正常浏览,不清楚问题出在哪里,请指导一下
配置文件如下:
########### paramter (ref to tulip_cedarx.conf)############
[parameter]
main_isp = 0
main_vipp = 0
main_src_width = 1920
main_src_height = 1080
main_pixel_format = “aw_lbc_2_0x” #nv21,nv12,yu12,yv12;aw_lbc_2_5x,aw_lbc_2_0x,aw_lbc_1_5x,aw_lbc_1_0x
main_wdr_enable = 0
main_vi_buf_num = 3
main_src_frame_rate = 20 #fps
main_viChn = 0 #-1:disale main stream
main_venc_chn = 0 #-1:disale main stream
main_encode_type = “H.265”
main_encode_width = 1920 #1280x720->720p, 1920x1080->1080p, 2304x1296->3M, 2560×1440->2k, 3840x2160->4k, 7680x4320->8k
main_encode_height = 1080
main_encode_frame_rate = 20 #fps
main_encode_bitrate = 1572864 #5M:5242880, 2M:2097152, 1.5M:1572864, 1M:1048576
main_file_path = #“/mnt/extsd/mainStream.raw” #if no path is specified, it will not be saved.
main_online_en = 0
main_online_share_buf_num = 2
main_encpp_enable = 1
sub_isp = 0
sub_vipp = 4
sub_src_width = 640
sub_src_height = 360
sub_pixel_format = “aw_lbc_2_0x” #nv21,nv12,yu12,yv12;aw_lbc_2_5x,aw_lbc_2_0x,aw_lbc_1_5x,aw_lbc_1_0x
sub_wdr_enable = 0
sub_vi_buf_num = 3
sub_src_frame_rate = 20 #fps
sub_vipp_crop_en = 1
sub_vipp_crop_rect_x = 0
sub_vipp_crop_rect_y = 0
sub_vipp_crop_rect_w = 1888
sub_vipp_crop_rect_h = 1072
sub_viChn = 0 #-1:disale sub stream
sub_venc_chn = 1 #-1:disale sub stream
sub_encode_type = “H.264”
sub_encode_width = 640 #1280x720->720p, 1920x1080->1080p, 2560×1440->2k, 3840x2160->4k, 7680x4320->8k
sub_encode_height = 360
sub_encode_frame_rate = 20 #fps
sub_encode_bitrate = 256000 #5M:5242880, 2M:2097152, 1M:1048576, 0.5M:512000
sub_file_path = #“/mnt/extsd/subStream.raw” #if no path is specified, it will not be saved.
sub_encpp_enable = 1
sub_lapse_viChn = 1 #-1:disale sub lapse stream
sub_lapse_venc_chn = 2 #-1:disale sub lapse stream
sub_lapse_encode_type = “H.264”
sub_lapse_encode_width = 640 #1280x720->720p, 1920x1080->1080p, 2560×1440->2k, 3840x2160->4k, 7680x4320->8k
sub_lapse_encode_height = 360
sub_lapse_encode_frame_rate = 20 #fps
sub_lapse_encode_bitrate = 256000 #5M:5242880, 2M:2097152, 1M:1048576, 0.5M:512000
sub_lapse_file_path = #“/mnt/extsd/subLapseStream.raw” #if no path is specified, it will not be saved.
sub_lapse_time = 1000000 #unit:us
sub_lapse_encpp_enable = 1
isp_ve_linkage_enable = 1
isp_ve_linkage_stream_channel = 0 #0:main stream, 1:sub stream, 2:sub lapse stream
wb_yuv_enable = 0
wb_yuv_buf_num = 20
wb_yuv_start_index = 0
wb_yuv_total_cnt = 100
wb_yuv_stream_channel = 0 #0:main stream, 1:sub stream, 2:sub lapse stream
wb_yuv_file_path = “/mnt/extsd/wb_yuv.yuv”
rtsp_net_type = 3 #RTSP Network type, 0: “lo”, 1: “eth0”, 2: “br0”, 3: “wlan0”
test_duration = 0 #unit:s, 0:Infinite duration.
以下是网络信息
root@TinaLinux:~# ifconfig
lo Link encap:Local Loopback
collisions:0 txqueuelen:1
wlan0 Link encap:Ethernet HWaddr 70:60:39:FF:3A:9A
inet addr:192.168.31.20 Bcast:192.168.31.255 Mask:255.255.255.0
inet6 addr: fe80::7260:39ff:feff:3a9a/64 Scope:Link
RX packets:741 errors:0 dropped:0 overruns:0 frame:0
TX packets:1646 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:59815 (58.4 KiB) TX bytes:231457 (226.0 KiB)
root@TinaLinux:~#
root@TinaLinux:/mnt/SDCARD# ./sample_rtsp -path ./sample_rtsp.conf
WARNING: Logging before InitGoogleLogging() is written to STDERR
I0101 01:51:36.613867 1266 sample_rtsp.c:77] sample virvi2venc path:[./sample_rtsp], arg number is [3]
I0101 01:51:36.616361 1266 confparser.c:60] load conf file ./sample_rtsp.conf ok!
I0101 01:51:36.617410 1266 sample_rtsp.c:276] IspAndVeLinkageEn:1, AdaptEn:0, LensMoveMaxQp:40
Committed_AS: 5532 kB
I0101 01:51:36.626088 1266 mpi_sys.c:842] <AW_MPI_SYS_SetConf> kfctmpdir is [/tmp]
modName : MPP-Platform
tag : V1.0 Release
branch: v5-dev
commit: 4eed413532ad87725895a8cb1ba75e22fc328233
date : 20170725
author: jenkins
iniparser: cannot open /etc/cedarx.conf
iniparser: cannot open /vendor/etc/cedarx.conf
I0101 01:51:36.629692 1266 mpi_sys.c:1455] <AW_MPI_SYS_Init> ISP init
I0101 01:51:36.630737 1266 isp_version.h:39] <isp_version_info>
IPCORE: ISP600
branch: libisp-dev
commit: 5b30d9b8f8190196d863bc91576af5356022b433
date : Thu Jan 25 17:23:23 2024 +0800
author: mayifei@allwinnertech.com
I0101 01:51:36.631408 1266 mpi_sys.c:1457] <AW_MPI_SYS_Init> ISP init done
I0101 01:51:36.632665 1266 hwdisplay.c:84] <hw_display_init>
I0101 01:51:36.633112 1266 hwdisplay.c:993] <hwd_init> (hwd_init 993)
I0101 01:51:36.633694 1266 hwdisplay.c:1048] <hwd_init> ret[0][2,0]ch[0]lyl[0] init: enable[0], screenwin[0,0, 0x0], zorder[0], alpha[mode:0, value:0]
I0101 01:51:36.660084 1266 audio_hw.c:189] pcm open and close, all MixerElems maybe exist.
I0101 01:51:36.660608 1266 alsa_interface.c:712] open mixer:hw:0
I0101 01:51:36.662780 1266 alsa_interface.c:767] set playback vol_val to value: 27
I0101 01:51:36.663317 1266 alsa_interface.c:712] open mixer:hw:1
I0101 01:51:36.664729 1266 sample_rtsp.c:407] main vipp0 ve_online_en:0, dma_buf_num:0, venc ch0 OnlineEnable:0, OnlineShareBufNum:0
I0101 01:51:36.665234 1266 sample_rtsp.c:434] main EncppSharpAttenCoefPer: 100%
I0101 01:51:36.665387 1266 sample_rtsp.c:448] main vbvThreshSize: 147450, vbvBufSize: 933882
I0101 01:51:36.665967 1266 video.c:107] <video_init> [ISP]video device name is vin_video0
I0101 01:51:36.666693 1266 isp_dev.c:566] <isp_video_open> [ISP]open video device[0], detect isp0 success!
I0101 01:51:36.667802 1266 video.c:1063] <video_set_isp_bk_buffer_align> [ISP]video_set_isp_bk_buffer_align yuv_align_en = 0, lbc_align_en = 1
E0101 01:51:36.668337 1266 video.c:1065] <video_set_isp_bk_buffer_align> [ISP_ERR]video0 video_set_isp_bk_buffer_align failed!!!
I0101 01:51:36.668928 1266 videoInputHw.c:1104] <videoInputHw_SetChnAttr> ViCh[0] LBC pix:0x3132434c, line_tar_bits[0]:9216, line_tar_bits[1]:13824
I0101 01:51:36.670168 1266 videoInputHw.c:1124] <videoInputHw_SetChnAttr> bs_len:61440, frm_bit:11520
I0101 01:51:36.670768 1271 mpi_sys.c:1073] detect user environment:
I0101 01:51:36.672136 1271 mpi_sys.c:1074] /tmp/mpp_log_level
I0101 01:51:36.672653 1271 mpi_sys.c:1075] /tmp/mpp_venc_sei_config_param
I0101 01:51:36.919179 1266 video.c:172] <video_set_fmt> [ISP]video0 fd[9] ve_online_en=0, dma_buf_num=0
I0101 01:51:36.926410 1266 isp_dev.c:390] <isp_tdm_open> [ISP]tdm_rx device name is sunxi_tdm_rx.0
I0101 01:51:36.927443 1266 isp_dev.c:460] <isp_dev_open> [ISP]open isp device[0] success!
E0101 01:51:36.928008 1266 isp_dev.c:956] <isp_sensor_get_configs> [ISP_ERR]gc2053_mipi get config failed: Invalid argument (22).
W0101 01:51:36.929556 1266 isp_helper.c:106] <isp_ctx_save_init> [ISP_WARN]open /mnt/extsd/isp0_0_0_0_0_gc2053_mipi_ctx_saved.bin failed, err:No such file or directory.
I0101 01:51:36.930169 1266 isp_ini_parse.c:1653] <parser_ini_info> [ISP]prefer isp config: [gc2053_mipi], 0x0, 0, 0, 0
W0101 01:51:36.930795 1266 isp_ini_parse.c:1672] <parser_ini_info> [ISP_WARN]cannot find gc2053_mipi_0_0_0_0_0 isp config, use gc2053_mipi_1920_1088_20_0_0 → [gc2053_mipi_isp600_20220511_164617_vlc4_day]
E0101 01:51:36.934311 1266 isp_manage.c:2575] <isp_ctx_config_init> [ISP_ERR]sensor attribute is not init.
I0101 01:51:36.934940 1266 isp.c:1235] <isp_run> [ISP]create isp0 server thread!
E0101 01:51:36.936230 1270 isp_dev.c:956] <isp_sensor_get_configs> [ISP_ERR]gc2053_mipi get config failed: Invalid argument (22).
W0101 01:51:36.936398 1270 videoInputHw.c:6258] <VideoInputHw_CapThread> fatal error! Get isp[0] sensor information failed! must be called AW_MPI_ISP_Run before AW_MPI_VI_EnableVipp.
E0101 01:51:36.943367 1272 isp_dev.c:718] <isp_dev_start> [ISP_ERR]unable to subscribe to tdm event: Not a tty (25).
E0101 01:51:36.945593 1270 video.c:324] <video_req_buffers> [ISP_ERR]/dev/video0: driver needs more buffers (3) than available (2).
E0101 01:51:36.948002 1270 videoInputHw.c:6290] <VideoInputHw_CapThread> fatal error! video req buffers fail
I0101 01:51:36.948561 1266 videoInputHw.c:1316] <videoInputHw_ChnEnable> receive enable vipp[0] reply: 0xa010800c!
I0101 01:51:36.948804 1266 mpi_vi.c:1319] <AW_MPI_VI_CreateVirChn> we allow to create virChn[0] in disable status of vipp[0]iniparser: cannot open /etc/cedarc.confiniparser: cannot open /etc/cedarc.confINFO : cedarc <cdc_log_set_level:43>: Set log level to 3 from /vendor/etc/cedarc.conf
DEBUG : cedarc LogVersionInfo:44: ag : branch: tina-v853-dev
commit: 3975729c81dab9f05e2722e09e64d018b4b03c44
date : Sat Jan 27 15:33:52 2024 +0800author: chenyibin
change-id : I1798fdb3cfa479b7f3eabb212078a906cbe503eb
release_author : ericwangDEBUG : cedarc VEncoderRegister:1022: 1117 register 2:h264
DEBUG : cedarc VEncoderRegister:1032: register codec: ‘2:h264’ success.
INFO : cedarc <CedarPluginVENCInit_h264:13347>: register h264 encoder success!
DEBUG : cedarc VEncoderRegister:1022: 1117 register 3:h265
DEBUG : cedarc VEncoderRegister:1032: register codec: ‘3:h265’ success.
INFO : cedarc <CedarPluginVENCInit_h265:14107>: register h265 encoder success!
DEBUG : cedarc VEncoderRegister:1022: 1117 register 1:jpeg
DEBUG : cedarc VEncoderRegister:1032: register codec: ‘1:jpeg’ success.
INFO : cedarc <CedarPluginVENCInit_jpeg:3199>: register jpeg encoder success!
DEBUG : cedarc VeInitialize:1138: shutdown power up ve
INFO : cedarc VeInitialize:1172: *** ic_version = 0x1302000023010,
DEBUG : cedarc CdcIniParserInit:36: cannot parse file: /etc/cedarc.conf
DEBUG : cedarc VeInitialize:1186: bUseProcessLock = 0, eVeHwLockType = 0
DEBUG : cedarc VeInitialize:1226: *** nPhyOffset = 0x0
DEBUG : cedarc VeSetSpeed:1734: *** set ve freq to 400 Mhz ***
DEBUG : cedarc VeInitialize:1281: ve init ok
DEBUG : ionAlloc <ion_alloc_open:173>: get offset by ve
DEBUG : ionAlloc <ion_alloc_open:182>: ** phy offset = 0
DEBUG : cedarc VeRelease:1334: ve release ok
DEBUG : cedarc H265SetParameter:13635: VENC_IndexParamProductCase: 0
I0101 01:51:36.975625 1266 VideoEnc_Component.c:7350] set inputPortTunnelFlag = TRUE
I0101 01:51:36.975808 1266 sample_rtsp.c:568] vipp[4] crop en:1 X:0 Y:0 W:1888 H:1072I0101 01:51:36.975895 1266 sample_rtsp.c:581] sub EncppSharpAttenCoefPer: 33%
I0101 01:51:36.975961 1266 sample_rtsp.c:595] sub vbvThreshSize: 24000, vbvBufSize: 152000
I0101 01:51:36.976106 1266 video.c:107] <video_init> [ISP]video device name is vin_video4
I0101 01:51:36.976264 1266 isp_dev.c:566] <isp_video_open> [ISP]open video device[4], detect isp0 success!
I0101 01:51:36.976428 1266 video.c:1063] <video_set_isp_bk_buffer_align> [ISP]video_set_isp_bk_buffer_align yuv_align_en = 0, lbc_align_en = 1
E0101 01:51:36.976519 1266 video.c:1065] <video_set_isp_bk_buffer_align> [ISP_ERR]video4 video_set_isp_bk_buffer_align failed!!!
I0101 01:51:36.976595 1266 videoInputHw.c:1104] <videoInputHw_SetChnAttr> ViCh[4] LBC pix:0x3132434c, line_tar_bits[0]:3072, line_tar_bits[1]:4608
I0101 01:51:36.976863 1266 videoInputHw.c:1124] <videoInputHw_SetChnAttr> bs_len:20480, frm_bit:3840
I0101 01:51:37.196450 1266 videoInputHw.c:1390] <videoInputHw_SetCrop> vipp[4] set crop X:0, Y:0, Width:1888, Height:1072
E0101 01:51:37.196729 1270 isp_dev.c:956] <isp_sensor_get_configs> [ISP_ERR]gc2053_mipi get config failed: Invalid argument (22).
W0101 01:51:37.196847 1270 videoInputHw.c:6258] <VideoInputHw_CapThread> fatal error! Get isp[0] sensor information failed! must be called AW_MPI_ISP_Run before AW_MPI_VI_EnableVipp.
I0101 01:51:37.197610 1270 videoInputHw.c:6297] <VideoInputHw_CapThread> EnableVipp[4]: vfmt.bufs:3, online:0
I0101 01:51:37.227439 1266 videoInputHw.c:1316] <videoInputHw_ChnEnable> receive enable vipp[4] reply: 0x0!
DEBUG : cedarc VencCreate:555: now cedarc log level:3
tag :
author: chenyibin
patch :
DEBUG : cedarc VEncoderRegister:1018: Add ‘2:h264’ fail! ‘2:h264’ already register!
DEBUG : cedarc <CedarPluginVENCInit_h264:13351>: h264 encoder had already register!
DEBUG : cedarc VEncoderRegister:1018: Add ‘3:h265’ fail! ‘3:h265’ already register!
DEBUG : cedarc <CedarPluginVENCInit_h265:14111>: h265 encoder had alread register
DEBUG : cedarc VEncoderRegister:1018: Add ‘1:jpeg’ fail! ‘1:jpeg’ already register!
DEBUG : cedarc <CedarPluginVENCInit_jpeg:3203>: jpeg encoder had already register
DEBUG : cedarc H264EncOpenVer2:10490: icverion = 0x23010, bIsRegVerE230 = 1
DEBUG : cedarc H264SetParameterVer2:12870: VENC_IndexParamProductCase: 0
I0101 01:51:37.242664 1266 VideoEnc_Component.c:7350] set inputPortTunnelFlag = TRUE
I0101 01:51:37.242847 1266 sample_rtsp.c:715] subLapse EncppSharpAttenCoefPer: 33%
I0101 01:51:37.242941 1266 sample_rtsp.c:729] SubLapse vbvThreshSize: 24000, vbvBufSize: 152000
I0101 01:51:37.258178 1266 sample_rtsp.c:1416] Lapse set TimeLapse 1000000 us
I0101 01:51:37.258883 1266 VideoEnc_Component.c:4345] SetTimeLapse: captureIntervalUs=1000000.000000, dstFrameIntervalUs=50000.000000, recType=1
I0101 01:51:37.259060 1266 VideoEnc_Component.c:7350] set inputPortTunnelFlag = TRUE
WARNING: cedarc CheckSetParamInt:1039: Notice: sVbrParam.nQuality is 10, but its suggested value is 1 !
DEBUG : cedarc H265SetParameter:13487: VENC_IndexParamPFrameIntraEn: use_intra_in_p_flag:1
I0101 01:51:37.259356 1274 VideoEnc_Component.c:823] user set stream buffer size[933882]bytes
I0101 01:51:37.259498 1274 VideoEnc_Component.c:833] user set threshSize[147450]bytes
I0101 01:51:37.259579 1274 VideoEnc_Component.c:860] bit rate is 1536Kb, set encode vbv size 933888, frame length threshold 147450
DEBUG : cedarc H265SetParameter:13036: set rot angle: p_enc->rot_angle = 0…
DEBUG : cedarc H265SetParameter:13627: VENC_IndexParamIsNightCaseFlag: is_night_case = 0
I0101 01:51:37.259706 1274 VideoEnc_Component.c:2122] DropFrameNum: 0
I0101 01:51:37.259779 1274 VideoEnc_Component.c:2138] VeRecRefBufReduceEnable: 0
DEBUG : cedarc VencInit:803: func = VencInit, line = 803
DEBUG : cedarc VencInit:816: bOnlineMode = 1, bOnlineChannel = 0
DEBUG : cedarc VencInit:819: lbc2.5 = 0, 2.0 = 1, 1.5 = 0, format = 19
DEBUG : cedarc H265Init:11191: share buf num = 1
DEBUG : cedarc BitStreamCreate:129: BitStreamCreate OK
DEBUG : cedarc h265InitMemRecRefE230:4296: recRefQsubDataBufSize = 190976, recRefQsubInfoBufSize = 8608, lbcBusSize = 3067904, lbcMode = 1
DEBUG : cedarc h265EncInitIPWeight:6836: H265SceneCoef{{20.000, 17.000, 15.000}, {1.000, 1.000, 1.000}}
DEBUG : cedarc h265EncInitIPWeight:6839: H265MoveCoef{{1.000, 0.750, 0.500, 0.250, 0.250}, {1.000, 1.000, 1.000, 1.000, 1.000}}
DEBUG : cedarc H265Init:11435: ********Channal[0]: H265Enc Ver.3975729c81dab9f05e2722e09e64d018b4b03c44 ********
DEBUG : cedarc H265Init:11436: h265 basic params*
DEBUG : cedarc H265Init:11442: profile:1, level:150, frameRate:20, bitRate:1572864, 3d_filter:1
DEBUG : cedarc H265Init:11447: idr_period:100, intra_period:100, gop_size:2, virtual_i_period:0
DEBUG : cedarc H265Init:11452: init_qp:37, color_format:19, rotage_angle:0, longTerm ref:0
DEBUG : cedarc H265Init:11454: size params*
DEBUG : cedarc H265Init:11460: input_size[1920x1088], output_size[2304x1296], vbv_size:933888
DEBUG : cedarc H265Init:11462: bitRate qp params*
DEBUG : cedarc H265Init:11492: bitRate mode: VBR: maxBitRate = 1572864, movingTh = 20, quality = 10, qp_init:37, i_qp[25~45], p_qp[25~45], mb_qp_limit:0
DEBUG : cedarc H265Init:11496: vbv params*
DEBUG : cedarc H265Init:11501: vbv_size:933888, coded_frame_num:0, coded_size:0, maxFrameLen:147450.
DEBUG : cedarc H265Init:11511: rc params*
DEBUG : cedarc H265Init:11512: rc_mode:1, set_mad_th:0
DEBUG : cedarc H265Init:11533: ctu_info_flag:1, bin_flag:1, uMaxBitRate:1572864, nMovingTh:20, nQuality:10
DEBUG : cedarc H265Init:11546: intra inter parm*
DEBUG : cedarc H265Init:11550: intra4x4_flag:1, intra_in_p_flag:1, adaptive_intra_in_p_flag:0
DEBUG : cedarc H265Init:11560: is_night_case:0, is_ipc_case:1
DEBUG : cedarc VencInit:932: pOnlineCxt->eOnlineBufNum = 0
DEBUG : cedarc VencInit:947: func = VencInit, line = 947
DEBUG : cedarc OnlineThreadProcess:2177: online thread start
DEBUG : cedarc H265SetParameter:12827: save bs filename:, save_start_time:0, save_end_time:0
DEBUG : cedarc h264SetH264Param:385: H264SetParameter
DEBUG : cedarc h264SetH264Param:396: profile:77, level:0, frameRate:20, bitRate:256000, idr_period:100, init_qp:37, i_qp[10~50], p_qp[10~50]
DEBUG : cedarc h264SetH264Param:401: 3d_filter:1, lt:0, hpf_flag:0, hpf_level:0
DEBUG : cedarc h264SetH264Param:406: vbr info: maxBitRate = 256000, movingTh = 20, quality = 10
DEBUG : cedarc H264SetParameterVer2:12695: VENC_IndexParamPFrameIntraEn : use_intra_in_p_flag = 1
I0101 01:51:37.282328 1276 VideoEnc_Component.c:823] user set stream buffer size[152000]bytes
I0101 01:51:37.282475 1276 VideoEnc_Component.c:833] user set threshSize[24000]bytes
I0101 01:51:37.282568 1276 VideoEnc_Component.c:860] bit rate is 250Kb, set encode vbv size 152576, frame length threshold 24000
DEBUG : cedarc H264SetParameterVer2:12139: set rot angle: pEnc->rot_angle = 0…
DEBUG : cedarc H264SetParameterVer2:12862: VENC_IndexParamIsNightCaseFlag: is_night_case = 0
I0101 01:51:37.282701 1276 VideoEnc_Component.c:2122] DropFrameNum: 0
I0101 01:51:37.282773 1276 VideoEnc_Component.c:2138] VeRecRefBufReduceEnable: 0
DEBUG : cedarc H264InitVer2:10793: share buf num = 1
DEBUG : cedarc h264InitMemRecRefE230:4838: recRefQsubDataBufSize = 17408, recRefQsubInfoBufSize = 3200, lbcBusSize = 262144, lbcMode = 1
DEBUG : cedarc h264EncInitIPWeight:7945: H264SceneCoef{{20.000, 17.000, 15.000}, {1.000, 1.000, 1.000}}
DEBUG : cedarc h264EncInitIPWeight:7948: H264MoveCoef{{1.000, 0.750, 0.500, 0.250, 0.250}, {1.000, 1.000, 1.000, 1.000, 1.000}}
DEBUG : cedarc H264InitVer2:11016: ********Channal[0]: H264Enc Ver.3975729c81dab9f05e2722e09e64d018b4b03c44 ********
I0101 01:51:37.289901 1280 sample_rtsp.c:1028] VencChn[0] stream_buf:0x11ae030, size=80240
DEBUG : cedarc H264InitVer2:11025: h264Init: input_size[640x368], output_size[640x360], virtual_period:0, color_format:19, vbv_size = 0 MB
DEBUG : cedarc H264InitVer2:11030: h264Init: hp_filter_flag = 0, coef_shift = 3, coef_th = 5, contrast_th = 0, mad_th = 0
DEBUG : cedarc H264InitVer2:11033: h264Init: eRcMode:1, is_night_case = 0, is_ipc_case = 1, longTermRefEnable = 0, eGopMode = 1, eRcMode = 1
DEBUG : cedarc H264InitVer2:11038: h264Init: init_qp:37, i_qp[25~45], p_qp[25~45], EnMbQpLimit:0
DEBUG : cedarc H264SetParameterVer2:12172: save bs filename:, save_start_time:0, save_end_time:0
I0101 01:51:37.295771 1278 VideoEnc_Component.c:823] user set stream buffer size[152000]bytes
I0101 01:51:37.295945 1278 VideoEnc_Component.c:833] user set threshSize[24000]bytes
I0101 01:51:37.296039 1278 VideoEnc_Component.c:860] bit rate is 250Kb, set encode vbv size 152576, frame length threshold 24000
I0101 01:51:37.296172 1278 VideoEnc_Component.c:2122] DropFrameNum: 0
I0101 01:51:37.296247 1278 VideoEnc_Component.c:2138] VeRecRefBufReduceEnable: 0
DEBUG : cedarc h264EncInitIPWeight:7945: H264SceneCoef{{20.000, 17.000, 15.000}, {1.000, 1.000, 1.000I0101 01:51:37.304086 1282 sample_rtsp.c:1028] VencChn[1] stream_buf:0x1290310, size=80240
> I0101 01:51:37.306313 1278 VideoEnc_Component.c:2304] <CedarvVideoEncInit> Color2Grey: 0
> DEBUG : cedarc <VencStart:966>: func = VencStart, line = 966
> E0101 01:51:37.307866 1284 sample_rtsp.c:1005] <getVencStreamThread> fatal error! invalid venc chn 2
> E0101 01:51:37.488796 1272 isp_dev.c:274] <isp_stat_process_buffer> [ISP_ERR]AEWB: stats error, skipping buffer.
> E0101 01:51:37.539437 1272 isp_dev.c:859] <isp_sync_debug_info> [ISP_ERR]VIDIOC_VIN_ISP_GET_INFO error!
> W0101 01:51:37.539588 1272 isp.c:450] <isp_ctx_get_sensor_info> [ISP_WARN]isp debugfs node not support!!!
> Arithmetic exception (core dumped)
please help for solve this problem ![]()
请问您的问题解决了吗,我碰到了相同的问题
请问您的问题解决了吗,我碰到了相同的问题。
