在按照资料中的快速启动接好线上电以后,发现屏幕背面有灯光亮起,但是屏幕无显示,摄像头板子上LED灯微微亮起。进入控制台,复位后看log输出发现有报错。
这里是部分log
GNNE sys clock freq changed: 400000000
GNNE AXI clock freq changed: 400000000
CPU freq 792 MHZ
yangguang: iomux_init ▒Flash: 0 Bytes
MMC: mmc0@93000000: 0, mmc2@93020000: 1
Loading Environment from FAT… OK
In: serial@96000000
Out: serial@96000000
Err: serial@96000000
1228800 bytes read in 50 ms (23.4 MiB/s)
dsi logo start
LT9611 ID 17 02
******Yourself bootcmd is ‘while true ; do fatload mmc 0:2 0x600000 bootm-bbl.img && fatload mmc 0:2 0x2000000 k510-hdmi.dtb && bootm 0x600000 - 0x2000000 ;done’
Display Config done!
dsi logo end use 851 msec
Net:
Warning: ethernet@93030000 (eth0) using random MAC address - 9a
e1:8d:f2:60
eth0: ethernet@93030000
13538468 bytes read in 318 ms (40.6 MiB/s)
65455 bytes read in 16 ms (3.9 MiB/s)
Booting kernel from Legacy Image at 00600000 …
Image Name:
Image Type: RISC-V Linux Kernel Image (uncompressed)
Data Size: 13538404 Bytes = 12.9 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum … OK
Flattened Device Tree blob at 02000000
Booting using the fdt blob at 0x2000000
Loading Kernel Image
Loading Device Tree to 0000000001fed000, end 0000000001ffffae … OK
Starting kernel …
[ 0.000000] OF: fdt: Ignoring memory range 0x0 - 0x200000
[ 0.000000] Linux version 4.17.0 (ubuntu@ubuntu2004) (gcc version 7.3.0 (2019-11-20_nds64le-linux-glibc-v5d-6c120106e03)) #4 SMP PREEMPT Wed May 31 05:14:48 EDT 2023
[ 0.000000] bootconsole [early0] enabled
[ 0.000000] Zone ranges:
[ 0.000000] DMA32 [mem 0x0000000000200000-0x000000000effffff]
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000200000-0x000000000effffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x000000000effffff]
[ 0.000000] software IO TLB [mem 0x0cc66000-0x0ec66000] (32MB) mapped at [ (ptrval)- (ptrval)]
[ 0.000000] elf_platform is rv64i2p0m2p0a2p0f2p0d2p0c2p0xv5-0p0
[ 0.000000] compatible privileged spec version 1.10
[ 0.000000] percpu: Embedded 17 pages/cpu @ (ptrval) s32408 r8192 d29032 u69632
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 60095
[ 0.000000] Kernel command line: root=/dev/mmcblk0p3 ro console=ttyS0,115200n8 debug loglevel=7 rootfstype=ext2 isolcpus=1
[ 0.000000] Dentry cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.000000] Sorting __ex_table…
[ 0.000000] Memory: 195268K/243712K available (6652K kernel code, 563K rwdata, 2978K rodata, 223K init, 737K bss, 48444K reserved, 0K cma-reserved)
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 72, nr_irqs: 72, preallocated irqs: 0
[ 0.000000] riscv,cpu_intc,0: 64 local interrupts mapped
[ 0.000000] riscv,cpu_intc,1: 64 local interrupts mapped
[ 0.000000] riscv,plic0,9ec00000: mapped 140 interrupts to 2/4 handlers
[ 0.000000] clocksource: riscv_clocksource: mask: 0xffffffffffffffff max_cycles: 0x127350b88, max_idle_ns: 1763180808480 ns
[ 0.000010] sched_clock: 64 bits at 1250kHz, resolution 800ns, wraps every 4398046510800ns
[ 0.008904] Console: colour dummy device 40x30
[ 0.013212] Calibrating delay loop (skipped), value calculated using timer frequency… 2.50 BogoMIPS (lpj=12500)
[ 0.023386] pid_max: default: 32768 minimum: 301
[ 0.028145] Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
[ 0.034533] Mountpoint-cache hash table entries: 512 (order: 0, 4096 bytes)
[ 0.094701] Hierarchical SRCU implementation.
[ 0.114782] smp: Bringing up secondary CPUs …
[ 0.154913] CPU1: online
[ 0.157452] smp: Brought up 1 node, 2 CPUs
[ 0.162152] devtmpfs: initialized
[ 0.188310] random: get_random_u32 called from bucket_table_alloc+0x198/0x1d8 with crng_init=0
[ 0.207696] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.217435] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.223694] pinctrl core: initialized pinctrl subsystem
[ 0.229423] NET: Registered protocol family 16
[ 0.316587] [K510_RESET]:sysctl reset phy addr 0x97002000
[ 0.316601] [K510_RESET]:k510_reset_probe ok!
[ 0.326421] pinctrl-k510 97040000.iomux: 1024 pins, size 4096
[ 0.377983] k510-powerdomain 97003000.sysctl_power: powerdomain init ok
[ 0.385128] SCSI subsystem initialized
[ 0.389276] usbcore: registered new interface driver usbfs
[ 0.394670] usbcore: registered new interface driver hub
[ 0.400128] usbcore: registered new device driver usb
[ 0.406041] [K510_RESET]:k510_reset_deassert id = 0x00408001
[ 0.412832] [K510_RESET]:k510_reset_deassert id = 0x00408002
[ 0.419264] [K510_RESET]:k510_reset_deassert id = 0x00448000
[ 0.428528] [K510_RESET]:k510_reset_deassert id = 0x00448001
[ 0.435481] media: Linux media interface: v0.10
[ 0.439903] Linux video capture interface: v2.00
[ 0.444741] Advanced Linux Sound Architecture Driver Initialized.
[ 0.452288] clocksource: Switched to clocksource riscv_clocksource
[ 0.470384] NET: Registered protocol family 2
[ 0.475660] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes)
[ 0.483288] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.490244] TCP bind hash table entries: 2048 (order: 3, 32768 bytes)
[ 0.496720] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.503293] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.508995] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.515563] NET: Registered protocol family 1
[ 0.550613] RPC: Registered named UNIX socket transport module.
[ 0.556456] RPC: Registered udp transport module.
[ 0.561058] RPC: Registered tcp transport module.
[ 0.565773] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.584749] Initialise system trusted keyrings
[ 0.589348] workingset: timestamp_bits=62 max_order=16 bucket_order=0
[ 0.618266] NFS: Registering the id_resolver key type
[ 0.623235] Key type id_resolver registered
[ 0.627324] Key type id_legacy registered
[ 0.631335] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.644493] NET: Registered protocol family 38
[ 0.648787] Key type asymmetric registered
[ 0.652932] Asymmetric key parser ‘x509’ registered
[ 0.657740] io scheduler noop registered
[ 0.662052] io scheduler cfq registered (default)
[ 0.666664] io scheduler mq-deadline registered
[ 0.671103] io scheduler kyber registered
[ 0.682585] insmode kendryte_td_init
[ 0.686686] kendryte_td_probe start
[ 0.765964] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[▒▒▒▒5▒W▒▒▒▒ՠ+▒▒▒d▒n▒▒V▒[▒▒▒r▒▒1▒Wʲ▒▒▒▒▒▒9.+▒▒▒▒▒▒a*▒I
¸.▒0▒▒▒(▒n▒=▒L ▒▒s▒%▒u▒ꠌ▒ҕ▒▒J▒A▒6M
5
[ 0.787028] console [ttyS0] enabled
[ 0.793860] bootconsole [early0] disabled
[ 0.803456] 96010000.serial: ttyS1 at MMIO 0x96010000 (irq = 2, base_baud = 1562500) is a 16550A
[ 0.818805] start kendryte_dsi_probe
[ 0.822746] SYSCTL_CLK_DISPLAY_PIXEL is 107
[ 0.827027] SYSCTL_CLK_DISP_SYS_AND_APB_CLK_DIV_DSI_SYSTEM is 100
[ 0.833248] SYSCTL_CLK_DISP_SYS_AND_APB_CLK_DIV_DSI_APB is 1f
[ 0.839096] get clk success
[ 0.842872] kendryte_layer_probe start
[ 0.846948] vo apb clk is 1f
[ 0.850008] vo axi clk is 3
[ 0.854432] kendryte-drm 99900000.noc_bus:apb_bus:display-subsystem: Linked as a consumer to 92710000.mipi_dsi
[ 0.865092] kendryte-drm 99900000.noc_bus:apb_bus:display-subsystem: Linked as a consumer to 92700000.vop
[ 0.875248] kendryte_dsi_bind is start
[ 0.879245] kendryte-drm 99900000.noc_bus:apb_bus:display-subsystem: failed to bind 92710000.mipi_dsi (ops kendryte_dsi_ops): -517
[ 0.891247] kendryte-drm 99900000.noc_bus:apb_bus:display-subsystem: master bind failed: -517
[ 0.899900] drm_debug, comp add match ret = -517
[ 0.904562] kendryte_drv_probe:disp_reset_control
[ 0.923979] i2c_add_driver start
[ 0.927506] lt9611_probe success
[ 0.930828] lt9611 check success
[ 0.934352] regmap_init success
[ 0.937606] dsi0_node name 1mipi_dsi
[ 0.941189] get_remote_port name 1port
[ 0.944980] get_remote_por_parent name 1mipi_dsi
[ 0.949602] lt9611_parse success
[ 1.152312] lt9611_reset success
[ 1.156861] ret 0
[ 1.160077] LT9611 rev1 17
[ 1.164100] LT9611 ret 0 rev1 02
[ 1.167338] lt9611 2-003b: LT9611 revision: 0x2
[ 1.171870] lt9611_read_device success
[ 1.176035] lt9611_irq success
[ 1.179188] drm_biidge succss
[ 1.204567] loop: module loaded
[ 1.210337] k510 dsp driver loaded, mapped sysctl base 97000000 at ffffffd0041c0000
[ 1.218973] drivers/misc/ws2812b.c:led_init:(658): spi_register_driver success!!!
[ 1.227805] dw_spi_mmio 96080000.spi: DMA init failed
[ 1.233787] dws->current_freq: 5952380, div: 42
[ 1.632316] spi-nand: probe of spi0.0 failed with error -110
[ 1.638744] dws->txburst: 16
[ 1.641634] dws->dma_sg_burst: 0
[ 1.646770] dws->txburst: 16
[ 1.649664] dws->dma_sg_burst: 0
[ 1.655417] libphy: Fixed MDIO Bus: probed
[ 1.659733] tun: Universal TUN/TAP device driver, 1.6
[ 1.666564] libphy: MACB_mii_bus: probed
[ 1.694485] Generic PHY 93030000.emac-ffffffff:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=93030000.emac-ffffffff:00, irq=POLL)
[ 1.707142] macb 93030000.emac eth0: Cadence GEM rev 0x1107010c at 0x93030000 irq 54 (9a
e1:8d:f2:60)
[ 1.719319] ftmac100: Loading version 0.2 …
[ 1.725093] usbcore: registered new interface driver usb-storage
[ 1.732710] cdncusb 93060000.usb: Cadence Host USB Driver
[ 1.738169] cdncusb 93060000.usb: new USB bus registered, assigned bus number 1
[ 1.746672] hub 1-0:1.0: USB hub found
[ 1.750484] hub 1-0:1.0: 1 port detected
[ 1.862431] cdn_h_hub_status_data value 64
[ 1.873896] Goodix-TS 1-005d: ID 911, version: 1060
[ 1.924699] input: Goodix Capacitive TouchScreen as /devices/platform/99900000.noc_bus/99900000.noc_bus:apb_bus/99900000.noc_bus:apb_bus:manage_subsys/97080000.i2c/i2c-1/1-005d/input/input0
[ 1.943872] into probe rtc
[ 1.946713] info->irq_alarm is 22 info->irq_tick is 21
[ 1.952518] kendryte-rtc 970d0000.rtc: rtc core: registered kendryte as rtc0
[ 1.960555] i2c /dev entries driver
[ 1.965307] imx219_0 0-0010: driver version: 00.01.02
[ 1.973503] random: fast init done
[ 1.982020] imx219_0 0-0010: Model ID 0x0219, Lot ID 0x5a2331, Chip ID 0x07a0
[ 1.989563] imx219_1 2-0010: driver version: 00.01.02
[ 2.002937] imx219_1 2-0010: Model ID 0x0219, Lot ID 0x542148, Chip ID 0x061b
[ 2.010746] this is hello word
[ 2.016733] isp probe ok, mapped 92600000 at ffffffd004300000, mapped size 2097152
[ 2.024695] get csi_en err
[ 2.027492] isp gpio get succes
[ 2.030721] mipi dsi rst succcess
[ 2.034145] isp has IRQ resource, irq 58
[ 2.038176] lat->irq_vo is 67 ,plat->irq_ds2 is 58
[ 2.043450] mipi_rxdphy_init done
[ 2.047779] (NULL device *): al5r_codec_probe
[ 2.053606] k510-isp 92600000.isp1: k510isp_probe:start
[ 2.061137] k510-isp 92600000.isp1: mem->start = 0x92600000,isp->isp_regs= 0x4580000
[ 2.069442] k510-isp 92600000.isp1: f2k_revision 0.3.5.4.0 found
[ 2.075727] [K510_RESET]:k510_reset id = 0x01344f80, offset = 0x00000134 type = 1 done = 31 reset =0
[ 2.075741] [K510_RESET]:k510_reset id = 0x01384f80, offset = 0x00000138 type = 1 done = 31 reset =0
[ 2.084908] [K510_RESET]:k510_reset id = 0x013c4f80, offset = 0x0000013c type = 1 done = 31 reset =0
[ 2.094066] [K510_RESET]:k510_reset id = 0x01404f80, offset = 0x00000140 type = 1 done = 31 reset =0
[ 2.103224] [K510_RESET]:k510_reset id = 0x01504f80, offset = 0x00000150 type = 1 done = 31 reset =0
[ 2.112469] [K510_RESET]:k510_reset id = 0x01484f80, offset = 0x00000148 type = 1 done = 31 reset =0
[ 2.121752] [K510_RESET]:k510_reset id = 0x01244f80, offset = 0x00000124 type = 1 done = 31 reset =0
[ 2.130958] [K510_RESET]:k510_reset id = 0x01584f80, offset = 0x00000158 type = 1 done = 31 reset =0
[ 2.140120] [K510_RESET]:k510_reset id = 0x01284f80, offset = 0x00000128 type = 1 done = 31 reset =0
[ 2.149276] [K510_RESET]:k510_reset id = 0x012c4f80, offset = 0x0000012c type = 1 done = 31 reset =0
[ 2.158554] k510-isp 92600000.isp1: k510isp_csi2_init:start
[ 2.173313] k510-isp 92600000.isp1: k510isp_vi_init:start
[ 2.178739] [K510_RESET]:k510_reset id = 0x01504f80, offset = 0x00000150 type = 1 done = 31 reset =0
[ 2.178751] [K510_RESET]:k510_reset id = 0x01484f80, offset = 0x00000148 type = 1 done = 31 reset =0
[ 2.187913] k510-isp 92600000.isp1: k510isp_f2k_init:start
[ 2.202566] k510-isp 92600000.isp1: k510isp_f2k_init_entities:start
[ 2.208863] k510-isp 92600000.isp1: k510isp_r2k_init: start
[ 2.214585] k510-isp 92600000.isp1: k510isp_video_register:start
[ 2.220935] k510-isp 92600000.isp1: k510isp_video_register:start
[ 2.227196] k510-isp 92600000.isp1: k510isp_video_register:start
[ 2.233434] k510-isp 92600000.isp1: k510isp_video_register:start
[ 2.239628] k510-isp 92600000.isp1: k510isp_video_register:start
[ 2.245842] k510-isp 92600000.isp1: k510isp_video_register:start
[ 2.252082] k510-isp 92600000.isp1: k510isp_video_register:start
[ 2.258304] k510-isp 92600000.isp1: k510isp_video_register:start
[ 2.264521] k510-isp 92600000.isp1: k510isp_video_register:start
[ 2.270698] k510-isp 92600000.isp1: k510isp_video_register:start
[ 2.281296] [K510_RESET]:k510_reset_deassert id = 0x00408003
[ 2.281992] [K510_RESET]:k510_reset_deassert id = 0x00408004
[ 2.288172] [K510_RESET]:k510_reset_deassert id = 0x00408005
[ 2.301964] sdhci: Secure Digital Host Controller Interface driver
[ 2.308212] sdhci: Copyright(c) Pierre Ossman
[ 2.313359] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.319334] sd_protect:0x41f9000 0x41f9168 0x70000
[ 2.324184] [K510_POWER]:sdhci_cdns_probe pm_runtime_enable!
[ 2.330002] [K510_RESET]:sdhci_cdns_probe reset!
[ 2.334753] [K510_RESET]:k510_reset id = 0x00c84f80, offset = 0x000000c8 type = 1 done = 31 reset =0
[ 2.334793] [K510_CLOCK]:sdhci_cdns_probe clock rate 200000000
[ 2.350154] mmc0: Unknown controller version (3). You may experience problems.
[ 2.388760] mmc0: SDHCI controller on 93000000.sdio [93000000.sdio] using ADMA 64-bit
[ 2.397105] sd_protect:0x4283000 0x4283168 0x70000
[ 2.401969] [K510_POWER]:sdhci_cdns_probe pm_runtime_enable!
[ 2.407830] [K510_RESET]:sdhci_cdns_probe reset!
[ 2.412596] [K510_RESET]:k510_reset id = 0x00cc4f80, offset = 0x000000cc type = 1 done = 31 reset =0
[ 2.412636] [K510_CLOCK]:sdhci_cdns_probe clock rate 200000000
[ 2.428086] sdhci-cdns 93010000.sdio: allocated mmc-pwrseq
[ 2.433665] mmc1: Unknown controller version (3). You may experience problems.
[ 2.472147] mmc1: SDHCI controller on 93010000.sdio [93010000.sdio] using ADMA 64-bit
[ 2.480604] sd_protect:0x428b000 0x428b168 0x70000
[ 2.485553] [K510_POWER]:sdhci_cdns_probe pm_runtime_enable!
[ 2.491349] [K510_RESET]:sdhci_cdns_probe reset!
[ 2.496182] [K510_RESET]:k510_reset id = 0x00d04f80, offset = 0x000000d0 type = 1 done = 31 reset =0
[ 2.496222] [K510_CLOCK]:sdhci_cdns_probe clock rate 200000000
[ 2.511810] mmc0: new high speed MMC card at address 0001
[ 2.518170] mmc2: Unknown controller version (3). You may experience problems.
[ 2.527710] mmcblk0: mmc0:0001 4FTE4R 3.64 GiB
[ 2.535582] mmcblk0boot0: mmc0:0001 4FTE4R partition 1 4.00 MiB
[ 2.544102] mmcblk0boot1: mmc0:0001 4FTE4R partition 2 4.00 MiB
[ 2.550928] mmcblk0rpmb: mmc0:0001 4FTE4R partition 3 512 KiB, chardev (246:0)
[ 2.560343] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2.567293] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.573319] mmcblk0: p1 p2 p3 p4
[ 2.581592] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.587208] mmc2: SDHCI controller on 93020000.sdio [93020000.sdio] using ADMA 64-bit
[ 2.597784] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.605368] usbcore: registered new interface driver usbhid
[ 2.610956] usbhid: USB HID core driver
[ 2.616291] canaan_mailbox 970e0000.mailbox: Mailbox enabled
[ 2.623522] mmc1: queuing unknown CIS tuple 0x81 (9 bytes)
[ 2.629600] mailbox_client 1087ffe00.mailbox_client: Successfully registered
[ 2.735682] mmc1: new high speed SDIO card at address 0001
[ 2.881292] canaan-snd-nau8822 sound: ASoC: CPU DAI (null) not registered
[ 2.888231] canaan-snd-nau8822 sound: Soc register card failed -517
[ 2.897088] NET: Registered protocol family 10
[ 2.913662] Segment Routing with IPv6
[ 2.917448] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 2.924420] NET: Registered protocol family 17
[ 2.928907] NET: Registered protocol family 15
[ 2.933920] Key type dns_resolver registered
[ 2.939363] Loading compiled-in X.509 certificates
[ 2.964100] kendryte_dsi_bind is start
[ 2.968103] lt9611_attach_dsi
[ 2.971335] kendryte_dsi 92710000.mipi_dsi: Attached device lt9611
[ 2.977678] kendryte-drm 99900000.noc_bus:apb_bus:display-subsystem: bound 92710000.mipi_dsi (ops kendryte_dsi_ops)
[ 3.102396] kendryte-drm 99900000.noc_bus:apb_bus:display-subsystem: bound 92700000.vop (ops kendryte_layer_component_ops)
[ 3.113477] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 3.120096] [drm] No driver support for vblank timestamp query.
[ 3.126065] show_loader_logo start
[ 3.130260] [drm] Initialized kendryte-drm 1.0.0 2021104 for 99900000.noc_bus:apb_bus:display-subsystem on minor 0
[ 3.140708] drm_debug, comp add match ret = 0
[ 3.145104] kendryte_drv_probe:disp_reset_control
[ 3.150443] canaan_thermal 970e0300.tsensor: clk: 125000000, irq: 28,
[ 3.177046] canaan-snd-nau8822 sound: nau8822-hifi ↔ 96060000.i2s mapping ok
[ 3.290074] [K510_POWER]:skip power off disp_domain
[ 3.296647] input: 99900000.noc_bus:gpio-keys as /devices/platform/99900000.noc_bus/99900000.noc_bus:gpio-keys/input/input1
[ 3.307877] [K510_POWER]:skip power off sram1_domain
[ 3.312898] [K510_POWER]:skip power off sram0_domain
[ 3.317871] [K510_POWER]:skip power off mctl_domain
[ 3.323268] kendryte-rtc 970d0000.rtc: hctosys: unable to read the hardware clock
[ 3.331415] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 3.339268] [K510_POWER]:skip power off ai_domain
[ 3.344008] [K510_POWER]:skip power off ax25m_domain
[ 3.351698] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 3.358607] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 3.367386] [dhd] _dhd_module_init: in Dongle Host Driver, version 101.10.361.28 (wlan=r892223-20221116-5)
[ 3.367386] drivers/net/wireless/bcmdhd compiled on May 31 2023 at 01:50:26
[ 3.367386]
[ 3.385532] cfg80211: failed to load regulatory.db
[ 3.390904] [dhd] ======== Get GPIO from DTS(android,bcmdhd_wlan) ========
[ 3.397898] [dhd] dhd_wlan_init_gpio: gpio_request(494) for WL_REG_ON failed -16
[ 3.405352] [dhd] dhd_wlan_init_gpio: WL_REG_ON=-1
[ 3.410148] [dhd] STATIC-MSG) dhd_static_buf_init : 101.10.361.26 (wlan=r892223-20221011-1)
[ 3.418696] [dhd] STATIC-MSG) dhd_init_wlan_mem : prealloc ok for index 0: 1099776(1074K)
[ 3.426934] [dhd] dhd_wifi_platform_load: Enter
[ 3.431472] [dhd] Power-up adapter ‘DHD generic adapter’
[ 3.437012] [dhd] dummy_probe: enter
[ 3.440812] [dhd] dummy_probe: enter
[ 3.444540] [dhd] wifi_platform_set_power = 1, delay: 200 msec
[ 3.450378] [dhd] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 3.772284] [dhd] wifi_platform_bus_enumerate device present 1
[ 3.778122] [dhd] ======== Card detection to detect SDIO card! ========
[ 3.800905] [dhd] bcmsdh_register: register client driver
[ 3.806443] [dhd] bcmsdh_sdmmc_probe: Enter num=1
[ 3.811296] [dhd] bcmsdh_sdmmc_probe: Enter num=2
[ 3.816028] [dhd] bus num (host idx)=1, slot num (rca)=1
[ 3.821345] [dhd] found adapter info ‘DHD generic adapter’
[ 3.826856] [dhd] STATIC-MSG) dhd_wlan_mem_prealloc : section 3, size 139264
[ 3.834169] [dhd] succeed to alloc static buf
[ 3.838540] [dhd] STATIC-MSG) dhd_wlan_mem_prealloc : section 4, size 0
[ 3.845308] [dhd] sdioh_attach: set sd_f2_blocksize 256
[ 3.850590] [dhd] sdioh_attach: sd clock rate = 50000000
[ 3.856305] [dhd] dhdsdio_probe : no mutex held
[ 3.860843] [dhd] dhdsdio_probe : set mutex lock
[ 3.865634] [dhd] F1 signature read @0x18000000=0x1541a9a6
[ 3.874476] [dhd] F1 signature OK, socitype:0x1 chip:0xa9a6 rev:0x1 pkg:0x4
[ 3.882672] [dhd] DHD: dongle ram size is set to 524288(orig 524288) at 0x0
[ 3.890861] [dhd] STATIC-MSG) dhd_wlan_mem_prealloc : section 7, size 32424
[ 3.897939] [dhd] dhd_conf_set_chiprev : devid=0xa9a6, chip=0xa9a6, chiprev=1
[ 3.905176] [dhd] STATIC-MSG) dhd_wlan_mem_prealloc : section 0, size 10320
[ 3.912916] [dhd] STATIC-MSG) dhd_wlan_mem_prealloc : section 5, size 65536
[ 3.940889] [dhd] STATIC-MSG) dhd_wlan_mem_prealloc : section 19, size 65688
[ 3.948264] [dhd] STATIC-MSG) dhd_wlan_mem_prealloc : section 20, size 262144
[ 3.956027] [dhd] STATIC-MSG) dhd_wlan_mem_prealloc : section 22, size 65536
[ 3.963520] [dhd] dhd_attach(): thread:dhd_watchdog_thread:74 started
[ 3.970104] [dhd] dhd_attach(): thread:dhd_dpc:75 started
[ 3.975757] [dhd] dhd_attach(): thread:dhd_rxf:76 started
[ 3.981187] [dhd] dhd_deferred_work_init: work queue initialized
[ 3.987260] [dhd] dhd_tcpack_suppress_set: TCP ACK Suppress mode 0 → mode 2
[ 3.994331] [dhd] dhd_tcpack_suppress_set: TCPACK_INFO_MAXNUM=4, TCPDATA_INFO_MAXNUM=4
[ 4.002343] [dhd] sdioh_cis_read: func_cis_ptr[0]=0x1070
[ 4.020162] [dhd] STATIC-MSG) dhd_wlan_mem_prealloc : section 1, size 10300
[ 4.027172] [dhd] STATIC-MSG) dhd_wlan_mem_prealloc : section 2, size 65536
[ 4.034372] [dhd] dhdsdio_probe_init: making DHD_BUS_DOWN
[ 4.040049] [dhd] Dongle Host Driver, version 101.10.361.28 (wlan=r892223-20221116-5)
[ 4.040049] drivers/net/wireless/bcmdhd compiled on May 31 2023 at 01:50:26
[ 4.040049]
[ 4.057425] [dhd] Register interface [wlan0] MAC: 8c:f7:10:8e:d4:68
[ 4.057425]
[ 4.065528] [dhd] [wlan0] wl_android_wifi_off : in g_wifi_on=1, on_failure=1
[ 4.072676] [dhd] dhd_bus_devreset: == Power OFF ==
[ 4.077865] [dhd] dhd_bus_stop: making DHD_BUS_DOWN
[ 4.082802] [dhd] dhd_bus_devreset: making dhdpub up FALSE
[ 4.088294] [dhd] dhd_txglom_enable: enable 0
[ 4.092707] [dhd] dhd_bus_devreset: making DHD_BUS_DOWN
[ 4.098048] [dhd] wifi_platform_set_power = 0, delay: 0 msec
[ 4.103756] [dhd] ======== PULL WL_REG_ON(-1) LOW! ========
[ 4.109332] [dhd] [wlan0] wl_android_wifi_off : out
[ 4.114307] [dhd] dhdsdio_probe : mutex is released.
[ 4.119448] [dhd] _dhd_module_init: Exit err=0
[ 4.123933] ALSA device list:
[ 4.126905] #0: CANAAN-I2S
[ 4.130500] ttyS0 - failed to request DMA
[ 4.136588] VFS: Mounted root (ext2 filesystem) readonly on device 179:3.
[ 4.144382] devtmpfs: mounted
[ 4.147841] Freeing unused kernel memory: 220K
[ 4.152419] This architecture does not have kernel memory protection.
Sysinit starting
/dev/mmcblk0p3 was not cleanly unmounted, check forced.
/dev/mmcblk0p3: ***** REBOOT SYSTEM *****
/dev/mmcblk0p3: 4462/32768 files (0.1% non-contiguous), 86016/131072 blocks
Wed Dec 1 10:00:00 UTC 2010
Starting rngd: OK
[ 6.160536] [dhd] dhd_pri_open : no mutex held
[ 6.172715] [dhd] dhd_pri_open : set mutex lock
[ 6.177264] [dhd] [wlan0] dhd_open : Enter
[ 6.181367] [dhd] Dongle Host Driver, version 101.10.361.28 (wlan=r892223-20221116-5)
[ 6.181367] drivers/net/wireless/bcmdhd compiled on May 31 2023 at 01:50:26
[ 6.181367]
[ 6.222316] [dhd] dhd_open: ######### called for ifidx=0 #########
[ 6.228520] [dhd] [wlan0] wl_android_wifi_on : in g_wifi_on=0
[ 6.252309] [dhd] wifi_platform_set_power = 1, delay: 200 msec
[ 6.258151] [dhd] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 6.272364] random: crng init done
[ 6.602295] [dhd] sdio_sw_reset: call mmc_hw_reset
[ 6.654338] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 6.661258] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 6.668540] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 6.676586] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 6.685345] mmc1: queuing unknown CIS tuple 0x81 (9 bytes)
[ 6.767489] [dhd] sdioh_start: set sd_f2_blocksize 256
[ 6.773013] [dhd] dhd_bus_devreset: == Power ON ==
[ 6.777948] [dhd] F1 signature read @0x18000000=0x1541a9a6
[ 6.787232] [dhd] F1 signature OK, socitype:0x1 chip:0xa9a6 rev:0x1 pkg:0x4
[ 6.795474] [dhd] DHD: dongle ram size is set to 524288(orig 524288) at 0x0
[ 6.803990] [dhd] dhd_bus_devreset: making DHD_BUS_DOWN
[ 6.809277] [dhd] dhdsdio_probe_init: making DHD_BUS_DOWN
[ 6.815136] [dhd] dhd_conf_set_path_params : Final fw_path=/lib/firmware/fw_bcm43438a1.bin
[ 6.823436] [dhd] dhd_conf_set_path_params : Final nv_path=/lib/firmware/nvram_ap6212a.txt
[ 6.831706] [dhd] dhd_conf_set_path_params : Final clm_path=/lib/firmware/clm_bcm43438a1.blob
[ 6.840576] [dhd] dhd_conf_set_path_params : Final conf_path=/lib/firmware/config.txt
[ 6.849141] [dhd] dhd_get_download_buffer: Open image file failed /lib/firmware/config.txt
[ 6.857852] [dhd] dhd_conf_read_config : Ignore config file /lib/firmware/config.txt
[ 6.866793] [dhd] dhd_os_open_image1: /lib/firmware/fw_bcm43438a1.bin (422713 bytes) open success
[ 6.947074] [dhd] dhd_os_open_image1: /lib/firmware/nvram_ap6212a.txt (1017 bytes) open success
[ 6.956513] [dhd] #AP6212A_NVRAM_V1.0.2_20191121
[ 6.961969] [dhd] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 7.046441] [dhd] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 7.055179] [dhd] wlc_ver_major 4, wlc_ver_minor 1
[ 7.060813] [dhd] dhd_preinit_ioctls: preinit_status IOVAR not supported, use legacy preinit
[ 7.069810] [dhd] dhd_tcpack_suppress_set: TCP ACK Suppress mode 2 → mode 0
[ 7.076904] [dhd] dhd_tcpack_suppress_set: TCPACK_INFO_MAXNUM=4, TCPDATA_INFO_MAXNUM=4
[ 7.086109] [dhd] dhd_legacy_preinit_ioctls: use firmware generated mac_address 8c:f7:10:8e:d4:68
[ 7.095096] [dhd] dhd_apply_default_clm: Ignore clm file /lib/firmware/clm_bcm43438a1.blob
[ 7.106718] [dhd] Firmware up: op_mode=0x0005, MAC=8c:f7:10:8e:d4:68
[ 7.113772] [dhd] Disable tdls_auto_op failed. -1
[ 7.121395] [dhd] dhd_legacy_preinit_ioctls Set scancache failed -23
[ 7.129006] [dhd] dhd_legacy_preinit_ioctls: event_log_max_sets: 31 ret: -23
[ 7.139289] [dhd] arp_enable:1 arp_ol:0
[ 7.150008] [dhd] Driver: 101.10.361.28 (wlan=r892223-20221116-5)
[ 7.150008] [dhd] Firmware: wl0: Mar 22 2022 15:43:28 version 7.45.96.132 (gf22502e8) FWID 01-7afc93f0 es7.c5.n4.a3
[ 7.150008] [dhd] CLM: 7.11.15 (2014-05-26 10:53:55)
[ 7.173067] [dhd] dhd_txglom_enable: enable 1
[ 7.177439] [dhd] dhd_conf_set_txglom_params : txglom_mode=copy
[ 7.183687] [dhd] dhd_conf_set_txglom_params : txglomsize=36, deferred_tx_len=0
[ 7.191005] [dhd] dhd_conf_set_txglom_params : txinrx_thres=-1, dhd_txminmax=1
[ 7.198532] [dhd] dhd_conf_set_txglom_params : tx_max_offset=0, txctl_tmo_fix=300
[ 7.206055] [dhd] dhd_conf_get_disable_proptx : fw_proptx=1, disable_proptx=-1
[ 7.214913] [dhd] dhd_wlfc_hostreorder_init(): successful bdcv2 tlv signaling, 64
[ 7.224422] [dhd] dhd_pno_init: Support Android Location Service
[ 7.231803] [dhd] dhd_wl_ioctl_get_intiovar: get int iovar wnm_bsstrans_resp failed, ERR -23
[ 7.240608] [dhd] failed to get wnm_bsstrans_resp
[ 7.246116] [dhd] failed to set WNM capabilities
[ 7.277418] [dhd] dhd_legacy_preinit_ioctls: Failed to get preserve log # !
[ 7.310364] [dhd] dhd_conf_set_country : set country CN, revision 0
[ 7.319469] [dhd] CFG80211-ERROR) wl_cfg80211_event : Event handler is not created (WLC_E_COUNTRY_CODE_CHANGED)
[ 7.330748] [dhd] dhd_conf_set_country : Country code: CN (CN/0)
[ 7.342720] [dhd] CONFIG-ERROR) dhd_conf_set_intiovar : ampdu_mpdu setting failed -29
[ 7.351379] [dhd] [wlan0] wl_android_wifi_on : Success
[ 7.396396] [dhd] CFG80211-ERROR) __wl_update_wiphybands : error reading vhtmode (-23)
[ 7.407100] [dhd] CFG80211-ERROR) __wl_update_wiphybands : error get bw_cap 6g (-13)
[ 7.429549] [dhd] CFG80211-ERROR) init_roam_cache : roamscan_mode iovar failed. -23
[ 7.437246] [dhd] CFG80211-ERROR) wl_cfg80211_up : Failed to enable RCC.
[ 7.445432] [dhd] [wlan0] dhd_open : Exit ret=0
[ 7.449975] [dhd] [wlan0] dhd_pri_open : tx queue started
[ 7.455673] [dhd] dhd_pri_open : mutex is released.
[ 7.724070] [dhd] P2P interface registered
[ 7.758799] [dhd] WLC_E_IF: NO_IF set, event Ignored
[ 7.766296] [dhd] P2P interface started
[ 7.919460] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
udhcpc: started, v1.31.1
udhcpc: sending discover
[ 8.992441] macb 93030000.emac eth0: unable to generate target frequency: 125000000 Hz
[ 9.000386] macb 93030000.emac eth0: link up (1000/Half)
[ 9.006318] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
udhcpc: no lease, forking to background
#############SDK VERSION######################################
v1.9-ed9472d-20230605-030730EDT-ubuntu-ubuntu2004
ifplugd(eth0): started: BusyBox v1.31.1 (2023-05-31 01:40:29 EDT)
ifplugd(eth0): using SIOCETHTOOL detection mode
ifplugd(eth0): link is up
[ 17.688600] lt9611_connect_detect 2
error: suitable connector not found
error: available drm devices not found
get resolution error!
[ 19.203010] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
