按东山派壹号操作手册,下载东山派壹号的SDK相关资料,并完成project烧录;烧录成功后,按复位进入kernel,打印提示缺少 .ko文件;检查后发现 /lib/modules/下面缺少 .ko,/config/modules目录下也缺少.ko;编译过程我没有做任何改动,直接按手册操作的。这是什么问题,请帮忙解决一下
UBIFS (ubi0:3): FS size: 3047424 bytes (2 MiB, 24 LEBs), journal size 1142785 bytes (1 MiB, 8 LEBs)
UBIFS (ubi0:3): reserved for root: 0 bytes (0 KiB)
UBIFS (ubi0:3): media format: w4/r0 (latest is w4/r0), UUID 0C838E3E-715A-4A3C-944F-4EF7325F5A7E, small LPT model
chmod: /etc/core.sh: Read-only file system
[1]+ Done busybox telnetd
insmod: can’t read ‘/config/modules/4.9.84/cifs.ko’: No such file or directory
insmod: can’t read ‘/config/modules/4.9.84/nls_utf8.ko’: No such file or directory
insmod: can’t read ‘/config/modules/4.9.84/grace.ko’: No such file or directory
insmod: can’t read ‘/config/modules/4.9.84/sunrpc.ko’: No such file or directory
insmod: can’t read ‘/config/modules/4.9.84/lockd.ko’: No such file or directory
insmod: can’t read ‘/config/modules/4.9.84/nfs.ko’: No such file or directory
insmod: can’t read ‘/config/modules/4.9.84/nfsv2.ko’: No such file or directory
insmod: can’t read ‘/config/modules/4.9.84/fat.ko’: No such file or directory
insmod: can’t read ‘/config/modules/4.9.84/msdos.ko’: No such file or directory
insmod: can’t read ‘/config/modules/4.9.84/vfat.ko’: No such file or directory
insmod: can’t read ‘/config/modules/4.9.84/ntfs.ko’: No such file or directory
insmod: can’t read ‘/config/modules/4.9.84/usb-common.ko’: No such file or directory
insmod: can’t read ‘/config/modules/4.9.84/usbcore.ko’: No such file or directory
insmod: can’t read ‘/config/modules/4.9.84/ehci-hcd.ko’: No such file or directory
insmod: can’t read ‘/config/modules/4.9.84/usb-storage.ko’: No such file or directory
insmod: can’t read ‘/config/modules/4.9.84/usbhid.ko’: No such file or directory
insmod: can’t read ‘/config/modules/4.9.84/mdrv_crypto.ko’: No such file or directory
insmod: can’t read ‘/config/modules/4.9.84/mhal.ko’: No such file or directory
insmod: can’t read ‘/config/modules/4.9.84/mi_common.ko’: No such file or directory
insmod: can’t read ‘/config/modules/4.9.84/mi_sys.ko’: No such file or directory
insmod: can’t read ‘/config/modules/4.9.84/mi_gfx.ko’: No such file or directory
insmod: can’t read ‘/config/modules/4.9.84/mi_divp.ko’: No such file or directory
insmod: can’t read ‘/config/modules/4.9.84/mi_vdec.ko’: No such file or directory
insmod: can’t read ‘/config/modules/4.9.84/mi_ao.ko’: No such file or directory
insmod: can’t read ‘/config/modules/4.9.84/mi_disp.ko’: No such file or directory
insmod: can’t read ‘/config/modules/4.9.84/mi_ipu.ko’: No such file or directory
insmod: can’t read ‘/config/modules/4.9.84/mi_ai.ko’: No such file or directory
insmod: can’t read ‘/config/modules/4.9.84/mi_venc.ko’: No such file or directory
insmod: can’t read ‘/config/modules/4.9.84/mi_panel.ko’: No such file or directory
BusyBox v1.20.2 (2019-06-02 23:36:03 HKT) multi-call binary.
Usage: mknod [-m MODE] NAME TYPE MAJOR MINOR
Create a special file (block, character, or pipe)
-m MODE Creation mode (default a=rw)
TYPE:
b Block device
c or u Character device
p Named pipe (MAJOR and MINOR are ignored)
insmod: can’t read ‘/config/modules/4.9.84/fbdev.ko’: No such file or directory
/ # ls lib/random: fast init done
ld-2.28.so libgcc_s.so libresolv.so.2
ld-linux-armhf.so.3 libgcc_s.so.1 librt-2.28.so
libc-2.28.so libm-2.28.so librt.so.1
libc.so.6 libm.so.6 libstdc++.so
libcrypt-2.28.so libpcprofile.so libstdc++.so.6
libcrypt.so.1 libpthread-2.28.so libstdc++.so.6.0.25
libdl-2.28.so libpthread.so.0 modules/
libdl.so.2 libresolv-2.28.so
/ # ls lib/modules/4.9.84
ls: lib/modules/4.9.84: No such file or directory
/ # ls
appconfigs customer home mnt sys var
bin dev lib proc tmp vendor
config etc linuxrc sbin usr
