不知道那段是摄像头的信息,全贴又超限了!!删除了一些我认为无关的信息。
[ 0.326193] io scheduler cfq registered (default)
[ 0.327477] [DISP]disp_module_init
[ 0.328958] [DISP] disp_init,line:2340:
[ 0.328972] smooth display screen:0 type:1 mode:4
[ 0.367650] lcd 0, driver_name tft08006, panel_name default_lcd
[ 0.367668] lcd 0, driver_name tft08006, panel_name k101im2qa04
[ 0.367676] lcd 0, driver_name tft08006, panel_name tft08006
[ 0.367683] lcd_cfg_panel_info
[ 0.367700] lcd 0, driver_name tft08006, panel_name super_lcd_driver
[ 0.367740] width: 480, hspw: 2, hbp: 12, ht: 515
[ 0.367749] height: 800, vspw: 5, vbp: 25, vt: 830
[ 0.367949] display_fb_request,fb_id:0
[ 0.372203] [DISP] de_fcm_set_para,line:491:
[ 0.372218] fcm lut 0 not find, auto retry after init
[ 0.373487] [DISP]disp_module_init finish
[ 0.376263] [DISP] de_fcm_set_para,line:491:
[ 0.376278] fcm lut 0 not find, auto retry after init
[ 0.376303] [DISP] de_fcm_set_para,line:491:
[ 0.376309] fcm lut 0 not find, auto retry after init
[ 0.376379] [DISP] lcd_clk_config,line:704:
[ 0.376393] disp 0, clk: pll(150000000),clk(150000000),dclk(25000000) dsi_rate(25000000)
[ 0.376393] clk real:pll(288000000),clk(288000000),dclk(72000000) dsi_rate(150000000)
[ 0.382642] uart0: ttyS0 at MMIO 0x2500000 (irq = 289, base_baud = 1500000) is a SUNXI
[ 0.382675] sw_console_setup()2073 - console setup baud 115200 parity n bits 8, flow n
[ 1.072592] Freeing logo buffer memory: 1500K
[ 1.675137] console [ttyS0] enabled
[ 1.680573] uart3: ttyS3 at MMIO 0x2500c00 (irq = 290, base_baud = 1500000) is a SUNXI
[ 1.691002] misc dump reg init
[ 1.695273] npu[1][1] vipcore, platform driver device=0xdf5ba410
[ 1.702311] npu[1][1] vipcore irq number is 291.
[ 1.707527] gckvip_drv_adjust_param 232 SUCCESS
[ 1.712752] Want set pclk rate(600000000) support(600000000) real(600000000)
[ 1.720849] Want set mclk rate(600000000) support(600000000) real(600000000)
[ 1.728795] npu[1][1] This device support 64bits DMA
[ 1.734892] npu[1][1] core_0, request irqline=291, name=vipcore_0
[ 1.742052] npu[1][1] =======vipcore parameter=====
[ 1.747538] npu[1][1] registerMemBase 0x03050000,
[ 1.753368] npu[1][1] registerMemSize 0x00020000,
[ 1.759159] npu[1][1] irqLine 0x00000123,
[ 1.764964] npu[1][1] contiguousSize 0x00100000
[ 1.770615] npu[1][1] contiguousBase 0x30000000
[ 1.776203] npu[1][1] vipContiguousBase 0x0
[ 1.781127] npu[1][1] drvType 0x00000000
[ 1.786703] npu[1][1] AXISramSize 0x00000000
[ 1.792318] npu[1][1] AXISramBaseAddress 0x00000000
[ 1.797894] npu[1][1] VIPSramSize 0x00020000
[ 1.803484] npu[1][1] VIPSramBaseAddress 0x00400000
[ 1.809068] npu[1][1] sysHeapSize 0x00200000
[ 1.814655] npu[1][1] ===============================
[ 1.820437] npu[1][1] VIPLite driver version 1.8.1.0-AW-2022-07-26
[ 1.828736] sun8iw21p1-pinctrl pio: expect_func as:fanout0, but muxsel(3) is func:clk
[ 1.837855] sunxi-wlan soc@03000000:wlan@0: wlan_busnum (1)
[ 1.844220] sunxi-wlan soc@03000000:wlan@0: wlan power voltage (3300000)
[ 1.851792] sunxi-wlan soc@03000000:wlan@0: wlan io voltage (3300000)
[ 1.859042] sunxi-wlan soc@03000000:wlan@0: wlan_power_num (1)
[ 1.865676] sunxi-wlan soc@03000000:wlan@0: wlan_power_name (axp2101-dcdc1)
[ 1.873534] sunxi-wlan soc@03000000:wlan@0: io_regulator_name (axp2101-dcdc1)
[ 1.881635] sunxi-wlan soc@03000000:wlan@0: wlan_regon gpio=239 mul-sel=1 pull=1 drv_level=2 data=0
[ 1.892240] sunxi-wlan soc@03000000:wlan@0: get gpio chip_en failed
[ 1.899335] sunxi-wlan soc@03000000:wlan@0: wlan_hostwake gpio=199 mul-sel=14 pull=1 drv_level=2 data=0
[ 1.910410] sunxi-wlan soc@03000000:wlan@0: clk_name ()
[ 1.917747] libphy: Fixed MDIO Bus: probed
[ 1.923733] sunxi gmac driver’s version: 1.0.0
[ 1.929002] gmac-power0: NULL
[ 1.932418] gmac-power1: NULL
[ 1.935750] gmac-power2: NULL
[ 1.940506] Failed to alloc md5
[ 1.944045] eth0: Use random mac address
[ 1.948962] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.956854] get ehci0-controller, regulator_io is no nocare
[ 1.963288] get ehci0-controller wakeup-source is fail.
[ 1.969389] sunxi ehci0-controller don’t init wakeup source
[ 1.975660] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0a699e8, 0x:e084b000, irq_no:137
[ 1.987838] [sunxi-ehci0]: Not init ehci0
[ 1.992870] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 2.000400] get ohci0-controller, regulator_io is no nocare
[ 2.006667] get ohci0-controller wakeup-source is fail.
[ 2.012816] sunxi ohci0-controller don’t init wakeup source
[ 2.019164] [sunxi-ohci0]: probe, pdev->name: 4101000.ohci0-controller, sunxi_ohci: 0xc0a69c0c
[ 2.028905] [sunxi-ohci0]: Not init ohci0
[ 2.034163] usbcore: registered new interface driver uas
[ 2.040560] usbcore: registered new interface driver usb-storage
[ 2.047618] usbcore: registered new interface driver ums-alauda
[ 2.054498] usbcore: registered new interface driver ums-cypress
[ 2.061538] usbcore: registered new interface driver ums-datafab
[ 2.068599] usbcore: registered new interface driver ums_eneub6250
[ 2.075831] usbcore: registered new interface driver ums-freecom
[ 2.082945] usbcore: registered new interface driver ums-isd200
[ 2.089880] usbcore: registered new interface driver ums-jumpshot
[ 2.096959] usbcore: registered new interface driver ums-karma
[ 2.103769] usbcore: registered new interface driver ums-onetouch
[ 2.110927] usbcore: registered new interface driver ums-realtek
[ 2.117965] usbcore: registered new interface driver ums-sddr09
[ 2.124889] usbcore: registered new interface driver ums-sddr55
[ 2.131890] usbcore: registered new interface driver ums-usbat
[ 2.138577] usb_serial_number:20080411
[ 2.150185] input: axp2101-pek as /devices/platform/soc/twi4/i2c-4/4-0034/axp2101-pek.0/input/input0
[ 2.162412] input: sunxi-wiegand0 as /devices/virtual/input/input1
[ 2.170803] sunxi_gpadc_init,1949, success
[ 2.175796] sunxi_gpadc_setup: get channel scan data failed
[ 2.183510] input: sunxi-gpadc0 as /devices/virtual/input/input2
[ 2.192600] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
[ 2.199876] sunxi-rtc rtc: RTC enabled
[ 2.204183] fix to cold boot, save boot reason
[ 2.209751] i2c /dev entries driver
[ 2.215703] usbcore: registered new interface driver uvcvideo
[ 2.222614] USB Video Class driver (1.1.1)
[ 2.227230] sunxi cedar version 0.1
[ 2.231606] [VE_DEBUG:2931] install start!!!
[ 2.231606]
[ 2.238178] VE: cedar-ve the get irq is 292
[ 2.243152] [VE_WARNING:3009] regs_csi = e0887000
[ 2.249019] [VE_DEBUG:3072] ve_proc_mgr: flag = 1
[ 2.249019]
[ 2.256240] [VE_DEBUG:3074] install end!!!
[ 2.256240]
[ 2.263059] google_vp9: sunxi google vp9 version 0.1
[ 2.273273] axp2101_charger: read chipid = 4a
[ 2.273273]
[ 2.287509] thermal thermal_zone3: power_allocator: sustainable_power will be estimated
[ 2.320041] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 2.330054] Bluetooth: HCI UART driver ver 2.2.d448471.20181218-163903
[ 2.337413] Bluetooth: HCI UART protocol H4 registered
[ 2.344041] Bluetooth: HCI H4 protocol initialized
[ 2.350259] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 01.00.07
[ 2.358745] axp2101_charger: the gauge have been reset, need to reload param
[ 2.358745]
[ 2.369670] bt_fdi debugfs_init
[ 2.399906] cpuidle: enable-method property ‘psci’ found operations
[ 2.408835] sunxi-mmc sdc2: SD/MMC/SDIO Host Controller Driver(v3.30 2022-7-20 15:45)
[ 2.418251] sunxi-mmc sdc2: ctl-spec-caps 308
[ 2.424634] sunxi-mmc sdc2: No vdmmc regulator found
[ 2.430278] sunxi-mmc sdc2: No vd33sw regulator found
[ 2.435942] sunxi-mmc sdc2: No vd18sw regulator found
[ 2.441705] sunxi-mmc sdc2: No vq33sw regulator found
[ 2.447373] sunxi-mmc sdc2: No vq18sw regulator found
[ 2.453481] sunxi-mmc sdc2: set host busy
[ 2.458056] mmc:failed to get gpios
[ 2.462389] sunxi-mmc sdc2: sdc set ios:clk 0Hz bm PP pm UP vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 2.499369] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 2.539350] sunxi-mmc sdc2: detmode:alway in(non removable)
[ 2.539371] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 2.547741] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 2.548806] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 2.559651] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 2.559732] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 2.572580] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 2.617301] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v3.30 2022-7-20 15:45)
[ 2.626314] sunxi-mmc sdc0: ctl-spec-caps 408
[ 2.631852] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 2.644568] sunxi-mmc sdc0: No vqmmc regulator found
[ 2.650194] sunxi-mmc sdc0: No vdmmc regulator found
[ 2.656310] sunxi-mmc sdc0: set host busy
[ 2.661015] sunxi-mmc sdc0: Got CD GPIO
[ 2.665359] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing MMC-HS(SDR20) dt B
[ 2.676246] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 22 width 1 timing MMC-HS(SDR20) dt B
[ 2.677004] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 22 width 8 timing MMC-HS(SDR20) dt B
[ 2.699660] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 22 width 8 timing MMC-DDR52 dt B
[ 2.711927] mmc0: new DDR MMC card at address 0001
[ 2.718150] mmcblk0: mmc0:0001 008G70 7.28 GiB
[ 2.723860] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 2.734500] mmcblk0boot0: mmc0:0001 008G70 partition 1 4.00 MiB
[ 2.734765] mmcblk0boot1: mmc0:0001 008G70 partition 2 4.00 MiB
[ 2.734987] mmcblk0rpmb: mmc0:0001 008G70 partition 3 4.00 MiB
[ 2.757228] mmcblk0: p1 p2 p3 p4 p5 p6 p7
[ 2.999412] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
[ 3.029341] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 3.069515] sunxi-mmc sdc0: detmode:gpio irq
[ 3.074774] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.30 2022-7-20 15:45)
[ 3.083733] sunxi-mmc sdc1: ctl-spec-caps 8
[ 3.089080] sunxi-mmc sdc1: No vmmc regulator found
[ 3.094592] sunxi-mmc sdc1: No vqmmc regulator found
[ 3.100173] sunxi-mmc sdc1: No vdmmc regulator found
[ 3.105738] sunxi-mmc sdc1: No vd33sw regulator found
[ 3.111486] sunxi-mmc sdc1: No vd18sw regulator found
[ 3.117152] sunxi-mmc sdc1: No vq33sw regulator found
[ 3.122833] sunxi-mmc sdc1: No vq18sw regulator found
[ 3.128883] sunxi-mmc sdc1: set host busy
[ 3.133477] mmc:failed to get gpios
[ 3.137678] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.169373] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.209381] sunxi-mmc sdc1: detmode:manually by software
[ 3.215365] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[ 3.221372] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[ 3.221396] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.229468] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.241274] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[ 3.252028] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[ 3.257917] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[ 3.263799] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[ 3.263842] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 3.264914] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.287002] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 3.297345] sunxi-mmc sdc1: sdc set ios:clk 300000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.319967] usbcore: registered new interface driver usbhid
[ 3.326233] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[ 3.332465] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[ 3.332532] sunxi-mmc sdc1: sdc set ios:clk 300000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.340840] sunxi-mmc sdc1: sdc set ios:clk 300000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.352815] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[ 3.363703] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[ 3.369658] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[ 3.375553] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[ 3.375575] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 3.376650] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.408992] sunxi-mmc sdc1: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.419902] usbhid: USB HID core driver
[ 3.427200] [sound 1158][DAUDIO snd_sunxi_regulator_init] regulator missing or invalid
[ 3.436600] [sound 1158][DAUDIO snd_sunxi_regulator_init] regulator missing or invalid
[ 3.445520] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[ 3.451560] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[ 3.451642] sunxi-mmc sdc1: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.459915] sunxi-mmc sdc1: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.471892] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[ 3.482754] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[ 3.488653] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[ 3.494548] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[ 3.494589] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 3.495674] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.529093] sunxi-mmc sdc1: sdc set ios:clk 100000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.541406] sunxi-snd-mach soc@03000000:codec_mach: sunxi-snd-codec ↔ soc@03000000:codec_plat mapping ok
[ 3.554572] sunxi-snd-mach soc@03000000:daudio0_mach: snd-soc-dummy-dai ↔ 2032000.daudio0_plat mapping ok
[ 3.565565] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[ 3.571841] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[ 3.571920] sunxi-mmc sdc1: sdc set ios:clk 100000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.580113] sunxi-mmc sdc1: sdc set ios:clk 100000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.592020] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[ 3.602860] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[ 3.608761] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[ 3.614645] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[ 3.614676] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 3.639747] sunxi-snd-mach soc@03000000:daudio1_mach: snd-soc-dummy-dai ↔ 2033000.daudio1_plat mapping ok
[ 3.652386] Netfilter messages via NETLINK v0.30.
[ 3.658267] nf_conntrack version 0.5.0 (8192 buckets, 32768 max)
[ 3.665249] ctnetlink v0.93: registering with nfnetlink.
[ 3.671676] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.678619] NET: Registered protocol family 10
[ 3.685217] NET: Registered protocol family 17
[ 3.690462] NET: Registered protocol family 15
[ 3.695547] Bluetooth: RFCOMM TTY layer initialized
[ 3.701137] Bluetooth: RFCOMM socket layer initialized
[ 3.706935] Bluetooth: RFCOMM ver 1.11
[ 3.712341] Registering SWP/SWPB emulation handler
[ 3.724632] get ctp_power is fail, -22
[ 3.728857] get ctp_power_ldo_vol is fail, -22
[ 3.734059] sunxi_ctp_startup: ctp_power_io is invalid.
[ 3.776913] twi twi0: i2c bus barrier failed, sda is still low!
[ 3.785074] twi twi1: i2c bus barrier failed, sda is still low!
[ 3.792399] sunxi-rtc rtc: setting system clock to 1970-01-01 00:00:06 UTC (6)
[ 3.801233] clk: Not disabling unused clocks
[ 3.806145] usb-vbus: disabling
[ 3.810046] axp2101-dcdc2: disabling
[ 3.814741] axp2101-rtcldo1: disabling
[ 3.819181] axp2101-aldo2: disabling
[ 3.823968] axp2101-aldo3: disabling
[ 3.828661] axp2101-aldo4: disabling
[ 3.833396] axp2101-bldo2: disabling
[ 3.838080] axp2101-dldo2: disabling
[ 3.842807] axp2101-cpusldo: disabling
[ 3.847452] ALSA device list:
[ 3.850796] #0: audiocodec
[ 3.854021] #1: snddaudio0
[ 3.857245] #2: snddaudio1
[ 3.865072] VFS: Mounted root (squashfs filesystem) readonly on device 179:4.
[ 3.876562] devtmpfs: mounted
[ 3.881553] Freeing unused kernel memory: 1024K
[ 3.886745] will run init …
mount: mounting none on /dev failed: Resource busy
[ 4.387674] EXT4-fs: Warning: mounting with data=journal disables delayed allocation and O_DIRECT support!
[ 4.401840] EXT4-fs (mmcblk0p5): mounted filesystem with journalled data mode. Opts: data=journal
starting pid 864, tty ‘’: ‘/etc/preinit’
can’t run ‘/etc/preinit’: No such file or directory
starting pid 865, tty ‘’: ‘/bin/mount -t proc proc /proc’
mount: mounting proc on /proc failed: Resource busy
starting pid 866, tty ‘’: ‘/bin/mount -t tmpfs tmpfs /run’
starting pid 867, tty ‘’: ‘/bin/mount -o remount,rw /’
starting pid 868, tty ‘’: ‘/bin/mkdir -p /dev/pts’
starting pid 869, tty ‘’: ‘/bin/mkdir -p /dev/shm’
starting pid 870, tty ‘’: ‘/bin/mount -a’
starting pid 871, tty ‘’: ‘/bin/hostname -F /etc/hostname’
hostname: can’t open ‘/etc/hostname’: No such file or directory
starting pid 872, tty ‘’: ‘/etc/init.d/rcS boot’
[ 4.566292] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
[ 4.712863] ======== XRADIO WIFI OPEN ========
[ 4.717885] [XRADIO] Driver Label:XR_V02.16.93_HT40_01.40 Feb 27 2024 07:33:16
[ 4.726315] [XRADIO] Allocated hw_priv @ dec74c80
[ 4.731822] [XRADIO_ERR] Access_file failed, path:/data/misc/wifi/xr_wifi.conf!
[ 4.740758] sunxi-wlan soc@03000000:wlan@0: bus_index: 1
[ 4.748068] sunxi-wlan soc@03000000:wlan@0: check wlan wlan_power voltage: 3300000
[ 4.758009] sunxi-wlan soc@03000000:wlan@0: check wlan io_regulator voltage: 3300000
[ 4.826850] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 4.837124] [XRADIO] Detect SDIO card 1
[ 4.879374] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 4.920004] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 4.933225] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 4.954249] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 4.964974] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 4.976014] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[ 4.987518] mmc2: new high speed SDIO card at address 0001
[ 4.994315] [SBUS] XRadio Device:sdio clk=50000000
[ 5.000506] [XRADIO] XRADIO_HW_REV 1.0 detected.
[ 5.099717] [XRADIO] xradio_update_dpllctrl: DPLL_CTRL Sync=0x01400000.
[ 5.178932] [XRADIO] Bootloader complete
[ 5.276031] [XRADIO] Firmware completed.
[ 5.281868] [WSM] Firmware Label:XR_C09.08.52.73_DBG_02.122 2GHZ HT40 May 18 2021 13:36:09
[ 5.299309] [XRADIO] Firmware Startup Done.
[ 5.304221] [XRADIO_WRN] enable Multi-Rx!
[ 5.323663] ieee80211 phy0: Selected rate control algorithm ‘minstrel_ht’
------run rc.final file-----
Load mpp modules
insmod: can’t insert ‘/lib/modules/4.9.191/videobuf2-core.ko’: No such file or directory
insmod: can’t insert ‘/lib/modules/4.9.191/videobuf2-memops.ko’: No such file or directory
insmod: can’t insert ‘/lib/modules/4.9.191/videobuf2-v4l2.ko’: N[ 5.428204] [VIN_WARN]sensor_helper_probe: cannot get sensor0_cameravdd supply, setting it to NULL!
[ 5.440632] [VIN_WARN]sensor_helper_probe: cannot get sensor1_cameravdd supply, setting it to NULL!
[ 5.542788] twi twi1: i2c bus barrier failed, sda is still low!
[ 5.550806] twi twi1: i2c bus barrier failed, sda is still low!
[ 5.558782] twi twi1: i2c bus barrier failed, sda is still low!
[ 5.565434] [VIN_DEV_I2C]gc2053_mipi read retry 3, read addr is 0xf0
[ 5.574188] twi twi1: i2c bus barrier failed, sda is still low!
[ 5.582172] twi twi1: i2c bus barrier failed, sda is still low!
[ 5.590158] twi twi1: i2c bus barrier failed, sda is still low!
[ 5.596794] [VIN_DEV_I2C]gc2053_mipi read retry 3, read addr is 0xf0
[ 5.605496] twi twi1: i2c bus barrier failed, sda is still low!
[ 5.613552] twi twi1: i2c bus barrier failed, sda is still low!
[ 5.621617] twi twi1: i2c bus barrier failed, sda is still low!
[ 5.628256] [VIN_DEV_I2C]gc2053_mipi read retry 3, read addr is 0xf0
[ 5.636965] twi twi1: i2c bus barrier failed, sda is still low!
[ 5.644955] twi twi1: i2c bus barrier failed, sda is still low!
[ 5.652953] twi twi1: i2c bus barrier failed, sda is still low!
[ 5.659611] [VIN_DEV_I2C]gc2053_mipi read retry 3, read addr is 0xf0
[ 5.666733] [gc2053_mipi] error, chip found is not an target chip.
[ 5.687391] [VIN_ERR]registering gc2053_mipi, No such device!
[ 5.732741] twi twi0: i2c bus barrier failed, sda is still low!
[ 5.740856] twi twi0: i2c bus barrier failed, sda is still low!
[ 5.748827] twi twi0: i2c bus barrier failed, sda is still low!
[ 5.755487] [VIN_DEV_I2C]gc2053_mipi_2 read retry 3, read addr is 0xf0
[ 5.764393] twi twi0: i2c bus barrier failed, sda is still low!
[ 5.772373] twi twi0: i2c bus barrier failed, sda is still low!
[ 5.780384] twi twi0: i2c bus barrier failed, sda is still low!
[ 5.787021] [VIN_DEV_I2C]gc2053_mipi_2 read retry 3, read addr is 0xf0
[ 5.795923] twi twi0: i2c bus barrier failed, sda is still low!
[ 5.803900] twi twi0: i2c bus barrier failed, sda is still low!
[ 5.811883] twi twi0: i2c bus barrier failed, sda is still low!
[ 5.818518] [VIN_DEV_I2C]gc2053_mipi_2 read retry 3, read addr is 0xf0
[ 5.827412] twi twi0: i2c bus barrier failed, sda is still low!
[ 5.835389] twi twi0: i2c bus barrier failed, sda is still low!
[ 5.843377] twi twi0: i2c bus barrier failed, sda is still low!
[ 5.850026] [VIN_DEV_I2C]gc2053_mipi_2 read retry 3, read addr is 0xf0
[ 5.857341] [gc2053_mipi] error, chip found is not an target chip.
[ 5.877948] [VIN_ERR]registering gc2053_mipi_2, No such device!
insmod: can’t insert ‘/lib/modules/4.9.191/sunxi_aio.ko’: No such file or directory
insmod: can’t insert ‘/lib/modules/4.9.191/sunxi_eise.ko’: No such file or directory
Starting logging: start-stop-daemon: unrecognized option: exec
OK
Starting audio: Successfully play boot music
Populating /dev using udev: playing ‘/home/res/audio/startup.wav’: 2 ch, 48000 hz, 16 bit
[ 6.093337] udevd[990]: could not create /tmp/run/udev: No such file or directory
done
mkdir: can’t create directory ‘/dev/pts’: File exists
mkdir: can’t create directory ‘/dev/shm’: File exists
Initializing random number generator… [ 6.289483] random: dd: uninitialized urandom read (512 bytes read)
done.
Starting network: Failed to connect to ubus
/sbin/ifup: line 51: /sbin/wifi: not found
FAIL
ifconfig: invalid hw-addr 00:
udhcpc: started, v1.27.2
Starting telnetd: OK
[ 6.692099] libphy: gmac0: probed
[ 6.699220] sunxi-gmac gmac0 eth0: eth0: Type(6) PHY ID 0000ffff at 0 IRQ poll (gmac0-0:00)
enable android usb
insmod: can’t insert ‘/lib/modules/4.9.191/sunxi_usb_udc.ko’: No such file or directory
insmod: can’t insert ‘/lib/modules/4.9.191/sunxi_usbc.ko’: No such file or directory
[ 6.749974] sunxi-gmac gmac0 eth0: Initialize hardware error
udhcpc: sending discover
[ 6.829063] random: dbus-uuidgen: uninitialized urandom read (12 bytes read)
[ 6.847539] random: dbus-uuidgen: uninitialized urandom read (8 bytes read)
udhcpc: sendto: Network is down
udhcpc: read error: Network is down, reopening socket
[ 6.992152] file system registered
[ 7.032579] configfs-gadget 4100000.udc-controller: failed to start g1: -19
Starting wifi_daemon…: Unknown group “lp” in message bus configuration file
[ 7.069510] read descriptors
[ 7.074681] read strings
[ACT D][ring_buff_init,27]enter
[ACT D][ring_buff_start,173]ring buffer start enter
[ACT D][ring_buff_start,187]ring buffer start quit
[ 7.329338]
[ 7.329338] insmod_device_driver
[ 7.329338]
[ 7.575102] android_work: sent uevent USB_STATE=CONNECTED
[ 7.604902] configfs-gadget gadget: high-speed config #1: c
[ 7.611284] android_work: sent uevent USB_STATE=CONFIGURED
[ 9.088865] random: crng init done
[ 9.092683] random: 2 urandom warning(s) missed due to ratelimiting
Close IRCUT…WINF: open sta mode
WWAR: Can’t get config: support_list
WINF: linux sta supplicant init now
WINF: linux ap init now
WINF: linux monitor nl init now
WINF: linux p2p supplicant init now
WINF: **************************************
WINF: * Copyright (c) 2019-2025 Allwinner Technology Co., Ltd. ALL rights reserved
WINF: * version: 2.0.7
WINF: * support mode:(sta | ap | mon | —)
WINF: * mode support list
WINF: * sta alone
WINF: * ap alone
WINF: * mon alone
/etc/init.d/rcS: /etc/init.d/rc.final: line 36: powerkey_daemon: not found
[ 9.218059] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Trying to connect to SWUpdate…
mount: mounting /dev/mmcblk1p1 on /mnt/sdcard failed: No such file or directory
dd: writing ‘/dev/fb0’: No space left on device
6001+0 records in
6000+0 records out
swu_param: ####
swu_software: ####
swu_mode: ####
[ 9.597973] ieee80211_do_open: vif_type=2, p2p=0, ch=3, addr=a4:8e:fd:5a:64:0b
[ 9.606306] [STA] !!!xradio_vif_setup: id=0, type=2, p2p=0, addr=a4:8e:fd:5a:64:0b
[ 9.621736] [AP_WRN] BSS_CHANGED_ASSOC but driver is unjoined.
[ 9.643399] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 9.694430] ieee80211_do_open: vif_type=10, p2p=0, ch=3, addr=a4:8e:fd:5a:64:0c
[ 9.702857] [STA] !!!xradio_vif_setup: id=2, type=10, p2p=0, addr=a4:8e:fd:5a:64:0c
WINF: wifi mode sta on success
WINF: wifi on sta success
starting pid 1151, tty ‘/dev/console’: ‘-/bin/sh’
------run profile file-----
|_ ||| ___ _ _ | | || ___ _ _ _ _
| | _ | || | | |__ | || || | ||'|
| | | || | || _ | |_____|||||||||,|
|| |||||||_| Tina is Based on OpenWrt!
root@TinaLinux:/# I0101 00:00:15.507734 1149 sample_virvi2vo.c:1042] sample_virvi2vo running!
I0101 00:00:15.531189 1149 sample_virvi2vo.c:108] sample_virvi2vo path:[sample_virvi2vo], arg number is [3]
I0101 00:00:15.561503 1149 confparser.c:60] load conf file /usr/bin/sample_virvi2vo.conf ok!
I0101 00:00:15.561856 1149 sample_virvi2vo.c:309] vipp[0]: captureSize[360x640], displayArea[0,0,480x800]
I0101 00:00:15.561995 1149 sample_virvi2vo.c:309] vipp[4]: captureSize[0x640], displayArea[0,0,0x640]
I0101 00:00:15.562087 1149 sample_virvi2vo.c:311] dispSync[1], dispType[64], frameRate[30], testDuration[0]
I0101 00:00:15.562246 1149 mpi_sys.c:842] <AW_MPI_SYS_SetConf> kfctmpdir is [/tmp]
Media Process Platform<<<<<<<<<<<<<<<<<<<<<<<<<<<<
modName : MPP-Platform
tag : V1.0 Release
branch: v5-dev
commit: 4eed413532ad87725895a8cb1ba75e22fc328233
date : 20170725
author: jenkins
I0101 00:00:15.630392 1149 mpi_sys.c:1455] <AW_MPI_SYS_Init> ISP init
[ISP]>>>>>>>>>>>>>>>>>>>> ISP VERSION INFO <<<<<<<<<<<<<<<<<<<
IPCORE: ISP600
branch: libisp-dev
commit: c3bfa4e23fb037123e65a04eaaa39f7876cfe1a6
date : Mon Apr 10 10:37:15 2023 +0800
author: zhenghanjie@allwinnertech.com
I0101 00:00:15.630770 1149 mpi_sys.c:1457] <AW_MPI_SYS_Init> ISP init done
I0101 00:00:15.769831 1149 hwdisplay.c:84] <hw_display_init>
I0101 00:00:15.770083 1149 hwdisplay.c:993] <hwd_init> (hwd_init 993)
I0101 00:00:15.770268 1149 hwdisplay.c:1048] <hwd_init> ret[0][2,0]ch[0]lyl[0] init: enable[0], screenwin[0,0, 0x0], zorder[0], alpha[mode:0, value:0]
ALSA lib pcm_dmix.c:1099:(snd_pcm_dmix_open) unable to open slave
E0101 00:00:15.823357 1149 audio_hw.c:237] fatal error! why snd pcm open fail?[-16]
I0101 00:00:15.823560 1149 alsa_interface.c:707] open mixer:hw:0
I0101 00:00:15.828600 1149 alsa_interface.c:762] set playback vol_val to value: 27
I0101 00:00:15.829165 1149 hwdisplay.c:1248] <hwd_get_disp_type> Current the disp_type:0x1 tv_mode:0x0
I0101 00:00:15.829466 1163 mpi_sys.c:1073] detect user environment:
I0101 00:00:15.829609 1163 mpi_sys.c:1074] /tmp/mpp_log_level
I0101 00:00:15.829704 1163 mpi_sys.c:1075] /tmp/mpp_venc_sei_config_param
I0101 00:00:15.849534 1149 sample_virvi2vo.c:419] Vipp dev[0] vir_chn[0]
[ISP]video device name is vin_video0
[ISP_ERR]video_init, line: 110,can not get entity by name vin_video0
[ISP_ERR]isp_video_open, line: 477,error: unable to initialize video device.
[ISP_ERR]isp_video_open, line: 496,unable to open video device[0]!
E0101 00:00:15.849869 1149 videoInputHw.c:638] <videoInputHw_ChnInit> error: isp video can not open, chn[0]!
E0101 00:00:15.849995 1149 mpi_vi.c:170] <AW_MPI_VI_CreateVipp> initialize video input hardware failed!!
E0101 00:00:15.850128 1149 sample_virvi2vo.c:423] fatal error! AW_MPI_VI CreateVipp:0 failed
No find video open @ isp[0].
E0101 00:00:15.850241 1149 sample_virvi2vo.c:1125] fatal error! isp switch wdr[0] fail[-1]
I0101 00:00:15.850328 1149 sample_virvi2vo.c:413] do not need create link for idx[1]
E0101 00:00:15.850420 1149 sample_virvi2vo.c:1125] fatal error! isp switch wdr[0] fail[-1]
udhcpc: no lease, forking to background
