我想实现当点击slider的时候只聚焦这个控件,而slider的进度不会发生变化,只有当拖拉slider的时候进度才会改变。
看了挺多资料都是通过lv_obj_add_flag(slider, LV_OBJ_FLAG_ADV_HITTEST)去实现仅旋钮控制模式,此模式下slider宽度较小触控就比较困难,希望大佬能帮忙解答一下怎么实现点击不改变进度,谢谢。
static void slider_cb(lv_event_t *e) // 滑动回调
static bool touched = false;
static lv_point_t click_point1, click_point2;
int movex, movey;
lv_obj_t *bak = (lv_obj_t *)e->target;
lv_obj_t *slider = lv_obj_get_child(bak, 0);
lv_obj_t *num_lable = lv_obj_get_child(bak, 1);
lv_obj_refr_size(bak);
if (e->code == LV_EVENT_SIZE_CHANGED && lv_obj_is_valid(slider))
int value = atoi(lv_label_get_text(num_lable));
if (lv_obj_has_flag(bak, direction_x))
lv_obj_set_x(slider, -lv_disp_get_hor_res(lv_disp_get_default()) + (int)((lv_obj_get_width(bak) * (((float)value) / 100))));
if (lv_obj_has_flag(bak, direction_y))
lv_obj_set_y(slider, (int)(lv_obj_get_height(bak) * (((float)(100 - value)) / 100)));
if (e->code == LV_EVENT_PRESSING)
if (touched == false)
lv_indev_get_point(lv_indev_get_act(), &click_point1);
touched = true;
return;
lv_indev_get_point(lv_indev_get_act(), &click_point2);
movex = click_point2.x - click_point1.x; // 记录x滑动了多少
movey = click_point2.y - click_point1.y; // 记录y滑动了多少
click_point1.x = click_point2.x;
click_point1.y = click_point2.y;
if (lv_obj_has_flag(bak, direction_x) && movex != 0)
if (movex + lv_obj_get_x(slider) < -lv_disp_get_hor_res(lv_disp_get_default()) ||
movex + lv_obj_get_x(slider) > -lv_disp_get_hor_res(lv_disp_get_default()) + lv_obj_get_width(bak))
return;
lv_obj_set_x(slider, movex + lv_obj_get_x(slider));
lv_obj_refr_pos(slider);
lv_label_set_text_fmt(num_lable, "%d%%", (int)((lv_disp_get_hor_res(lv_disp_get_default()) + lv_obj_get_x(slider)) / ((float)(lv_obj_get_width(bak)) / 100)));
lv_event_send(bak, LV_EVENT_VALUE_CHANGED, 0);
if (lv_obj_has_flag(bak, direction_y) && movey != 0)
if (movey + lv_obj_get_y(slider) > lv_obj_get_height(bak) ||
movey + lv_obj_get_y(slider) < 0)
return;
lv_obj_set_y(lv_obj_get_child(bak, 0), movey + lv_obj_get_y(slider));
lv_label_set_text_fmt(num_lable, "%d%%", (int)((lv_obj_get_height(bak) - lv_obj_get_y(slider)) / ((float)(lv_obj_get_height(bak)) / 100)));
if (e->code == LV_EVENT_RELEASED)
touched = false;
return;
谢谢你的回复,不过使用你的函数后点击slider的时候,进度还是会跳到点击的位置
自定义一个,创建两个tileview,再用这个事件,因为我就是这么干的
关于这个问题已经有视频教程了:https://www.bilibili.com/video/BV1H1421i79r
早上刚看完,嘿嘿嘿 ![]()
