root@V851s:/# Successfully initialized wpa_supplicant
dbus[867]: Unknown group “lp” in message bus configuration file
[ 9.835479] ieee80211_do_open: vif_type=2, p2p=0, ch=3, addr=b0:55:a5:63:72:af
[ 9.843706] [STA] !!!xradio_vif_setup: id=0, type=2, p2p=0, addr=b0:55:a5:63:72:af
[ 9.857123] [AP_WRN] BSS_CHANGED_ASSOC but driver is unjoined.
[ 9.876399] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 10.027104] [STA_WRN] !!! xradio_remove_interface: vif_id=0
[ 13.040392] ieee80211_do_open: vif_type=2, p2p=0, ch=3, addr=f4:cf:a2:db:10:d3
[ 13.048636] [STA] !!!xradio_vif_setup: id=0, type=2, p2p=0, addr=f4:cf:a2:db:10:d3
[ 13.061997] [AP_WRN] BSS_CHANGED_ASSOC but driver is unjoined.
[ 13.080917] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
wlan0: SME: Trying to authentica[ 15.572566] [STA_WRN] Freq 2462 (wsm ch: 11) prev: 3.
te with 34:79:16:13:96:de (SSID=[ 15.580724] wlan0: authenticate with 34:79:16:13:96:de (try 1)
‘yurkyang_home’ freq=2462 MHz)
[ 15.594480] [STA_WRN] [HT40][xradio_join_work][bss_ht_info]:
[ 15.594480] [primary_chan :0x0000000b]
[ 15.594480] [ht_param :0x00000007]
[ 15.594480] [operation_mode:0x00000000]
[ 15.594480] [stbc_param :0x00000000]
[ 15.594480] [basic_set[0] :0x00000000]
[ 15.622289] [STA_WRN] [HT40][xradio_join_work][PhyModeCfg:0x0027]
[ 15.622289] [ModemFlags :0x00000007]
[ 15.622289] [ChWidthCfg :0x00000002]
[ 15.622289] [PriChCfg :0x00000000]
[ 15.622289] [BandCfg :0x00000000]
[ 15.622289] [STBC_Enable :0x00000000]
[ 15.622289] [PreambleCfg :0x00000000]
[ 15.622289] [SGI_Enable :0x00000000]
[ 15.622289] GF_Enable :0x00000000]
[ 15.686983] wlan0: authenticated
wlan0: Trying to associate with [ 15.691678] wlan0: associate with 34:79:16:13:96:de (try 1)
34:79:16:13:96:de (SSID=‘yurkyang_home’ freq=2462 MHz)
[ 15.705186] wlan0: RX AssocResp from 34:79:16:13:96:de (capab=0x411 status=0 aid=4)
[ 15.714074] [TXRX_WRN] [RX] IF=0, No key found.
[ 15.719361] wlan0: associated
[ 15.727478] [AP_WRN] [STA] ASSOC HTCAP 11N 58
[ 15.732363] [AP_WRN] [HT40][xradio_bss_info_changed][ht_prot:0x00000000][HtProtMode:0x0000][Green:0x0000]
[ 15.743529] [AP_WRN] [HT40][xradio_bss_info_changed][PhyModeCfg:0x5027]
[ 15.743529] [ModemFlags :0x00000007]
[ 15.743529] [ChWidthCfg :0x00000002]
[ 15.743529] [PriChCfg :0x00000000]
[ 15.743529] [BandCfg :0x00000000]
[ 15.743529] [STBC_Enable :0x00000000]
[ 15.743529] [PreambleCfg :0x00000001]
[ 15.743529] [SGI_Enable :0x00000001]
[ 15.743529] [GF_Enable :0x00000000]
wlan0: Associated with 34:79:16:[ 15.793260] [AP_WRN] [STA] ASSOC HTCAP 11N 58
13:96:de
wlan0: CTRL-EVENT-SUBN[ 15.800743] [AP_WRN] [HT40][xradio_bss_info_changed][ht_prot:0x00000000][HtProtMode:0x0000][Green:0x0000]ET-STATUS-UPDATE status=0
[ 15.813605] [AP_WRN] [HT40][xradio_bss_info_changed][PhyModeCfg:0x4027]
[ 15.813605] [ModemFlags :0x00000007]
[ 15.813605] [ChWidthCfg :0x00000002]
[ 15.813605] [PriChCfg :0x00000000]
[ 15.813605] [BandCfg :0x00000000]
[ 15.813605] [STBC_Enable :0x00000000]
[ 15.813605] [PreambleCfg :0x00000000]
[ 15.813605] [SGI_Enable :0x00000001]
[ 15.813605] [GF_Enable :0x00000000]
[ 15.857131] [TXRX_WRN] [RX] IF=0, No key found.
wlan0: WPA: Key negotiation comp[ 15.868792] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
leted with 34:79:16:13:96:de [PTK=CCMP GTK=CCMP]
wlan0: CTRL-EVENT-CONNECTED - Connection to 34:79:16:13:96:de completed [id=0 id_str=]
udhcpc: started, v1.33.2
udhcpc: sending discover
udhcpc: sending select for 192.168.3.47
udhcpc: lease of 192.168.3.47 obtained, lease time 86400
[ 17.940869] [TXRX_WRN] drop=1759, fctl=0x00d0.
ping 延时很长 传输文件多次不成功
PING 192.168.3.1 (192.168.3.1): 56 data bytes
[ 239.272555] [TXRX_WRN] drop=1759, fctl=0x00d0.
64 bytes from 192.168.3.1: seq=0 ttl=64 time=135.936 ms
64 bytes from 192.168.3.1: seq=1 ttl=64 time=128.245 ms
64 bytes from 192.168.3.1: seq=2 ttl=64 time=24.396 ms
64 bytes from 192.168.3.1: seq=3 ttl=64 time=33.663 ms
64 bytes from 192.168.3.1: seq=4 ttl=64 time=22.502 ms
64 bytes from 192.168.3.1: seq=5 ttl=64 time=124.266 ms
64 bytes from 192.168.3.1: seq=6 ttl=64 time=147.647 ms
64 bytes from 192.168.3.1: seq=7 ttl=64 time=26.500 ms
64 bytes from 192.168.3.1: seq=9 ttl=64 time=226.462 ms
64 bytes from 192.168.3.1: seq=12 ttl=64 time=145.317 ms
64 bytes from 192.168.3.1: seq=13 ttl=64 time=22.772 ms
64 bytes from 192.168.3.1: seq=14 ttl=64 time=129.305 ms
64 bytes from 192.168.3.1: seq=15 ttl=64 time=29.874 ms
64 bytes from 192.168.3.1: seq=16 ttl=64 time=33.749 ms
64 bytes from 192.168.3.1: seq=17 ttl=64 time=24.272 ms
64 bytes from 192.168.3.1: seq=18 ttl=64 time=37.048 ms
64 bytes from 192.168.3.1: seq=19 ttl=64 time=23.056 ms
64 bytes from 192.168.3.1: seq=20 ttl=64 time=23.595 ms
64 bytes from 192.168.3.1: seq=21 ttl=64 time=41.003 ms
64 bytes from 192.168.3.1: seq=22 ttl=64 time=26.938 ms
64 bytes from 192.168.3.1: seq=24 ttl=64 time=140.368 ms
64 bytes from 192.168.3.1: seq=25 ttl=64 time=30.713 ms
[ 265.307118] [BH_WRN] miss interrupt!
64 bytes from 192.168.3.1: seq=26 ttl=64 time=160.161 ms
64 bytes from 192.168.3.1: seq=27 ttl=64 time=38.889 ms
64 bytes from 192.168.3.1: seq=28 ttl=64 time=29.519 ms
64 bytes from 192.168.3.1: seq=29 ttl=64 time=30.008 ms
64 bytes from 192.168.3.1: seq=30 ttl=64 time=326.835 ms
64 bytes from 192.168.3.1: seq=31 ttl=64 time=131.015 ms
64 bytes from 192.168.3.1: seq=32 ttl=64 time=39.121 ms
64 bytes from 192.168.3.1: seq=33 ttl=64 time=31.866 ms
64 bytes from 192.168.3.1: seq=34 ttl=64 time=36.800 ms
64 bytes from 192.168.3.1: seq=37 ttl=64 time=145.092 ms
64 bytes from 192.168.3.1: seq=38 ttl=64 time=50.935 ms
64 bytes from 192.168.3.1: seq=39 ttl=64 time=29.087 ms
64 bytes from 192.168.3.1: seq=41 ttl=64 time=183.578 ms
64 bytes from 192.168.3.1: seq=43 ttl=64 time=132.679 ms
64 bytes from 192.168.3.1: seq=45 ttl=64 time=141.909 ms
64 bytes from 192.168.3.1: seq=46 ttl=64 time=32.434 ms
64 bytes from 192.168.3.1: seq=47 ttl=64 time=30.137 ms
64 bytes from 192.168.3.1: seq=48 ttl=64 time=110.694 ms
64 bytes from 192.168.3.1: seq=49 ttl=64 time=54.834 ms
64 bytes from 192.168.3.1: seq=50 ttl=64 time=25.518 ms
