#include "app.h"
static btn_attr_t attr;
static btn_attr_t btn_attributes[NUM_ROWS][NUM_COLS];
static btn_pos_t * pos;
/*事件函数*/
void serial_btn_event_cb(lv_event_t * e){
/*获取事件类型*/
/*获取触发事件的目标对象*/
lv_obj_t * btn = lv_event_get_target(e);
/*获取btn的后代label*/
lv_obj_t * img = lv_obj_get_child(btn, 0);
if (code == LV_EVENT_SHORT_CLICKED){
lv_color_t current_color = lv_obj_get_style_bg_color(btn, LV_PART_MAIN);// 获取按钮当前的背景颜色
const char *label_text = lv_label_get_text(img); /*获取按钮中的内容*/
// 获取按钮在网格中的位置
btn_pos_t *pos = (btn_pos_t *)lv_obj_get_user_data(btn);
int row = pos->row;
int col = pos->col;
char msg[20]; // 用于存储发送的信息
if(current_color.full == lv_color_hex(0x4684FD).full) //判断按钮的开关情况,默认蓝色为关
lv_obj_set_style_bg_color(btn, lv_color_hex(0x00ff00), LV_PART_MAIN); //绿色开
if (strcmp(label_text, "关") == 0){
lv_label_set_text(img, "开");//按钮获取按键的文本
sprintf(msg, "(%d,%d):1", row+1, col+1); // 生成开启时的消息
//LV_LOG_USER(msg);
serial_send("1"); // 发送开启消息
else{
lv_obj_set_style_bg_color(btn, lv_color_hex(0x4684FD), LV_PART_MAIN);
if (strcmp(label_text, "开") == 0){
lv_label_set_text(img, "关");//按钮获取按键的文本
sprintf(msg, "(%d,%d):0", row + 1, col + 1); // 生成关闭时的消息
//LV_LOG_USER(msg);
serial_send("2"); // 发送关闭消息
lv_obj_t *create_serial_btn(lv_obj_t * parent, int row, int col, btn_attr_t attr) {
lv_obj_t * btn = lv_btn_create(parent);
/*设置按钮位置*/
lv_coord_t x = 150 + col * X_OFFSET;
lv_coord_t y = 140 + row * Y_OFFSET;
lv_obj_set_pos(btn, x, y);
lv_obj_set_size(btn, BTN_WIDTH, BTN_HEIGHT);
lv_obj_set_style_bg_color(btn, attr.color, 0);
/*设置图标样式*/
lv_obj_t * img = lv_label_create(btn);
lv_obj_set_style_text_font(img, &myfont, 0);
lv_label_set_text(img, attr.img);
lv_obj_align(img, LV_ALIGN_CENTER, 0 ,10);
/*设置文本样式*/
lv_obj_t * label = lv_label_create(parent);
lv_label_set_text(label, attr.label);
lv_obj_set_style_text_font(label, &myfont, 0);
lv_obj_set_style_text_opa(label, LV_OPA_100, 0);
lv_obj_align_to(label, btn, LV_ALIGN_OUT_BOTTOM_MID, 0, 10);
lv_obj_set_style_text_color(label, lv_color_hex(0x000000), 0);
lv_obj_add_event_cb(btn, serial_btn_event_cb, LV_EVENT_ALL, NULL);
/*动态分配位置数据并设置为用户数据*/
btn_pos_t *pos = (btn_pos_t *)lv_mem_alloc(sizeof(btn_pos_t));
pos->row = row;
pos->col = col;
lv_obj_set_user_data(btn, pos);
return btn;
void create_buttons_matrix(lv_obj_t * parent) {
btn_attr_t btn_attributes[NUM_ROWS][NUM_COLS] = {
{{"关", "卷膜(左)", lv_color_hex(0x4684FD)}, {"关", "卷膜(右)", lv_color_hex(0x4684FD)}, {"关", "棉被(左)", lv_color_hex(0x4684FD)}, {"关", "棉被(右)", lv_color_hex(0x4684FD)}},
{{"关", "风机", lv_color_hex(0x4684FD)}, {"关", "地加热", lv_color_hex(0x4684FD)}, {"关", "喷雾", lv_color_hex(0x4684FD)}, {"关", "滴灌", lv_color_hex(0x4684FD)}},
{{"关", "预备", lv_color_hex(0x4684FD)}, {"关", "预备", lv_color_hex(0x4684FD)}, {"关", "预备", lv_color_hex(0x4684FD)}, {"关", "预备", lv_color_hex(0x4684FD)}}
for (int row = 0; row < NUM_ROWS; row++) {
for (int col = 0; col < NUM_COLS; col++) {
create_serial_btn(parent, row, col, btn_attributes[row][col]);
如果是内存泄漏问题我尝试添加了释放内存代码,结果还是那样的,是不是因为我创建按钮矩阵的原因啊?请教一下怎么解决这个问题啊,没有头绪。
void destroy_serial_btn(lv_obj_t * btn) {
lv_mem_free(pos);
lv_obj_del(btn);
