测试配置HDMI输出流程
根据我的步骤,这里先测试下hdmi硬件,先看下输出是否正常。
- 先配置设备树
- 查看/home/allwinner/Desktop/tina-d1-h/lichee/linux-5.4/arch/riscv/boot/dts/sunxi/sun20iw1p1.dtsi,如下将status设置为"okay",开启disp
	disp: disp@5000000 {
  		compatible = "allwinner,sunxi-disp";
  		reg = <0x0 0x05000000 0x0 0x3fffff>,	/* de0 */
  		      <0x0 0x05460000 0x0 0xfff>,	/*display_if_top*/
  		      <0x0 0x05461000 0x0 0xfff>,	/* tcon-lcd0 */
  		      <0x0 0x05470000 0x0 0xfff>,	/* tcon-tv */
  		      <0x0 0x05450000 0x0 0x1fff>;	/* dsi0*/
/*			interrupts = <GIC_SPI 90 IRQ_TYPE_LEVEL_HIGH>,tcon-lcd0
  			     <GIC_SPI 91 IRQ_TYPE_LEVEL_HIGH>,tcon-tv
  			     <GIC_SPI 92 IRQ_TYPE_LEVEL_HIGH>;dsi*/
  		interrupts-extended = <&plic0 106 IRQ_TYPE_LEVEL_HIGH>,
  				      <&plic0 107 IRQ_TYPE_LEVEL_HIGH>,
  				      <&plic0 108 IRQ_TYPE_LEVEL_HIGH>;
  		clocks = <&ccu CLK_DE0>,
  			 <&ccu CLK_DE0>,
  			 <&ccu CLK_BUS_DE0>,
  			 <&ccu CLK_BUS_DE0>,
  			 <&ccu CLK_BUS_DPSS_TOP0>,
  			 <&ccu CLK_MIPI_DSI>,
  			 <&ccu CLK_BUS_MIPI_DSI>,
  			 <&ccu CLK_TCON_LCD0>,
  			 <&ccu CLK_TCON_TV>,
  			 <&ccu CLK_BUS_TCON_LCD0>,
  			 <&ccu CLK_BUS_TCON_TV>,
  			 <&ccu CLK_BUS_MIPI_DSI>;
  		clock-names = "clk_de0",
  				"clk_de1",
  				"clk_bus_de0",
  				"clk_bus_de1",
  				"clk_bus_dpss_top0",
  				"clk_bus_dpss_top1",
  				"clk_mipi_dsi0",
  				"clk_bus_mipi_dsi0",
  				"clk_tcon0",
  				"clk_tcon1",/*tcon-tv actually*/
  				"clk_bus_tcon0",
  				"clk_bus_tcon1",/*tcon-tv actually*/
  				"clk_mipi_dsi0",
  				"clk_bus_mipi_dsi0";
  		resets = <&ccu RST_BUS_DE0>,
  			 <&ccu RST_BUS_DE0>,
  			 <&ccu RST_BUS_DPSS_TOP0>,
  			 <&ccu RST_BUS_MIPI_DSI>,
  			 <&ccu RST_BUS_TCON_LCD0>,
  			 <&ccu RST_BUS_TCON_TV>,
  			 <&ccu RST_BUS_LVDS0>;
  		reset-names = "rst_bus_de0",
  				"rst_bus_de1",
  				"rst_bus_dpss_top0",
  				"rst_bus_dpss_top1",
  				"rst_bus_mipi_dsi0",
  				"rst_bus_tcon0",
  				"rst_bus_tcon1",
  				"rst_bus_lvds0";
  		assigned-clocks = <&ccu CLK_DE0>,
  		<&ccu CLK_TCON_TV>;
  		assigned-clock-parents = <&ccu CLK_PLL_PERIPH0_2X>,
  		<&ccu CLK_PLL_PERIPH0>,
  		<&ccu CLK_PLL_VIDEO0_4X>,
  		<&ccu CLK_PLL_VIDEO1_4X>;
  		assigned-clock-rates = <300000000>,
  		<150000000>,
  		<0>,
  		<0>;
  		boot_disp = <0>;
  		boot_disp1 = <0>;
  		boot_disp2 = <0>;
  		fb_base = <0>;
  		iommus = <&mmu_aw 2 0>;
将hdmi的status设置为"okay",如下:
    hdmi: hdmi@5500000 {
        compatible = "allwinner,sunxi-hdmi";
        reg = <0x0 0x05500000 0x0 0xfffff>;
        interrupts-extended = <&plic0 93 IRQ_TYPE_LEVEL_HIGH>;
        clocks = <&ccu CLK_BUS_HDMI>,
            <&ccu CLK_HDMI_24M>,
            <&ccu CLK_HDMI_CEC>,
            <&ccu CLK_TCON_TV>;
        clock-names = "clk_bus_hdmi",
                "clk_ddc",
                "clk_cec",
                "clk_tcon_tv";
        resets = <&ccu RST_BUS_HDMI_SUB>,
            <&ccu RST_BUS_HDMI_MAIN>;
        reset-names = "rst_bus_sub",
                    "rst_bus_main";
        assigned-clocks = <&ccu CLK_HDMI_CEC>;
        assigned-clock-parents = <&ccu CLK_HDMI_CEC_32K>;
        assigned-clock-rates = <0>;
- 查看板级dts,路径:/home/allwinner/Desktop/tina-d1-h/device/config/chips/d1-h/configs/nezha/board.dts
根据需要将HDMI设置如下:
&hdmi {
	hdmi_used = <1>;
	hdmi_power_cnt = <0>;
	hdmi_cts_compatibility = <1>;
	hdmi_hdcp_enable = <1>;
	hdmi_hdcp22_enable = <0>;
	hdmi_cec_support = <1>;
	hdmi_cec_super_standby = <0>;
	ddc_en_io_ctrl = <0>;
	power_io_ctrl = <0>;
一些主要参数说明:
| 参数 | 说明 |
| hdmi_cec_super_standby | 开启此功能可以使系统休眠时, cec 不休眠,接收端可以通过 cec唤醒发送端; |
| hdmi_hdcp_enable | 当需要开启 hdcp 时,必须置 1 该参数; |
| hdmi_hdcp22_enable | 置 0 时,只开启 hdcp1.4 功能,置 1 时,开启 hdcp2.2 的功能; |
| ddc_en_io_ctrl | 控制是否使用 ddc contrl io 功能(即下面的 ddc_io_ctrl 引脚配置),由硬件平台决定。 |
| ddc_control_io | 在 hdmi 插入时输出 1,在 hdmi 拔出时输出 0,可以使 ddc 的光电特性更加符合 CTS 测试的要求。 |
- 修改config文件,
- 执行make menuconfig
 .config - Tina Configuration
 > Kernel modules > Video Support ────────────────────────────────────────────────────────────────────────────────────────────────
  ┌────────────────────────────────────────────────────── Video Support ───────────────────────────────────────────────────────┐
  │  Arrow keys navigate the menu.  <Enter> selects submenus ---> (or empty submenus ----).  Highlighted letters are hotkeys.  │
  │  Pressing <Y> includes, <N> excludes, <M> modularizes features.  Press <Esc><Esc> to exit, <?> for Help, </> for Search.   │
  │  Legend: [*] built-in  [ ] excluded  <M> module  < > module capable                                                        │
  │ │                         < > kmod-backlight-pwm................................. PWM Backlight support                  │ │
  │ │                         < > kmod-fb.............................................. Framebuffer support                  │ │
  │ │                         < > kmod-fb-cfb-copyarea.............. Framebuffer software copy area support                  │ │
  │ │                         < > kmod-fb-cfb-fillrect...... Framebuffer software rectangle filling support                  │ │
  │ │                         < > kmod-fb-cfb-imgblt............... Framebuffer software image blit support                  │ │
  │ │                         < > kmod-fb-sys-fops.................... Framebuffer software sys ops support                  │ │
  │ │                         < > kmod-fbcon................................... Framebuffer Console support                  │ │
  │ │                         < > kmod-ge8300-km-opencl............................... GE8300 Device Driver                  │ │
  │ │                         -*- kmod-sunxi-disp....................................... sunxi-disp support                  │ │
  │ │                         <*> kmod-sunxi-g2d......................................... sunxi-g2d support                  │ │
  │ │                         <*> kmod-sunxi-hdmi....................................... sunxi-hdmi support                  │ │
  │ │                         <*> kmod-sunxi-uvc......................................... sunxi-uvc support                  │ │
  │ │                         < > kmod-sunxi-vin......................................... sunxi-vin support                  │ │
  │ │                         < > kmod-video-core...................................... Video4Linux support
保存退出
- 执行make kernel_menuconfig,选中如下
 .config - Linux/riscv 5.4.61 Kernel Configuration
 > Device Drivers > Graphics support > Frame buffer Devices > Video support for sunxi ────────────────────────────────────────────
  ┌───────────────────────────────────────────────── Video support for sunxi ──────────────────────────────────────────────────┐
  │ │                         [ ] Framebuffer Console Support(sunxi)                                                         │ │
  │ │                         <*> DISP Driver Support(sunxi-disp2)                                                           │ │
  │ │                             DISP2 Framebuffer rotation support (Disable rotation)  --->                                │ │
  │ │                         [*] Framebuffer show bootlogo from lzma file                                                   │ │
  │ │                         < > HDMI Driver Support(sunxi-disp2)                                                           │ │
  │ │                         <*> HDMI2.0 Driver Support(sunxi-disp2)  ----                                                  │ │
  │ │                             HDMI2.0 PHY SELECT. (Allwinner PHY)  --->                                                  │ │
  │ │                         < > HDMI EP952 Driver Support(sunxi-disp2)                                                     │ │
  │ │                         [ ] HDMI2.0 HDCP  ----        │ │
  │ │                         [*] HDMI2.0 CEC  --->        │ │
  │ │                         [ ] new frequency spread spectrum(hershey) of sunxi                                            │ │
  │ │                         < > TV Driver Support(sunxi-disp2)                                                             │ │
  │ │                         < > VDPO Driver Support(sunxi-disp2)                                                           │ │
  │ │                         < > EDP Driver Support(sunxi-disp2)                                                            │ │
  │ │                         [ ] boot colorbar Support for disp driver(sunxi-disp2)                                         │ │
  │ │                         [*] debugfs support for disp driver(sunxi-disp2)                                               │ │
  │ │                         [ ] composer support for disp driver(sunxi-disp2)                                              │ │
  │ │                         [ ] ESD detect support for LCD panel                                                           │ │
  │ │                         < > Framebuffer implementaion without display hardware of AW                                   │ │
  │ │                         [ ] Enable LCD_FB FB_DEFERRED_IO                                                               │ │
  │ │                             LCD panels select  --->        │ │
  │ │                             Display engine feature select  --->                                                        │ │
保存退出
make,然后pack打包,最后烧录完成,这时,按照默认sdk的配置,hdmi这里应该还是黑的
用串口终端(我这里用的是MobaXterm,很全的一款终端调试工具)打开板子的调试串口,波特率呢选1152000,
等待日志停下来,然后在终端回车,进入root的shell下
root@TinaLinux:/#
这时可以查看模块状态
root@TinaLinux:/#  cat /sys/class/disp/disp/attr/sys
screen 0:
de_rate 300000000 hz, ref_fps:58
mgr0: 480x800 fmt[rgb] cs[0x204] range[full] eotf[0x4] bits[8bits] err[0] force_sync[0] unblank direct_show[false] iommu[1]
dmabuf: cache[0] cache max[0] umap skip[0] umap skip max[34]
        lcd output      backlight(100)  fps:59.1         480x 800
        err:1   skip:191        irq:2871        vsync:0 vsync_skip:0
   BUF    enable ch[1] lyr[0] z[16] prem[N] a[pixel 255] fmt[  0] fb[ 480, 800; 480, 800; 480, 800] crop[   0,   0, 480, 800] frame[   0,   0, 480, 800] addr[ffc00000,       0,       0] flags[0x       0] trd[0,0]
depth[ 0] r
可以看到当前默认是lcd输出,前面开启了debugfs,那尝试用命令切换到HDMI输出看看能不能行
cd /sys/kernel/debug/dispdbg切换到dspdbg目录
目录下有以下参数
command  dbglvl   info     name     param    start
根据文档描述呢,参数定义如下
| 参数 | 描述 |
| name | disp0/1/2 //表示显示通道0/1/2 |
| command | switch切换显示通道,blank关闭显示 |
| param | type mode,其中type 0(none),1(lcd),2(tv),4(hdmi),8(vga);mode对应disp_tv_mode |
| start | 1 执行命令 |
| 从disp_tv_mode参数看,测试屏幕是1080P,对应mode值为DISP_TV_MOD_1080P_60HZ = 0xa,也就是10,那么命令就是 |
echo disp0 > name;echo switch > command; echo 4 10 > param;echo 1 > start
回车,此时输出如下:
[  799.576040] disp 0, type 4, mode10
[  799.580705] lcd_close_flow
[  799.583929] lcd_bl_close
[  799.587063] lcd_panel_exit
[  799.752110] lcd_power_off
[  799.932136] [HDMI receive params]: tv mode: 0xa format:0x1 data bits:0x0 eotf:0x4 cs:0x101 dvi_hdmi:2 range:2 scan:0 aspect_ratio:8
[  799.945491] [HDMI2 error]: sink do not support this mode:16
[  800.962142] disp_al_manager_apply ouput_type:0
[  800.967271] disp_al_hdmi_cfg
[  801.081913] HDMI Audio Enable Successfully
[  801.086640] [DISP] disp_device_attached_and_enable,line:233:
[  801.086647] attached ok, mgr0<-->dev0
[  801.097246] [DISP] disp_device_attached_and_enable,line:236:
[  801.097256] type:4,mode:10,fmt:yuv444,bits:8bits,eotf:4,cs:257 dvi_hdmi:2, range:2 scan:0 ratio:8
说明执行成功,可以用上面查看模块的命令看一下,执行cat /sys/class/disp/disp/attr/sys
这是输出:
screen 0:
de_rate 300000000 hz, ref_fps:60
mgr0: 1920x1080 fmt[yuv444] cs[0x101] range[limit] eotf[0x4] bits[8bits] err[0] force_sync[0] unblank direct_show[false] iommu[1]
        hdmi output mode(10)    fps:60.6        1920x1080
        err:1   skip:193        irq:47406       vsync:0 vsync_skip:0
depth[ 0]
但是切换成功,依然黑屏,因为没有内容,还好有colorbar测试,执行如下命令
此时能看到屏幕上的色条,说明HDMI输出正常,不过有个问题,能不能默认输出HDMI呢?这个肯定可以的,要不咋用呢
- 设置HDMI为默认输出屏
这里回到前面修改设备树那里,默认输出由设备树配置
路径/home/allwinner/Desktop/tina-d1-h/device/config/chips/d1-h/configs/nezha/board.dts,修改disp部分,下面是原来的
&disp {
	disp_init_enable         = <1>;
	disp_mode                = <0>;
	screen0_output_type      = <1>;
	screen0_output_mode      = <4>;
	screen1_output_type      = <3>;
	screen1_output_mode      = <10>;
	screen1_output_format    = <0>;
	screen1_output_bits      = <0>;
	screen1_output_eotf      = <4>;
	screen1_output_cs        = <257>;
	screen1_output_dvi_hdmi  = <2>;
	screen1_output_range     = <2>;
	screen1_output_scan      = <0>;
	screen1_output_aspect_ratio = <8>;
	dev0_output_type         = <1>;
	dev0_output_mode         = <4>;
	dev0_screen_id           = <0>;
	dev0_do_hpd              = <0>;
	dev1_output_type         = <4>;
	dev1_output_mode         = <10>;
	dev1_screen_id           = <1>;
	dev1_do_hpd              = <1>;
	def_output_dev           = <0>;
	hdmi_mode_check          = <1>;
	fb0_format               = <0>;
	fb0_width                = <0>;
	fb0_height               = <0>;
	fb1_format               = <0>;
	fb1_width                = <0>;
	fb1_height               = <0>;
	chn_cfg_mode             = <1>;
	disp_para_zone           = <1>;
	/*VCC-LCD*/
/*	dc1sw-supply = <®_dc1sw>;*/
	/*VCC-DSI*/
/*	eldo3-supply = <®_eldo3>;*/
	/*VCC-PD*/
/*	dcdc1-supply = <®_dcdc1>;*/
说明在disp上面,也贴出来
| 参数 | 描述 |
| disp_mode | (0:screen0<screen0,fb0>) |
| screenx_output_type | (0:none; 1:lcd; 2:tv; 3:hdmi;5:vdpo) |
| screenx_output_mode | (used for hdmi output, 0:480i 1:576i 2:480p 3:576p 4:720p50,5:720p60 6:1080i50 7:1080i60 8:1080p24 9:1080p50 10:1080p60) |
| screenx_output_format | (for hdmi, 0:RGB 1:yuv444 2:yuv422 3:yuv420) |
| screenx_output_bits | (for hdmi, 0:8bit 1:10bit 2:12bit 2:16bit) |
| screenx_output_eotf | (for hdmi, 0:reserve 4:SDR 16:HDR10 18:HLG) |
| screenx_output_cs | (for hdmi, 0:undefined 257:BT709 260:BT601 263:BT2020) |
| screenx_output_dvi_hdmi | (for hdmi, 0:undefined 1:dvi mode 2:hdmi mode) |
| screen0_output_range | (for hdmi, 0:default 1:full 2:limited) |
| screen0_output_scan | (for hdmi, 0:no data 1:overscan 2:underscan) |
| screen0_output_aspect_ratio | (for hdmi, 8-same as original picture 9-4:3 10-16:9 11-14:9) |
| fbx format | (4:RGB655 5:RGB565 6:RGB556 7:ARGB1555 8:RGBA5551 9:RGB888 10:ARGB8888 12:ARGB4444) |
| fbx pixel sequence | (0:ARGB 1:BGRA 2:ABGR 3:RGBA) |
| fb0_scaler_mode_enable | (scaler mode enable, used FE) |
| fbx_width,fbx_height | (framebuffer horizontal/vertical pixels, fix to output resolution while equal 0) |
| lcdx_backlight | (lcd init backlight,the range:[0,256],default:197 |
| lcdx_yy | (lcd init screen bright/contrast/saturation/hue, value:0~100, default:50/50/57/50) |
| lcd0_contrast | (LCD contrast, 0~100) |
| lcd0_saturation | (LCD saturation, 0~100) |
| lcd0_hue | (LCD hue, 0~100) |
| framebuffer software rotation setting: | |
| disp_rotation_used | (0:disable; 1:enable,you must set fbX_width to lcd_y,set fbX_height to lcd_x) |
| degreeX | (X:screen index; 0:0 degree; 1:90 degree; 3:270 degree) |
| degreeX_Y | (X:screen index; Y:layer index 0~15; 0:0 degree; 1:90 degree; 3:270 degree) |
| devX_output_type | config output type in bootGUI framework in UBOOT-2018. (0:none; 1:lcd; 2:tv; 4:hdmi;) |
| devX_output_mode | config output resolution(see include/video/sunxi_display2.h) of bootGUI framework in UBOOT-2018 |
| devX_screen_id | config display index of bootGUI framework in UBOOT-2018 |
| devX_do_hpd | whether do hpd detectation or not in UBOOT-2018 |
| chn_cfg_mode | Hardware DE channel allocation config. 0:single display with 6 channel, 1:dual display with 4 channel in main display and 2 channel in second display, 2:dual display with 3 channel in main display and 3 channel in second in display. |
| 根据上面,修改如下 |
&disp {
	disp_mode                = <0>;
	screen1_output_type      = <1>;
	screen1_output_mode      = <4>;
	screen0_output_type      = <3>;
	screen0_output_mode      = <10>;
	screen0_output_format    = <0>;
	screen0_output_bits      = <0>;
	screen0_output_eotf      = <4>;
	screen0_output_cs        = <257>;
	screen0_output_dvi_hdmi  = <2>;
	screen0_output_range     = <2>;
	screen0_output_scan      = <0>;
	screen0_output_aspect_ratio = <8>;
;	dev1_output_type         = <1>;
;	dev1_output_mode         = <4>;
;	dev1_screen_id           = <1>;
;	dev1_do_hpd              = <0>;
	dev0_output_type         = <4>;
	dev0_output_mode         = <10>;
	dev0_do_hpd              = <1>;
	fb0_format               = <0>;
	fb0_width                = <0>;
	fb0_height               = <0>;
	fb1_format               = <0>;
	fb1_width                = <0>;
	fb1_height               = <0>;
	chn_cfg_mode             = <1>;
	/*VCC-LCD*/
	/*VCC-DSI*/
	/*VCC-PD*/
然后对于uboot-board.dts里disp同样的修改(路径:/home/allwinner/Desktop/tina-d1-h/device/config/chips/d1-h/configs/nezha/uboot-board.dts)
经过上面配置,已经可以开机显示在hdmi上了,但是开机部分会有花屏,得设置boot时,加载logo,前面make kernel_menuconfig,我已经选中了[*] Framebuffer show bootlogo from lzma file,但是不会开机加载,需要额外设置下,如下
执行make kernel_menuconfig,将下面bootlogo选中
 > Device Drivers > Graphics support ─────────────────────────────────────────────────────────────────────────────────────────────
  ┌───────────────────────────────────────────────────── Graphics support ─────────────────────────────────────────────────────┐
  │ │                         [ ] Direct Rendering Manager (XFree86 4.1.0 and higher DRI support)  ----                      │ │
  │ │                         [ ] Enable DisplayPort CEC-Tunneling-over-AUX HDMI support                                     │ │
  │ │                             ARM devices  ----        │ │
  │ │                             ACP (Audio CoProcessor) Configuration  ----                                                │ │
  │ │                             Frame buffer Devices  --->        │ │
  │ │                             Backlight & LCD device support  --->                                                       │ │
  │ │                             Console display driver support  --->                                                       │ │
  │ │                         [*] Bootup logo  --->        │ │
此时已经可以开机加载logo了,但是默认的logo图片是竖屏的哪吒,我的hdmi是横屏,显示依然花屏,所以得替换掉,logo路径在/home/allwinner/Desktop/tina-d1-h/device/config/chips/d1-h/configs/nezha/configs/bootlogo.bmp,替换一个bmp就行
最后make,pack,将生成的img文件烧录,应该就ok了
