【GzMark】D1h开发板添加红外遥控器驱动到LVGL
添加红外遥控器驱动到LVGL
经过前面测试,红外驱动工作正常,这一步准备将红外遥控器加入到lvgl的输入设备中。
前面lvgl的例子里预留了输入驱动部分,这里补上:
#include "irdev.h"
#include <linux/input.h>
#include <stdlib.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <sys/time.h>
#include <limits.h>
#include <unistd.h>
#include <signal.h>
#define DEV_PATH "/dev/input/event1" //difference is possible
static int irfd = 0;
 * Initialize the evdev
void irdev_init(void){
    irfd = open(DEV_PATH,O_RDONLY);
    printf("%d\r\n",irfd);
    if(irfd>0){
        fcntl(irfd,F_SETFL,O_NONBLOCK);
        printf("open ir input ok\r\n");
 * reconfigure the device file for evdev
 * @param dev_name set the evdev device filename
 * @return true: the device file set complete
 *         false: the device file doesn't exist current system
bool irdev_set_file(char* dev_name){
 * Get the current position and state of the evdev
 * @param data store the evdev data here
 * @return false: because the points are not buffered, so no more data to be read
void irdev_read(lv_indev_drv_t * drv, lv_indev_data_t * data){
    static int lastbtn = 0;
    static int lasttm=0;
    if(irfd>0){
        struct input_event ir={0};
        static uint64_t start_ms = 0;
        if(start_ms == 0) {
            struct timeval tv_start;
        struct timeval tv_now;
        gettimeofday(&tv_now, NULL);
        uint64_t now_ms;
        if(read(irfd,&ir,sizeof(ir))>0){
            if(ir.code){
                if(lastbtn != ir.value){
                    // switch(ir.value){
                    //     case 70:data->key=LV_KEY_UP;break;
                    //     case 21:data->key=LV_KEY_DOWN;break;
                    //     case 68:data->key=LV_KEY_LEFT;break;
                    //     case 67:data->key=LV_KEY_RIGHT;break;
                    //     case 64:data->key=LV_KEY_ENTER;break;
                    //     case 74:data->key=LV_KEY_ESC;break;
                    //     case 7:data->key=LV_KEY_PREV;break;
                    //     case 9:data->key=LV_KEY_NEXT;break;
                    //     default:break;
                    data->state= LV_INDEV_STATE_PRESSED;
                    data->btn_id = ir.value;
                    lastbtn = ir.value;
            }else{
                if(time_ms>200){
                    lastbtn = 0;
                    data->btn_id = 0;
                    data->state = LV_INDEV_STATE_RELEASED;
        }else
        if(time_ms>200 && lastbtn){
            lastbtn = 0;
            data->btn_id = 0;
        // data->continue_reading = true;
上面本来想将部分键值注册成导航键,但物理按键,可能都会用到,导航键不一定够,起码我之前的产品用的按键就16个物理按键,所以,这里就不用导航,直接用实际键值,在main.c中注册时,注册为button类型(其实我这里的用法,跳过了输入注册这层,压根没用lvgl的输入设备框架)
main.c中,前面已经加入驱动了,这里就过掉注册驱动
修改前面的test部分代码,让它响应按键
在前面,我初始化界面控件后,开启了一个定时器,主要是来轮询按键(其实这里用法很多,这里用的定时器,还可以做一个界面管理器,有界面管理器去挂输入设备,将键值作为事件给界面管理器当前的界面去处理,不过这里用定时器最方便),下面是定时器事件部分代码:
void checkkey(lv_timer_t * t){
        lv_indev_data_t data={0};
        curinput->driver->read_cb(curinput->driver,&data);
        if(data.state==LV_INDEV_STATE_PRESSED && data.btn_id){
            switch(data.btn_id){
                case 70:{
                    //up
                    const uint32_t c = lv_obj_get_child_id(cur);
                    if(c>0){
                        lv_obj_clear_state(cur,LV_STATE_FOCUSED);
                        cur = lv_obj_get_child(list,c-1);
                        lv_obj_add_state(cur,LV_STATE_FOCUSED);
                        lv_obj_scroll_to_view(cur,LV_ANIM_ON);
                    }else{
                        cur = lv_obj_get_child(list,lv_obj_get_child_cnt(list)-1);
                }break;
                case 21:{
                    // down
                    if(c<lv_obj_get_child_cnt(list)-1){
                        cur = lv_obj_get_child(list,c+1);
                    }else{
                        cur = lv_obj_get_child(list,0);
                }break;
                case 68:{
                    //  left
                    lv_tabview_t* tabview = (lv_tabview_t*)base;
                    if(tabview->tab_cur>0){
                        lv_tabview_set_act(base,tabview->tab_cur-1,LV_ANIM_ON);
                    }else{
                        lv_tabview_set_act(base,tabview->tab_cnt-1,LV_ANIM_ON);
                }break;
                case 67:{
                    //  right
                    if(tabview->tab_cur<tabview->tab_cnt-1){
                        lv_tabview_set_act(base,tabview->tab_cur+1,LV_ANIM_ON);
                    }else{
                        lv_tabview_set_act(base,0,LV_ANIM_ON);
                    // lv_event_send(base,LV_EVENT_SCROLL_END,NULL);
                }break;
这里,模拟了上下左右的导航切换功能
完整的test.c
#include "test.h"
#include "stdio.h"
#include "lv_conf.h"
static lv_obj_t* base ;
static lv_obj_t* list;
static lv_obj_t* tabs[3] = {0};
static lv_obj_t* cur;
static lv_timer_t* timer;
int tabindex=0,listindex=0;
static lv_indev_t* curinput;
                case 70:{
                    //up
                    if(c>0){
                    }else{
                }break;
                case 21:{
                    // down
                    }else{
                }break;
                case 68:{
                    //  left
                    }else{
                }break;
                case 67:{
                    //  right
                    }else{
                }break;
void test(lv_indev_t* d){
    base = lv_tabview_create(lv_scr_act(),LV_DIR_TOP, 80);
    lv_obj_set_size(base,1920,1080);
    lv_obj_set_pos(base,0,0);
    tabs[0] = lv_tabview_add_tab(base,"Item1");
    tabs[1] = lv_tabview_add_tab(base,"Item2");
    tabs[2] = lv_tabview_add_tab(base,"Item3");
    static lv_style_t style;
    lv_style_init(&style);
    lv_style_set_bg_opa(&style, LV_OPA_100);
    lv_style_set_bg_color(&style, lv_palette_main(LV_PALETTE_BLUE));
    lv_style_set_bg_grad_color(&style, lv_palette_darken(LV_PALETTE_BLUE, 1));
    lv_style_set_bg_grad_dir(&style, LV_GRAD_DIR_VER);
    lv_style_set_text_color(&style, lv_color_white());
    list = lv_list_create(tabs[0]);
    lv_obj_set_size(list,200,400);
    lv_obj_set_pos(list,0,0);
    for(int i=0; i<6; i++){
        char t[5] = {0};
        sprintf(t,"T%d",i+1);
        cur = lv_list_add_btn(list,NULL,t);
        lv_obj_add_style(cur,&style,LV_STATE_FOCUSED);
    curinput = d;
    timer = lv_timer_create(checkkey,5,NULL);
void test_quit(){
    if(base){
        lv_obj_clean(base);
        lv_obj_del(base);
上面的修改完成,在lv_ir_test目录下,建立shell,在shell下执行 mm
等待编译完成,将out目录下的lv_ir_test 执行文件通过adb push到板子上
在串口终端下,执行lv_ir_test,此时可以通过红外遥控的上下切换tabview的tab页,通过上下去切换list的选项。
最后呢,可以通过pack打包成镜像,烧录下,此时lv_ir_test 在/usr/bin/下,可以直接在串口终端执行测试
