100ASK-T113S3 开发板蓝牙启动失败
root@TinaLinux:/# bt_test
root@TinaLinux:/# 1675661278.114213: BTMG[bt_manager_set_enable_default:513]: enable default profile from bt config.
1675661278.114275: BTMG[bt_manager_enable:407]: bt manager version:Version:3.0.1.202110291544,builed time:Oct 29 2021-09:14:39
1675661278.114313: BTMG[bt_test_status_cb:82]: bt is turnning on.
hcidump_xr start
Bluetooth init has been completed!!
/etc/bluetooth/bt_init.sh: line 92: hcidump_xr: not found
ln: /var/lib/bluetooth: No such file or directory
bluetoothd[385]: Bluetooth daemon 5.54
D-Bus setup failed: Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory
bluetoothd[385]: Unable to get on D-Bus
bluealsa: Couldn’t initialize controller thread: Bad file descriptor
1675661279.394013: BTMG[bt_profile_global_init:355]: start bluealsa :1 times
1675661279.394757: [a2dp_sink_thread_process:270]: BlueALSA connection failed: No such file or directory
1675661279.395432: [hfp_thread_process:662]: BlueALSA connection failed: No such file or directory
1675661279.399876: BTMG[bt_routine:68]: Couldn’t obtain D-Bus connection: Could not connect: No such file or directory
1675661279.896096: BTMG[bt_manager_enable:449]: init connection to bluez failed!
nothing to do.
1675661279.902913: BTMG[bt_test_status_cb:65]: BT is off
