日志如下:
[20]HELLO! BOOT0 is starting!
[23]BOOT0 commit : 2c94b33
[26]set pll start
[32]periph0 has been enabled
[35]set pll end
[36][pmu]: bus read error
[39]board init ok
[41]enable_jtag
[42]ZQ value = 0x2f***********
[45]get_pmu_exist() = -1
[48]ddr_efuse_type: 0xa
[51][AUTO DEBUG] single rank and full DQ!
[55]ddr_efuse_type: 0xa
[58][AUTO DEBUG] rank 0 row = 13
[62][AUTO DEBUG] rank 0 bank = 8
[65][AUTO DEBUG] rank 0 page size = 2 KB
[69]DRAM BOOT DRIVE INFO: V0.24
[72]DRAM CLK = 792 MHz
[74]DRAM Type = 3 (2:DDR2,3:DDR3)
[77]DRAMC read ODT off.
[80]DRAM ODT value: 0x42.
[82]ddr_efuse_type: 0xa
[86]DRAM SIZE =128 M
[88]PLL_DDR_CTRL_REG:0xf8004100
[91]DRAM_CLK_REG:0xc0000000
[98]DRAM simple test OK.
[100]rtc standby flag is 0x0, super standby flag is 0x0
[106]dram size =128
[109]card no is 0
[110]sdcard 0 line count 4
[113][mmc]: mmc driver ver 2021-03-22 20:20
[122][mmc]: Wrong media type 0x0
[125][mmc]: Try SD card 0
[137][mmc]: HSSDR52/SDR25 4 bit
[139][mmc]: 50000000 Hz
[142][mmc]: 7600 MB
[143][mmc]: SD/MMC 0 init OK!!!
[237]Loading boot-pkg Succeed(index=0).
[241]Entry_name = u-boot
[248]Entry_name = optee
[252]Entry_name = logo
[255]Entry_name = dtb
[258]mmc not para
[259]Jump to second Boot.
U-Boot 2018.05 (Aug 01 2022 - 04:03:28 +0000) Allwinner Technology
[00.315]CPU: Allwinner Family
[00.318]Model: sun8iw20
[00.320]DRAM: 128 MiB
[00.323]Relocation Offset is: 04ebd000
[00.350]secure enable bit: 0
[00.353]smc_tee_inform_fdt failed with: -65526[00.357]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=300Mhz
[00.363]gic: sec monitor mode
[00.366]line:703 init_clocks
[00.369]drv_disp_init
request pwm success, pwm7:pwm7:0x2000c00.
[00.384]drv_disp_init finish
[00.386]boot_gui_init:start
[00.389]set disp.dev2_output_type fail. using defval=0
[00.395]boot_gui_init:finish
[00.413]flash init start
[00.415]workmode = 0,storage type = 1
[00.419][mmc]: mmc driver ver uboot2018:2021-09-07 19:43:00
[00.424][mmc]: get sdc_type fail and use default host:tm1.
[00.430][mmc]: can’t find node “mmc0”,will add new node
[00.435][mmc]: fdt err returned
[00.439][mmc]: Using default timing para
[00.442][mmc]: SUNXI SDMMC Controller Version:0x50310
[00.461][mmc]: card_caps:0x3000000a
[00.464][mmc]: host_caps:0x3000003f
[00.469]sunxi flash init ok
[00.490]Loading Environment from SUNXI_FLASH… OK
[00.513]Item0 (Map) magic is bad
[00.516]the secure storage item0 copy0 magic is bad
[00.525]Item0 (Map) magic is bad
[00.527]the secure storage item0 copy1 magic is bad
[00.532]Item0 (Map) magic is bad
[00.538]secure storage read widevine fail with:-1
[00.545]secure storage read ec_key fail with:-1
[00.552]secure storage read ec_cert1 fail with:-1
[00.560]secure storage read ec_cert2 fail with:-1
[00.567]secure storage read ec_cert3 fail with:-1
[00.576]LCD open finish_key fail
[00.578]secure storage read rsa_key fail with:-1
[00.585]secure storage read rsa_cert1 fail with:-1
[00.593]secure storage read rsa_cert2 fail with:-1
[00.600]secure storage read rsa_cert3 fail with:-1
[00.605]usb burn from boot
delay time 0
weak:otg_phy_config
[00.616]usb prepare ok
[00.826]usb sof ok
[00.828]usb probe ok
[00.829]usb setup ok
set address 0x27
set address 0x27 ok
set address 0x27
set address 0x27 ok
set address 0x27
set address 0x27 ok
[03.834]do_burn_from_boot usb : have no handshake
partno erro : can’t find partition private
root_partition is rootfs
set root to /dev/mmcblk0p5
[03.853]update part info
[03.857]update bootcmd
[03.862]change working_fdt 0x4487ce70 to 0x4485ce70
[03.880]update dts
phy_mode=rmii, phy_interface=6
eth0
Error: eth0 address not set.
card0 has inited
curr_device:0
Device: SUNXI SD/MMC
Manufacturer ID: 27
OEM: 5048
Bus Speed: 50000000
Mode : SD High Speed (50MHz)
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 7.4 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
Partition Map for MMC device 0 – Partition Type: EFI
Part Start LBA End LBA Name
Attributes
Type GUID
Partition GUID
1 0x00008a40 0x00009a3f “boot-resource”
attrs: 0x0000000000000000
type: 0fc63daf-8483-4772-8e79-3d69d8477de4
guid: 7c1aa552-060d-468e-85ed-df57fdf711c9
2 0x00009a40 0x00009b3f “env”
guid: 729e74af-f666-41ae-bc02-36bab89b86e7
3 0x00009b40 0x00009c3f “env-redund”
guid: db1b4c6d-52ca-43f3-b15c-2a0e8131fd4f
4 0x00009c40 0x00019c3f “boot”
attrs: 0x0000000000000004
guid: 832d6419-2418-4164-aa82-fbca1725ee60
5 0x00019c40 0x00099c3f “rootfs”
guid: d06434b9-6e6d-497d-b89e-c91b43702210
6 0x00099c40 0x00119c3f “share”
guid: 5f281b55-c115-41d9-a8b7-4c666b732708
261240 bytes read in 14 ms (17.8 MiB/s)
5025792 bytes read in 216 ms (22.2 MiB/s)
[06.261]no vendor_boot partition is found
Android’s image name: sun8iw20p1
[06.273]Starting kernel …
[06.276][mmc]: MMC Device 2 not found
[06.279][mmc]: mmc 2 not find, so not exit
[ 0.000000] Linux version 5.4.61 (book@virtual-machine) (arm-linux-gnueabi-gcc (Linaro GCC 7.2-2017.11) 7.2.1 20171011, GNU ld (Linaro_Binutils-2017.11) 2.28.2.20170706) #4 SMP PREEMPT Fri Aug 5 03:58:45 UTC 2022
[ 0.000000] cma: Reserved 16 MiB at 0x47000000
[ 0.000000] percpu: Embedded 15 pages/cpu s30860 r8192 d22388 u61440
[ 0.000000] pcpu-alloc: s30860 r8192 d22388 u61440 alloc=15*4096
[ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0x05000000 clk_ignore_unused initcall_debug=0 console=ttyS3,115200 loglevel=8 root=/dev/mmcblk0p5 init=/sbin/init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:share@mmcblk0p6 cma=16M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.hardware=sun8iw20p1 boot_type=1 androidboot.boot_type=1 gpt=1 uboot_message=2018.05(08/01/2022-04:03:28) disp_reserve=2457600,0x448a6000 androidboot.dramsize=128
[ 0.000000] Memory: 90588K/131072K available (7168K kernel code, 410K rwdata, 2424K rodata, 1024K init, 183K bss, 24100K reserved, 16384K cma-reserved)
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] random: get_random_bytes called from start_kernel+0x248/0x3d0 with crng_init=0
[ 0.000195] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000788] Console: colour dummy device 80x30
[ 0.000826] Calibrating delay loop (skipped), value calculated using timer frequency… 48.00 BogoMIPS (lpj=240000)
[ 0.000840] pid_max: default: 32768 minimum: 301
[ 0.000921] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.000935] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.001550] CPU: Testing write buffer coherency: ok
[ 0.001881] /cpus/cpu@0 missing clock-frequency property
[ 0.001903] /cpus/cpu@1 missing clock-frequency property
[ 0.001915] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002595] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.002759] rcu: Hierarchical SRCU implementation.
[ 0.003095] BOOTEVENT: 3.086790: ON
[ 0.003303] smp: Bringing up secondary CPUs …
[ 0.004599] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.004756] smp: Brought up 1 node, 2 CPUs
[ 0.004771] SMP: Total of 2 processors activated (96.00 BogoMIPS).
[ 0.004778] CPU: All CPU(s) started in SVC mode.
[ 0.005348] devtmpfs: initialized
[ 0.106727] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.110541] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.110575] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.111325] pinctrl core: initialized pinctrl subsystem
[ 0.122965] NET: Registered protocol family 16
[ 0.124927] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.458089] rtc_ccu: sunxi ccu init OK
[ 0.498994] ccu: sunxi ccu init OK
[ 0.501489] r_ccu: sunxi ccu init OK
[ 0.959440] iommu: Default domain type: Translated
[ 0.961805] sunxi iommu: irq = 24
[ 0.994392] SCSI subsystem initialized
[ 1.004973] usbcore: registered new interface driver usbfs
[ 1.005100] usbcore: registered new interface driver hub
[ 1.007949] usbcore: registered new device driver usb
[ 1.012765] mc: Linux media interface: v0.10
[ 1.012868] videodev: Linux video capture interface: v2.00
[ 1.037112] Advanced Linux Sound Architecture Driver Initialized.
[ 1.053730] Bluetooth: Core ver 2.22
[ 1.053846] NET: Registered protocol family 31
[ 1.053857] Bluetooth: HCI device and connection manager initialized
[ 1.053883] Bluetooth: HCI socket layer initialized
[ 1.053896] Bluetooth: L2CAP socket layer initialized
[ 1.053933] Bluetooth: SCO socket layer initialized
[ 1.056491] pwm module init!
[ 1.073521] g2d 5410000.g2d: Adding to iommu group 0
[ 1.076499] G2D: rcq version initialized.major:251
[ 1.090063] input: sunxi-keyboard as /devices/virtual/input/input0
[ 1.101686] clocksource: Switched to clocksource arch_sys_counter
[ 1.281890] sun8iw20-pinctrl pio: initialized sunXi PIO driver
[ 1.646368] thermal_sys: Registered thermal governor ‘step_wise’
[ 1.646374] thermal_sys: Registered thermal governor ‘user_space’
[ 1.659447] NET: Registered protocol family 2
[ 1.669954] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 1.669989] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 1.670013] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 1.670035] TCP: Hash tables configured (established 1024 bind 1024)
[ 1.670203] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 1.670240] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 1.673762] NET: Registered protocol family 1
[ 1.680911] RPC: Registered named UNIX socket transport module.
[ 1.680928] RPC: Registered udp transport module.
[ 1.680935] RPC: Registered tcp transport module.
[ 1.680942] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.695244] sun8iw20-pinctrl pio: pio supply vcc-pc not found, using dummy regulator
[ 1.708488] spi spi0: spi0 supply spi not found, using dummy regulator
[ 1.708866] sunxi_spi_resource_get()2151 - [spi0] SPI MASTER MODE
[ 1.715298] sunxi_spi_resource_get()2189 - Failed to get sample mode
[ 1.715313] sunxi_spi_resource_get()2194 - Failed to get sample delay
[ 1.715323] sunxi_spi_resource_get()2198 - sample_mode:-1431633921 sample_delay:-1431633921
[ 1.715404] sunxi_spi_clk_init()2240 - [spi0] mclk 100000000
[ 1.729093] sunxi_spi_probe()2653 - [spi0]: driver probe succeed, base c8821000, irq 42
[ 1.764517] Initialise system trusted keyrings
[ 1.764731] workingset: timestamp_bits=30 max_order=15 bucket_order=0
[ 1.782320] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 1.782475] fuse: init (API version 7.31)
[ 1.825918] NET: Registered protocol family 38
[ 1.825945] Key type asymmetric registered
[ 1.825954] Asymmetric key parser ‘x509’ registered
[ 1.826100] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 1.826113] io scheduler mq-deadline registered
[ 1.826122] io scheduler kyber registered
[ 1.826271] atomic64_test: passed
[ 1.863966] [DISP]disp_module_init
[ 1.868092] disp 5000000.disp: Adding to iommu group 0
[ 1.878716] [DISP] disp_init,line:2386:
[ 1.878724] smooth display screen:0 type:1 mode:4
[ 1.889971] disp 5000000.disp: 5000000.disp supply vcc-lcd not found, using dummy regulator
[ 1.900231] disp 5000000.disp: 5000000.disp supply vcc-pd not found, using dummy regulator
[ 1.909345] display_fb_request,fb_id:0
[ 1.919894] disp_al_manager_apply ouput_type:1
[ 1.926482] wait for new fb take effect
[ 1.926852] [DISP] lcd_clk_config,line:732:
[ 1.926865] disp 0, clk: pll(306000000),clk(306000000),dclk(51000000) dsi_rate(306000000)
[ 1.926865] clk real:pll(300000000),clk(300000000),dclk(50000000) dsi_rate(0)
[ 1.927220] sun8iw20-pinctrl pio: pio supply vcc-pd not found, using dummy regulator
[ 1.973404] Freeing logo buffer memory: 2400K
[ 1.980796] [DISP]disp_module_init finish
[ 1.985823] sunxi_sid_init()551 - insmod ok
[ 1.989740] pwm-regulator: supplied by regulator-dummy
[ 2.021574] sun8iw20-pinctrl pio: pio supply vcc-pg not found, using dummy regulator
[ 2.028875] uart uart1: get regulator failed
[ 2.028906] uart uart1: uart1 supply uart not found, using dummy regulator
[ 2.037405] uart1: ttyS1 at MMIO 0x2500400 (irq = 34, base_baud = 1500000) is a SUNXI
[ 2.050359] sun8iw20-pinctrl pio: pio supply vcc-pb not found, using dummy regulator
[ 2.050855] uart uart3: get regulator failed
[ 2.050880] uart uart3: uart3 supply uart not found, using dummy regulator
[ 2.061413] uart3: ttyS3 at MMIO 0x2500c00 (irq = 35, base_baud = 1500000) is a SUNXI
[ 2.061446] sw_console_setup()1784 - console setup baud 115200 parity n bits 8, flow n
[ 3.050260] printk: console [ttyS3] enabled
[ 3.066623] misc dump reg init
[ 3.096289] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
[ 3.103558] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
[ 3.110855] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
[ 3.118274] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
[ 3.124803] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
[ 3.131718] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
[ 3.139408] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=204 assert=1
[ 3.147227] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
[ 3.155309] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
[ 3.166337] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
[ 3.173147] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
[ 3.180638] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=207 assert=0
[ 3.240595] libphy: Fixed MDIO Bus: probed
[ 3.256317] sun8iw20-pinctrl pio: pio supply vcc-pe not found, using dummy regulator
[ 3.268719] sunxi gmac driver’s version: 1.0.0
[ 3.277395] gmac-power0: NULL
[ 3.280737] gmac-power1: NULL
[ 3.284094] gmac-power2: NULL
[ 3.307498] Failed to alloc md5
[ 3.311043] eth0: Use random mac address
[ 3.315853] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 3.323194] sunxi-ehci: EHCI SUNXI driver
[ 3.328083] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 3.335040] sunxi-ohci: OHCI SUNXI driver
[ 3.344873] usbcore: registered new interface driver uas
[ 3.356924] usbcore: registered new interface driver usb-storage
[ 3.363799] usbcore: registered new interface driver ums-alauda
[ 3.370494] usbcore: registered new interface driver ums-cypress
[ 3.378333] usbcore: registered new interface driver ums-datafab
[ 3.387623] usbcore: registered new interface driver ums_eneub6250
[ 3.394691] usbcore: registered new interface driver ums-freecom
[ 3.408492] usbcore: registered new interface driver ums-isd200
[ 3.415246] usbcore: registered new interface driver ums-jumpshot
[ 3.422120] usbcore: registered new interface driver ums-karma
[ 3.432220] usbcore: registered new interface driver ums-onetouch
[ 3.439168] usbcore: registered new interface driver ums-realtek
[ 3.445954] usbcore: registered new interface driver ums-sddr09
[ 3.452703] usbcore: registered new interface driver ums-sddr55
[ 3.459360] usbcore: registered new interface driver ums-usbat
[ 3.484466] ts probe start
[ 3.495549] input: 2009c00.rtp as /devices/platform/soc@3000000/2009c00.rtp/input/input1
[ 3.511484] ts probe success
[ 3.519225] sunxi_gpadc_init,2137, success
[ 3.527443] sunxi_gpadc_setup: get channel scan data failed
[ 3.536519] input: sunxi-gpadc0 as /devices/virtual/input/input2
[ 3.585888] sunxi-rtc 7090000.rtc: registered as rtc0
[ 3.591644] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T01:19:06 UTC (4746)
[ 3.600854] sunxi-rtc 7090000.rtc: sunxi rtc probed
[ 3.610128] i2c /dev entries driver
[ 3.614324] IR NEC protocol handler initialized
[ 3.619374] IR RC5(x/sz) protocol handler initialized
[ 3.632761] sunxi_ir_startup: get ir protocol failed
[ 3.632792] (NULL device *): deviceless supply not found, using dummy regulator
[ 3.646718] Registered IR keymap rc_map_sunxi
[ 3.658858] rc rc0: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0
[ 3.671193] input: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0/s_cir_rx
[ 3.696631] usbcore: registered new interface driver uvcvideo
[ 3.703077] USB Video Class driver (1.1.1)
[ 3.707659] gspca_main: v2.14.0 registered
[ 3.712233] sunxi cedar version 1.1
[ 3.716359] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
[ 3.722627] VE: sunxi_cedar_probe power-domain init!!!
[ 3.728346] VE: install start!!!
[ 3.728346]
[ 3.737481] VE: cedar-ve the get irq is 43
[ 3.737481]
[ 3.751111] VE: ve_debug_proc_info:(ptrval), data:(ptrval), lock:(ptrval)
[ 3.751111]
[ 3.760357] VE: install end!!!
