我自己外接了一个四键小键盘,用了扩展接口里面的GPIO4_19-22以及GND五个口。照着韦东山老师给的教程和代码写好了按键驱动(主要修改了board_100ask_imx6ull.c这个文件,下文也只贴出了这个文件里的代码),设置了上拉电阻。但是外接的那四个键总是不管按不按都读到0
接线图和按键内部电路图如下:
键盘GND ----- GND (J7 - 2)
键盘k1 ----- GPIO_19 (J7 - 13)
键盘k2 ----- GPIO_20 (J7 - 14)
键盘k3 ----- GPIO_21 (J7 - 15)
键盘k4 ----- GPIO_22 (J7 - 16)
board_100ask_imx6ull.c代码如下:
(贴出来的代码省略了头文件和两个struct的定义。代码包括imx6ull pro原来的两个按键,一共有6个按键。但是测试时imx6ull pro自带的2个按键没有问题,我自己外接的4个按键表现异常)
struct iomux {
struct imx6ull_gpio {
// virtual address of register to enable GPIO4
static volatile unsigned int *CCM_CCGR3;
// virtual address of register to enable GPIO5
static volatile unsigned int *CCM_CCGR1;
// virtual address of register to set GPIO5_IO03 (key0) as GPIO
static volatile unsigned int *IOMUXC_SNVS_SW_MUX_CTL_PAD_SNVS_TAMPER1;
// virtual address of register to set GPIO4_IO14 (key1) as GPIO
static volatile unsigned int *IOMUXC_SW_MUX_CTL_PAD_NAND_CE1_B;
// virtual address of register to set GPIO4_IO19 (key2) as GPIO
static volatile unsigned int *IOMUXC_SW_MUX_CTL_PAD_CSI_VSYNC;
// virtual address of register to set GPIO4_IO20 (key3) as GPIO
static volatile unsigned int *IOMUXC_SW_MUX_CTL_PAD_CSI_HSYNC;
// virtual address of register to set GPIO4_IO21 (key4) as GPIO
static volatile unsigned int *IOMUXC_SW_MUX_CTL_PAD_CSI_DATA00;
// virtual address of register to set GPIO4_IO22 (key5) as GPIO
static volatile unsigned int *IOMUXC_SW_MUX_CTL_PAD_CSI_DATA01;
// virtual address of register to set pull-up resistor for GPIO4_IO19 (key2)
static volatile unsigned int *IOMUXC_SW_PAD_CTL_PAD_CSI_VSYNC;
// virtual address of register to set pull-up resistor for GPIO4_IO20 (key3)
static volatile unsigned int *IOMUXC_SW_PAD_CTL_PAD_CSI_HSYNC;
// virtual address of register to set pull-up resistor for GPIO4_IO21 (key4)
static volatile unsigned int *IOMUXC_SW_PAD_CTL_PAD_CSI_DATA00;
// virtual address of register to set pull-up resistor for GPIO4_IO22 (key5)
static volatile unsigned int *IOMUXC_SW_PAD_CTL_PAD_CSI_DATA01;
static struct iomux *iomux;
static struct imx6ull_gpio *gpio4;
static struct imx6ull_gpio *gpio5;
static void board_imx6ull_button_init (int which) /* initialize the specific button */
if (!CCM_CCGR1 && !CCM_CCGR3)
//map the physical address of registers
CCM_CCGR1 = ioremap(0x20C406C, 4);
CCM_CCGR3 = ioremap(0x20C4074, 4);
IOMUXC_SNVS_SW_MUX_CTL_PAD_SNVS_TAMPER1 = ioremap(0x229000C, 4);
IOMUXC_SW_MUX_CTL_PAD_NAND_CE1_B = ioremap(0x20E01B0, 4);
IOMUXC_SW_MUX_CTL_PAD_CSI_VSYNC = ioremap(0x20E01DC, 4);
IOMUXC_SW_MUX_CTL_PAD_CSI_HSYNC = ioremap(0x20E01E0, 4);
IOMUXC_SW_MUX_CTL_PAD_CSI_DATA00 = ioremap(0x20E01E4, 4);
IOMUXC_SW_MUX_CTL_PAD_CSI_DATA01 = ioremap(0x20E01E8, 4);
IOMUXC_SW_PAD_CTL_PAD_CSI_VSYNC = ioremap(0x20E0468, 4);
IOMUXC_SW_PAD_CTL_PAD_CSI_HSYNC = ioremap(0x20E046C, 4);
IOMUXC_SW_PAD_CTL_PAD_CSI_DATA00 = ioremap(0x20E0470, 4);
IOMUXC_SW_PAD_CTL_PAD_CSI_DATA01 = ioremap(0x20E0474, 4);
iomux = ioremap(0x20e0000, sizeof(struct iomux));
gpio4 = ioremap(0x20A8000, sizeof(struct imx6ull_gpio));
gpio5 = ioremap(0x20AC000, sizeof(struct imx6ull_gpio));
if (which == 0)
//1. enable GPIO5: CG15, b[31:30] = 0b11
*CCM_CCGR1 |= (3<<30);
//2. set GPIO5_IO01 as GPIO: MUX_MODE, b[3:0] = 0b101
*IOMUXC_SNVS_SW_MUX_CTL_PAD_SNVS_TAMPER1 = 5;
//3. set GPIO5_IO01 as input: GPIO5 GDIR, b[1] = 0b0
gpio5->gdir &= ~(1<<1);
else{
//1. enable GPIO4: CG6 b[13:12] = 0b11
*CCM_CCGR3 |= (3<<12);
if(which == 1)
//2. set GPIO4_IO14 as GPIO: MUX_MODE, b[3:0] = 0b101
*IOMUXC_SW_MUX_CTL_PAD_NAND_CE1_B = 5;
//3. set GPIO4_IO14 as input: GPIO4 GDIR, b[14] = 0b0
gpio4->gdir &= ~(1<<14);
else if(which == 2) //GPIO4_IO20 (key2)
//2. set GPIO4_IO19 as GPIO: MUX_MODE, b[3:0] = 0b101
*IOMUXC_SW_MUX_CTL_PAD_CSI_VSYNC = 5;
//set pull-up resistor for GPIO4_IO19
//mask to clear bits 15-13 (make them `00`)
*IOMUXC_SW_PAD_CTL_PAD_CSI_VSYNC &= ~(0x7 << 13);
//enable pull: set bits 13 to `1`
*IOMUXC_SW_PAD_CTL_PAD_CSI_VSYNC |= (0x1 << 13);
//set bits 15-14 to `11` (22K Ohm Pull Up)
*IOMUXC_SW_PAD_CTL_PAD_CSI_VSYNC |= (0x3 << 14);
//3. set GPIO4_IO19 as input: GPIO4 GDIR, b[19] = 0b0
gpio4->gdir &= ~(1<<19);
else if(which == 3) //GPIO4_IO20 (key3)
*IOMUXC_SW_PAD_CTL_PAD_CSI_HSYNC = 5;
*IOMUXC_SW_PAD_CTL_PAD_CSI_HSYNC &= ~(0x7 << 13);
*IOMUXC_SW_PAD_CTL_PAD_CSI_HSYNC |= (0x1 << 13);
*IOMUXC_SW_PAD_CTL_PAD_CSI_HSYNC |= (0x3 << 14);
gpio4->gdir &= ~(1<<20);
else if(which == 4)
*IOMUXC_SW_MUX_CTL_PAD_CSI_DATA00 = 5;
*IOMUXC_SW_PAD_CTL_PAD_CSI_DATA00 &= ~(0x7 << 13);
*IOMUXC_SW_PAD_CTL_PAD_CSI_DATA00 |= (0x1 << 13);
*IOMUXC_SW_PAD_CTL_PAD_CSI_DATA00 |= (0x3 << 14);
gpio4->gdir &= ~(1<<21);
else if(which == 5)
*IOMUXC_SW_MUX_CTL_PAD_CSI_DATA01 = 5;
*IOMUXC_SW_PAD_CTL_PAD_CSI_DATA01 &= ~(0x7 << 13);
*IOMUXC_SW_PAD_CTL_PAD_CSI_DATA01 |= (0x1 << 13);
*IOMUXC_SW_PAD_CTL_PAD_CSI_DATA01 |= (0x3 << 14);
gpio4->gdir &= ~(1<<22);
else{
printk("illegal button number\n");
static int board_imx6ull_button_read (int which) /* read specific button*/
//printk("%s %s line %d, button %d, 0x%x\n", __FILE__, __FUNCTION__, __LINE__, which, *GPIO1_DATAIN);
if (which == 0)
return (gpio5->psr & (1<<1)) ? 1 : 0; //gpio5->psr & (1<<1) ---> gpio5_io01
else if (which == 1)
return (gpio4->psr & (1<<14)) ? 1 : 0; //gpio4->psr & (1<<14) ---> gpio5_io14
else if (which == 2)
return (gpio4->psr & (1<<19)) ? 1 : 0;
else if (which == 3)
return (gpio4->psr & (1<<20)) ? 1 : 0;
else if (which == 4)
return (gpio4->psr & (1<<21)) ? 1 : 0;
else if (which == 5)
return (gpio4->psr & (1<<22)) ? 1 : 0;
static struct button_operations my_buttons_ops = {
.count = 6,
.init = board_imx6ull_button_init,
.read = board_imx6ull_button_read,
int board_imx6ull_button_drv_init(void)
register_button_operations(&my_buttons_ops);
void board_imx6ull_button_drv_exit(void)
unregister_button_operations();
module_init(board_imx6ull_button_drv_init);
module_exit(board_imx6ull_button_drv_exit);
MODULE_LICENSE("GPL");
