用tf卡烧录官方镜像启动系统失败
U-Boot 2018.05-g3a34d5f (Jul 08 2022 - 07:00:11 +0000) Allwinner Technology
[00.947]CPU: Allwinner Family
[00.950]Model: sun8iw21
I2C: [I2C-ERROR]:twi_send_clk_9pulse() 147 SDA is still Stuck Low, failed.
ready
[01.010]DRAM: 64 MiB
[01.014]Relocation Offset is: 00ed0000
[01.047]secure enable bit: 0
E/TC:0 tee_read_fdt:433 fine node /firmware/optee failed with FDT_ERR_NOTFOUND
[01.062]smc_tee_inform_fdt failed with: ffff0000
[I2C-ERROR]:twi_stop() 339 STOP can’t sendout!
[01.072]pmu_axp2101_probe pmic_bus_read fail
[01.080]bmu_axp2101_probe pmic_bus_read fail
[01.084]CPU=900 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=24Mhz MBus=300Mhz
[01.090]gic: sec monitor mode
sunxi flash map init
[01.095]flash init start
[01.097]workmode = 0,storage type = 1
[01.101][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
[01.106][mmc]: get sdc_type fail and use default host:tm1.
[01.112][mmc]: can’t find node “mmc0”,will add new node
[01.117][mmc]: fdt err returned
[01.121][mmc]: Using default timing para
[01.125][mmc]: SUNXI SDMMC Controller Version:0x50400
[01.140][mmc]: card_caps:0x3000000a
[01.144][mmc]: host_caps:0x3000003f
[01.147]sunxi flash init ok
[01.149]line:724 init_clocks
[01.153]drv_disp_init
request pwm success, pwm6:pwm6:0x2000c00.
[01.167]drv_disp_init finish
GUID Partition Table Header signature is wrong: 0x0 != 0x5452415020494645
part_get_info_efi: *** ERROR: Invalid GPT ***
part_get_info_efi: *** ERROR: Invalid Backup GPT ***
[01.192]Loading Environment from SUNXI_FLASH… GUID Partition Table Header signature is wrong: 0x0 != 0x5452415020494645
*** Warning - no device, using default environment
Failed (-19)
[01.224]boot_gui_init:start
[01.227]set disp.dev2_output_type fail. using defval=0
[01.232]LCD open finish
[01.235]boot_gui_init:finish
partno erro : can’t find partition bootloader
partno erro : can’t find partition boot-resource
[01.291]Get bootloader and boot-resource partition number fail!
[01.314]Item0 (Map) magic is bad
[01.317]the secure storage item0 copy0 magic is bad
[01.339]Item0 (Map) magic is bad
[01.341]the secure storage item0 copy1 magic is bad
[01.346]Item0 (Map) magic is bad
[01.349]out of usb burn from boot: not need burn key
[01.376]update part info
[01.401]update bootcmd
[01.448]change working_fdt 0x41e8fe70 to 0x41e6fe70
disable nand error: FDT_ERR_BADPATH
[01.461]The storage not support sample function
[01.467]## error: update_fdt_dram_para : FDT_ERR_NOTFOUND
[01.476]update dts
Error: “distro_bootcmd” not defined
在之前用tf卡启动成功过,之后很长时间没有用,再次尝试时所有版本的官方镜像都无法启动成功,官方docker编译的镜像也无法启动成功,只有我很早之前通过百问网教程配置的系统能够成功运行,实在是搞不懂无法向下推进了,跪求大佬官方解答!!!
