下载的测试固件,开机之后就一直打印下面语句,速度很快都没有办法输入命令了。请问一下,这个是怎么回事呢?
[   43.815995] usb 1-1: new high-speed USB device number 32 using sunxi-ehci
[   43.816087] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
[   43.832516] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
[   44.276020] usb 1-1: device not accepting address 32, error -71
[   44.645990] usb 1-1: new high-speed USB device number 33 using sunxi-ehci
[   44.646085] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
[   44.662510] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
[   45.105985] usb 1-1: device not accepting address 33, error -71
[   45.113370] usb usb1-port1: unable to enumerate USB device
[   45.125827] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
[   45.134718] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
[   45.143307] sunxi-ohci 4200400.ohci1-controller: ohci_irq: fullspeed or lowspeed device disconnect
[   45.153374] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
[   45.175988] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
[   45.184879] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
[   45.205983] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
[   45.214874] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
[   45.246003] sunxi-ohci 4200400.ohci1-controller: ohci_irq: fullspeed or lowspeed device disconnect
[   45.575979] usb 1-1: new high-speed USB device number 34 using sunxi-ehci
[   45.576085] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
[   45.592489] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
[   45.946019] random: crng init done
[   45.946091] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
[   45.949845] random: 2 urandom warning(s) missed due to ratelimiting
[   45.958743] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
[   45.979282] usb 1-1: device descriptor read/64, error -71
ssh-keygen: generating new host keys: RSA [   46.475991] usb 1-1: device descriptor read/64, error -71
[   46.476087] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
[   46.490932] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
[   46.966000] usb 1-1: new high-speed USB device number 35 using sunxi-ehci
[   46.966086] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
[   46.982527] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
[   47.365986] usb 1-1: device descriptor read/64, error -71
[   47.366084] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
[   47.866000] usb 1-1: device descriptor read/64, error -71
[   47.866088] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
[   47.880954] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
[   47.986059] usb usb1-port1: attempt power cycle
[   48.695988] usb 1-1: new high-speed USB device number 36 using sunxi-ehci
[   48.696085] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
              如果使用自带的SPI——flash固件,就会一直打印下面内容!
t113 login: [   29.201759] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   30.241433] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   31.281236] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   32.321127] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   33.361033] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   34.400709] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   35.440453] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   36.480330] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   37.520328] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   38.560304] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   39.600387] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   40.640403] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   41.680246] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   42.720077] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   43.759846] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   44.799716] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   45.839668] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   46.879707] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   47.919844] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   48.959894] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   49.999880] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   51.039717] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   52.079602] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   53.119749] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   54.159793] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   55.199714] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   56.239813] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   57.279989] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   58.320124] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   59.360199] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   60.400261] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   61.440232] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   62.480284] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   63.520277] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   64.560418] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   65.600623] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   66.640635] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   67.680717] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   68.720742] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   69.760668] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   70.800597] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   71.840586] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   72.880657] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   73.920709] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   74.960826] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   76.000932] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   77.041021] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   78.081007] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[   79.121273] configfs-gadget 4100000.udc-controller: failed to start g1: -19
              这是USB HUB芯片连接出现了问题,请问您是否有焊接过HUB芯片 或者USB座子周边电路?
              没有焊接过。我正常使用过程中,复位之后就变成这样了。
这个确实存在问题,请尝试烧录配套的 TF卡系统镜像,重启开发板进行尝试,如果依旧存在问题,请联系客服,给我寄回来我们专门排查一下。
              网上说是供电不足的原因,现在使用充电头进行供电,这个问题就没有再出现了。
