问题现象:
显示屏启动后会在屏幕侧边出现如下图所示的花边。
解决办法:
此问题是由于hbp和vbp的参数设置有误导致的,在全志Tina SDK中,Kernel的Timming值是读取uboot设备而来的,所以需要修改uboot设备树.
注意:全志SDK的设备树中:
lcd_hbp = hsync back porch(pixel) + hsync plus width(pixel);
lcd_vbp = vsync back porch(line) + vysnc plus width(line);
下面贴出修改后的device/config/chips/xxx/configs/xxx/uboot-board.dts设备树:
&lcd0 {
base_config_start = <1>;
lcd_used = <1>;
lcd_driver_name = "tft08006";
lcd_backlight = <0>;
lcd_if = <4>;
lcd_x = <480>;
lcd_y = <800>;
lcd_width = <52>;
lcd_height = <52>;
lcd_dclk_freq = <25>;
lcd_pwm_used = <1>;
lcd_pwm_ch = <9>;
lcd_pwm_freq = <5000>;
lcd_pwm_pol = <1>;
lcd_pwm_max_limit = <255>;
lcd_hbp = <60>;
lcd_ht = <515>;
lcd_hspw = <40>;
lcd_vbp = <20>;
lcd_vt = <830>;
lcd_vspw = <5>;
lcd_dsi_if = <0>;
lcd_dsi_lane = <2>;
lcd_dsi_format = <0>;
lcd_dsi_te = <0>;
lcd_dsi_eotp = <0>;
lcd_frm = <0>;
lcd_io_phase = <0x0000>;
lcd_hv_clk_phase = <0>;
lcd_hv_sync_polarity= <0>;
lcd_gamma_en = <0>;
lcd_bright_curve_en = <0>;
lcd_cmap_en = <0>;
lcdgamma4iep = <22>;
lcd_gpio_0 = <&pio PH 0 1 0 3 1>;
base_config_end = <1>;
