第一个内核驱动程序编译出错!!!
book@100ask:~/100ask_imx6ull-sdk/Linux-4.9.88$ make zImage -j4
scripts/kconfig/conf --silentoldconfig Kconfig
WRAP arch/arm/include/generated/asm/bitsperlong.h
WRAP arch/arm/include/generated/asm/clkdev.h
WRAP arch/arm/include/generated/asm/cputime.h
WRAP arch/arm/include/generated/asm/current.h
WRAP arch/arm/include/generated/asm/early_ioremap.h
WRAP arch/arm/include/generated/asm/emergency-restart.h
WRAP arch/arm/include/generated/asm/errno.h
WRAP arch/arm/include/generated/asm/exec.h
WRAP arch/arm/include/generated/asm/ioctl.h
WRAP arch/arm/include/generated/asm/ipcbuf.h
CHK include/generated/uapi/linux/version.h
WRAP arch/arm/include/generated/asm/kdebug.h
WRAP arch/arm/include/generated/asm/irq_regs.h
UPD include/config/kernel.release
WRAP arch/arm/include/generated/asm/local.h
UPD include/generated/uapi/linux/version.h
WRAP arch/arm/include/generated/asm/local64.h
WRAP arch/arm/include/generated/asm/mm-arch-hooks.h
WRAP arch/arm/include/generated/asm/msgbuf.h
WRAP arch/arm/include/generated/asm/msi.h
WRAP arch/arm/include/generated/asm/param.h
WRAP arch/arm/include/generated/asm/parport.h
WRAP arch/arm/include/generated/asm/poll.h
WRAP arch/arm/include/generated/asm/resource.h
WRAP arch/arm/include/generated/asm/preempt.h
WRAP arch/arm/include/generated/asm/seccomp.h
WRAP arch/arm/include/generated/asm/rwsem.h
WRAP arch/arm/include/generated/asm/segment.h
WRAP arch/arm/include/generated/asm/sembuf.h
WRAP arch/arm/include/generated/asm/serial.h
WRAP arch/arm/include/generated/asm/shmbuf.h
WRAP arch/arm/include/generated/asm/siginfo.h
WRAP arch/arm/include/generated/asm/sizes.h
WRAP arch/arm/include/generated/asm/simd.h
WRAP arch/arm/include/generated/asm/socket.h
HOSTCC scripts/basic/bin2c
WRAP arch/arm/include/generated/asm/sockios.h
WRAP arch/arm/include/generated/asm/termios.h
WRAP arch/arm/include/generated/asm/termbits.h
WRAP arch/arm/include/generated/asm/timex.h
WRAP arch/arm/include/generated/asm/trace_clock.h
UPD include/generated/utsrelease.h
HOSTCC scripts/dtc/dtc.o
HOSTCC scripts/genksyms/genksyms.o
HOSTCC scripts/kallsyms
CC scripts/mod/empty.o
gcc: error: unrecognized argument in option ‘-mabi=aapcs-linux’
gcc: note: valid arguments to ‘-mabi=’ are: ms sysv
gcc: error: unrecognized command line option ‘-mlittle-endian’; did you mean ‘-fconvert=little-endian’?
gcc: error: unrecognized command line option ‘-mapcs’; did you mean ‘-maes’?
gcc: error: unrecognized command line option ‘-mno-sched-prolog’; did you mean ‘-Wno-sign-promo’?
gcc: error: unrecognized command line option ‘-mno-thumb-interwork’; did you mean ‘-fno-sched-interblock’?
gcc: error: unrecognized command line option ‘-mfpu=vfp’; did you mean ‘-mcpu=’?
scripts/Makefile.build:293: recipe for target ‘scripts/mod/empty.o’ failed
make[2]: *** [scripts/mod/empty.o] Error 1
scripts/Makefile.build:544: recipe for target ‘scripts/mod’ failed
make[1]: *** [scripts/mod] Error 2
make[1]: *** Waiting for unfinished jobs…
SHIPPED scripts/genksyms/parse.tab.c
SHIPPED scripts/genksyms/lex.lex.c
SHIPPED scripts/genksyms/keywords.hash.c
SHIPPED scripts/genksyms/parse.tab.h
HOSTCC scripts/genksyms/parse.tab.o
HOSTCC scripts/dtc/flattree.o
HOSTCC scripts/genksyms/lex.lex.o
HOSTCC scripts/dtc/fstree.o
HOSTCC scripts/dtc/data.o
HOSTCC scripts/dtc/livetree.o
HOSTCC scripts/dtc/treesource.o
HOSTCC scripts/dtc/srcpos.o
HOSTCC scripts/dtc/checks.o
HOSTCC scripts/dtc/util.o
SHIPPED scripts/dtc/dtc-lexer.lex.c
SHIPPED scripts/dtc/dtc-parser.tab.h
SHIPPED scripts/dtc/dtc-parser.tab.c
HOSTCC scripts/dtc/dtc-lexer.lex.o
HOSTLD scripts/genksyms/genksyms
HOSTCC scripts/dtc/dtc-parser.tab.o
HOSTLD scripts/dtc/dtc
Makefile:557: recipe for target ‘scripts’ failed
make: *** [scripts] Error 2
貌似你的工具链环境变量没有配置正确吧?下面都还是gcc的提示
