[292]HELLO! BOOT0 is starting!
[295]BOOT0 commit : 88480af-dirty
[298]set pll start
[300]fix vccio detect value:0xc0
[303]periph0 has been enabled
[306]set pll end
[308][pmu]: bus read error
[310]board init ok
[312]ZQ value = 0x2d
[314]get_pmu_exist() = -1
[317]DRAM BOOT DRIVE INFO: V0.33
[320]DRAM CLK = 528 MHz
[322]DRAM Type = 2 (2:DDR2,3:DDR3)
[325]DRAMC read ODT off.
[328]DRAM ODT off.
[329]ddr_efuse_type: 0xa
[332]DRAM SIZE =64 M
[334]dram_tpr4:0x0
[336]PLL_DDR_CTRL_REG:0xf8002b00
[339]DRAM_CLK_REG:0xc0000000
[342][TIMING DEBUG] MR2= 0x0
[346]DRAM simple test OK.
[348]dram size =64
[350]card no is 0
[352]sdcard 0 line count 4
[354][mmc]: mmc driver ver 2021-04-2 16:45
[364][mmc]: Wrong media type 0x0
[367][mmc]: ***Try SD card 0***
[377][mmc]: HSSDR52/SDR25 4 bit
[380][mmc]: 50000000 Hz
[382][mmc]: 121 MB
[384][mmc]: ***SD/MMC 0 init OK!!!***
[391]error:bad magic.
[455]Loading boot-pkg Succeed(index=0).
[458]Entry_name = opensbi
[461]Entry_name = u-boot
[465]Entry_name = dtb
[468]mmc not para
[470]Jump to second Boot.
OpenSBI auto-t113-linux-V0.8-3-ge39e937
____ _____ ____ _____
/ __ \ / ____| _ \_ _|
| | | |_ __ ___ _ __ | (___ | |_) || |
| | | | '_ \ / _ \ '_ \ \___ \| _ < | |
| |__| | |_) | __/ | | |____) | |_) || |_
\____/| .__/ \___|_| |_|_____/|____/_____|
|_|
Platform Name : T-HEAD Xuantie Platform
Platform HART Features : RV64ACDFIMSUVX
Platform Max HARTs : 1
Current Hart : 0
Firmware Base : 0x41fc0400
Firmware Size : 75 KB
Runtime SBI Version : 0.2
MIDELEG : 0x0000000000000222
MEDELEG : 0x000000000000b1ff
PMP0 : 0x0000000041fc0000-0▒
U-Boot 2018.07-ge987def5-dirty (Mar 08 2025 - 15:12:07 +0800) Allwinner Technology
[00.539]DRAM: 64 MiB
[00.541]Relocation Offset is: 01ee9000
[00.545]secure enable bit: 0
can't support chip type 24064
[00.551]CPU=720 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=300Mhz
sunxi flash map init
SPI ALL: ready
[00.562]flash init start
[00.564]workmode = 0,storage type = 1
[00.568][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
[00.573][mmc]: get sdc_type fail and use default host:tm1.
[00.580][mmc]: can't find node "mmc0",will add new node
[00.585][mmc]: fdt err returned <no error>
[00.589][mmc]: Using default timing para
[00.592][mmc]: SUNXI SDMMC Controller Version:0x50310
[00.611][mmc]: card_caps:0x3000000a
[00.614][mmc]: host_caps:0x3000003f
[00.618]sunxi flash init ok
[00.620]line:703 init_clocks
[00.623]drv_disp_init
request pwm success, pwm7:pwm7:0x2000c00.
[00.645]drv_disp_init finish
[00.652]Loading Environment from SUNXI_FLASH... OK
[00.677]boot_gui_init:start
[00.680]set disp.dev2_output_type fail. using defval=0
[00.707]set disp.fb0_rot_used fail. using defval=0
[00.712]set disp.fb0_rot_degree fail. using defval=0
[00.882]boot_gui_init:finish
[00.890]bmp_name=bootlogo.bmp size 38454
[00.902]out of usb burn from boot: not need burn key
[00.907]Item0 (Map) magic is bad
[00.910]the secure storage item0 copy0 magic is bad
[00.915]Item0 (Map) magic is bad
[00.917]the secure storage item0 copy1 magic is bad
[00.922]Item0 (Map) magic is bad
partno erro : can't find partition private
root_partition is rootfs
set root to /dev/mmcblk0p5
[00.934]update part info
[00.937]update bootcmd
[00.941]LCD open finish
[00.943]change working_fdt 0x42aa8da0 to 0x42a88da0
disable nand error: FDT_ERR_BADPATH
[00.953]The storage not support sample function
No reserved memory region found in source FDT
[00.987]update dts
input addr exceed dram scope
[02.442]no vendor_boot partition is found
Android's image name: d1s-nezha
Detect comp none
[02.463]
Starting kernel ...
[02.465][mmc]: MMC Device 2 not found
[02.469][mmc]: mmc 2 not find, so not exit
▒** 8 printk messages dropped **
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x0000000043ffffff]
[ 0.000000] On node 0 totalpages: 16384
[ 0.000000] DMA32 zone: 224 pages used for memmap
[ 0.000000] DMA32 zone: 0 pages reserved
[ 0.000000] DMA32 zone: 16384 pages, LIFO batch:3
[ 0.000000] elf_hwcap is 0x20112d
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 16160
[ 0.000000] Kernel command line: earlyprintk=sunxi-uart,0x02500C00 clk_ignore_unused initcall_debug=0 console=ttyS3,115200 loglevel=8 root=/dev/mmcblk0p5 init=/pseudo_init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:recovery@mmcblk0p6:rootfs_data@mmcblk0p7:UDISK@mmcblk0p8 cma=8M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.mode=normal androidboot.hardware=sun20iw1p1 boot_type=1 androidboot.boot_type=1 gpt=1 uboot_message=2018.07-ge987def5-dirty(03/08/2025-15:12:07) mbr_offset=1556480 disp_reserve=4096000,0x0000000042b3a000 androidboot.dramsize=64
[ 0.000000] Dentry cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.000000] Sorting __ex_table...
[ 0.000000] Memory: 44248K/65536K available (4828K kernel code, 447K rwdata, 1881K rodata, 160K init, 228K bss, 13096K reserved, 8192K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS: 0, nr_irqs: 0, preallocated irqs: 0
[ 0.000000] plic: mapped 200 interrupts with 1 handlers for 2 contexts.
[ 0.000000] riscv_timer_init_dt: Registering clocksource cpuid [0] hartid [0]
[ 0.000000] clocksource: riscv_clocksource: mask: 0xffffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000009] sched_clock: 64 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000032] riscv_timer_clockevent depends on broadcast, but no broadcast function available
[ 0.000469] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.001278] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.001304] pid_max: default: 32768 minimum: 301
[ 0.001530] Mount-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.001553] Mountpoint-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.003964] ASID allocator initialised with 65536 entries
[ 0.004190] rcu: Hierarchical SRCU implementation.
[ 0.005048] devtmpfs: initialized
[ 0.023304] random: get_random_u32 called from bucket_table_alloc.isra.27+0x10a/0x12c with crng_init=0
[ 0.024640] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.024683] futex hash table entries: 256 (order: 0, 6144 bytes, linear)
[ 0.025343] pinctrl core: initialized pinctrl subsystem
[ 0.027099] NET: Registered protocol family 16
[ 0.029867] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.030624] cpuidle: using governor menu
[ 0.075370] rtc_ccu: sunxi ccu init OK
[ 0.086041] clock: sunxi ccu init OK
[ 0.088082] clock: sunxi ccu init OK
[ 0.125443] sun6i-dma 3002000.dma-controller: sunxi dma probed
[ 0.128009] iommu: Default domain type: Translated
[ 0.128236] sunxi iommu: irq = 4
[ 0.129674] SCSI subsystem initialized
[ 0.130154] usbcore: registered new interface driver usbfs
[ 0.130289] usbcore: registered new interface driver hub
[ 0.130439] usbcore: registered new device driver usb
[ 0.131002] videodev: Linux video capture interface: v2.00
[ 0.132258] Advanced Linux Sound Architecture Driver Initialized.
[ 0.133117] Bluetooth: Core ver 2.22
[ 0.133225] NET: Registered protocol family 31
[ 0.133238] Bluetooth: HCI device and connection manager initialized
[ 0.133266] Bluetooth: HCI socket layer initialized
[ 0.133283] Bluetooth: L2CAP socket layer initialized
[ 0.133321] pwm module init!
[ 0.135611] clocksource: Switched to clocksource riscv_clocksource
[ 0.153070] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
[ 0.156050] sunxi udc is no enable
[ 0.156454] NET: Registered protocol family 2
[ 0.157606] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.157663] TCP established hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.157689] TCP bind hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.157710] TCP: Hash tables configured (established 512 bind 512)
[ 0.157903] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.157958] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.158267] NET: Registered protocol family 1
[ 0.159799] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
[ 0.160509] spi spi0: spi0 supply spi not found, using dummy regulator
[ 0.160882] sunxi_spi_resource_get()2438 - [spi0] SPI MASTER MODE
[ 0.160961] sunxi_spi_resource_get()2476 - Failed to get sample mode
[ 0.160974] sunxi_spi_resource_get()2481 - Failed to get sample delay
[ 0.160987] sunxi_spi_resource_get()2485 - sample_mode:-1431633921 sample_delay:-1431633921
[ 0.161070] sunxi_spi_clk_init()2527 - [spi0] mclk 100000000
[ 0.162081] sunxi_spi_probe()2978 - [spi0]: driver probe succeed, base ffffffd004056000, irq 31
[ 0.164869] workingset: timestamp_bits=62 max_order=14 bucket_order=0
[ 0.175173] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.175485] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.205008] io scheduler mq-deadline registered
[ 0.205026] io scheduler kyber registered
[ 0.206121] [DISP]disp_module_init
[ 0.206899] disp 5000000.disp: Adding to iommu group 0
[ 0.207809] [DISP] parser_disp_init_para,line:1430:
[ 0.207816] of_property_read fb0_width fail
[ 0.207843] [DISP] disp_init,line:2387:
[ 0.207849] smooth display screen:0 type:1 mode:4
[ 0.258161] display_fb_request,fb_id:0
[ 0.280803] [DISP]disp_module_init finish
[ 0.281700] sunxi_sid_init()783 - insmod ok
[ 0.282683] pwm-regulator: supplied by regulator-dummy
[ 0.284294] disp_al_manager_apply ouput_type:1
[ 0.284450] [DISP] lcd_clk_config,line:774:
[ 0.284466] disp 0, clk: pll(420000000),clk(420000000),dclk(70000000) dsi_rate(70000000)
[ 0.284466] clk real:pll(420000000),clk(420000000),dclk(105000000) dsi_rate(150000000)
[ 0.284565] sunxi_pwm_enable_dual: can't parse pwm device
[ 0.285212] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
[ 0.285898] uart uart3: uart3 supply uart not found, using dummy regulator
[ 0.286400] uart3: ttyS3 at MMIO 0x2500c00 (irq = 21, base_baud = 1500000) is a SUNXI
[ 0.286437] sw_console_setup()1807 - console setup baud 115200 parity n bits 8, flow n
[ 0.464160] Freeing logo buffer memory: 4000K
[ 1.021875] printk: console [ttyS3] enabled
[ 1.029043] [ADDR_MGT] addr_mgt_probe: module version: v1.0.11
[ 1.037078] [ADDR_MGT] addr_mgt_probe: success.
[ 1.043286] sunxi-spinand: AW SPINand MTD Layer Version: 2.3 20211223
[ 1.050636] sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.10 20200306
[ 1.064036] random: fast init done
[ 1.424219] random: crng init done
[ 2.055691] sunxi-spinand-phy: read id failed : -110
[ 2.061306] spi-nand: probe of spi0.0 failed with error -110
[ 2.068271] libphy: Fixed MDIO Bus: probed
[ 2.073748] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.081118] sunxi-ehci: EHCI SUNXI driver
[ 2.086174] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.093130] sunxi-ohci: OHCI SUNXI driver
[ 2.098461] usbcore: registered new interface driver uas
[ 2.104601] usbcore: registered new interface driver usb-storage
[ 2.112135] sunxi-rtc 7090000.rtc: errata__fix_alarm_day_reg_default_value(): ALARM0_DAY_REG=0, set it to 1
[ 2.123301] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
[ 2.134422] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
[ 2.145165] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
[ 2.156647] sunxi-rtc 7090000.rtc: registered as rtc0
[ 2.162300] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
[ 2.173042] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:00:04 UTC (4)
[ 2.182047] sunxi-rtc 7090000.rtc: sunxi rtc probed
[ 2.188074] i2c /dev entries driver
[ 2.192039] IR NEC protocol handler initialized
[ 2.200687] usbcore: registered new interface driver uvcvideo
[ 2.207181] USB Video Class driver (1.1.1)
[ 2.211764] sunxi cedar version 1.1
[ 2.216071] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
[ 2.222358] VE: install start!!!
[ 2.222358]
[ 2.228069] VE: cedar-ve the get irq is 6
[ 2.228069]
[ 2.234485] VE: ve_debug_proc_info:00000000f5cbfd08, data:00000000000f2a11, lock:000000007b60a9c6
[ 2.234485]
[ 2.246090] VE: install end!!!
[ 2.246090]
[ 2.251170] VE: sunxi_cedar_probe
[ 2.255173] Bluetooth: HCI UART driver ver 2.3
[ 2.260208] Bluetooth: HCI UART protocol H4 registered
[ 2.266055] Bluetooth: HCI UART protocol BCSP registered
[ 2.275239] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.25 2022-6-21 13:40)
[ 2.285386] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
[ 2.291628] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
[ 2.298061] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
[ 2.304503] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
[ 2.310953] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
[ 2.317567] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
[ 2.324101] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
[ 2.330712] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
[ 2.337885] sunxi-mmc 4020000.sdmmc: Got CD GPIO
[ 2.343471] sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
[ 2.350335] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.361565] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
[ 2.381745] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.406314] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
[ 2.412086] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 2.424729] ashmem: initialized
[ 2.428477] exFAT: Version 1.3.0
[ 2.439252] NET: Registered protocol family 10
[ 2.446265] Segment Routing with IPv6
[ 2.450655] NET: Registered protocol family 17
[ 2.488436] sunxi udc is no enable
[ 2.495497] get ehci0-controller wakeup-source is fail.
[ 2.501437] sunxi ehci0-controller is no enable
[ 2.506563] sunxi-ehci 4101000.ehci0-controller: init_sunxi_hci is fail
[ 2.514054] sunxi-ehci: probe of 4101000.ehci0-controller failed with error -1
[ 2.522817] get ohci0-controller wakeup-source is fail.
[ 2.528784] sunxi ohci0-controller is no enable
[ 2.533872] sunxi-ohci 4101400.ohci0-controller: init_sunxi_hci is fail
[ 2.541400] sunxi-ohci: probe of 4101400.ohci0-controller failed with error -1
[ 2.552066] clk: Not disabling unused clocks
[ 2.557148] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 2.566850] ALSA device list:
[ 2.570167] No soundcards found.
[ 2.574013] alloc_fd: slot 0 not NULL!
[ 2.578300] cfg80211: failed to load regulatory.db
[ 2.584219] VFS: Cannot open root device "mmcblk0p5" or unknown-block(0,0): error -6
[ 2.593049] Please append a correct "root=" boot option; here are the available partitions:
[ 2.602473] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[ 2.611725] CPU: 0 PID: 1 Comm: swapper Not tainted 5.4.61 #14
[ 2.618247] Call Trace:
[ 2.621004] [<ffffffe00002a154>] walk_stackframe+0x0/0x98
[ 2.627050] [<ffffffe00002a30c>] show_stack+0x2a/0x34
[ 2.632718] [<ffffffe0004c91ca>] dump_stack+0x20/0x28
[ 2.638378] [<ffffffe00002e7cc>] panic+0xec/0x272
[ 2.643646] [<ffffffe000000ef2>] mount_block_root+0x214/0x27a
[ 2.650077] [<ffffffe000000fde>] mount_root+0x86/0x90
[ 2.655730] [<ffffffe000001130>] prepare_namespace+0x148/0x152
[ 2.662263] [<ffffffe000000b54>] kernel_init_freeable+0x166/0x198
[ 2.669090] [<ffffffe0004d9d98>] kernel_init+0x12/0xee
[ 2.674845] [<ffffffe000028ec0>] ret_from_exception+0x0/0xc
[ 2.681086] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---
