t113开发板烧录镜像后,无法再通过USB烧录
通过USB烧录固件后,板子串口首先输出以下信息,然后就无输出,并且用USB OTG口重新烧录也无反应
[2025-06-10 17:56:30] [29]HELLO! BOOT0 is starting!
[2025-06-10 17:56:30] [31]BOOT0 commit : 2386bdb825
[2025-06-10 17:56:30] [34]set pll start
[2025-06-10 17:56:30] [36]fix vccio detect value:0xc0
[2025-06-10 17:56:30] [43]periph0 has been enabled
[2025-06-10 17:56:30] [46]set pll end
[2025-06-10 17:56:30] [48][pmu]: bus read error
[2025-06-10 17:56:30] [50]board init ok
[2025-06-10 17:56:30] [52]enable_jtag
[2025-06-10 17:56:30] [54]ZQ value = 0x2f
[2025-06-10 17:56:30] [55]get_pmu_exist() = -1
[2025-06-10 17:56:30] [58]DRAM BOOT DRIVE INFO: V0.34
[2025-06-10 17:56:30] [61]DRAM CLK = 792 MHz
[2025-06-10 17:56:30] [63]DRAM Type = 3 (2:DDR2,3:DDR3)
[2025-06-10 17:56:30] [66]DRAMC read ODT off.
[2025-06-10 17:56:30] [68]DRAM ODT value: 0x42.
[2025-06-10 17:56:30] [71]ddr_efuse_type: 0xa
[2025-06-10 17:56:30] [102]HELLO! BOOT0 is starting!
[2025-06-10 17:56:30] [105]BOOT0 commit : 2386bdb825
[2025-06-10 17:56:30] [108]set pll start
[2025-06-10 17:56:30] [114]periph0 has been enabled
[2025-06-10 17:56:30] [117]set pll end
[2025-06-10 17:56:30] [118][pmu]: bus read error
[2025-06-10 17:56:30] [121]board init ok
[2025-06-10 17:56:30] [123]enable_jtag
[2025-06-10 17:56:30] [125]ZQ value = 0x2f
[2025-06-10 17:56:30] [126]get_pmu_exist() = -1
[2025-06-10 17:56:30] [129]DRAM BOOT DRIVE INFO: V0.34
[2025-06-10 17:56:30] [132]DRAM CLK = 792 MHz
[2025-06-10 17:56:30] [134]DRAM Type = 3 (2:DDR2,3:DDR3)
[2025-06-10 17:56:30] [137]DRAMC read ODT off.
[2025-06-10 17:56:30] [140]DRAM ODT value: 0x42.
[2025-06-10 17:56:30] [143]ddr_efuse_type: 0xa
[2025-06-10 17:56:30] [146]DRAM SIZE = 128 MB
[2025-06-10 17:59:45] [33]HELLO! BOOT0 is starting!
[2025-06-10 17:59:45] [36]BOOT0 commit : 2c94b33
[2025-06-10 17:59:45] [39]set pll start
[2025-06-10 17:59:45] [44]periph0 has been enabled
[2025-06-10 17:59:45] [47]set pll end
[2025-06-10 17:59:45] [49][pmu]: bus read error
[2025-06-10 17:59:45] [51]board init ok
[2025-06-10 17:59:45] [53]enable_jtag
[2025-06-10 17:59:45] [55]ZQ value = 0x2f***********
[2025-06-10 17:59:45] [58]get_pmu_exist() = -1
[2025-06-10 17:59:45] [61]ddr_efuse_type: 0xa
[2025-06-10 17:59:45] [64][AUTO DEBUG] single rank and full DQ!
[2025-06-10 17:59:45] [68]ddr_efuse_type: 0xa
[2025-06-10 17:59:49] [29]HELLO! BOOT0 is starting!
[2025-06-10 17:59:49] [32]BOOT0 commit : 2c94b33
[2025-06-10 17:59:49] [34]set pll start
[2025-06-10 17:59:49] [40]periph0 has been enabled
[2025-06-10 17:59:49] [43]set pll end
[2025-06-10 17:59:49] [45][pmu]: bus read error
[2025-06-10 17:59:49] [47]board init ok
[2025-06-10 17:59:49] [49]enable_jtag
[2025-06-10 17:59:49] [51]ZQ value = 0x2f***********
[2025-06-10 17:59:49] [54]get_pmu_exist() = -1
[2025-06-10 17:59:49] [56]ddr_efuse_type: 0xa
请问有什么方法进入强制烧录模式吗?或者另外的解决方法
你是不是烧写了什么特殊的固件把芯片锁了?
出现问题之前,我通过./build.sh menuconfig,将aic8800使能了,然后重新编译打包镜像,烧录后就变成这样了
