Error locking file /var/lock/fw_printenv.lock
starting pid 757, tty ‘’: ‘/etc/preinit’
can’t run ‘/etc/preinit’: No such file or directory
starting pid 758, tty ‘’: ‘/bin/mount -t proc proc /proc’
mount: mounting proc on /proc failed: Resource busy
starting pid 759, tty ‘’: ‘/bin/mount -t tmpfs tmpfs /run’
starting pid 760, tty ‘’: ‘/bin/mount -o remount,rw /’
starting pid 761, tty ‘’: ‘/bin/mkdir -p /dev/pts’
starting pid 762, tty ‘’: ‘/bin/mkdir -p /dev/shm’
starting pid 763, tty ‘’: ‘/bin/mount -a’
starting pid 764, tty ‘’: ‘/bin/hostname -F /etc/hostname’
hostname: can’t open ‘/etc/hostname’: No such file or directory
starting pid 765, tty ‘’: ‘/etc/init.d/rcS boot’
/etc/init.d/rcS: line 23: mkfs.ubifs: not found
[ 5.429013] ======== XRADIO WIFI OPEN ========
[ 5.434026] [XRADIO] Driver Label:XR_V02.16.91 _HT40_01.33 Aug 17 2025 11:24:44
[ 5.442545] [XRADIO] Allocated hw_priv @ c3bf6c80
[ 5.447877]
[ 5.447877] insmod_device_driver
[ 5.447877]
[ 5.448522] device_chose finished 122!
[ 5.460122] [XRADIO_ERR] Access_file failed, path:/data/misc/wifi/xr_wifi.conf!
[ 5.469396] sunxi-wlan soc@03000000:wlan@0: bus_index: 1
[ 5.585600] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 5.595856] [XRADIO] Detect SDIO card 1
[ 5.609601] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
[ 5.645151] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 5.685770] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 5.698977] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 5.720138] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 5.730865] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 5.741882] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[ 5.753567] mmc1: new high speed SDIO card at address 0001
[ 5.760630] [SBUS] XRadio Device:sdio clk=50000000
[ 5.767580] [XRADIO] XRADIO_HW_REV 1.0 detected.
[ 5.905724] [XRADIO] xradio_update_dpllctrl: DPLL_CTRL Sync=0x00c00000.
[ 6.004187] [XRADIO] Bootloader complete
[ 6.093298] [XRADIO] Firmware completed.
[ 6.099149] [WSM] Firmware Label:XR_C09.08.52.73_DBG_02.122 2GHZ HT40 May 18 2021 13:36:09
[ 6.116655] [XRADIO] Firmware Startup Done.
[ 6.121686] [XRADIO_WRN] enable Multi-Rx!
[ 6.138635] ieee80211 phy0: Failed to initialize wep: -2
[ 6.144682] ieee80211 phy0: Selected rate control algorithm ‘minstrel_ht’
------run rc.final file-----
/etc/init.d/rcS: /etc/init.d/rc.final: line 24: /etc/init.d/S00mpp: Permission denied
/etc/init.d/rcS: /etc/init.d/rc.final: line 24: /etc/init.d/S01logging: Permission denied
/etc/init.d/rcS: /etc/init.d/rc.final: line 24: /etc/init.d/S10udev: Permission denied
/etc/init.d/rcS: /etc/init.d/rc.final: line 24: /etc/init.d/S11dev: Permission denied
/etc/init.d/rcS: /etc/init.d/rc.final: line 24: /etc/init.d/S20urandom: Permission denied
/etc/init.d/rcS: /etc/init.d/rc.final: line 24: /etc/init.d/S40network: Permission denied
/etc/init.d/rcS: /etc/init.d/rc.final: line 24: /etc/init.d/S41netparam: Permission denied
/etc/init.d/rcS: /etc/init.d/rc.final: line 24: /etc/init.d/S50telnet: Permission denied
/etc/init.d/rcS: /etc/init.d/rc.final: line 24: /etc/init.d/S50usb: Permission denied
/etc/init.d/rcS: /etc/init.d/rc.final: line 24: /etc/init.d/S50wifideamon: Permission denied
mount: mounting /dev/mmcblk0p1 on /mnt/extsd failed: No such file or directory
starting pid 816, tty ‘/dev/console’: ‘-/bin/sh’
