v851sWiFi无法连接
root@TinaLinux:/# wifi -c RedmiK60 ljjshisb123
root@TinaLinux:/# 1970-01-01 00:05:31:439: WMG_DEBUG [wifi_daemon.c:cmd_handle_thread:702]: get cmd: c RedmiK60 ljjshisb123
1970-01-01 00:05:31:439: WMG_DEBUG [wifi_daemon.c:cmd_handle_c:232]: cmd handle c: RedmiK60 ljjshisb123
1970-01-01 00:05:31:439: WMG_INFO [wifi_daemon.c:cmd_handle_c:256]: connect to sta(RedmiK60) with pask(ljjshisb123)
1970-01-01 00:05:31:439: WMG_DEBUG [src/wmg_sta.c:sta_mode_ctl:463]: =====sta_mode_ctl cmd: 1=====
1970-01-01 00:05:31:440: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:command_to_supplicant:195]: do cmd LIST_NETWORKS
1970-01-01 00:05:31:440: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:command_to_supplicant:203]: do cmd LIST_NETWORKS, reply: network id / ssid / bssid / flags
1970-01-01 00:05:31:440: WMG_WARNG [src/os/linux/linux_wpa.c:linux_supplicant_connect_to_ap:1510]: current bss is not exist, need to add it
1970-01-01 00:05:31:440: WMG_EXCESSIVE [src/os/linux/event.c:evt_socket_clear:76]: clear data 4
1970-01-01 00:05:31:440: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:command_to_supplicant:195]: do cmd ADD_NETWORK
1970-01-01 00:05:31:441: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:command_to_supplicant:203]: do cmd ADD_NETWORK, reply: 0
1970-01-01 00:05:31:441: WMG_DEBUG [src/os/linux/linux_wpa.c:wpas_select_network:1046]: add network id=0
1970-01-01 00:05:31:441: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:command_to_supplicant:195]: do cmd SET_NETWORK 0 ssid “RedmiK60”
1970-01-01 00:05:31:441: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:command_to_supplicant:203]: do cmd SET_NETWORK 0 ssid “RedmiK60”, reply: OK
1970-01-01 00:05:31:441: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:command_to_supplicant:195]: do cmd SET_NETWORK 0 key_mgmt WPA-PSK
1970-01-01 00:05:31:442: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:command_to_supplicant:203]: do cmd SET_NETWORK 0 key_mgmt WPA-PSK, reply: OK
1970-01-01 00:05:31:442: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:command_to_supplicant:195]: do cmd SET_NETWORK 0 psk “ljjshisb123”
1970-01-01 00:05:31:572: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:command_to_supplicant:203]: do cmd SET_NETWORK 0 psk “ljjshisb123”, reply: OK
1970-01-01 00:05:31:572: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:command_to_supplicant:195]: do cmd SELECT_NETWORK 0
1970-01-01 00:05:31:573: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:command_to_supplicant:203]: do cmd SELECT_NETWORK 0, reply: OK
1970-01-01 00:05:31:578: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-SCAN-STARTED D
1970-01-01 00:05:31:578: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-SCAN-STARTED
1970-01-01 00:05:31:579: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1279]: event name:SCAN-STARTED
1970-01-01 00:05:31:579: WMG_EXCESSIVE [src/os/linux/event.c:evt_read:128]: Excessive: read event 1
1970-01-01 00:05:31:579: WMG_DUMP [src/os/linux/linux_wpa.c:linux_supplicant_connect_to_ap:1531]: receive wpas event ‘SCAN_STARTED’
1970-01-01 00:05:36:496: WMG_EXCESSIVE [src/os/linux/linux_wpa.c[ 82.414910] [STA_WRN] Freq 2412 (wsm ch: 1) prev: 3.
:wifi_wait_on_socket:263]: wifi_[ 82.422262] wlan0: authenticate with 82:7f:14:f5:e8:fb (try 1)
ctrl_recv: <3>CTRL-EVENT-BSS-ADDED 14 5a:4f:3b:16:d1:2f
1970-01[ 82.435894] [STA_WRN] [HT40][xradio_join_work][bss_ht_info]:
[ 82.435894] [primary_chan :0x00000001]
[ 82.435894] [ht_param :0x00000000]
[ 82.435894] [operation_mode:0x00000011]
[ 82.435894] [stbc_param :0x00000000]
[ 82.435894] [basic_set[0] :0x00000000]
-01 00:05:36:497: WMG_DUMP [src/[ 82.464683] [STA_WRN] [HT40][xradio_join_work][PhyModeCfg:0x0007]
[ 82.464683] [ModemFlags :0x00000007]
[ 82.464683] [ChWidthCfg :0x00000000]
[ 82.464683] [PriChCfg :0x00000000]
[ 82.464683] [BandCfg :0x00000000]
[ 82.464683] [STBC_Enable :0x00000000]
[ 82.464683] [PreambleCfg :0x00000000]
[ 82.464683] [SGI_Enable :0x00000000]
[ 82.464683] GF_Enable :0x00000000]
os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-BSS-ADDED 14 5a:4f:3b:16:d1:2f
1970-01-01 00:05:36:497: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1279]: event name:BSS-ADDED
1970-01-01 00:05:36:497: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-BSS-ADDED 15 50:4f:3b:16:d1:2f
1970-01-01 00:05:36:497: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-BSS-ADDED 15 50:4f:3b:16:d1:2f
1970-01-01 00:05:36:497: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-BSS-ADDED 16 d8:09:7f:e8:db:0c
1970-01-01 00:05:36:498: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1[ 82.582026] wlan0: authenticated
252]: receive wpa event: CTRL-EV[ 82.588860] wlan0: associate with 82:7f:14:f5:e8:fb (try 1)
1970-01-01 00:05:36:498: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1279]: event name:BSS-ADDED
1970-01-01 00:05:36:498: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-BSS-ADDED 17 80:2d:1a:73:16:9e
1970-01-01 00:05:36:498: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-BSS-ADDED 17 80:2d:1a:73:16:9e
1970-01-01 00:05:36:498: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-SCAN-RESULTS 2d:1a:73:16:9e[ 82.654450] wlan0: RX AssocResp from 82:7f:14:f5:e8:fb (capab=0x1431 status=0 aid=2)
1970-01-01 00:05:36:498: WMG_D[ 82.666040] wlan0: associated
UMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive[ 82.675595] [TXRX_WRN] [RX] IF=0, No key found.
wpa event: CTRL-EVENT-SCAN-RESU[ 82.682567] [TXRX_WRN] [RX] IF=0, No key found.
LTS
1970-01-01 00:05:36:499: W[ 82.692575] [AP_WRN] [STA] ASSOC HTCAP 11N 58
MG_DUMP [src/os/linux/linux_wpa.[ 82.698031] [AP_WRN] [HT40][xradio_bss_info_changed][ht_prot:0x00000004][HtProtMode:0x0001][Green:0x0000]c:wpas_dispatch_event:1279]: event name:SCAN-RESULTS
1970-01-01
00:05:36:499: WMG_EXCESSIVE [sr[ 82.714597] [AP_WRN] [HT40][xradio_bss_info_changed][PhyModeCfg:0x5007]
[ 82.714597] [ModemFlags :0x00000007]
[ 82.714597] [ChWidthCfg :0x00000000]
[ 82.714597] [PriChCfg :0x00000000]
[ 82.714597] [BandCfg :0x00000000]
[ 82.714597] [STBC_Enable :0x00000000]
[ 82.714597] [PreambleCfg :0x00000001]
[ 82.714597] [SGI_Enable :0x00000001]
[ 82.714597] [GF_Enable :0x00000000]
c/os/linux/event.c:evt_read:128][ 82.761838] [TXRX_WRN] [RX] IF=0, No key found.
: Excessive: read event 3
1970-01-01 00:05:36:499: WMG_DUMP [src/os/linux/linux_wpa.c:linux_supplicant_connect_to_ap:1531]: receive wpas event ‘SCAN_RESULTS’
1970-01-01 00:05:36:499: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>WPS-AP-AVAILABLE LTS
1970-01-01 00:05:36:499: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: WPS-AP-AVAILABLE
wlan0: SME: Trying to authenticate with 82:7f:14:f5:e8:fb (SSID=‘RedmiK60’ freq=2412 MHz)
1970-01-01 00:05:36:500: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>SME: Trying to authenticate with 82:7f:14:f5:e8:fb (SSID=‘RedmiK60’ freq=2412 MHz)
1970-01-01 00:05:36:500: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: SME: Trying to authenticate with 82:7f:14:f5:e8:fb (SSID=‘RedmiK60’ freq=2412 MHz)
wlan0: Trying to associate with 82:7f:14:f5:e8:fb (SSID=‘RedmiK60’ freq=2412 MHz)
1970-01-01 00:05:36:674: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>Trying to associate with 82:7f:14:f5:e8:fb (SSID=‘RedmiK60’ freq=2412 MHz) MHz)
1970-01-01 00:05:36:674: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: Trying to associate with 82:7f:14:f5:e8:fb (SSID=‘RedmiK60’ freq=2412 MHz)
wlan0: Associated with 82:7f:14:f5:e8:fb
1970-01-01 00:05:36:861: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>Associated with 82:7f:14:f5:e8:fb:e8:fb (SSID=‘RedmiK60’ freq=2412 MHz)
1970-01-01 00:05:36:861: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: Associated with 82:7f:14:f5:e8:fb
wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
1970-01-01 00:05:36:862: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-SUBNET-STATUS-UPDATE status=0(SSID=‘RedmiK60’ freq=2412 MHz)
1970-01-01 00:05:36:862: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
1970-01-01 00:05:36:862: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1279]: event name:SUBNET-STATUS-UPDA
[ 83.496819] [TXRX_WRN] [RX] IF=0, No key found.
[ 83.790284] [AP_WRN] [STA] ASSOC HTCAP 11N 58
[ 83.795179] [AP_WRN] [HT40][xradio_bss_info_changed][ht_prot:0x00000008][HtProtMode:0x0002][Green:0x0000]
[ 83.806486] [AP_WRN] [HT40][xradio_bss_info_changed][PhyModeCfg:0x5007]
[ 83.806486] [ModemFlags :0x00000007]
[ 83.806486] [ChWidthCfg :0x00000000]
[ 83.806486] [PriChCfg :0x00000000]
[ 83.806486] [BandCfg :0x00000000]
[ 83.806486] [STBC_Enable :0x00000000]
[ 83.806486] [PreambleCfg :0x00000001]
[ 83.806486] [SGI_Enable :0x00000001]
[ 83.806486] [GF_Enable :0x00000000]
[ 86.898074] wlan0: disassociated from 82:7f:14:f5:e8:fb (Reason: 15)
[ 86.905297] [WSM_WRN] Issue unjoin command (RX).
[ 86.916786] [WSM_WRN] Offchannel fctl=0x00d0
[ 86.933646] [AP_WRN] BSS_CHANGED_ASSOC but driver is unjoined.
[ 86.967688] wlan0: deauthenticating from 82:7f:14:f5:e8:fb by local choice (reason=3)
wlan0: CTRL-EVENT-DISCONNECTED bssid=82:7f:14:f5:e8:fb reason=15
1970-01-01 00:05:41:063: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-DISCONNECTED bssid=82:7f:14:f5:e8:fb reason=15freq=2412 MHz)
1970-01-01 00:05:41:063: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-DISCONNECTED bssid=82:7f:14:f5:e8:fb reason=15
1970-01-01 00:05:41:064: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1279]: event name:DISCONNECTED
1970-01-01 00:05:41:064: WMG_EXCESSIVE [src/os/linux/event.c:evt_read:128]: Excessive: read event 0
1970-01-01 00:05:41:064: WMG_DUMP [src/os/linux/linux_wpa.c:linux_supplicant_connect_to_ap:1531]: receive wpas event ‘DISCONNECTED’
wlan0: WPA: 4-Way Handshake failed - pre-shared key may be incorrect
1970-01-01 00:05:41:064: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>WPA: 4-Way Handshake failed - pre-shared key may be incorrect=2412 MHz)
1970-01-01 00:05:41:064: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: WPA: 4-Way Handshake failed - pre-shared key may be incorrect
1970-01-01 00:05:41:064: WMG_EXCESSIVE [src/os/linux/event.c:evt_read:128]: Excessive: read event 5
1970-01-01 00:05:41:064: WMG_DUMP [src/os/linux/linux_wpa.c:linux_supplicant_connect_to_ap:1531]: receive wpas event ‘PASSWORD_INCORRECT’
1970-01-01 00:05:41:064: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:command_to_supplicant:195]: do cmd REMOVE_NETWORK 0
wlan0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid=“RedmiK60” auth_failures=1 duration=10 reason=WRONG_KEY
1970-01-01 00:05:41:065: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:wifi_wait_on_socket:263]: wifi_ctrl_recv: <3>CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid=“RedmiK60” auth_failures=1 duration=10 reason=WRONG_KEY
1970-01-01 00:05:41:065: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1252]: receive wpa event: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid=“RedmiK60” auth_failures=1 duration=10 reason=WRONG_KEY
1970-01-01 00:05:41:065: WMG_DUMP [src/os/linux/linux_wpa.c:wpas_dispatch_event:1279]: event name:SSID-TEMP-DISABLED
1970-01-01 00:05:41:066: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:command_to_supplicant:203]: do cmd REMOVE_NETWORK 0, reply: OK
1970-01-01 00:05:41:066: WMG_DUMP [src/os/linux/linux_wpa.c:linux_supplicant_connect_to_ap:1567]: remove network 0 because of connection failure
1970-01-01 00:05:41:066: WMG_ERROR [src/wifimg.c:__wifi_sta_connect:89]: wifi station connect fail
1970-01-01 00:05:41:067: WMG_INFO [wifi_daemon.c:cmd_handle_c:269]: ===Wi-Fi connect use wep===
1970-01-01 00:05:41:067: WMG_DEBUG [src/wmg_sta.c:sta_mode_ctl:463]: =====sta_mode_ctl cmd: 1=====
1970-01-01 00:05:41:067: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:command_to_supplicant:195]: do cmd LIST_NETWORKS
1970-01-01 00:05:41:068: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:command_to_supplicant:203]: do cmd LIST_NETWORKS, reply: network id / ssid / bssid / flags
1970-01-01 00:05:41:068: WMG_WARNG [src/os/linux/linux_wpa.c:linux_supplicant_connect_to_ap:1510]: current bss is not exist, need to add it
1970-01-01 00:05:41:068: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:command_to_supplicant:195]: do cmd ADD_NETWORK
1970-01-01 00:05:41:069: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:command_to_supplicant:203]: do cmd ADD_NETWORK, reply: 0
1970-01-01 00:05:41:069: WMG_DEBUG [src/os/linux/linux_wpa.c:wpas_select_network:1046]: add network id=0
1970-01-01 00:05:41:069: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:command_to_supplicant:195]: do cmd SET_NETWORK 0 ssid “RedmiK60”
1970-01-01 00:05:41:069: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:command_to_supplicant:203]: do cmd SET_NETWORK 0 ssid “RedmiK60”, reply: OK
1970-01-01 00:05:41:069: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:command_to_supplicant:195]: do cmd SET_NETWORK 0 key_mgmt NONE
1970-01-01 00:05:41:070: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:command_to_supplicant:203]: do cmd SET_NETWORK 0 key_mgmt NONE, reply: OK
1970-01-01 00:05:41:070: WMG_ERROR [src/os/linux/linux_wpa.c:wpas_select_network:1101]: The password does not conform to the specification!
1970-01-01 00:05:41:401: WMG_ERROR [src/os/linux/linux_wpa.c:linux_supplicant_connect_to_ap:1520]: failed to config network
1970-01-01 00:05:41:402: WMG_ERROR [src/wifimg.c:__wifi_sta_connect:89]: wifi station connect fail
1970-01-01 00:05:41:402: WMG_ERROR [wifi_daemon.c:cmd_handle_c:279]: ===Wi-Fi connect failed,time 330.000000 ms===
WiFi无法搜索问题已经按照论坛的方法搜索到,但是无法连接上去,WiFi是2.4的,大佬们这是什么问题啊
