适配K230 SDK AI POC
文件路径: k230_sdk/src/reference/ai_poc/vi_vo/目录下
修改vi_vo.h文件,修改参考:
--- a/vi_vo.h
+++ b/vi_vo.h
-#if (defined(CONFIG_BOARD_K230D_CANMV) || defined(CONFIG_BOARD_K230D_CANMV_BPI))
+#if (defined(CONFIG_BOARD_K230D_CANMV) || defined(CONFIG_BOARD_K230D_CANMV_BPI) || defined(CONFIG_BOARD_K230_CANMV_DONGSHANPI))
     #define CONFIG_BOARD_K230D_CANMV 1
 #elif defined(CONFIG_BOARD_K230D_CANMV)
-#define SENSOR_CHANNEL (3)
-#define SENSOR_HEIGHT (720 / 2)
-#define SENSOR_WIDTH  (1280 / 2)
-#define ISP_CHN0_WIDTH  (800)
-#define ISP_CHN0_HEIGHT (480)
-#define ISP_INPUT_WIDTH (1920)
-#define ISP_INPUT_HEIGHT (1080)
-#define vicap_install_osd                   (1)
-#define osd_id                              K_VO_OSD3
-#define osd_width                           (480)
-#define osd_height                          (800)
+#define SENSOR_CHANNEL (3)
+// chn1 RGB888 使用 1280x720
+#define SENSOR_HEIGHT (720)
+#define SENSOR_WIDTH  (1280)
+#define ISP_CHN0_WIDTH  (800)
+#define ISP_CHN0_HEIGHT (480)
+#define ISP_INPUT_WIDTH (1920)
+#define ISP_INPUT_HEIGHT (1080)
+#define vicap_install_osd                   (1)
+#define osd_id                              K_VO_OSD3
+#define osd_width                           (480)
+#define osd_height                          (800)
