Ethernet Pins
Hello, How to add ethernet to this DongshanPI-PicoW.
Do we need external Phy? or is it integrated? Could someone supply the datasheet of the SSD210?
Many Thanks.
Mauricio
Hello, there is no corresponding data sheet for this chip. For Ethernet, you can use ipl101 as a PHY chip. The firmware is compatible by default. For specific signal pin multiplexing, please see the execl form in the attachment below.
SSD210_HW CheckList_V05.xlsx (134.7 KB)
Thanks very much!
